5 hours ago, Justin P. said:
What a beautiful result!   So clean and uniform...   you must be proud of that job!
Thanks for the kudos, @Justin P. Justin!  Deeply appreciated.
Actually, I almost changed my mind to go with the Amati plates when I saw how beautiful your hull came out. But, I spent so much time making those stamps, I felt ‘pot committed’ with regards to using the kit supplied tape!!!  🤣
“Here.  Hold my beer..." --- Common phrase uttered by Lord Admiral Nelson at any pub. 🍺
Coppering is complete!  Cutting away the tape was a bit more difficult than I expected. Doing it this way made it easy to visualize the waterline, but it left a nasty edge to the existing copper plates.
However, the copper tape was wider than the stripping tape, so installing the upper belt was a breeze.
A few of the copper plate edges have popped up, but nothing major. So I’ll call this finished and move on to the rudder.
:dancetl6:
Edited by Overworked724
You know what, I think you did such a nice job that the Amati plates would have been a mistake.   If I thought could have done it this well with that material and a stamp I might have stuck with that method myself.   The Amati plates I think were a bit of a cheat.   Yours turned out really fantastic.
As always Patrick your attention to detail ends with magnificent results. Very well done really well done I mean. Just one thing I did not think of on my and has resulted it uneven tarnishing. FINGERPRINTS.
Best regards and a Happy and Healthy New Year
Will
HM Cutter Cheerful  Syren Shipmodel Scratch 1:48 scale
On Hold:
Syren by pearwill Model Shipways 1:64 scale
1776 Washington Row Galley scratch scratch from NRG plans #121  1:48 scale
Completed Build:
Erycina 1882 Fishing Trawler by Vanguard Models 1:64 scale
Charles W. Morgan by Artesania Latina circa 1988, Lowell Grand Banks Dory 1:24 scale by Model Shipways, Norwegian.Sailing Pram 1:12 scale by Model Shipways, Muscongus Bay Lobster Smack 1:24 scale by Model Shipways
8 hours ago, CiscoH said:
Thank you again for your thorough explanation and pics, it really helps newbies like me.
Hey Cisco. Much appreciated!  But I am still very much a newbie with only the completed Sultana in my model resume. I can say that most of my ideas are adopted (or modified) from other modeler’s posts. But posting the process helps me as well…to keep me motivated and to look back on what I did for future reference!  Good and bad alike…it’s all beneficial to others.
@niwotwill Will, 🙌 yes!  I can honestly say I’ve got 3 miles of fingerprints on my hull. I tried using gloves but that’s simply a no go. I plan to do a gentle once over with isopropyl alcohol to try and remove the majority of the finger oil. Just tried on a swatch of plates I laid down a couple weeks ago and it doesn’t seem to impact the plate adherence.
@Justin P. Hey Justin! I would say the Amati plates have some advantages…and you save some time in not having to make them. I honestly wasn’t too confident I could glue them on cleanly since they aren’t self adhering. You did a beautiful job with them. 👍🏽 Pluses and minuses to both options.
Quickie post. Got the false keel in.  Wood glue with pins. Since I broke up the keel into sections, was much simpler to install.  Also confirmed clean access for mounting screws. 👍🏽
Rudder is next…
If I could repeat this step, I’d have used a round edge exacto like a #10 instead of the straight edge #11. I think it would have made the cutting easier and the exposed edge a bit less raw.
2 hours ago, CPDDET said:
As always Pat, your setting the bar for the rest of us.
Thanks, Dave!  Flattery earns you a beer at the next MMS club meeting! 🤣
4 hours ago, abelson said:
Excellent work on the coppering. One of the better ones I've seen. I'm enjoying your progress.
Thanks, Steve!!
Rudder made. Painted the entire thing black above the copper just because.  Now getting ready for the part which has given me frets and the area I particularly struggled on the Sultana…the Pintles and Gudgeons!
Moving on..,👍🏽
Very nice look of the rudder!
You may have it finished by the time you read this, but have you considered faking the Pintles and Gudgeons?
The method is to pin the rudder to the stern post, then use card or tape to simulate the straps..
One of my pins is not as well hidden as it should be..  Do you see it?
