I received this hull of the Cutty Sark back in 2013. A friend of my son gave it to him to give to me. It has sat in my boatyard all this time. Back in March I started working on by planking the deck.
Al
Current Build
The President by Sergal
Completed Build
Cutty Sark 1:75
SIB Hannah
Opium Smuggler
SIB Pride of Baltimore II
On Deck
This planking was started in March as you can see there wasn't  a false deck. I had to put in wood block in order to support the decking. The planks were marked with a black magic marker. 20180313_190913_001.thumb.jpg.c5d64cb4a74d9098a1d11ecae9a93d0c.jpg
Al
Current Build
Completed Build
Cutty Sark 1:75
SIB Hannah
Opium Smuggler
On Deck
After the deck was planked I moved on to building the deck houses and other deck fittings. As I have no real plans I used the Billings plans and a copy of the Scientific plans. I believe that the deck house on the cutty was smaller than this one. April 2018 - June 2018
Edited by Cuda1949
Al
Current Build
Completed Build
Cutty Sark 1:75
SIB Hannah
Opium Smuggler
On Deck
I then created the other two deck houses and the chicken houses and hatches.
Al
Current Build
Completed Build
Cutty Sark 1:75
SIB Hannah
Opium Smuggler
On Deck
The deck houses are not glued onto the deck as I am currently working on attaching the rails and deadeyes. I also have the two bathrooms built and the winch and chain. This was completed on July 7, 2018.
Al
Current Build
Completed Build
Cutty Sark 1:75
SIB Hannah
Opium Smuggler
On Deck
Looks food so far. Keep on!
In progress:
CUTTY SARK - Tehnodidakta => scratch => Campbell plans
http://modelshipworld.com/index.php/topic/2501-cutty-sark-by-nenad-tehnodidakta-scratched-campbells-plans/page-1#entry64653
Content of log :
http://modelshipworld.com/index.php/topic/2501-cutty-sark-by-nenad-tehnodidakta-scratched-campbells-plans/page-62#entry217381
Past build:
Stella, Heller kit, plastic, Santa Maria, Tehnodidakta kit, wood, Jolly Roger Heller kit, plastic
Thanks for the encouragement
Al
Current Build
Completed Build
Cutty Sark 1:75
SIB Hannah
Opium Smuggler
On Deck
I have attached the railing supports on the rear deck.  Still working on attaching the deadeyes to the deck.
Al
Current Build
Completed Build
Cutty Sark 1:75
SIB Hannah
Opium Smuggler
On Deck
In order to attach the deadeyes inside the bulkhead I attached and glued the bass wood strips to the deck.
Edited by Cuda1949
Al
Current Build
Completed Build
Cutty Sark 1:75
SIB Hannah
Opium Smuggler
On Deck
After the glue dried on the bass wood strips I attached the railing and drilled holes into the bass strips so the deadeyes would be able to be glued in place.1938995895_20180811_211800(1).thumb.jpg.bf3a860900f4269884faafbfdf7066ef.jpg
Al
Current Build
Completed Build
Cutty Sark 1:75
SIB Hannah
Opium Smuggler
On Deck
Currently awaiting delivery of Longridge's books but in the meantime I have installed the deadeyes for all the masts. I have glued in the two chicken houses and the two bathrooms. I also installed the stanchions on the foredeck. 20180822_160847.thumb.jpg.d29887a4b16108f963f75bd3276b4116.jpg20180822_160855.thumb.jpg.6656186a60ab443028b254c759f09245.jpg20180822_160900.thumb.jpg.452642b6101527869db417c496654d55.jpg
Al
Current Build
Completed Build
Cutty Sark 1:75
SIB Hannah
Opium Smuggler
On Deck
You're doing a fantastic job bringing this model back to life...what a gift to have been given.  One thing, If I may...you might consider bringing those deadeyes up closer to the rails...l think you'll appreciate it when you begin to rig the shrouds...More to scale and such.
Great job.
Rob
Edited by rwiederrich
Current build:
Finished build:
Current build(On hold):
Thanks for the kind words I will try moving them unfortunately they are glued in place.
Al
Al
Current Build
Completed Build
Cutty Sark 1:75
SIB Hannah
Opium Smuggler
On Deck
Longridge's books arrived and after some investigation I have started on the masts, I also have made two pin rails with the belaying pins.  I took the advice from the books and made a stand to build the masts off from the ship. Much easier to work on.  The ship in the background is a sib of the Flying Cloud awaiting insertion into a bottle.
Edited by Cuda1949
Al
Current Build
Completed Build
Cutty Sark 1:75
SIB Hannah
Opium Smuggler
On Deck
Hi Patrick,
Thanks for the kind words. I really am enjoying the build. I really like figuring out what I should do next. It is quite a challenge.
