Note: In past builds I have rigged the lines and belayed them on the belaying pins, with sufficient extra line to loop them and tie them off as it is actually done on real ships. Those loops looked really good.
Phil, stick with what works. Although rigging the loops the way you described is a pain in the a** the results are worth the effort. These photos show just how bad reality can look. (Photos taken aboard the Bluenose II this last summer in Nova Scotia.)
I belay the rope as you described with extra line to coil. I then use Alene’s Tacky Glue for fabrics it dries clear and is somewhat flexible. Working quickly before the glue sets up I use tweezers and rigging tools to form the rope loops.
Results on my 1921 Bluenose are shown in the photos below.
Edited by John Ruy
John,
The ropes on your Bluenose look great!
The reason I want to make separate rope loops and not try to make the loops in situ is that on this model there are 70 of them. There are too many lines crowding around the pin rails and fife rails to allow the access I need to tie them in place, especially with the sails in the way. It is going to be difficult enough just to tie off all of those lines on the crowded pin rails.
Edited by Dr PR
Phil
Current build: USS Cape MSI-2
Phil,
I used a very similar technique a few years back on my Sherbourne. The difference was in forming the little loop early on in the process. Part of the answer is to make the loop come up over the coils from deep down below and then hook it over a belaying pin.
The picture below is page 93 from my book on Sherbourne
Here are the finished coils on the fife rail. The one on the left has a long loop, and the belaying pins are bulky clubs from Caldercraft which I did not replace. The ropes (Caldercraft) are quite hairy at this magnification.
George
George Bandurek
Near the coast in Sussex, England
Current build: HMS Whiting (Caldercraft Ballahoo with enhancements)
Previous builds: Cutter Sherbourne (Caldercraft) and many non-ship models
George,
Thanks!
Note: "Pin loop" means the small twisted loop that fits over the belaying pin. "Coils" refer to the larger multiple loops that make up the bulk of the assembly.
I think one problem I had was caused by wrapping the coils "backwards." In the photos I posted I started wrapping with the end that eventually was pulled up for the loop over the belaying pin. As a result the ends of the pin loop pulled up from the bottom end of the coils. That was wrong! I should have started the coils from the end hanging down loose when the coils are belayed to the pin. When this end was pulled up to make the pin loop only the hanging loose end would be shortened to get material for the pin loop and not rope from any of the coils.
The real problem is that when you are belaying a real rope on a real pin, one end of the "pin loop" is already secured around the pin, so when you pull it tight it comes up and around the loops in the rope coil. But with the way I did it there is no way to pull the pin loop tight around the rope coils. So it falls apart!
I like your idea of securing the first loop in the coil with a knot at the end where the pin loop will be made. The knot will be covered by the other loops. When the pin loop is pulled up the knot will prevent it from pulling rope from any of the coils.
It will be a couple of days before I get a chance to implement your method, but thanks for providing it!
PS: Happy Mozart's birthday.
Phil
If at first you don't succeed ... The main problem I was having is that there is no line connected to the belaying pin to provide a solid point to pull on. You can see this in this video about 1 minute 15 seconds from the start.
https://www.youtube.com/watch?v=awiFzE5SXzU
When the fellow pulls the rope through to make the loop to go over the pin, he is pulling against the rope already tied on the pin. So I decided to start with a loop that will go over the pin first, then make the coil, and end with another loop over the pin.
Note: On the tool I used to make the coils the left most pin was mounted on a surface perpendicular to the surface the other two pins were on. See the pictures in this post above:
https://modelshipworld.com/topic/19611-albatros-by-dr-pr-mantua-scale-148-revenue-cutter-kitbash-about-1815/?do=findComment&comment=1084631
In this drawing S = short stationary end of the line, L = the long end that is wrapped and tied around things, 1 and 2 = the loops that will go over the belaying pin. The left most pin on the tool is the belaying pin substitute and the right two are used to make the rope coil.
A. Pull the rope long end around the two pins on the left. Leave a long loop 1 to the right.
B. Loop the long end around the pin on the left (a substitute for the belaying pin). This creates the second loop that will fit over the belaying pin.
C. Bring the long end back over the first loop.
D. Wrap the long end around loop 1.
E. Make a loose knot (don't pull tight yet) between the end of loop 1 and the pin.
F. Now start wrapping the loose end around the two right hand posts.
G. Make the desired number of loops for the rope coil.
H. Compress the loose loops into the coil.
I. Bring loop 1 up through the center of the rope coils.
J. Bring loop 1 up and over the the middle pin.
K. Put a twist in loop 1 and pull it over the left pin.
L. Pull loop 1 down above loop 2.
M. Pull on the short end S to tighten loop 1 around the post. Put a drop of glue on the base of loop 1 at the middle pin (use one that won't leave a stain of shine on the ropes).
