HM Brig-Sloop Speedy by glennard2523 - Vanguard Models - 1/64
The masking tape is a good idea, I use black card stock, but that has to be glued on with CA, the tape saves a step once painted.  Thanks for sharing that.
Regards,
Glenn
Current Build: HMS Winchelsea
Completed Builds: HM Flirt (paused) HM Cutter CheerfulLady NelsonAmati HMS Vanguard,
HMS Pegasus, Fair American, HM Granado, HM Pickle, AVS, Pride of Baltimore, Bluenose
Link to comment
Share on other sites
While waiting for the new copper plates to arrive I decided to build one of the 14 off 4 pounder cannons.
I started with the standard dry fit.
As everything was a good fit I went ahead and painted all the photo etched brass parts using my gun metal black paint along with one of the cannons. I applied a few light coats of paint and then built the first cannon.
 I was very happy with the end result and it looks really nice when positioned at a gun port, sitting nicely in the centre of the gun port opening.
1025534223_095GunCarriage.thumb.jpg.82f122a413aed6547e1e5bc55a6ba738.jpg2121513058_096GunCarriage.thumb.jpg.8cfa4b2d3129a27a88e5393ad5dde5a0.jpg681412118_097GunCarriage.thumb.jpg.e16ae218ece19a842ebc6bda7ca3735d.jpg273447173_098GunCarriage.thumb.jpg.b3bcd013d72fcf8be63779a10e208279.jpg390105645_099GunCarriage.thumb.jpg.82c99f6955eb695acbbcfeb15a204914.jpg
Glenn (UK)
Link to comment
The new copper plates I have ordered have now been shipped, so they should arrive by first class post sometime tomorrow.🤞
In the meantime I decided to paint the Wales.
I have applied 3 coats so far, giving the Wales a light sand between each coat. I will give it the wales a final coat later on today.
In the attached pictures below you can see my work station (and working outlook) in the top right corner of the two photos.
In between the coats of paint I continued with the assembly the 13 outstanding 4 pounder cannons. The gun carriages are now ready for painting with the fully completed cannon looking on, like an expected parent.
1482176399_100Wales.thumb.jpg.e984991d1d9475b500b007ec66edb17b.jpg1560949270_101Wales.thumb.jpg.3f4cb0f79160f5fa8229bd855365ccf6.jpg285228_102Cannons.thumb.jpg.279059d54f99dce063bd37987910f174.jpg876374713_103Cannons.thumb.jpg.7a618ec24189dccc0cd7e4f625bd0f43.jpg
Edited by glennard2523
Glenn (UK)
Link to comment
That's a great work station and great view, I'm just looking at the spare room wall. Speedy is coming along nicely, nice job!!
Current builds;
 Henry Ramey Upcher 1:25
Providence whaleboat- 1:25     HMS Winchelsea 1764 1:48
Completed:
HM Cutter Sherbourne- 1:64- finished    Triton cross section scratch- 1:60 - finished
Link to comment
That’ll look really nice, I’m planning on rigging them for my Alert as well after seeing the beautiful job the Blue Ensign did on his. I’ll be looking forward to see how you rig yours (I’ve never done it before and am trying to learn as much as possible before I get there).
Link to comment
Take a look at the following for my attempt to rig cannons a few years ago.
Glenn (UK)
Link to comment
I have now completed the copper plating of the port side (take 2). I have much happier with the results this time. I started out using the evo-stick instant for this task which I had used when for HMS Victory, however I soon reverted to using CA glue.
I did add a 1mm x 1mm strip along the water line which really helped to get a neat finish.
919222186_108CopperPlates.thumb.jpg.9023eea35a5c30f8019ac1b3c21db60d.jpg312567_109CopperPlates.thumb.jpg.d32b2f4abbae5f6058b7eea523ada8ea.jpg2114375595_110CopperPlates.thumb.jpg.2a12ab70fb1ab2d02626548c7382bd3b.jpg
Glenn (UK)
Link to comment
Looking good!
Cheers, Derek
Current build:   Duchess of Kingston
On hold:              HMS Winchelsea
Previous builds:  HMS SpeedyEnglish Pinnace, Royal Yacht Caroline (gallery),
                            Victory Cross-section (gallery), US Clipper Albatros, Red Dragon (years ago!)
On the stocks:    18th Century Longboat
Link to comment
I have finally completed the copper plating task. I am reasonably happy with the end result. It took a while to find the best working method which was to add a drop of ca to the centre of the plate and then to position the leading edge against the previously fitted plate and once I was happy with the alignment I then gently dropped the plate , using a metal pointer to make any minor alignment adjustments before the ca glue cured.
Once the copper plating was completed I then added the hair brackets (which required a bit of trimming) , the bow checks and the hawse bolsters.
