15 minutes ago, Old Collingwood said:
You building a sub aswel mate ..... you kept that was "hush hush";)
OC.
You know what he's like ... he builds anything he can lay his hands on ;)
masking ... 3mm wide
Edited by cog
Carl
Oh....WOW!  a Banana boat!  ;)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
:D:D:D:D
Jack
Current buildUS Constellation
Wow, beautifully done Carl ;)
Cheers,
Piet, The Flying Dutchman.
                       VOC Ship Surabaya
                             Friendship Sloop Gwenfra
                           Muscongus Bay Lobster Smack
9 minutes ago, lmagna said:
It's the latest in camouflage! Makes it harder to see on the work table.
Or on the veggy rack.........:P
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
I've been looking all over the kitchen table for that blasted hull, must haven been thrown in the garbage ... with the rotten fruits. Temps are 30ºC presently and food is hard to keep fresh ... so is my hull it seems, ah well, I'll just have to start over again :huh:  Should have warned the missus ... :wacko:
H92 (that's the other one) is at the painters. First 8 layers of primer have been applied, it seems I'll have quite a few more to go ... Last rattle can is being used ... I'll just need to order a couple more ... Have been looking for Glowworm ... she'll turn out like Vendetta for colour scheme ... no "other" camo known, so I can put some more effort into weathering ... would like to come close to RGL's artful creations, don't tell him, but he's good!!
Carl
must be the smoke Lou. on the other hand ... German photography ... they've always have had something for the obscure, darkish, dramatic side of life, not like monty python or fawlty towers ...
Carl
It is, Lou, it is. Have you read convoy PQ17 .. it has always reminded me of bravery bordered on stupidity ... it doesn't diminish the courage of those serving, and do what they think is justified at that moment and place in time ...
Carl
Received some parts for the build, these are large images (courtesy of Shapeways, and their copyright) in reality most parts (i.e. the entire set) are no bigger than the nail of my pinky finger
1/350 4.7"/45 (12cm) QF Mark IX CPXVII Guns x4
1/350 Royal Navy Tribal Class Fairleads
1/350 Royal Navy Tribal Class Bollards x10
1/350 Quad Vickers 0.50"/62 MKIII 45º No Shield x4
Edited by cog
Carl
your scavenger hunt is Bering some fruit Car......very nice add ons  ;)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Who's that spinach-man talking to ...?
Did anyone say camouflage could be colourless ... I like the yellow one at the bottom ... could be a desert ship ( in Dutch that's the alternative name for a Camel :D )
Carl
5b3d163c50900_IMG_3663copy.thumb.jpg.9c3fb7b0345d07b032956141700b794c.jpg5b3d1647719ea_IMG_3664copy.thumb.jpg.377898f11019c85019d3d2472bdab33d.jpg5b3d165d445cc_IMG_3668copy.thumb.jpg.2f740ed873d61bc7f71a1a3ce2b2ab51.jpg5b3d16529f3df_IMG_3666copy.thumb.jpg.b787e4379b08e98eacc87f3e2a9121db.jpg
That's the first layer, now for getting theses parts on their respective places ... got some more reading to do on the RN style deck layout
Cheers
Edited by cog
Carl
Removed the banana stripes ...
5b3d32a6b9963_IMG_3640copy.thumb.jpg.7166da241655293da0f6571b4e91c7d5.jpg5b3d32b97a9c5_IMG_1960copy.thumb.jpg.65a8b8a0b8db945bedd93a1d460cf8b7.jpg
One more layer to add, so the entire tub will be primed. I wonder if I need to set highlights and/or shading on the hull plating ...
Carl
That is the question mate, do we highlight shade our models as If we were doing a painting or drawing, or being viewed in real life under different lighting conditions.
OC.
Current builds
Completed works.
The point is, when I look at the model in her present paint covering, I can distinghuis the hull plates quite well. What will be the result after the final colour coats have been applied ... will the plating still be visible ... I can try it on this one, and if it isn't pronouced enough, I can add the highlights and shades on the HMCS Huron, which I'll be building too ... decisions, decisions, decisions ...
(Never knew plastic models could be so hard to build)
Carl
You could try shading along the inside edges and catching the outside edges with highlights, if done real subtly almost not seen it would look superb.
OC.
Current builds
Completed works.
OC.
The hull plating I applied with primer over the length of the ship is just 3mm wide ... I'll be needing a brush with a single hair :wacko: :blink::huh::(
Carl
You can get pin point pencils that have a very fine point, they might be useful for shading.
OC.
Current builds
Completed works.
very nice progress on the hull Carl........came out with some nicely defined lines
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Really tidy mate,  you can see the armor belts really well, looks just right.
OC.
Current builds
Completed works.
Right on Carl, the plating shows up real nice.
Cheers,
                       VOC Ship Surabaya
(For Lou ;) )
Bringing the aft raised gun platform into proportions for Glowworm ... (glad I have two of this kit, so I can mess up )
ripping it up ..
5b40b2260a84b_IMG_0002copy.thumb.jpg.b556f581ac8baaaa4baa313a4523f222.jpg5b40b234570e7_IMG_0004copy.thumb.jpg.ec3512c3815a8a933a27b0376aa1aa3e.jpg
Putting it back together again ...
5b40b2411f190_IMG_0006copy.thumb.jpg.cc3816fe73d545b9d75f630ebd9b7804.jpg5b40b24ec38fd_IMG_0007copy.thumb.jpg.e8a4c59ed638e93e954e96fe3bb5fe27.jpg5b40b25c0b54e_IMG_0009copy.thumb.jpg.b623e6039f2fb2f013a38da9ab02758b.jpg
Carl