N. Remove the coil from the pins and  cut off the short end S.
Hang it over the belaying pin. Put loop 2 on first, followed by loop 1. Pull the coils down below the pin/fife rail.
ropeloops2.jpg.c092dcffd967f4c4543db2cf1f37bb4a.jpgHere is the result. The two coils on the right were made as described above. The far right coil was a test made with ordinary carpet thread. The middle coil is 0.012 inch (0.3 mm) rope. While loop 2 did work to provide something for loop 1 to pull against, the knot made in step E is pretty obvious. Not perfect!
The coil on the left was made without tying the knot (steps D and E). I put a drop of white glue in place of the knot and when it dried I continued with the rope coils. After taking the coils off the pins and trimming the short end S the white glue failed and the end of loop 1 came loose!
I glued it back on with some CA gel, but I can see here that I glued it to the wrong side of the coils!!
I think the double loop approach has promise. I'll keep working on this to perfect my "technique." I'll try using the CA gel instead of the white glue to "tie the knot" in steps D and E.
I think I am really going to enjoy the MSI build - it has almost no rigging!
Edited by Dr PR
Phil
Try again, and again, ..., until you get it right!
I think I am getting somewhere. I improved the technique described above, eliminating the knots. As before I have an initial loop to fit over the belaying pin and provide a fixed end to pull on, and a final loop that fits over the belaying pin to hold the rope coils in place.
Here you see two coils made with the new method. They look pretty good! No bulging knots and they hang reasonably "naturally." These are test pieces made with carpet thread.
I made a new tool, lengthening the distance between posts so the coils would hang almost to the deck. With the new tool I start with a 6 inch (150 mm) piece of rope and have only about an inch (25 mm) of scrap cut off the ends after the coil is finished.
Here is the step by step procedure. S = the short, unmoving end of the rope, L = the long end that is wrapped around the posts. 1 and 2 are the two loops that fit over the belaying pin in the pin/fife rail. The arrows show when the ends of the rope are pulled. Be careful to not cut the short end too short!
The new fixture has four pins for the rope coils to wind around, placed in an elongated "diamond" or parallelogram pattern (see photos farther down in the post). The fifth pin on the left serves as a pseudo belaying pin.
A. I attach a small clamp on to the short end (S) to keep it from moving. Then the long end (L) is pulled around the two pins in the middle of the diamond pattern. This forms the start of loop 1.
B. The long end is pulled to the pseudo-belaying pin (left most in picture).
C. Now the long end curves back around this pin to start loop 2. It must curve back around the second pin to the left in the picture on the same side as the first leg of the loop. This ensures that loop 2 will be formed correctly to loop around the base of the belaying pin under the rope coils.
D. The long end runs all the way to the right around the right most pin and curves around to start making the rope coils.
E. The long end continues to wind around the four pins that form the coils until enough turns have been made for the piece that is appropriate for the rigging at a particular belaying point. Some may have fewer turns, and some may have many.
F. After all the coils have been made they should be pressed down to make easy access to the end of loop 1.
G. Pull the end of loop 1 up through the center between the coils. It was initially looped around the outside of the two central pins. Now it must be lifted over these pins so the "legs" of the loop are free to move inside the coils.
This will pull in the short end of the rope. Be sure it doesn't pull in past the left most pin!
H. Continue pulling the end of loop 1 back over the second pin from the right. This is where it hooks over the coils.
I. Hook the end of loop 1 over the top of the left most pin. Put a twist in the loop as you hook it over the pin.
J. Now pull on the short end (S) of the rope to tighten loops 1 and 2 around the left most pin.
K. Place a drop of thin white glue on the cluster of ropes around the pin second from the left. The glue must soak into all the ropes at this point so the assembly doesn't become unwound after it is lifted from the pins. Pull the short end (S) back along the side of the coils so it will be glued in this position.
L. After the glue has set you can lift the assembly from the pins. Trim the long end (L) to the desired length. Trim the short end (S) fairly close to the glued ropes, but leave a bit between 1 and 2 mm long. I find it useful to place a small drop of cyanoacrylate (CA) glue on this "tail" of the short end just to be sure it doesn't come loose.
Here is a photo of the tool and a coil assembly in progress. The four pins of the "diamond" to form the coils are on the top of the tool. The middle two pins serve to open the coils and also serve to form loop 1. The "leftmost" pin in the illustrations above is the ball headed pin on the side of the tool. This represents the belaying pin.
This illustrates step C showing how both legs of loop 2 pass on the same side of the left most pin in the diamond. This is important!
This is a better view of the tool. I made seven "stations" so several coils can be made at a time.
You can see how I use the small clamps to "tame" the rope - it wants to unwind from around the pins.
This is step H after the coils have been pushed down on the tool.
Makingropecoils3.jpg.632f325c613ff3335f9a9b5e5e41416d.jpgThis is step M after the short end has been pulled to tighten loops 1 and 2 around the "belaying pin" shaft.
I apply dilute white glue where the arrows indicate. I soak the bunch of ropes around the pin, and also paint some glue on the ropes down the side of the coil to glue the long end (running off the top of the photo) to the lower ropes of the coils. This prevents it from coming loose and causes it to hang down when the assembly is on the pin/fife rail.
