Hrs 928-933
Port Midships chain wale done. This time with 12 deadeyes in chain wale and 5 above. Could not really replicate the Lavery plans exactly as the gun ports seem slightly off versus the drawings and I need to avoid covering gun ports with ratlines (that would be bad...nice broadside, we lost our main sail...).
Oh well. Still looks good.
Note the 5 trenails I put in to add strength and to hold the molding on tighter.
Also, used 2 finishing nails in main board to stiffen, then covered with outer molding. (not shown)
3 more to go...
Hrs 938-945
Been busy as... well, I just decided to add bee-keeping as a hobby. Have chosen to sort of augment the standard hive with a faux decorative skep on top, cedar shake roof, copper dormer. Also, decided to keep two different varieties (Italian and Carniolan: note the flags).
Also managed to finish one chain wale and start the last one (of 6).
Empty nest = lots of hobbies...  ;)
(PS Note the snow...)
Edited by Mayohoo
Finished the last Chain Wale. Question for Gurus:
Should I complete the deck with cannons, bell, wheel etc? Or should I begin the rigging? I am not sure if having the netting /rigging/masts in place will interfere with putting all the other stuff in place. On the other hand, does the rigging force where I put the other stuff?
Thoughts?
Here's my tuppence... I find that rigging gets in the way of installing any deck furniture.  There might be some bits that have to wait on the rigging but that would need to be sorted out on a piece by piece basis.
  • 5 months later...
Hrs 938-950
After a long summer hiatus with soccer coaching, learning to keep bees, a trip to England to see the son as he studied at Oxford and a trip to Stockholm with the daughter for her vacation (saw the Wasa, quite a ship and museum!), I am back to the HMS Surprise. Got the carronades mounted and named, now working on rigging them. Have two 9 pounder bow chasers (brass, just like Jack liked them) and the 24 carronades (all named with small jokes or people I know).
It's good to see you back and that you had a great summer.    The guns look great as do the bees.
Hi
This looks really good and is inspiring me to get back to mine. Quick question are you thinking of adding stern chasers as well? Saw them in the movie but not sure if I will add.
Waitoa
I am conflicted about the stern chasers. I have slots I could fit them in in the stern, and I trialed them there but the 9 pounders really crowd the flag lockers and also look like they would interfere with the stern boat davits.
I got the impression from some of the books I have read that the brass bow and stern chasers were sometimes moved from bow to stern and back as needed (I would guess one wouldn't need to fire forward and backward during the same engagement!) I may put in the ringbolts only.
So right now, probably not.
Mayhoo,
The guns only on the gundeck would have been shifted and usually not from bow to stern but from the closest gunports.  For the forecastle and quarterdeck, no such luck as the gangways wouldn't handle the weight.  I'd suggest just leave it as it is as the quarterdeck shifting of the last two guns would indeed crowd things a bit.
Hi Mike,  Sorry to have missed you in Minneapolis.  Your message arrived the day after I left Seattle.
I thoroughly enjoyed reviewing your log on the Surprise and the great progress you've made, facing the same conundrums I did on the bow works. Earlier, you noted the difficulty painting the blue stripes on the timbers.  May I humbly offer a tip (too late), that may come in handy on a later detail.  At 82, my hands aren't as steady as they used to be. One solution is to cut out the detail on a very thin strip of styrene, paint it and glue it in place, giving it a clean edge.  At normal viewing distance, the eye doesn't distinguish between an elevation or depression.  An example on the cathead.
post-68-0-14806400-1445636134_thumb.jpgpost-68-0-04238300-1445636177_thumb.jpgpost-68-0-68220000-1445636198_thumb.jpg
Next time I go to Minneapolis, I'll give you an earlier heads up.  Cheers,  Gil
http://modelshipworld.com/index.php?/topic/485-hmsHMS Victory by Gil Middleton - JoTika - 1:72
  • 2 months later...
Hrs 951-965
Finally finished mounting the carronades. Been a busy summer and I have just gotten back to it during the long winter here in Minnesota. Holiday trip to Napa and the Rose Bowl with the kids. Go Cardinal!
Got the bronze chasers plus the carronades. Working on the rest of the carronade rigging now.
  • 7 months later...
Back from a long hiatus. Am finishing the carronades and their rigging. Also found some unusual wood from a display in Rome. There is a hidden Nativity scene that was built by the Sanitation Workers of Rome. A tour guide from the Vatican got us in to see it... lot of detailed work including a piece of lunar rock.
