On 3/18/2020 at 8:55 PM, BobG said:
Beautiful boat!
Thanks Bob, I appreciate it.
The boats are now firmly in place, tied onto cleats which are glued to the deck.
The dory hooks are also in place, and you may notice that the bow of the dory blocks access to the belay point for the forward dory hook's hauling line.  This is due to a combination of fiddly problems that I couldn't work around.  The next photo (of the starboard side with no dory) illustrates the issue:
Ideally, the line would belay to the pin location nearest the aft deadeye, but then the line would foul the shroud.  It could belay to a pin in the space just left of the hook, but that is taken up by the hawse hole reinforcing plate.  On top of that, the dory completely blocks access to the long wooden cleat to the right of the hook.  This may be a case of mixing features from an earlier era (the dories) with the current era.  Oh well...
Andrew Bodge
Finished:  Muscongus Bay Lobster Smack (Midwest / Model Shipways)
Finished: Maine Lobster Boat (BlueJacket)
Finished: Yankee Hero (BlueJacket)
Finished: Emma C. Berry (Model Shipways)
Finished: Northeaster Dory (Chesapeake Light Craft)
Finished: Schooner Bowdoin (BlueJacket)
Finished: US Revenue Cutter "Joe Lane" (Marine Models)
Missing and presumed lost: Friendship Sloop (Laughing Whale)
Final bits and pieces.  I installed the propeller and rudder that I built up more than a year ago...
The kit comes with BOWDOIN decals for the bow, but not for the stern.  Maybe someday I will make up something for the transom, but for now I just put on the bow decals.
The proper placement of the name is above the scuppers - in the real schooner, there is more room there.  As I noted in post #48, I believe the bulwarks should be higher, with the break between the planking and the bulwarks level with the foredeck, not the main deck.
Finally, I installed jib sheets (even though I am not adding a jib) and the anchors.
The jib sheets simply hook on to the forestay at the point they would normally attach to the sail.  As anticipated, the anchors were fiddly and the limited space under the cap rail didn't help.  In the end, I used CA to glue the anchor fluke into its deck cleat to keep everything secure.
I will do a round of tidying and touching up, take some final pictures, and declare this one done!
Andrew Bodge
Wonderful build, Andrew! I've always been fascinated with the ships that braved polar explorations. You've built a beauty!
Bob Garcia
"Measure once, cuss twice!"
Current Builds:
Hms Brig-Sloop Flirt 1782 - Vanguard Models
Pen Duick - Artesania Latina 1:28
Completed: Medway Longboat 1742 - Syren Ship Model Co.
6 hours ago, NovaStorm said:
... I wish this kit didn't come with sheet decking. I would much rather be able to plank the deck with nibbing like the real ship has. ...
I see no reason you couldn't make that modification - just make the "waterways" a little wider and substitute planks for the sheet decking.  The deck restoration archive at the Maine Maritime Academy site has excellent photos of the decking installation.  I agree that would look stunning.
Andrew Bodge
Andrew thank you so much for that information. I meant to ask you that more as a question than i did, so glad you caught my drift ;) I will seriously consider getting this kit knowing that. Cheers ~
My Bowdoin is marked "finished" on the 99th anniversary of her launch at East Boothbay, Maine.  I took her out to the deck to get some natural light and took these photos.
I will probably mount the model on a baseboard (the keel is already drilled for pedestals) and will think about a case.
This has been quite an adventure.  I have about 320 hours of work time (and uncounted think time) invested, over 1-1/2 years of calendar time.  There has been a lot of frustration, learning, skill acquisition, and satisfaction along the way.  I know the result is imperfect but I'm still very pleased with it - she puts a smile on my face whenever I look.
Historically, this Bowdoin is a bit of a mish-mash.  Some features, such as the ice sheathing, haven't been on the schooner for many years, but a lot of the little details, taken from contemporary photos, are probably more recent.  I certainly could have added more details, but I'm happy with the level of detail as it stands.
I'm very appreciative of the encouragement and support I've received from this community and from Nic at BlueJacket.  MSW is a bit of a two-edged sword for someone like myself - I despair of ever reaching the level of expertise I see in so many logs, but at the same time, what I see on MSW enables me to do work I couldn't possibly do on my own.  Thank you.
Andrew Bodge
Congratulations on the completion. She is a beautiful model. Fine work Sir!
Current build: Model Shipways “Confederacy “
Completed builds:
Mamoli “Royal Louis“
Mantua “Royal Caroline”
Scratch 1/4 scale gondola “Philadelphia”
Scratch “Hannah” from Hahn plans.
  • 2 years later...
21 hours ago, BobG said:
I missed seeing your final photos somehow, Andrew. She's really a gorgeous model!
Thanks, Bob. She's sitting on the mantel now, and some day I'll get a case for her.  She puts a smile on my face every time I look.
Andrew Bodge