The short end is pulled off to the left side of the picture to pull it tight around the metal pin.
After the glue dries the "belaying pin" is removed and the coil assembly is lifted off the pins. It helps if the pins are bent inward slightly.
The coil shown in these photos was made with 0.012 inch (0.30 mm) rope. It is the first of 70 rope coils for the model.
Edited by Dr PR
Phil
Mass production has started. Here are 37 coils of 0.012 inch (0.3 mm) rope - 30 finished and 7 in progress.
Makingropecoils4.jpg.306f1161bd101b12c6be05e6aa470314.jpgropecoils.jpg.e063443740c9163f41bfaa5f0f295501.jpg
The method I described above works pretty good. So far I have had 6 failures out of 36 attempts - a 16% failure rate. All of these occurred because I got into a rush and failed to follow the steps correctly. Operator error. Actually, on a few I thought I found a better way to loop the rope, and it turned out not to work. Also, the dilute white glue is a VERY weak glue and if the lines are not wrapped correctly the thing falls apart as it is being removed from the pins. However, the rope is still useable and already cut to length, so I just wrapped it again
When I am on a roll I can complete wrapping a coil in about 45 seconds. But occasionally I lose control and the rope springs off the pins and I have to start over. Patience is a virtue ...
stepK.jpg.a36c06f26704654a0acc04cf34c71c3f.jpgI have found one slight modification that improves success. The last step before applying the white glue is to pull the long end around the pin on the right, to the opposite side of the pin from where the coils would normally wrap. This puts a bit of pull on the rope as it passes the two middle pins. I apply white glue to the side of the loop to the left of the center pins where the long end lays along the other strands to hold it in place after the loop is removed from the pins.
With a bit of luck I am about half through this phase of the build.
I had an "OH!" moment when I wondered if I had accounted for the 6 inches (152 mm) of rope I was using for these coils when I ordered the rope from Syren? I checked my rigging spreadsheet and I had allowed 7" (178 mm) for most of the rope coils, but only 3.5 inches (89 mm) for those that wouldn't need as many loops. So I was planning ahead. I should have over 100 inches (2.5 meters) excess rope for all the ropes used on the model! Whew!!
Edited by Dr PR
Phil
Ever have one of those days when nothing seems to go right? This was one of those days!
I have been preparing the main gaff topsail for installation. Lines for the tack and sheet were measured and cut to length, then tied to the cringles at the lower corners of the sail.
The halliard posed a special problem. One end of this line was tied to the sail's spar a bit below the center. The other end will be stropped around a double block that is part of a luff tackle that belays to a ring bolt on deck.
However the line must pass through a single block at the top of the main topmast. Since neither the sail and spar nor the double block will pass through the sheave hole of the block on the mast I had the fasten one end first, then pass the line through the single block and then attach the other end. And since the single block is already rigged to the mast, all of the work must be done in situ, on the mast.
I decided it would be more difficult to tie the halliard to the spar while everything was dangling from the mast top than it would be to strop the other end to the block after the sail was hoisted on the mast.
The halliard was tied to the spar with a rolling hitch. I got this idea from Darcy Lever's The Young Sea Officer's Sheet Anchor. This part was pretty easy. Then the halliard was reeved through the single block at the top of the mast and the sail was raised into position. So far, so good.
The other end of the halliard was pulled down to deck level and a small clamp was fastened to it to keep tension on the line and pull the sail into position as shown in this picture.
The double block of the luff tackle was to be stropped to the lower end of the halliard while the sail was hoisted.
Next I ran the sheet line through a single block tied to the end of the gaff and then to another single block tied to an eye bolt on the underside of the gaff jaws. From there the line runs down to belay on a cleat on the main boom.
This is where Murphy stepped in. I pulled the sheet through the blocks and down to the boom, but just placed a small clamp on the lower end of the line to put a bit of tension on it. But when I pulled the line taut to haul down the clew of the sail the seizing on the strop of the block at the end of the gaff failed, and the block pulled loose! The strop around the block was still good, but the loop around the end of the gaff had pulled open.
So I had to stop rigging the gaff topsail and put the sheet block back on the gaff!
I think the diluted white glue that was supposed to hold the seizing for the loop failed to prevent the end of the line from pulling through. The seizing itself just pulled off the end of the line. To prevent this from happening again I pulled the loop closed and placed some super glue (cynaoacrylate) on the lines. When this hardened I wrapped new seizing around the throat of the loop, tied it off, and soaked it in white glue.
After all the glue had dried I started to place the loop over the end of the gaff and found I had another problem - this was operator error. The flag halliard had already been rigged through a small "jewel block" tied to a eye at the end of the gaff. There was no way to get the sheet block loop over the end of the gaff! This was poor planning. I really wanted to keep the hardened loop on the sheet block, so I moistened the seizing for the jewel block attachment to the eye and pulled it loose. Then the sheet block loop was pulled over the end of the gaff and more seizing was added to pull it tight around the gaff end.