Edited by Gregory
― Jimmy Buffett
Slow crawl:    Rattlesnake
@Gregory Your P&G’s look marvelous!  I did consider paper and had actually used them in the past on another build. This time, my goal was to actually make them as real functional P&G’s…bolts and all.
Mounting the rudder using pins certainly makes the process more bullet proof. I’ll probably use this method in future builds.  If anything, it will lower my blood pressure!  😁
Pintles in…they look OK. I think I could still go down a bit in thickness on them but they work. The small brass nails were actually quite easy to install…was lucky enough to invest in a ‘nail’ pliers which made inserting the bolts much easier. I test fit the pins into the pintles and will install them later after the gudgeons (🤞) have been installed.
Baby pics:
Moving on…
:dancetl6:
Ok. Got my gudgeons in…I’m not certain how others make/line up/install there P&G’s, but this part of the build is really intimidating to me. So I put a lot of preparation into how I would avoid bruising the copper. That was my biggest concern!
So… here was my ridiculous approach to mounting these suckers.
First, I put in the ‘pins’ into the pintles on the rudder:
Next, I sanded in a slight bevel into the inner edge of each side of the gudgeons. Imagine snow skis. I wanted the gudgeons to slide across the sternpost without grabbing/scratching the copper foil.
Then, I slid the gudgeon onto the stem post, using the tiny nail head I had placed into the post as an abutment to keep them from sliding. If you recall, when I test fit the P&G’s, I put in tiny nails (used in installing the P&G’s) as markers. They can’t really be seen and the copper easily wrapped around them.
Then I lined up the gudgeons with the pintles and inserted the nails.
The end result is pretty nice. 👍🏽 The copper plating was unscathed, and the rudder was cleanly aligned.
The only minor discrepancy which my eye sees immediately is the fact that the bottom of the rudder ended up about 0.5mm higher then the false keel. However, I’m totally willing to accept that little ‘wart’ considering how nicely they turned out.
Miller Time!!!!
:cheers:
FYI…and the rudder is easily removed and installed as needed which was my ultimate goal. 👍🏽
Just a thought. Did you consider blackening these pieces or coating the brass to prevent discoloration?
Previous build: NRG Half Hull
Previous build: MS Bluenose
Nope. Call it a purposeful deviation. I think the P&G’s, polished and with an obvious brass metallic sheen contrasted nicely with the copper. I’m a chemist, and I’m not entirely certain that copper (a soft metal) was used in the P&G’s. Anodic/cathodic reactions would occur due to impurities in the metals available in that age regardless of whether they were the same metals or not. So I’m more inclined to believe they may have been bronze.
The copper plating and brass P&G’s will oxidize and take on a different patina.
Either way, they look good and the idea of blackening never touched my awareness!  😁
They look great against the copper plate.
I've often struggled over consistency in my model when it comes to metal work. All blackened? All natural brass color? Mixed?
Actually, Dave…the topmost P&G’s are supposed to be black to match the paint. However, now that they’re on, I reconsidered and went with exotic metal clash rather than historic accuracy!  😜
5 hours ago, abelson said:
Excellent working rudder.
Thanks , Abe!
Just putzed a bit with the figurehead. Spent some time polishing it and getting rid of the burrs and roughness. It’s actually a pretty nicely shaped piece after all that…and I’ve double checked the fit and she slides onto the stem like a glove.
I had briefly entertained the idea of trying to carve one, but I’m humble enough to admit I’d never come close to this clean of an image. So I’ll plan on painting her…just not sure the effect I’m shooting for…Wood? Copper? Multicolor?  Decisions…
3 hours ago, Gahm said:
You did an excellent job on your rudder! It looks great!
Thomas
Sincere thanks, Thomas!!!  It was a joy to see the rudder slide into place without issue. Over planning made that fearful task a bit less ominous. I won’t be so gun shy on my next build…which at my current speed probably won’t occur until 2030!
Don't worry about the year 2030. At the speed I am going you will be finished before me anyway 🙂
Thomas
Current Built:   Model Shipways  Syren  (US Brig 1803)
Last Built:        Anfora (kit bashed)  Ictineo II  (1st steam powered submarine 1864)
