32 minutes ago, Jim Rogers said:
Think about Syren Ship Company
High quality,good prices and fantastic service. A no lose situation.
Lou
Currant builds:
Schooner USS Lanikai/Hermes
Non ship build log:
1/35th UH-1H Huey
Hey CDW, Jim and Lou,
Thanks for the comments. Funny that you should mention Syren Ship Company as I just ordered one roll of light brown rigging thread for the cannons on the Spar deck. If I like it compared to what came in the box I may order more but not sure on the lengths per spool. Don't want to "short" order but also don't want to buy more than I need.
Taking a little break while I wait for the wooden gun carriages to come from HiSModel in the Czech Republic.
Had a real pain on the Helm Wheel in wrapping the thread around it as it is supposed to be a functional wheel. Figuring I would NEVER play with the wheel to watch the rudder move, I just glued the thread, tied a know and glued everything to the wheel hub. Replacing the Helm wheel at this point would be impossible as the thread was glued to the hub.
I have used HiSmodel for the accessories as he had them categorized for the USS Constitution 1/96 scale. I would have absolutelly no way of knowing the different size blocks or rigging threads needed nor would I know the number of different blocks. well...I guess I could count them...lol
I think I will try to assemble a few long gun wooden carriages from HiSModel. I originally ordered them for the gun deck. Seeing that they would not be seen, I decided to just hold on to them for the spar deck. Then I realized only one long gun is illustrated for the spar deck and the carriages needed for the main deck guns where different. Ordered those from HiSModel as well. Radek and I are on a first name basis now Lou...lol
He sent me assembly instructions but his English is a challenge at times. He mentions using a dispersive glue on the wood which I take to mean like Elmers Glue. I'm awaiting an answer on 2 wood pieces that I don't find in his assembly picture.
This will be challenging as these pieces are tiny and my fingers aren't...lol
I work with wood a bit boxes and  furniture a little and can attest to Tite bond.When I built the grates for the America I put a touch with a toothpick and by the time the first was glued it was already setting sanded 15 minutes later for scale effect. ;) Kevin
36 minutes ago, MikeU48 said:
NOW I just have to find some tiny fingers
Some people call those TWEEZERS! :D:rolleyes:
I'm jealous on your first name basis status. I have not "talked" to him since we discussed a set of custom sails several months ago.
What were the pieces you could not identify on the carriage?
Lou
Currant builds:
Non ship build log:
1/35th UH-1H Huey
I did that, Lou, JUST FOR YOU...lol
I figured it out 3 seconds after I posted the comment. I LOVE THIS SITE....No dry humor here.... he he he You get smacked right between your eyes for stupidity....just kidding... of course.
Here's the pic of the pieces. The red arrows are the mystery parts. Note: there are six wheels. Humm
This is the assembly pic. The mystery pieces may be glued together under the main frame but never want to guess as none of the other parts are assembled. Better safe than sorry.
Talking about the wedge itself ? Sounds like they are not there on the real ones they are used to glue the guns to the deck instead of gluing the wheels less mess and what mess is hidden.I really like that green upstairs what color for the cannon carriages?
Edited by Javlin
I agree with Javlin.
The two wedge shaped pieces are not really part of a real gun carriage but a hidden base used to attach the carriage to the deck. Not a bad idea when you think about it.
I'm not so certain about the extra wheels.
Edited by lmagna
Lou
Currant builds:
Non ship build log:
1/35th UH-1H Huey
Well, the assembly of the spar deck long gun carriage was a little bit of a challenge even with tweezers. You can see on the pics above that the "axel" for the wheels is square and the wheels have a round hole. Something in the back of my mind says you can't fit a square peg in a round hole. The instruction stated one side of a wheel has a larger hole than the other and to rotate that on the square axle. After many failed attempts I used an emery board to round out the square axle as best as I could because this is a tiny part. Contrary to the instructions I found it easier to hold onto the front piece and axle than when the sides were glued on. At least the carronades will be easier as there are fewer pairs and different wheel mountings. All in all, I am satisfied with the results. I just have to figure out how to attach the two long wedges to the bottom of the long gun carriage. No rush.
Now I await the carronades from the Czech Republic.
Edited by MikeU48
Nice looking guns.
I think I just had a brainstorm.
(I know, pretty hard to believe that my brain is able to function at all) but I think I now have an idea of what the extra wheels are for. These carriages are designed to be used on models other than the Revell Constitution. On those models the deck will normally have a camber and it was normal to make the wheels larger on one end of the carriage larger than the other to compensate for this. The deck on the Revell kit is pretty much flat and in order to make the carriage look level while sitting on this flat deck it is necessary to use the same size wheels on both front and rear. Does this seem possible to others?
Lou
Currant builds:
Non ship build log:
1/35th UH-1H Huey
Hey Lou,
The other oddity is that there are 3 wheels larger than the other 3. I used the 2 small wheels and 2 from another sheet. These long gun carriages would really not be seen once the spar deck is in place. Seeing there are 6 wheels per carriage I imagine the intent was to use 2 large and 2 small with a spare of each. I have an email off to Radek at HiSModel for his explanation.
Well so much for my idea.
From the pictures I thought there were four small wheels and two large.Even though most of the guns will be hidden under the spar deck the size of the front wheels will still kind of determine where the tip of the barrel will be located in the gunport opening. Ideally they should be centered.
I kind of knew that the idea of my feeble mind having a solution to the question was highly suspect. Hopefully we will both know fairly soon.
Lou
Currant builds:
Non ship build log:
1/35th UH-1H Huey
The way I rounded the square axles: Locate a drill bit the same size as the hole in the wheel, take one of your Dremel grinders and drill a hole in it, now just put the square axle in and hit for a second. Now round.🤗
Regards,
Jim Rogers
Damn the Torpedoes , Full speed ahead.   Adm David Farragut.
Hey Lou,
 Just heard back from Radek at HiSModel. He said the larger wheels go up front. The six wheels included where for possible breakage. I used his brass cannons on the gun deck and they came in two pieces: cannon and center pin. Some were movable so I glued them in place....I think...lol
Well Jim, YOUR brain is engaged....Mine...not so much... When I was looking at these tiny parts I just happened to have an emery board laying right by my mat. Luckily I just had one to do for the long gun on the spar deck. Good to know for the future. Thanks for the tip.
Hey Lou,
I was just browsing through the Connie instruction manual as I do pretty often and guess what? I was a picture on the cannon carriages. Yepper....Big wheels up front for the gun deck carriages. NOW I can sleep tonight...lol
Night Night!:D
Lou
Currant builds:
Non ship build log:
1/35th UH-1H Huey