The next task will be to drill out the hawse holes with a 2mm drill and then to fit the capping rails and stern counter side timbers. This will not take took long to complete so I can also fit the upper rail and swivel gun post patterns.
724083866_111CopperPlate.thumb.jpg.7474b7ed56c83cc414787471768b8384.jpg1121062246_112CopperPlate.thumb.jpg.41c7a535121448cb1df9fc9698f076cb.jpg1109767548_113CopperPlate.thumb.jpg.a5b0860d91bb5cdbd4c4f4b6b94cba50.jpg
Glenn (UK)
Link to comment
Good job on the copper. I've fallen further behind you as I've been concentrating on finishing my pinnace. Now that's done I want to get on with  Speedy. I'll follow your lead and use a wood strip to define the upper edge of the copper, but as I've never done coppering before I'm not sure how smooth I need to get the second planking below the waterline. Is the copper relatively forgiving, or do you need to smooth out even the tiniest lumps and bumps?
Derek
Cheers, Derek
Link to comment
Derek
Hello Derek
I found the coppering is relatively forgiving. My hull was reasonable smooth but it did have the odd lump and depression. It is important to get the area around the rudder post and keel right,, I have one plate that sits a bit proud at the keel edge, but it is not noticeable unless you have the boat in you hand and upside down. With regards to the water line I did use the rudder with the copper template fitted to get the right height at the stern and I used the picture in the manual for the bow (5 copper plates). I did find the wood strip (1mm by 1mm) a god send. I also made a 12 plate wide template to get the position for the water line at the middle. I then used my water line marker and was very pleased to find my 3 reference points all lined up as I drew the line.
I opted to use ca glue in the end as the evo stick instant has a very strong odour, and harder to apply to the plates than I remembered. It took a while to find the best method. For me that was to put some ca glue in the centre of the plate, then to place the plates leading edge to the previously fitted plate and once I was happy with the alignment to gently drop the plate into position. I used a small metal pointer to move the plate, when needed before the glue stuck fast. With some plates, which I was not totally happy with, I simply lifted them, using an old craft knife blade and then tried again. If a bit of the plate edge had not stuck down, as the ca glue did not fully spread, I simply applied a drop on ca glue to a scrap piece of copper plate and then used that to apply the ca glue to the underside of the lifted edge.
I used a sharp pair of scissors to trim the plates, when necessary. I worked from left to right, so one side I was working from the stern to the bow and the other side I worked from the bow to the stern. For the first row of plates I actually started in the centre as that seemed the best for me to get the "brick pattern". As the plate line does curve I did find it necessary overlap the plates leading edges a tad. I used nail polish remover (with cotton buds) to remove any excess ca glue from the plates (and fingers).
Glenn (UK)
Link to comment
Thanks Glenn, that's very helpful. I tried to get references for the waterline from the plans and photos in the manual. I've not drawn the line yet, but when I put a laser level on the three reference points I'd marked they lined up well. However I like your idea of using the rudder as the primary reference, and shall check my points against that. If the plans are accurate I shouldn't be too far off.
Thanks also for explaining your technique in more detail - very useful for a newcomer to copper work.
Derek
Cheers, Derek
Link to comment
I was not totally happy with the natural wood finish of the hull above the copper plates so I applied an oak wood stain but was still not happy so I decided to paint the hull using my yellow ochre  paint. I think it looks better now.
I have also added the capping rail and upper support rails and the decoration looks really nice. I have already painted the fender patterns yellow ochre and I will fix them to the upper rail patterns in due course.
Glenn (UK)
Link to comment
I have now added the swivel post support timbers (painted yellow ochre) to the upper rail. Having read the manual for the next part of the build I have realised the swivel posts should sit flush with the top edge of the capping. I positioned mine to be level with lower edge of the capping. I probably could remove and reposition but I think I may leave them as fitted, in case I damage them.
I have also drilled the 4 off haswe holes using a 2mm drill.
Next up will be the fitting of the swivel gun bases to the capping.
I have just noted, looking at the photo below, a couple of copper plates with some ca glue which will need removing.
1297635602_117Fenders.thumb.jpg.c46a5e8c839b1a6a4290ed6ced97071b.jpg1569147692_118Fenders.thumb.jpg.ba63ce3edd211eb617acd35567b1c5e5.jpg1768961992_119Fenders.thumb.jpg.42b2b4c9b39d047b16cd78e0ed338eba.jpg
Glenn (UK)
Link to comment
Here is an update of my progress. The first two pictures show the swivel gun bases (unpainted) fitted to the capping
The next couple of pictures show the swivel gun bases painted black
I initially painted the swivel gun post supports yellow, but as I had incorrectly positioned them I was not happy with the results as shown in the following picture
I added some wood filler to the gaps and then painted the gun post supports black. It looks better.
I have painted the stern area a mixture of yellow and black. I have filled in the hole on the bottom left of the picture
I have added the 3 off stern board rails, the stern capping and the 2 stern crutch boom patterns.