Throathalliard.jpg.f70d147689a41ee2c035fb88142863b6.jpgBefore putting the jewel block and flag halliard back on the end of the boom I decided to finish rigging the gaff topsail. But Murphy wasn't done for the day!
As I pulled the sail sheet through the sheet block at the end of the gaff and the single block under the gaff jaws the rope twisted and a kink hung up in the block. Then I heard a "pop" and the gaff dropped down a bit on the mast! I wasn't pulling hard but apparently it was hard enough to break the plastic hook that attached the lower single block of the gaff throat halliard to the gaff.
I have broken several of these hooks while rigging the model, so a while back I made a bunch of metal hooks to be used where more strength was needed. I used one here.
Great! Now I had to repair the throat halliard before I could finish rigging the sail!! One step forward, two steps back! This was becoming tedious and frustrating.
But as you can see in this picture I did get the throat halliard tackle back in place.
And I did get the topsail sheet installed and run down to belay on a cleat on the port side of the boom.
The tack was pulled down and belayed on a cleat on the starboard side of the boom.
Then I installed the jewel block and flag halliard back on the eye at the end of the gaff.
And I did get the double block stropped to the lower end of the topsail halliard. I am waiting for the glue to dry completely before I rig the luff tackle for the halliard. The single block will hook to an eye bolt on deck near the bulwark, and the fall of the tackle will belay on a pin on the port aft pin rail.
Over the past week or two I have been tidying up loose ends for lines already belayed to pin rails and fife rails. All of the lines for the main gaff sail, the main gaff and main boom have been belayed, so most of the rigging for the main mast has been completed!
This picture shows the schooner as it stands today. But if you look closely you will see several lines with clamps hanging from them to keep the lines taut while glue dries so that rigging can be finished.
Edited by Dr PR
Phil
I had an "OH!" moment when I wondered if I had accounted for the 6 inches (152 mm) of rope I was using for these coils when I ordered the rope from Syren? I checked my rigging spreadsheet and I had allowed 7" (178 mm) for most of the rope coils, but only 3.5 inches (89 mm) for those that wouldn't need as many loops. So I was planning ahead. I should have over 100 inches (2.5 meters) excess rope for all the ropes used on the model! Whew!!”
That’s pretty good to be able to measure out your rope needs. I’m a habitual rope waster so don’t even try.
Completed Builds: AL Bounty Jolly Boat, Constructo Enterprise (logs lost in the great crash)
Current Builds: Constructo Bounty, AL King of the Mississippi
Up next: undetermined
Auger,
I have a 2D CAD model profile that has all the rigging. From this I can measure the lengths of the lines. However, it isn't perfect! It also takes a bit of guesswork about how much line is used passing through blocks, deadeyes and such, how long the ropes in tackles will be, how much rope will be used in rope coils, etc.
So far it has been pretty accurate, but in at least one case so far my guess was about an inch (25.4 mm) short and I had to splice the line. Later I went back and replaced the spliced line with one long enough.
Even with my estimations there is a lot of scrap rope in the waste basket!
Phil
The ship now has a main topmast staysail
The tack is tied to a ring on a metal band on the fore mast head. The halliard and stay pass through single blocks on the main mast and descend to belay on a fife rail in front of the main mast. I haven't rigged the downhaul yet (it is coiled beside the main top mast). It will pass through a single block tied to the same loop that the tack is belayed to and then descend to a pin on the fore starboard pin rail.
Right now the sail is supported only by the halliard and the tack. I am trying to decide how to tie the sail to the stay. Some people use wooden or metal hanks, but other books say metal hanks were introduced in the mid 1800s when wire rope came into use. Lees says they were used on English ships much earlier than that. And others say only wooden hanks or rope grommets were used with rope stays.
I think I will use rope grommets, but haven't made up my mind.
This was another trying day! Some place where I have shopped was hacked and my credit card number was stolen. I blocked a couple of illegal purchases last week, but my card was disabled. Then we had snow and ice for a couple of days and the credit union was closed Thursday through Monday. Finally today I got down there and got a new card.
maintopstaysailrigging.jpg.40f6cb31ccfca0ba1e2868f62893aaba.jpgWhen I got home I started rigging the main topmast staysail. And this turned out to be an exasperating exercise! This picture shows the luff tackles for the halliard and sheet. The lower blocks hook to eyebolts in the deck in front of the main mast partners - that was no problem. But the falls from those tackles belay to the outer pins on the fife rail in front of the mast.
It took one hour each to fasten those falls to the belaying pins!
The area is on the centerline, and there are dozens of stays and lines coming down all around, leaving very little room to get my hands in there. I had to work with two long tweezers and a hook to pull the lines in under the pin rail, loop them around the lower part of the pins, then back up behind the rail, over the top of the pin, and then pull the loose end under the part of the line looped around the pin.
For every step the rope kept springing back out of position, sometimes undoing two, three or all steps. So I started over, and over, and over ...
When I finally got everything in place I put some white glue on the rope where it crossed over and hooked under the rail.
