MicroLux® Benchtop Variable Speed Mini Hobby Drill Press - I'm considering this as my next power tool purchase. Any comments good, bad, or ugly!!! I am leaving my Delta bench top drill press in my garage shop and this will be a dedicated model ship tool in my workshop. How does it compare with the Proxxon Bench Drill Press TBM115??
Thanks in advance!
Hank
Edited by Hank
Construction Underway:
Builder's Yard - USS STODDARD (DD-566) 1967-68 Configuration (Revell 1:144 FLETCHER - bashed)
In Development - T2 or T3 Fleet Oil Tanker (1:144 Scratch Build Model) - 1950s era
Currently - 3D Design/Printed 1/200 scale USS PURITAN (BM-1)
Completed:
Armed Virginia Sloop (1768)
Royal Caroline (1748)
Sloop/Ship PEACOCK (1813) (Scratchbuilt)
USS NEW JERSEY (BB-62) 1967-69 Configuration (Trumpeter 1:200 bashed MISSOURI)
3D Design/Printed various scale USN Gun Mounts/Turrets, and GFCS Directors
Member:
New Bern Ship Modeler's Guild
NRG
NCMM Beaufort -CSMA
This looks like a fancier version of the one sold by Modelexpo.  Some time Model Expo puts them on sale for under $100.  This  one looks to have a better level of finish than the Modelexpo one but aside from the digital readout and other mostly cosmetic differences I would assume that under the skin they are the same drill.  My Modelexpo drill press works good, very little vibration and seems to have a lot of power for its size.  Haven't had a chance to do much work on it but seems to do what it is supposed to.
My advice and comments are always worth what you paid for them.
The Proxxon TBM drill press is first rate very accurate and well made.  I have only recently sold one in order to move up to its big brother which suits the work I do.
Reg
It seems fairly expensive to me.   I get acceptable results from a EuroTool DRL 300.  I have only used wire gauge bits with it.  I added an XY table that cost more than the drill,  but now I see that I could have gotten the same thing from Ali Express for ~$40.  The price has jumped from $80 to $110.  Tariff result is my guess.   I would sooner use a $100 machine if I was going to break the rules and use it for lite milling on wood, than a $350 machine.  Neither has bearings for lateral force.   I also use a momentary foot switch with it.  For drilling wood, I do not see the benefit of a bells and whistle level speed control.  A sharp cutting edge is more important.  Isn't the speed control a metal being worked thing- Al vs Fe vs CU?
If you are going to use it to make tools and will be milling metals, a for real milling machine would be reasonable expenditure.  For wood, you do not even need accuracy. You do need precision though - i.e.  once you determine what and where, that it repeats doing that exactly the same every time.  My DRL-300 will do that.  My sin is that I use a bit until it bends or breaks.  Some burning in a #70 hole does not bother me.
NRG member 50 years
Current:
NMS
The U.S. Ex. Ex. 1838-1842
Other
Thanks GRSJAX, NZREG, and Jaager!
I will certainly take your various comments into account. I should have mentioned up front that most of the work will be drilling wood, plastic, & small metal parts. Nothing really major and no milling. I will look at the various models you three have suggested as I think a larger selection to consider might be advantageous in the long run.
I already have an XY table & assorted drill press vises & accessories, it's just the drill press that needs to be purchased. I too tend to hang on to bits well after their useful life is long since passed. And yes! the prices on these items does seem a bit high when compared to the price of buying another 2nd Delta Bench Drill Press. That (price) will be a selling point, as well.
NZREG - A question re. the TBM115 - does it require a separate power supply or not?
GRSJAX - A question re. the Micro-Make drill presses - do they require a separate power supply and if so, is this their std. power supply that works for their other line of tools?
Seems that the item details on both products don't really mention this one way or another.