Al
Al
Current Build
Completed Build
Cutty Sark 1:75
SIB Hannah
Opium Smuggler
On Deck
And so it begins. I have completed the build of the foremast. I am currently rigging the deadeyes on the upper part of the mast. Quite a challenge using small deadeyes what with my big fingers lol. Also received The Neophyte Jackstay what a great reference 20180923_164752_001.thumb.jpg.c739fa4c9ec5c54d5ea826d509ffa100.jpg20180925_164143_001.thumb.jpg.3cc4b7fbd28780282b379631d81ed5fb.jpgbook.
Al
Current Build
Completed Build
Cutty Sark 1:75
SIB Hannah
Opium Smuggler
On Deck
Latest update. Foremast is finished and has been placed on the ship. Now I am working on the main mast just started rigging the dead eyes and started to rig the upper shrouds.
Al
Current Build
Completed Build
Cutty Sark 1:75
SIB Hannah
Opium Smuggler
On Deck
Two down one to go. Finished the main mast. Now on to the last mast. I also added a railing on the top of the rear cabin.
Al
Current Build
Completed Build
Cutty Sark 1:75
SIB Hannah
Opium Smuggler
On Deck
The last mast is done and placed in the deck. The deck houses are placed on the deck ready for gluing. Now onto the bowsprit.
Al
Current Build
Completed Build
Cutty Sark 1:75
SIB Hannah
Opium Smuggler
On Deck
Bowsprit finished and starting to glue down deck houses etc. Pin rails in place,  glued down as well as chain crank (?) and hatch cover. Next is forming the spars and finish the rigging.
Edited by Cuda1949
Al
Current Build
Completed Build
Cutty Sark 1:75
SIB Hannah
Opium Smuggler
On Deck
So I am starting to rig the lower masts but really did not have any place where I could work on the rigging as the table is too low and the ship too tall to fit on my work desk. So I built a rigging stand so the deadeyes are almost eye level.
Al
Current Build
Completed Build
Cutty Sark 1:75
SIB Hannah
Opium Smuggler
On Deck
Here are some pictures of the rigging so far foremast and main mast.
Al
Current Build
Completed Build
Cutty Sark 1:75
SIB Hannah
Opium Smuggler
On Deck
So I have finished the rigging for the shrouds 6 on each side for the fore mast and main mast. 4 on each side for mizzen mast. I have glued the deck houses ( all except the one on the poop deck). So I guess I will start the spars although I am not sure how I am going to attach them to the masts. When I build by ships in bottle I drill holes through the mast and through the spar and tie it to the mast. I read somewhere that you can do it by using a piece of wire. Guess trial and error.  Happy Thanksgiving to everyone.
Al
Current Build
Completed Build
Cutty Sark 1:75
SIB Hannah
Opium Smuggler
On Deck
So after some research I realized I had placed the front deadeyes and lines in the wrong position. I am in the process of  correcting this.
My question is I am ready to build the spars and I am not sure How to attach them to the masts? My first full sized build so any help is appreciated.
Al
Current Build
Completed Build
Cutty Sark 1:75
SIB Hannah
Opium Smuggler
On Deck
Two ways that I know of Al.  The best probably is it pin the yard to the mast in the proper location.  The yard should at least be completely ready for it's rigging or even pre-rigged.  The other way, and I'm not a fan of it, is to rig the yard, hoist it aloft using the rigging and them a spot of glue to hold it to the mast.  You might have a look at way Rob is doing his:
Thanks Mark,
 I will try doing your method/ Very similar to the way I do my sib models.
Merry Christmas
Al
Al
Current Build
Completed Build
Cutty Sark 1:75
SIB Hannah
Opium Smuggler
On Deck
Hi Al
It depends on whether you want to do it as per the real boat or not, each yard had a metal truss of different shapes and slings to hold up, the different similar trusses can be seen in Ed t's young America log and there are pictures for most of the yards in Longridges Cutty Sark vol 2
Or of course you can do it like Mark said with a pin or glue, the amount of metalwork required for the sarks yards is  quite incredible as can be seen in eds log, remember also that originally the sark's yards were iron and had considerably less bands than a wooden yard
Hope that helps
Regards
Paul
The clerk of the cheque's yacht of sheerness
Current build HMS Sirius (1797) 1:48 scratch POF from NMM plans
HMS Winchelsea by chuck 1:48
Cutter cheerful by chuck 1:48
Previous builds-
Elidir - Thames steam barge
Cutty Sark-Billings boats
Wasa - billings boats
Among others 😁
Hi Paul
Thanks for the help it give me some thought as how I will do it. I will post pictures once they are under way. Thanks again
Al
Current Build
Completed Build
Cutty Sark 1:75
SIB Hannah
Opium Smuggler
On Deck
Thank you Things have come to halt what with the Holidays but I may be getting started again in a day or so. Hope your seat is up front and did you bring popcorn
Al
Current Build
Completed Build
Cutty Sark 1:75
SIB Hannah
Opium Smuggler
On Deck