Part of the real problem can be seen where the back part of the pivot gun slide comes very close to the fife rail. I can't belay the line to the front side of the rail because the rope coils would interfere with the motion of the gun! The lines have to be belayed from the back side of the rail. And that is a VERY tight workspace!
I still have two more lines to belay to the two center pins on that rail. They are the foremast topsail yard braces, and the yard isn't installed yet. That would have been difficult if the main topmast staysail halliard and sheet were not there. But they are, and they may make belaying the other two lines virtually impossible!
I'm pretty sure I will have to figure out a way to belay the braces to the pins before the lines are rigged up to the brace pendants.
When I finally got the halliard and sheet belayed I leaned back, took a deep breath, and reached to put a tool back in the box. My hand brushed the trailing edge of the main sail and there was a "pop!"
AARRRGGGGGHHHHHH!
failedseizing.jpg.454c3742742987b35cbce16eb8b12153.jpgThe double block of the main gaff sail sheet luff tackle pulled loose from an eye bolt on the bottom of the boom jaws!
Two steps forward and one step back!
The seizing on the rope eye around the eye bolt failed. Again, the white glue failed to hold and allowed the end of the rope to pull through the seizing. This is the same thing that happened to the main gaff topsail sheet block on the end of the gaff.
But the eyebolt under the jaws of the boom is in a very crowded, narrow space, with lines all around it. Repairing this will be like working through a spider's web without disturbing the web.
It was time to put the build aside and take a muscle relaxer. A double martini took the edge off for a while!
This build was a lot of fun up until I started on the sails and their rigging. Every step since then has been tedious, frustrating and very unrewarding. I started the hull in the 1980s and then other things took priority. The unfinished hull sat on the shelf for 35 years until I took up the build again about six years ago. I am thinking I may put it back on the shelf again for another 35 years!
Edited by Dr PR
Phil
Phil, I am in awe 🫢 of your incredible detail. Especially the Sail works. You are doing incredible work.
You are almost there, sometimes we can get a bit weary. Our own criticisms slow us down but that is what’s driving us to perfection. Take your time, work on it when you feel like it. Take a step back and take a look. Wow, she is beautiful.
John
John,
Thanks. Flattery will get you everywhere!
I will fix that ^*&@! main sail sheet! But I may recall some sailor talk from when I was in the Navy!
I have a shipment of scale lumber on the way to add another layer of planking to the MSI hull. I will probably work on that project for a few weeks, and maybe do a bit of cleanup on the schooner.
But the schooner rigging isn't even close to half done, and there will be a LOT of lines belayed on the fife rail at the base of the fore mast! Imagine all the joy in that!
Phil
No more shelf time Phil!   Ordinary only leads to troubles!   It looks fabulous and you're almost there.  (Maybe more martinis in your future though! 🤣 )
The sails really make an impression - I'll likely follow your lead!
Steve
Edited by Coyote_6
Steve
San Diego Ship Modelers Guild
Don't you dare!
After all the time and research you've put in to getting this build right you deserve the satisfaction of calling it complete! Besides, you can't be the Godfather of schooner rigging with an unfinished schooner.
Jsk nailed it.   That handle is gonna stick!
"Godfather of Schooner Rigging!"
Edited by Coyote_6
Steve
Steve,
I have a number of ship modelling books that all advise against adding sails. They say the sails detract from the model, and hide some of the deck details. I suppose they might if not done correctly (whatever that means), but I really suspect these guys have tried it and know what a hassle it turns into!
I'm sure I won't shelve it permanently. I restarted the 30+ year old build because I got tired of looking at the unfinished model. Having only half the sails on it will be even more annoying!
But for now I think I will take a break. The Admiral also "suggests" a break (and you know what a "suggestion" from a superior officer means). I think she is annoyed because she thinks I spend more time on the model than with her.
Thanks for all the comments and support. But I'm not sure about that Godfather thing! What am I supposed to do, start rigging a new line and make it an offer it can't refuse?
Phil
"Leave the jib.  Take the cannoli."
But yeah - a "suggestion" from the Admiral is not to be ignored.
Edited by Coyote_6
Steve
That ^*&@! main sail sheet has been fixed!
I have been experimenting with hanks to attach the main topmast staysail to the stay. First I did some research to determine what types of hanks were being used in the early 1800s. I have posted the results of that investigation at this link:
https://modelshipworld.com/topic/38044-hanks-for-attaching-staysails-to-stays/?do=findComment&comment=1088102
At the time of my model, about 1815-20, three types of hanks were used, and smaller vessels still laced staysails to stays. I decided that either grommets or wooden hanks would be appropriate for my model. But since I have already rigged the stays putting grommets (three turns of rope around the stay) would be a lot harder that making wooden hanks.
hanks1.jpg.33a5affe32ec108eec2607023a9dd310.jpgI decided to use the wooden hanks. But I think it would be very difficult to work with extremely thin wooden sticks (split bamboo) and get them curved properly. They might want to uncurl, especially when I was trying to tie them in place.