Edited by Hank
Add question
Completed:
Member:
NRG
NCMM Beaufort -CSMA
Hank,
Sort of off the wall,
1) I first thought that by Micro-Make, that MM had a drill press as part of their rebranded line of Kaleas DC tools.  The right angle sander I like -a lot.  The belt sander does jobs that are difficult otherwise, as long as it is held with a wood spacer to stop it throwing the belt, which takes about a minute otherwise.  I am not sure about the other tools.  No drill press though.
2) USS Pennsylvania - I first thought of the 1830 120 gun liner-  an absolute monster,  it has all of the beauty and grace of a Stalin Era high rise apartment building with spars and sails.
NRG member 50 years
Current:
NMS
Other
The Micro Mark drill press just plugs into the wall as do the Modelexpo and Harbor Freight versions.
GRSJAX - Thanks, I needed that info!!
Jaager - Also appreciate the reply. It seems a lot of mfgrs. end up parceling out their product to "sub-brands" in order to make more sales (or fool the public!!). I beg to differ with you, sir: PENNSYLVANIA (1820) does have more curb appeal than a Soviet era Apartment Bldg.!!! And was probably warmer inside to boot!!!
Completed:
Member:
NRG
NCMM Beaufort -CSMA
Just make sure it has a very good chuck and/or capacity for collets. When you get down to the very fine drill bits like we use for modeling, the slightest bit out of true, or a little wobble, and the bit will snap. Anybody can make a cheap small drill press, but accuracy to high tolerances costs money. An x-y table will be keenly appreciated, too, so add the cost of that to the package.
Bob,
Right on!! Got it!! That's one thing the Delta bench top D.P. was not designed for - more a shop tool for woodworking than a modeler's tool for ship models, etc. As for the X-Y Table, I already have one and have a couple good D.P. vises to use with this. In fact, I plan to shortly (as something to get me back C-L-O-S-E to modeling) make a jig stand to hold the upside down hull of the next model I will be building in order to drill out various holes in exact locations for the drains, discharges, intakes, etc. that I will add that are not part of the model as purchased. Having a quality D.P. in tandem with the X-Y capabilities will serve very well. I can't wait....:omg:
Note: I already have a Proxxon Bench Top Lathe DB-250 and while my use of it was very limited in 2018 prior to retirement, I am leaning towards the Proxxon D.P. or the Micro-Lux 3 speed D.P. The lathe is very high quality in construction and that's a big plus. However, price will be factored before a decision is reached.
Thanks for your input - good advice!!!
Hank
Completed:
Member:
NRG
NCMM Beaufort -CSMA
No, runs off the mains voltage. Proxxon produce this drill press in both 115 and 230 volt for different markets.
Reg
NZREG,
Thanks! I'll keep that in mind!
Hank
Completed:
Member:
NRG
NCMM Beaufort -CSMA
Hank,
Just curious here, will you also be looking for a mill at some point?   If so, consider the mill instead of a drill press.
Mark,
No, I don't have any plans to do milling. I've got a fellow modeler close by who does quite a bit of model machining in steel, brass, etc. It there is something I can get him to do for me, he's always happy to help out!
Thanks!
Hank
Completed:
Member:
NRG
NCMM Beaufort -CSMA
Hank,
Keep him seriously bribed.  Saw dust is messy but easy to clean up; and not critical if you miss some.  Steel kerf and shavings are something else.  They can play havoc with a machine.  When a job is finished, a mill or lathe needs serious and time consuming disassembly,  messy cleaning, and reassembly.  Steel shavings are really unpleasant to deal with.  And the oil...., I use laxative mineral oil for way oil, but it is still a chore to remove.
NRG member 50 years
Current:
NMS
Other
Will do!! What drilling I've done with metals IS a messy proposition and the cleanup as you state is a pain. I've considered whether or not my modeling needs would ever to that point and can't say as they would, a drill press is all I'm after. One of the guys in our modeling crew actually has a Micro-Lux 3 speed for sale (with XY Table & bells & whistles), but his price is rather steep and I am not really considering it. The new ones are on mark down at Micro Mark and that's very tempting.
Thanks for the cautionary note!
