Good evening everyone
i think that the hull and fittings is now about 75-80% complete, every time i look at photos i see more to add, also now that im more confident with soldering, im  happy to have a go at making bits
12 ships boats make up the compliment on here, these will be made up over the coming months, as much as i hate making them, one of the motor launces was started by me 12 years ago, at present being taken back to the frame
the accommodation ladders are now done, just the lifting gear/davits to be made up
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
its that stage of the build where i am worried i am going to go out of my depth,
 i have no decent instructions,
i have a rigging plan but no idea what size threads to use
no sail plan but 30 odd sails to make
and im absolutely loving it
i noticed that the build i am following had a lot of changes made during this stage onwards, where things had to be moved/adapted to get the rigging done, i certainly wont avoid that, but i am aware of it hence some items are still removable on the forecastle, to this end i have proceeded with the bowsprit
the chain i am using is 1.5 and 2mm jewellery chain, this will be pained later on, in these colours it looks like a cheap toy
yes i am making more work for myself but my plan is to proceed with that ever i have in my rigging threads, and see how it goes, then replace with my home made ropes,  and tumbled blocks this will keep my interest going and allow me to show my mistakes as i go along
all the fittings being used now are now scratched, from 1.5mm brass tube and .4 brass wire, soldered where necessary
please feel free to scream at me if you see anything wrong, or better ways of doing things
 question
 what comes first, the chains or the stays
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
She is looking Superb Kevin  -  you know  some people build a model  but this is more like  scale engineering, and trust me you are doing a wondeful job.
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
OC.
Thank you OC , a very much appreciated complement
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
2 hours ago, Ian_Grant said:
Lovely job on the model. Should those chains not be a little more taut though?
Looking forward to more.
yes the whole lot will be removed when im sure everything is in the right place,  now the dolphin striker has been pulled forward the ones behind are too tight now, bear with me
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
good evening everyone
over the last week i have been ensuring everything fits and works as it is meant to,ie that most of the brackets and blocks etc will be in the right place
so yesterday i salvaged the chains, painted them and set them in place, they look ok to me, time will tell if they are actually where they need to be
over the next week i am going to plan the new display area in the garage and learn to use the @Alexey Domanoff rope walk
Edited by Kevin
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
Good morning everyone
planning for the display area is still ongoing it seams i will have a area approx 2.3m x 1m x 2.3 so some of the larger vessels like the st Nectan will have to be displayed at an angle
yesterday i learnt how to use the @Alexey Domanoff rope maker and have now started to get some nice results, using Guttermans Mara threads and serpia ink
its attached to one of the roof beams, i will try for a better photo
im using 4 sizes of thread 30, 70, 100, and 120 ( 30 is the largest i have)
and some of the results including using some of the many different kit ropes i have
IMG_0020.thumb.JPG.71f2572c55cf698362c4617a87458599.JPGIMG_0014.thumb.JPG.40060ac7f1da7e74c58df0f46f83cba6.JPGIMG_0015.thumb.JPG.bf2d6024d296121c7e43b5a5c6eb6543.JPGIMG_0016.thumb.JPG.b85cdcb1d9c630c47a22f9e7fb31d76c.JPGIMG_0017.thumb.JPG.011fbfc4dc13bd4dceb8d73686933f98.JPGIMG_0018.thumb.JPG.f3988137d562ccfe2a6b1af6d97a9824.JPGIMG_0019.thumb.JPG.fffcae43810dba6edd890d95db271a83.JPG
Edited by Kevin
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
the display area
on the left will be any hobby related bits, with the exception of tools
on the right will be the big cabinet to keep the builds dust free
before, the garage has Been a dumping ground for the last couple of years
 the cabinets have been resorted and the worktop cut back
IMG_0009.thumb.JPG.5a523f282d072beda8e2b71622f6dbd1.JPGIMG_0010.thumb.JPG.142469830cded6d907f8215975364002.JPG
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
the wood arrives tomorrow, so i will be away from the build until the cabinet is up and running, i have two weeks to get it done, and i have have changed my mind so many times on how to do it, i dont have a way ahead
the acrylic sheets arrived at the weekend, broken, they are being replaced and i have been told to keep them and dispose of or use as i see fit sized 900x1800, possible 1/5 has been lost, so i will be making good use of them
IMG_0023.thumb.JPG.d07c29df7624e0fae02ff290874c36fd.JPGIMG_0024.thumb.JPG.e6d0e20415e494ab357bd8c4b353b127.JPG
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
as for the build, i am making progress albeit very slow, this morning i made up 6 lengths or rope in two sizes, some soldering and shaping a few blocks, i wish i knew the names of the ropes im putting in, oh and some German, as all my dropbox contents are gobblygook to me
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
2 minutes ago, yvesvidal said:
Kevin, you are becoming the King of Brass !!!
