One more row of planking!
I anticipated running out of 1/16x1/4 planks, a quick trip to my local Hobby Lobby took care of that issue…
Also, the curve at the bow is turning out to be more challenging than I expected, but I think I’m winning…
On 8/21/2019 at 9:13 PM, SomethingIsFishy said:
Starboard fairing is almost there, and the port bow filler is shaped and glued into place... I'm done for tonight...
Did you craft or was there an included kit part that needing shaping for your bow filler?
13 hours ago, SomethingIsFishy said:
Planking sure does take a while… I’ve found that if you don’t leave the wet planks clamped in place until they’re fully dry they won’t hold their shape…
I am making progress though…
Are you gluing wet planks? Or shaping them then gluing?
An inexpensive hot air gun will speed up the drying process and I find it holds its shape as well or better than air drying.  I THINK it has something to do with setting the elasticized lignan in the wet wood.   There are far more knowledgeable members regarding the chemistry and the whys and why nots on this.
Wood of course swells so gluing it before it is completely dry is problematic as it will shrink as it dries.
Allan
Shaping then glueing. I just unclamped a few of the first planks when I thought they were dry and they didn’t hold their shape.
On 8/17/2019 at 10:23 PM, SomethingIsFishy said:
Got the rabbets cut on the bow half of the false keel. Was a lot easier to keep it even than I thought it would be...
Hello, I am just starting on this model. I see you tapered the rabbit on the false keel. I was going to cut it as a square notch, which is what I have always thought of as a "rabbit". Is tapered the better choice here for a ship kneel? It appears that spot of the false keel will be where the "bottom" plank meets the keel, so, tapered would seem to make more sense now that I see what you did.
I am NOT criticizing, I am asking, I know NOTHING about what I am doing - lol! So, any advice or help would be appreciated.
Edited by Frank NIchols
First build - in process: Model Shipways - 18th Century Armed Longboat - Scale 1:24
  • 6 months later...
Sorry, it’s been a while since I’ve worked on the boat, and since I’ve been on the forum. Hopefully you found the answer already but if not… you want an angle in the rabbit to match the angle of the plank that fits into the rabbit… the planks don’t meet the keel at a 90 degree angle…
  • 9 months later...
That’s what I did when I built mine. No regrets…would do the same again.
Jim
Current Build: HMS Winchelsea, Model Shipways Mayflower
Completed Builds: NRG Half Hull Project
                                   Model Shipways 18th Century Armed Longboat
                                   Dumas 1954 Chris Craft 36' Commander
                                   Dumas 1940 Chris Craft 19' Barrel Back
Decided to go blue… (cap rails aren’t glued on yet, they’re just sitting roughly in place…)
Not too sure about the color of the stand… it doesn’t really seem to match anything on the boat. I’m trying to decide between white, black, or blue; at this point I’m leaning towards black hoping it will sort of disappear underneath the boat…