Hank
Completed:
Member:
NRG
NCMM Beaufort -CSMA
Metal cleanup of the chips, shavings is a bear which why I try not to do metal.
Leaning towards the Micro-Lux 3 speed D.P., but not quite there yet. Concerned about height from table to chuck (how much working space I'll have with a chuck & bit in place, etc.)
Edited by Hank
Completed:
Member:
NRG
NCMM Beaufort -CSMA
Email them, they usually respond pretty quick but given the way things are these days, may take longer.
Thanks both Gaetan & Mark! I'll send an email to Micro Mark and ask about the column and whether an extended version is available. Just a guess, but since it's made in Japan, more than likely its column diameter is metric which may not be easy to find in the U.S. should I want to make a longer replacement myself.
Completed:
Member:
NRG
NCMM Beaufort -CSMA
A longer column is nice to have.  My late friend Steve Wheeler purchased a longer length piece of the right diameter off the internet.  Sorry I don't know the source but it was a standard item from the place he purchased it.
Kutr
Kurt Van Dahm
Director
NAUTICAL RESEARCH GUILD
www.thenrg.org
CLUBS
Midwest Model Shipwrights
North Shore Deadeyes
Butch O'Hare - IPMS
Thanks Kutr (must be the middle Eastern spelling of your name😂)
This is the kind of information that's going to cost me money sooner than later!!!!
Much appreciated. (I kind of felt that the column must be made out of a std. diameter stock, whatever the diameter turns out to be).
Hakn (maintaining the now established format from The Chief)😁LOL!!!
Completed:
Member:
NRG
NCMM Beaufort -CSMA
Hank,
Model Expo just had their version on sale for well under $100.00 so just couldn’t pass it up - so far am happy. Not sure why I wanted to do this, but just for kicks I chucked a small Starrett pin vice with a #77 bit and it worked great.
By by the way, I’ve really enjoyed your workshop renovation posts and am envious, but it’s time to finish that up and get back in the ship business 😸😎
Don
Don,
Well thanks! Actually, I was just on my way out the door to get back into workshop mode and decided to check the forum. So, you're to blame for today's short work schedule!!!! LOL!!!
I'm just about decided on purchasing the Micro Lux 3 speed. Believe it or not, I used the Delta for drilling all sorts of very small holes for items on 4 different models, so I'm guessing the Micro-Lux should be an improvement over the clumsiness of the Delta, so to speak. Thanks for your input - FYI - the Micro Lux is currently at $199.95 which is a sale price for how much longer I don't know.
OK, time to get back out and switch gears to workshop construction mode....
Hank
Edited by Hank
Completed:
Member:
NRG
NCMM Beaufort -CSMA
I've gone ahead and ordered the Micro Lux 3 speed D.P. I appreciate all the comments regarding this topic. Hopefully, this choice will be a lasting one as far as a modeling size drill press is concerned.
Hank
Completed:
Member:
NRG
NCMM Beaufort -CSMA
True but it will also be less rigid than a shorter one.  Increasing the length can have an undesirable impact on vibration and accuracy.
Except this is a 1 3/16" dia. solid steel piece about 12" long that was replaced with a similar piece 4 to 6" longer.  Still pretty darn substantial.
Kurt Van Dahm
Director
www.thenrg.org
CLUBS
Butch O'Hare - IPMS
GRSJAX/KVD,
Thanks for the further comments. This model D.P. is supposed to have a clearance height of 7" from chuck to base, so if I were to find a column replacement I'm only looking for another 1"-2" at most. I would guess that a thick walled pipe of matching O.D. would serve the purpose. We shall see....
Hank
Edited by Hank
Completed:
Member:
NRG
NCMM Beaufort -CSMA
I believe the column on the MicroMark drill is a tube, not a solid bar.  I could be wrong as I have not had the chance to take one apart.  One way to stiffen a tube it is to fill it with concrete or a wooden dowel that is a snug fit in the tube.
Edited by grsjax