As souvenirs, they gave us some of the street broom pieces, which I am going to put by the Galley oven like firewood.
  • 2 months later...
Hrs 966-1000
Finished the carronade rigging. Now working on cannon ball holders (12 gauge shotgun pellets). I think they are called garlands?
Added small stack of firewood from the Rome sanitation workers brooms (see above) next to the oven (hard to see as it is under the deck).
  • 2 months later...
Hrs 1001 to 1020
Finished the carronades and garlands and added shot holders all along the deck. Began working on Binnacle and Ship's wheel. The Binnacle contains a lamp and two compasses inside a glass wood framed cabinet topped with a brass chimney. Used a convenient brass nut from he hardware store. Still finishing the base of the cabinet.
The Ship's wheel will also serve as a way to cover and secure the removable trap door I built into the deck so as to see inside the Captain's cabin. Still working on the engineering of that...
Used two beads to serve as stops for the cable for the steering mechanism. Developing a frame for the entire device.
Hrs 1021 -1030
Finishing the Binnacle and Wheel (also preserving the trap door to look in the cabin from the deck).
First the Binnacle. I decided to attach to the deck with ropes similar to what I found online but more secure.
The wheel and the trap door are in place being held in place by my thumb. Note gold leaf on the hub of the wheel.
View into the cabin with books on the desk.
Initially, I thought I would use wood constructs to hold the wheel down against the flexible deck. However, they looked too bulky.
So I designed a more streamlined version. using wires. See next panel.
Just "wow!".  The details are amazing.
Hrs 1031-1039
Bell tower: After looking at the included bell (lame looking) decided to order some on-line. Found several but really liked the shiny brass ones I found at Etsy. Works out to be a about 15 inches in length to scale. Mounted on a metal bar so it can be rung by swinging the handle. Just need to drill holes and then add roof before mounting on the ship.
HRS 1040-1043
So once again accessed the laser my friend has (nerds rule)... He layered out several script S in 7, 9, 11 mm. I am going to place on side of completed bell tower. Oh,they are going to be covered by 24k gold leaf...
Bell tower...
And dry placed on bell tower.
I am going for a different insignia on the other side... hopefully a lion rampant...
Onward!
Hrs 1044-1052
Waiting on the Lion to be cut out and have started working on the ship's boats.
Only one boat comes with the kit so it will be one of the scale 24 foot cutters. Doing plank on plank construction. Am also taking the cut out basswood part sheet and photocopying the part openings. Will use photocopier to expand to the 28 foot pinnace and also reduce to the other 23 foot cutter using basswood plywood and the laser cutter.
Used a separate model kit I found to make the jolly boat, which by scale is 18 feet long. This will be mounted on the stern.
Although there are supposed to be 5 ship's boats, I may stop at only 4 as they will completely obscure the waist opening of the ship with the cannons, stove etc.
Maybe Maturin is off looking for birds...
DSC_0290.thumb.jpg.aef355b7a3577b7eed7d7f2abf0ee158.jpgDSC_0292.thumb.jpg.9c40bb01f718bd7a1289d5d8215e0589.jpgDSC_0293.thumb.jpg.8c396812faf90f22eb918defde99b438.jpg
Still a loooong way to go....
  • 4 months later...
Hrs 1070-72
Found a source for a figurehead called Hero Forge, They make customized miniatures in a variety of poses using injected plastic. They seem to be perfect size so I chose a figurine with long flowing hair carrying a sword wearing a blindfold ("Surprise": get it?).  Attached are my attempts to paint the figure. Will gild the sword at the end.
Hour 1073-1074
Learning to make oars to row de boat. There is a formula based on the beam of the boat so calculating from that. Using bamboo skewers and toothpicks for the shaft and planks for the paddle area. Need some thinning of the shaft but looks pretty good so far. Stabbed my finger though...ouch.IMG_1054.thumb.JPG.de2e1f677d1fc01265c2b822e6923886.JPG
Edited by Mayohoo
Fired too early...
Hrs 1076-1100
An update is in order. Finished the red cutter and blue cutter. Note gunpowder or water barrel, buckets, and coiled rope in the boats along with sweeps/oars. Am securing the red cutter in the waist with lines and the blue cutter along the stern with davits. The oars are in my sons university crew pattern.
Also finished and mounted the figurehead. She is blindfolded and armed with a gilded sword, then sealed with shellac.
Edited by Mayohoo
Duplicate picture