So I decided to use 0.012 inch (0.3 mm) brass wire. I used forceps to clamp one end of the wire to a 0.625 inch (1.6 mm) diameter drill bit shank. Then I wrapped the wire around the bit and trimmed off the end, making a "bow tie" shaped loop.
These are supposed to be wood so I painted them with the straw color acrylic paint I used on the masts and spars. I really didn't think the paint would stay on while was installing them, but maybe some would. And there is enough remaining on them after they were installed to look something like wood.
The first thing I did was lay the ship on its side so the stays would be parallel to the table top. I dreaded trying to fit the hank over a downward angled stay, they try to get it to hold in one place long enough to tie thread around it and then lace the whole thing to the sail.
Putting the ship on its side eliminated the problem.
hanks2.jpg.8bbf98d037e47d53cfdd8eeb9d296496.jpghanks3.jpg.4007df965703737c0cc9751b53085f01.jpg
The hanks had a gap between the ends wide enough to slip over the stay. Then I closed the gap with forceps. Next I used small (less than 0.006 inch or 0.15 mm) silk thread to tie an overhand knot horizontally across the "X" where the ends crossed and added a small drop of diluted white glue (about 2:1 glue to water). Then the long ends of the thread were looped under the "X" and back through the eye of the hank, and back down again. These ends were then used to tie an overhand knot vertically across the "X". This is actually the way the books show the real hanks being tied.
hanks4.jpg.05c3df1c7b59dae272a88ed6e7edb2e7.jpgThe long ends of the thread were pulled through a small hole in the sail, one from one side and the other in the opposite direction from the other side. The ends were pulled through the hank loop from opposite sides and tied in an overhand knot. Then all of the thread was soaked with the diluted white glue.
Here you can see the thread passed around the bolt rope and through the tabling This is important with silkspan sail material, because the thread could easily slice through the silkspan and come loose from the sail. Just as in real sails, it is the bolt ropes that carry the load.
I use silk thread for the seizings and other tying. The main advantage is that it goes totally limp with just a drop of water or water based glue. It isn't springy and always trying to unwind.
Here is the finished product.
maintopmaststaysail2.jpg.34f52919a511e269bb08663a808957af.jpgThe downhaul is tied to the peak cringle on the sail, where the halliard is also attached. The downhaul passes through every third or fourth hank to keep it hanging near the head of the sail along the stay. At the sail tack it passes through a single sheave block and then descends to belay to a pin on the starboard forward pin rail.
The sail tack is tied (or hooked) to a ring on a band around the mast head. The downhaul block is also secured to the same ring on the mast band.
It actually was pretty easy attaching these hanks to the stay and sail. If you look closely at the photos you will see that some of the paint did chip off of the hanks. But enough remains that the hanks still look something like wood.
Four (sails) down and five to go.
Edited by Dr PR
Phil
Phil, your rigging is looking really good, and your instructions can be implemented to other builds as well.
Respectfully
Per, Thanks.
There is a bit noire progress to report. I have started rigging the fore mast, and that called for a review of the belaying plan. That revealed a few missing elements - a few eye bolts on deck, a change of a couple lines, and calculations of line lengths. I attached sheets and halliard blocks to the fore sails . The length of the sling for the fore course yard was adjusted so it didn't hang too low and ride on the parrals for the fore gaff. But it had to hang low enough for me to rig the truss luff tackle below the trestletrees.
But the main time sink has been rigging 31 more hanks to the fore stay, jib stay and outer jib stay. That was tedious work.
As before I put the model on its side so the stays would not be running vertical. Here you can see the last bunch of hanks tied to the outer jib stay. I needed to get all the hanks on the stays before I started rigging the fore course yard and the fore topsail yard and sail. With these in place on the mast I wouldn't be able to put the model on its side..
foresheethanks2.jpg.0a9bb6fb49807f295bb60a30d0b14897.jpg I slip the hank over the stay and then squeeze the legs together with forceps so the hank cannot slip off the stay. Then I tie the knots around the "X" of the hank. The long ends of the line are weighted down with small clamps. Then a drop of white glue is applied to the knots to hold everything in place. After the glue sets the clamps are removed.
You can see how much the weight of 11 clamps pulls down the stay. But when the clamps were removed the stay pulled back taut.
After rigging 40 hanks it became pretty easy to do each one. Still, it took 45 minutes to tie eleven hanks, or about four minutes each. There are four knots on each hank.
foresheethanks4.jpg.b66471fcf8dc9bb1333ca285190431fb.jpgforesheethanks3.jpg.31044ee8f12c4ff395100c81d8eff56c.jpg
Now that the hanks are in place I need to decide what to rig next. There are a lot of lines on the fore mast, and no matter what order I select to add the sails each one will be in the way of rigging the next one!
I have decided I will not rig the fore course. I will rig the fore staysail, and that would not be flown when the course was rigged. The yard will be there to serve as the spreader for the topsail, with all the yard rigging. But I probably won't try to rig any of the fore course sail lines. That will relieve the line congestion around the mast.