Yves
lol oh dear
but its better than my painting
Edited by Kevin
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
27 minutes ago, egkb said:
She looks a treat in close up Kevin.. We can't ask for better than that !
Keep Up The Great Work Mate
Eamonn
Thank you
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
i  just deleted yesterdays post as i was unable to rotate the photos and added todays progress to it
the wood arrived yesterday, and i made a start on building the showcase
it has a footprint of 90" (2.2m) x 43" (1.1m)
the Victory, Dorade and later the Amerigo and eventually the Enterprise will sit on a low platform, where as the St Nectan, Bismarck, Bluebell and eventually the SD14 will be on adjustable shelfs on the back wall
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
cabinet continued today
walls prepared for paper, electrics/lighting and cabinets moved
architrave/ window beading being put in, and test fit of the acrylic panels, hoping this will be completely finished by this time next week, i have a build to finish and put in there with the other dust collectors
the replacement acrylic panels arrived today, and i have been told to keep the other stuff
20210624_194015.thumb.jpg.846a51bae2d485ef520f3324d37acd38.jpg20210624_194056.thumb.jpg.86431b11f40b8bf5bebb9cd41ef484d5.jpg
Edited by Kevin
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
Some beautiful  pieces of work there mate.
OC.
Current builds
Completed works.
not much of an update. wallpaper now on, and will be painted tomorrow
Edited by Kevin
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
Busy busy mate  - gonna be a great area.
OC.
Edited by Old Collingwood
Current builds
Completed works.
OC.
thank you, its actually turned out better than i thought, will get all my builds in and and room for another couple of 7 year  builds
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
wallpapering and pained, also got the floor in
tomorrow electrics and start the shelving
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
Looking great mate.
OC.
Current builds
Completed works.
coming to the end of this project, hope to finish tomorrow and get the boats in Thursday
i needed  a set of spot lights so stole them out of the kitchen, replacing the halogen GU10 with LED
dont worry the admiral can see her cakes now
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
Thats the ticket mate  - that will look superb when all displayed.
OC.
Current builds
Completed works.
cabinet is now up and running, however it is to reflective at present to get any decent shots, blinds are next to be sorted, hopefully i will get some decent shots then, but for now i present,
next week i will start to clean them up and repair/ redo a few lines
Edited by Kevin
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
That is looking so nice mate  - like a museum display  love the room you have in there.
OC.
Current builds
Completed works.
30 minutes ago, yvesvidal said:
This is looking fantastic Kevin. Your models will be safe and well protected from the dust.
What is that hull with parts and plans, hanging in the display?
Yves
hello my friend
it is the Mountfleet Talisman hull
P.S Talisman (mountfleetmodels.co.uk)
PS Talisman (Clyde Paddler 1935)
Hull: 1434mm
Hull: 56 1/2 inch
Beam: 7 inch
Scale: 1:48
Image result for Talisman Paddle Steamer. Size: 247 x 160. Source: www.ianwattphotography.com
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
did a bit more to the display area, including rearraigning the ring main and ,moving eclectic sockets, i just want to put a extension lead in there to power the St Nectan and any other build that might have lights fitted, and fit the windows
back onto the build today, and the foremast
i presume the futtock shrouds are the right name for this type of vessel
the top platform on all masts has spreaders fitted, another item not mentioned in the kit, aft of the platform is what i presume to be another line guide, i have no measurements for any of this, just trying to follow another build, but if wrong, i will do again
futtock shrouds
Edited by Kevin
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
