Hey Chris. I don’t know about the best but my favorites for the smaller 6” files are Grobet or Vallorbe . They’re PRICEY but imo they’re great. The grading system they use (or at least I’m familiar with for the files I have) goes from 0 or 00  (the most corse) and then 1, 2, 3 and 4 to progressively finer finishes. I originally ordered a 4 and it was too fine for initial wood (or metal) removal  but was usable for fine finishing.
By no means am I an expert and I’m sure others will offer better information.  Just google those brand names If you’re interested.  Stay Safe...Moab
Completed Builds:
Virginia Armed Sloop...Model Shipways
Ranger...Corel
Louise Steam Launch...Constructo
Hansa Kogge...Dusek
Yankee Hero...BlueJacket
Spray...BlueJacket
26’ Long Boat...Model Shipways
Under Construction:
Emma C. Berry...Model Shipways
https://www.artcotools.com/grobet-habilis-files/
No perspective on the subject but the files in this link might serve.
But even with these, it is a bad idea  to hold the handle end,  file with the tip end, and apply downward force in the area in between - especially if the area under the downward force is not in contact with anything.
Hard steel, that really holds a sharp edge does not like to bend.  It would rather break.
NRG member 50 years
Current:
NMS
The U.S. Ex. Ex. 1838-1842
Other
I ordered this set from Otto Frei.    https://www.ottofrei.com/Glardon-Vallorbe-LA2442-2-Needle-File-Sets-of-6-5-1-2-14-cm-Medium
I am satisfied with the files and the service was excellent.  I highly recommend this company.
Here is a link to the main page of their files: https://www.ottofrei.com/jewelry-tools-equipment/bench-tools/files
Ryland
               - Nautical Research Guild
Vallorbe files have served me well. Not cheap but good quality. I have escapement files from them as well as a cheaper mini file set from Husky.
The escapement files are smaller than the mini files.
Previous build: NRG Half Hull
Previous build: MS Bluenose
A jewelers' supply is a good source for files and other small hand tools.  And I find that wine corks make excellent handles. Small file tangs can be pushed in, while for larger files I drill a hole first and sometimes glue in a brass tube that accepts the tang.  Finally, avoid using the same file for both wood and metal.
There was a recent discussion on Vallorbe files here that might also help.
Derek
Cheers, Derek
Current build:   Duchess of Kingston
On hold:              HMS Winchelsea
Previous builds:  HMS SpeedyEnglish Pinnace, Royal Yacht Caroline (gallery),
                            Victory Cross-section (gallery), US Clipper Albatros, Red Dragon (years ago!)
On the stocks:    18th Century Longboat
I didn't think MSC could be beat for one-stop-shopping for files but I just checked McMaster Carr.  McMaster Carr has more.
McMaster Carr only sells to business.  If you can make that sort of connection, they are a great resource for tooling or fasteners.
If these industrial supply houses have a physical presence where you live, Granger has a store here, they usually have a City Desk that deals with walk in customers.  They will order what they don’t have in stock.  You just don’t have a house account so it’s credit card or cash.
Roger
  • 2 months later...