I did find an interesting note while researching fore sail rigging. The fore staysail wasn't used on most merchant vessels, but was mainly used on warships.
Edited by Dr PR
Phil
I have been preparing things for installing the fore topsail. I made the sail months ago, but there was still some rigging to attach before it could be hung on the mast.
I attached the clue line blocks to the clews and placed two cringles on the foot of the sail for the buntline attachment points.
Two thimbles were tied to the topsail yard for the buntlines to pass through. Then the topsail was fastened to the yard with robands.
Truss.jpg.ef67c4f1ce5ad6053b88a2b12facb00c.jpgTwo truss ropes were constructed and then tied around the course yard. Each truss was about 2 inches (50 mm) long, with an eye seized into each end.
One eye was positioned above the yard. The other end of the truss was looped behind the yard and then up and over. Where it met itself the two parts were seized together above the yard.
The long ends will loop behind the mast and then come back around and through the lower eye of the other truss. Hooks on the single blocks of the truss luff tackles will engage the free end eyes of the truss lines.
At least that is the plan. I measured and calculated the truss rope lengths, but the test will come when I try to rig this on the mast!
Stunslboom.jpg.97f80c4e3794e837017cf7eafa00a049.jpgI finished the studding sail booms and slipped them into the irons on the course yard. A block was attached to the end of the studding sail booms.
They are in the stowed position. I do not intend to rig these sails. I still need to add some rope on the inboard ends to fasten the booms to the yard.
I think all the other blocks for the remaining lines are in place so the topsail yard and sail should be ready to install.
But first the course yard will be hung and the lifts and braces put in place. Then the truss tackles will be hung and everything will be adjusted to hold the course yard in its place.
Phil
Looking real nice Phil.  It’s really coming together.  You should be very proud.
Question, shouldn’t the truss slings be served?
Able bodied seaman, subject to the requirements of the service.
"I may very well sink, but I'm damned if I'll Strike!" JPJ
My Pacific Northwest Discovery Series:
On the slipways in the lumberyard
Union, 1792 - 1:48 scale - POF Scratch build
18th Century Longboat - circa 1790 as used in the PNW fur trade - FINISHED
Future Builds (Wish List)
Columbia Redidiva, 1787
HM Armed Tender Chatham, 1788
HMS Discovery, 1789 Captain Vancouver
Santiago, 1775 - Spanish Frigate of Explorer Bruno de Hezeta
Lady Washington, 1787 - Original Sloop Rig
Dowmer,
Lever (The Young Sea Officer's Sheet Anchor) says the ropes were wormed and served. There are many other lines that could also be served (shrouds, stays, etc.) that I have not served. I don't have a serving machine, and the only lines I have served on this model are the long hook straps for the Burton tackles.
If I was attempting a super accurate model like archjofo I would serve all of these lines. But this schooner build is just a learning experience for me, and certainly isn't an accurate model of any vessel. In fact, I have a list of 13 errors I have made so far - and the model isn't finished. I intend to list these mistakes in my final post so others may learn from them.
In my opinion there are features of real ships that aren't worth repeating on a realistic model because the scale makes them impractical. Trenails is one such item. I served on three ships with wooden decks that had plugs of the same wood (teak) hammered in over the bolts that held the planks down, and even when standing with these plugs between my toes they were barely visible. In photos taken dozens of feet distant these details are invisible. I don't "do" trenails because they would not be visible in anything but the very largest scale models (1:10 or larger). But if you want to put trenails on your model just to accomplish it that's fine with me.
Likewise, I don't care much for serving. But again that is the builder's choice. But if you insist on being truly accurate shouldn't you first worm the lines before serving, and pay attention to the different lays of the ropes that are being served?
In the end, the only truly accurate rendition of a vessel is the vessel itself. Any model will have inaccuracies and omissions.
Edited by Dr PR
Phil
Phil,
I understand your last post and agree that there are choices to make about the level of detail to include on a model. I also ignore trenails but others like to include them. I have copper plated the hull with Amati parts which have representations of nail holes because to my eye plain ones look as if something is missing. My most extreme inclusion is probably the furniture in the captain's cabin on Whiting which is only just visible through a skylight. Methods for serving a rope is something that I have been experimenting on and at present I rely on thick paint; I doubt if the turns of a serving line would be visible at normal viewing distance in 1/64. But if I make myself a serving machine then I might change my mind.
To me a joy of the hobby and this forum is that people make their own choices and accept that others can follow different paths.
George
George Bandurek
I have some "progress" to report - more like two steps backward and two forward!
I few posts back I griped about it taking an hour each to attach two lines (main topmast staysail halliard and sheet) to belaying pins on the fife rail in front of the main mast. Well, while planning the rigging for the fore course braces I noticed that I had wrapped the main topmast staysail halliard around another line! So It has to be redone! That's one step backwards!
Then while I was starting the rigging for one of the braces the seizing on one of the blocks at the main top failed and the eye opened, allowing the block to fall off the mast. Another step backwards.
