Here's some thing I came across that might interest some looking for a real small lathe
https://www.wdivorce66.com/products/hot-sale-mini-diy-lathe?fbclid=IwAR16a0CVIN
completed build: Delta River Co. Riverboat     HMAT SUPPLY
                         USRC "ALERT"
in progress: Red Dragon  (Chinese junk)
River,  this could be a worth while heads up.  For $20, it is hard to go bad, even if it does not work out.  Almost seems like the link should be to Harbor Freight.
There is not all that much on a model that requires a lathe.  This may do  for windlass drums, capstan spindles.
The following would probably not work out: Cannons would need to be wood, and belaying pins made of wood. ( Boy, wouldn't doing that about a hundred times be a load of fun?)  There is no tool holder or micro adjustment.  Rigging a duplicator looks impractical if wood is the choice.  The sharp tools vs motor power is a clue that this is right at the edge of useful.  I am betting that brass is right out.
NRG member 50 years
Current:
NMS
The U.S. Ex. Ex. 1838-1842
Other
A very small lathe.  From reviews it's not big enough to turn a pen.  Also, do some research on them before buying as there are some negative reviews out on the web.
I think it is $70 - still cheap - but not if its a waste of money.
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
Keith, I agree.  I did not notice what was checked for the $20 bit.   $70  is a different category.  Still,  for someone who does not intend to turn metal to make tools, but still thinks that a lathe is important to have for wood model parts and does not have money to burn,  this may scratch that itch enough to save them from spending big bucks on a precision lathe and finding out that it is little more than a paper weight.
NRG member 50 years
Current:
NMS
Other
That's $20 worth of my time.  And that looks like an extrusion of standard dimensions that I might be able to find i a longer length.  And if I couldn't, I suppose a carefully dressed piece of wood or baltic birch ply would be adequate.
Sneaky they are.  I didn't notice that the $20 was for the cutters.
The Chinese have been flooding ebay et al. with these thingies in various configurations for some time now.
A couple of observations on the 'designs' (not really designs, but put together from commercially available parts).
- there is no separate bearing for the spindle; this can be ok, if the motor has ball-bearings (some Chines motors are available with such); however, motor bearings are for radial loads, not for axial loads, as occur during turning; one should have an axial bearing too.
- the motor is uncovered and the collector might get covered quickly in dust ...
- they use a drill-chuck on the spindle end, which is a no-no; drill-chucks are not designed for axial loads, as they occur during turning; one might think of replacing the chuck with an ES collet-holder; much safer and more precise.
- There is no tool-rest for the gravers; one should configure a T-rest, as commonly used on wood- or watchmakers lathes.
In summary, these thingies might be ok for back-room workshops in China, India or such places, but could be significantly improved with little expenditure.
I think, for less than 100 EUR/USD/GBP one could configure a much better tool with parts easily available from ebay et al.
