Hi, Elmir, She's looking good.
Bob
Current build:  SS_ Mariefred
Thanks Anja and Bob.
Well Anja about preparations for deck :D Well where l live you can't find some wood sheet thick about 0,5 mm or 1mm to glue them to frames and have nice surface for deck. So I made wood parts to fill big holes between frames and then I use a wood putty. So next is sanding and I think I will have fine surface for deck planks.
Current build: LA MARTEGAOU
Past build:
BRACERA
"Twenty years from now you will be more disappointed by the things that you didn't do than by the ones you did do... Sail away from the safe harbor. Catch the tradewinds in your sails. Explore. Dream. Discover"
KIND REGARDS!
ELMIR
Continuation:
Making planks for deck:
Holes for water from deck:
One hole is higher which will be seen better when I glue plank which is in line with deck. :D Well it isn't first mistake and won't be last I'm sure :)
:piratebo5:
Past build:
BRACERA
KIND REGARDS!
ELMIR
Hello Elmir,
Nice job on sawing the planks. They look good.
'Experience is simply the name we give to our mistakes'.
I think it was Oscar Wilde who said that.
Good luck.
Anja
Those we loved but lost are no longer where they were, but are always where we are.
In the gallery: Albatros 1840 - Constructo
Tnx Anja. Right words :D
Continuation
Deck hatches and openings for anchor rope:
Past build:
BRACERA
KIND REGARDS!
ELMIR
Thanks Alex. Yes I have a little extra time. And I'm waiting news from your build log?
Edited by Wishmaster
Past build:
BRACERA
KIND REGARDS!
ELMIR
Nice work on the hatch and the sawn planks, I am looking forward to seeing the deck go down.
Michael
Well somebody is on vacation and somebody works :D
Continuation
Works on deck. Its mix of ink and glue. It's very dirty but also fast and effective :)
Past build:
BRACERA
KIND REGARDS!
ELMIR
Very nice progress Elmir,
The planks look indeed 'dirty' as you said.
What will you do with the deck once it is finished planking?
Anja
Thanks Anja. Well I will take off (sand) about half mm of deck as planned to get nice surface. So it should be enough to take off this mess also ?
Past build:
BRACERA
KIND REGARDS!
ELMIR
i am interested to see how much the planks will clean up, i had guessed the ink would stain through the full depth of the plank
All the best
Kevin
KEEP IT REAL!
On the build table
https://modelshipworld.com/topic/25373-hms-enterprise-by-kevin-caf-148-august-2020/
My other builds:
Well I seen this method many times. But also Kevin you might have a right. Best option is to little sand this planks to see result ? :D I'm beginner so everything is possible. I can not ignore warnings from my older and experienced colleagues. Thanks
Past build:
BRACERA
KIND REGARDS!
ELMIR
although i tend to use a permanent market on one edge of each board - i still get some bleeding, other prefer using card, which gives a nice result, i hope your way works
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
Well i tried just a little sanding and here is result.
Past build:
BRACERA
KIND REGARDS!
ELMIR
Looks great after sanding... post-76-0-53442500-1374014667.gifpost-76-0-53442500-1374014667.gifpost-76-0-53442500-1374014667.gif
Before you go any farther with the deck, make a mock-up off the model and then apply a coat of finish.  If there is going to be any bleeding, it will show up then.
Toni
Member IPMS
                           Utrecht-1742
I'm not sure that I understand you very well Toni. Are you saying about possibility of stains from ink after wet finish apply? If that so deck is already finished yesterday :D And also from beginning I'm aware of that possibility but I think that glue and ink are now solid mix and won't make problems with linen oil.
We will see in next few days :)
Cheers everyone and thanks my friends for interest, kind words and encouragement.
Past build:
BRACERA
KIND REGARDS!
ELMIR
Elmir, I am not sure what linen oil is...maybe linseed oil?  From personal experience, I have had the experience of bleeding as a result of the finish being applied.  I hope you do not have any problems.
Toni
Member IPMS
                           Utrecht-1742
Continuation:
Well i work a little and here is result how Bracera look now (black color and flax oil are aplied)
Past build:
BRACERA
KIND REGARDS!
ELMIR
Elmir
What is the elevation of the fourth support post from the bow to the deck ?
In progress:
CUTTY SARK - Tehnodidakta => scratch => Campbell plans
http://modelshipworld.com/index.php/topic/2501-cutty-sark-by-nenad-tehnodidakta-scratched-campbells-plans/page-1#entry64653
Content of log :
http://modelshipworld.com/index.php/topic/2501-cutty-sark-by-nenad-tehnodidakta-scratched-campbells-plans/page-62#entry217381
Past build:
Stella, Heller kit, plastic, Santa Maria, Tehnodidakta kit, wood, Jolly Roger Heller kit, plastic
About 1,5cm.
Past build:
BRACERA
KIND REGARDS!
ELMIR
Elmir the work you have done so far looks terrific.
Michael
Sweet looking hull.  Nice job.
Bob