I have been having too many problems with the seizings failing and allowing eyes to open that fastened ropes around hooks, blocks, spars and such.
THE PROBLEM IS THAT WHITE GLUE DOES NOT STICK TO POLYESTER ROPES.
To make the eyes I have been looping the short end of a rope back on the long end and clamping the two strands. Then I used thin (0.003 inch, 0.08 mm) silk or cotton thread to tie an overhand knot around the two rope strands where I wanted the seizing to start. One end of the knotted thread was taped to a clamp to keep it out of the way. I put a drop of diluted (1:1 with water) white glue on the knot and the two strands of rope. Then I looped the long end of the thread around the two rope strands 6-8 times, using the seizings to close the eye down to the desired size. These turns were also wetted with diluted white glue. Then I tied a final overhand knot to finish the seizing. While the glue was still damp I used tweezers to push the seizing coils together tightly, and then tugged on both ends of the seizing thread to tighten the coils around the rope strands.
When the glue dried the eye looked quite strong - and is strong enough for lines that have no stress on them. But just the force of pulling loose ropes through blocks was enough to cause the short end of the rope to pull through the seizing, opening the eye and leaving a perfectly formed seizing on the long end of the rope!
I have had half a dozen of these seizings fail, especially when I accidentally bumped a line or spar while working in the rigging. The sudden force on the ropes just opens up the eyes as if there was no glue at all!
I have resorted to placing a small drop of super glue (cyanoacrylate) gel on the two rope strands after tying the first knot to pull the strands together. Then I have to wrap the seizing rapidly before the glue gel hardens. But the superglue becomes very sticky rapidly and it is hard to finish the loops and tie the second knot before it hardens. I cannot push the coils of the seizing together or pull on the ends of the thread to tighten the seizing into a neat finished shape. But it appears the super glue does bind the two rope strands together, and it sticks to the seizing as well.
Here are some repaired seizings.
Blockandhookseizing.jpg.2dda7223d5a044fafdaa760fa0913e01.jpgRepairedblocks.jpg.5226eb6562fb9161f0360bbdb2228d84.jpg
On the left are two block and hook assemblies after tying and two more after the ropes and threads have been trimmed. On the right is a close up of these assemblies showing the rather lumpy seizings created with superglue. One step forward.
I have also had a lot of the Syren plastic hooks fail. I think one problem is that you can twist them as you are trying to hook onto eyebolts inside a bunch of rigging lines and other obstructing objects. This can cause the opening in the hook to be stretched, cracking the plastic. Sometimes the hook breaks immediately. But often it is when I am pulling rigging through the blocks the hook breaks, or if I bump a line or spar. Of course it always will be a hook that is buried behind a lot of other lines where it is near impossible to reach! Another step back!
My solution is to make metal hooks from hard brass wire, and solder the eye loops closed so lines cannot squeeze between the wire ends. Then I blacken them with Birchwood Casey Brass Black. I cannot make hooks as uniformly sized or pretty as the Syren hooks, but they are a LOT stronger. The hooks on the blocks in the pictures above are my metal hooks. Another step forward!
Blocksonmaintop.jpg.6c04571f6a0599183323e8426f609815.jpgHere are several of my superglued metal hook and block assemblies hanging from eye bolts on the main mast top. The lower aft (port and starboard) are for the main course brace lines, and the two on the face of the top outboard (port and starboard) are for the fore topsail yard braces.
Now I can proceed with rigging these lines with confidence these seizings will not come undone nor the hooks break!
The center block is attached to an eyebolt with a white glued seized eye. And the seizing around the eye of the staysail sheet is another white glued seizing. Neither failed while I was rigging the main topmast staysail sheet. But I have to be very careful to not place any stress on this line!
Edited by Dr PR
Phil
Phil,
Thanks for your very detailed description of issues and resolutions. As always, reading your log is a learning experience. Good job… 👍
Carry on Sir. 🍻
PS, Might I suggest the tinniest drop of Thin CA glue over your White Glue seizings to hold them from failing.
Edited by John Ruy
Very interesting report Phil.  I too had similar issues with the plastic hooks, and this was with them just out of the package.  Concern for performance over time forced me to switch to handmade brass.
I was hoping to avoid the CA for the majority of my rigging.  It looks like that may not work as I have been enjoying the look of Syren's poly-cotton rope.
Thanks for the tips.  I have been using superglue to make eyes on my breeching lines and then seizing per Ashley's.  I coat the seizings with diluted white glue and have been fine.  But breeching lines are unstressed.  I was gonna switch to white glue only after the guns, but now we know.  Ugh.
Glad to see things getting straightened out.
Steve
Thanks for the comments. I was hoping to avoid using CA. It makes my eyes water and burn.
I don't know if adding the CA over the white glue will do any good. I doubt it will penetrate the white glue on the seizing. It isn't the white glue on the seizing that is failing - the seizing is still intact, leaving a nice hollow tube of tightly wound thread. The CA really needs to be applied directly to the polyester rope inside the seizing.
Phil