Finally I have checked the fitting of the 3 off bow frames. They all fitted OK. I have shown a picture with one bow frame in place during a test fit. The slots were tight and took some of the yellow paint of the bow strip. They will be repainted.
Glenn (UK)
Link to comment
I have fitted the bow main rails and the three bow vertical rails, some of the photos were take before the vertical rails and been attached to the main rails.
I would say that this was the most difficult task to date with this build, it took a while to find the best methods for painting and then fixing parts to the hull. I ended up pinning the main bow rail to the hull, noting the pin will be hidden once the catheads have been installed.
I have built and painted the catheads and they will be glued in place tomorrow. I have also assembled the majority of deck items and placed in position (not glued). The two deck pumps (shown on the photos) just need to be painted and fitted to 4mm  x 40mm dowels.
The 4lb cannons can be seen in the first photo, on the window ledge.
722027739_129DeckFittings.thumb.jpg.a2819ea2563f774931328b2b3d03a5c7.jpg1648900614_130DeckFittings.thumb.jpg.d8565b18cd72c4d2688711b40e8208c9.jpg1795223035_132DeckFittings.thumb.jpg.ba523abfdcd49059b8fc8eed10846e6e.jpg819810584_131DeckFittings.thumb.jpg.e73f76bbfa2a02451a8ac2ba88da519f.jpg609426226_133DeckFittings.thumb.jpg.01a4abd51c9e559d5a963f92c8af8fdb.jpg
-tab=comments#.url
Glenn (UK)
Link to comment
Great progress Glenn. Looking really good.
Derek
Cheers, Derek
Link to comment
Thanks Derek. It has been a very productive day. I will start the mass production the swivel gun assemblies later this week. I have tended to paint the parts before removing from the sheets, and then touching up where necessary.
Glenn (UK)
Link to comment
3 minutes ago, dzerbato said:
Nice work. Your build is certainly making me eager to start my Speedy.
It is a great design which I'm sure you will enjoy building. I always think adding the deck fittings really starts brings the build to life.
Glenn (UK)
Link to comment
I have started the assembly of the 20 off swivel guns. I am just waiting for a delivery of a new set of micro drills (due later today) as I have snapped all my 0.8mm and 0.6mm drill bits before I can complete this task. In the first picture you can also see the steps painted side steps, in readiness for installation. In the second picture you see one completed swivel gun assembly, prior to snapping my final 0.8mm drill bit.
I used some 2mm tape, marked with the position of the steps to help position the side steps.
654969391_138Steps.thumb.jpg.751a16764fe8e68565788ff29cd0af0d.jpg1847697302_139Steps.thumb.jpg.376bced6f364a9b64e6ceefa7dba5bea.jpg655637615_140Steps.thumb.jpg.32ddac93e0f2ee8511389973dcb5acaa.jpg
Finally I have also assembled the two ladders and test fitted them.
1654637391_141Ladders.thumb.jpg.19178f7062195d975fed1e6ca177400a.jpg1983728208_142Ladders.thumb.jpg.1a745f905d9d49577bcbf4213efb2875.jpg199892541_143Ladders.thumb.jpg.ecb29214618d57ff6c85ee3e60d87c36.jpg528175724_144Ladders.thumb.jpg.ba0126eda74c4dda621bf4399ddeb1e6.jpg
Glenn (UK)
Link to comment
More great progress. Will you mount all the swivels? I recall Chris saying that would have been unlikely on the real ship, but on the other hand it might seem a shame to leave any off.
Derek
Cheers, Derek
Link to comment
Derek
I plan to fit all the swivel guns. I also read that they may not have all been fitted but I think it will look more impressive with all guns and cannons fitted. I also thinking about rigging all (or some of) the 4lb cannons. If I do so I will build a rigging jig to make the task easier.
Glenn (UK)
Link to comment
Greetings from long ago. Hope you are keeping well. Just had a quick look through your log. Your build is very impressive. I will have a proper look at it later. I have just started back on the Diana after leaving it for a year or two. it should have been finished by now, and I have only just finished the second planking today.  So it’s a good sand now, and then I will be happy. Anyway it’s good to see you again, and I  shall follow your progress. Yes your build is looking really good Best wishes.     DAVID
Link to comment
Hi David
Great to hear from you again. I have been away from model boat building for a couple of years (or more). I was really excited by the Chris Watton  design and as I was move my work area in to my conservatory (from the garage) I took the plunge. It is a great kit and I really happy to be back building.
I look forward to watching you progress with Diana.
Glenn (UK)
Link to comment
Hi Glenn
Apologies if you’ve mentioned this and I’ve missed it, but have you applied a finish to your copper, or do you plan to? I see some people use varnish or lacquer whilst others prefer the copper to tarnish naturally. What’s your preference?
Derek
Cheers, Derek
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
