@KatsumotoThank you Peter for watching my work and many thanks for your kind words.
I am working on wooden ship models since 2015. Before that -as a student in the 70s-80s-  I used to make plastic models. There was much painting but no other skills or knowledge, as wooden ships require. So am still a trainee in this aspect, on the contrary with your skills which am watching closely.Actualy I believe that when and if I reach your level, -and only then-am going to consider my self as a good and  experienced modeller.
Cheers Peter
Christos
Edited by MESSIS
Very nice soldering job Christos. Hardly visible at all.
Carl
@cog thank you. The 0.5 mm  wire gave me a hard time. It was to hard to bend correctly in a circle. The flame heating and the shocking cooling through cold water, made it softer and after more than a few trials I got it right.
Edited by MESSIS
Cheers Peter
Christos
It’s a work of art, ofcourse I’m watching. 🙂
your level is just as good or better than mine, so no worries about that my Cyprian friend. 😉
So today SWC completed 200 hrs of work. The crow's nest in now on the foremast. I rather call it the "cuckoo's nest" after all the hard time I had with this detail. Even installing it on the mast wasnt easy because the parts had to be and were allready painted.
The blocks of the kit look realy nice. They are plastic but  need to be painted. There is a good tamiya brown paint:
Edited by MESSIS
Shipyard's electricians worked some overtime today to install the position lights on the foremast. Rigging begins on Monday and it looks it want be easy. I never had a for- and - aft boat.
So you can turn on the lights ;)
The rigging is just an additional mast. Instead of one you do two
Carl
@cog😃😁 yeap! But the lights are on.... its just still daylight in Cyprus and you can not see them😀.  The engines are also running already, but Cyprus its far and you cannot hear them😉.
The rigging its not just an additional mast... its another two masts😉
Thank you for dropping by
Wish you a nice day my friend
Edited by MESSIS
Hard work last two days. 8 hrs total and the foremast rigging starts to get formed. Didnt use GAC 400 to blow wind into the sails but just a thin brass wire at the bottom and the side opposite the mast. The two square sails are furled because thats the plan as the picture below.
Messis, beautiful build you have going there.
I truly hope the picture in post #13 is messing with me. But the waterline doesn't seem to be straight to me.
If I put a ruler on top of the picture between stern and stem, you have a drop in the middle
Respectfully
If a photograph is taken above or below a horizontal line on a curved object, there will always be a drop or a rise visible at the centre of the image, depending if the shot is taken up or downwards
Very nice work on the rigging Messis
Edited by cog
Carl
Carl, I am fully aware about that.
Respectfully
20190123_095002.thumb.jpg.39cd7f76b3bb5bcafb3b4df4e1e36c41.jpg@NirvanaThank you.  Yes, I checked and there is a small deviation there. You are right. I dont know how it happend  the tape I used was straight. Have to think how to correct it if possible at this.stage. I think I can still  do that.
Edited by MESSIS
draw the line with a very soft pencil (e.g. hardness B6) you can wipe that of very easily, remask and do your colour magic. If uncertain about the pencil you could either try it on a test piece, or take another road altogether. That's my two pennies
Carl
@Nirvana thank you so much for your excellent remark Sir. It seems you saved my model! You got an eye! Thats fascinating seeing that just through a picture.
@cog  I did what you said me to do! Thank you my friend... it was decisive what you told me, the moment you did and your concern over the disaster I was facing this morning.
Hura rescue operation of this morning, called "mission impossible"... SUCCEEDED!
Here the result:
Edited by MESSIS
glad it worked out
Perhaps Nirvana should change his name to "Eagle Eye"!
Carl
@Nirvana@cog wish you were here this moment Nirvana & Carl... I was going to offer you one.Am having a Monkey's Shoulder. Cheers and thank you again🍻
Messi's. Now that looks right. Great save.
Respectfully
Messis,
When I did the waterline on my Bluenose I used a laserlever, I have a cheap one........ you can get them from any hardware store or online.
With that tool you will for certain get a straight waterline. I am to buy a new one for my next ship.
Respectfully
Christos,
Respectfully
Attached the laser unit to a camera tri-pod about 4ft away, this way I got some working space.
Then use a pencil to make tick marks along the line. Then you can start masking off for painting.
Respectfully
@Katsumoto thank you Dutchman for your nice words. Yes as the song of Rod Steward says:
"I am sailing
I am sailing
Home again
'Cross the sea"
next build its frigate Hermione building her for a second time. Want to rebuild her in order to correct all mistakes and errors I did when building her in the first time.
Christos the Cypriot 🇨🇾
Edited by MESSIS
