I’m giving my first resin model a try, a 1/700 SS Normandie. Unfortunately, the bottom half of the hull was considerably wider than the top. This has taken a bunch of time and aggravation to join but it seems like it looks reasonable enough to proceed. I epoxied some nuts to the inside of the hull so I can mount it to a display stand.
That turned out great  - but frankly is did not expect any less from you Chris.
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
Thank you. I did some masking and painting. Between the resin and the scale I'm finding it very hard to do a decent paint job. Being basically one big piece there is way too much masking. This is definitely a challenge for me. I'm not sure how I'm going to paint the windows...they are TINY! The black is in gloss now until I get the decals on, then I will tone it down with some flat clear. I prefer styrene lol.
You must be traveling tourist class Chris if all they will give you is a Styrofoam cup!:D Nice work so far. It looks like all your effort in masking paid off.
Lou
Currant builds:
Schooner USS Lanikai/Hermes
Non ship build log:
1/35th UH-1H Huey
Thanks Lou, yes low budget lol! Today I'm experimenting with getting color into the window recesses of 1/700 resin Normandie. Some will have tiny white PE frames over them if I can get them on and some need touch ups.
Hi Chap,
Looks awesome!!
I admire your attention to detail, esp. at 1/700!!
Great stuff and certainly an inspiration.
(The Coffee is "Huge!!")
Cheers and Regards,
Harry.
Completed Builds:
A/L Bluenose II
A/L Mare Nostrum
Sergal/Mantua Cutty Sark
A/L Pen Duick
A/L Fulgaro
Amati/Partworks 1/200 Bismarck
A/L Sanson
Thanks Wayne. The only thing I could come up with was using a Faber-Castell artist pen. It is the only thing I have found with a small enough tip to get in these tiny recesses. The issue is it is India Ink which doesn't dry on plastic or paint, at least not for a long time. I am going to seal it with light coats of flat clear and hope it does not run. I would rather have used a different type of ink but I ordered a bunch of artist pens and this small of a tip only comes in pens with India Ink as far as I can tell. The windows don't appear as tiny as they really are in photos. In person some are terribly small. I have my fingers crossed that the ink stays put after I clear over it!
Edited by ChrisSC
Excellent work as usual Chris.
OC.
Current builds
Completed works.
Thanks. I had to take a break from this 1/700 resin Normandie to preserve my sanity. I now attached one side of the lower hull PE window frames and decals. This model is beyond my abilities and patience but I will finish it. The size of the PE and resin combination is not something I will do again lol!
Edited by ChrisSC
9 hours ago, ChrisSC said:
I may need a straight jacket when I'm done though
You should possibly have gone through the straight jacket routine BEFORE you started. By the time you are done with this excellent build you will be due a medal!
Lou
Currant builds:
Non ship build log:
1/35th UH-1H Huey
I wasn’t happy with the forecastle paint so I tried to touch it up with a brush. This turned into a disaster as there was a bad paint reaction that ruined the whole forecastle. I thought the model was trash. I stripped it all off with acetone which caused a gloppy mess. After it was cleaned up I sanded, carefully masked and sprayed it again. Thankfully it looks OK to me now. I need to learn to leave well enough alone lol. New paint is on the right in the photo.
Looks good. Glad it made it. We don't want any repeats of Normandie history! 😭
Edited by lmagna
Lou
Currant builds:
Non ship build log:
1/35th UH-1H Huey
Glad you got it fixed Chris,   no worse headache or dissapointment to get to that stage and have a  problem like that.
OC.
Current builds
Completed works.
OC.
Thanks OC. Not to worry, there are many things left for me to screw up lol! Some of these 1/700 parts are crazy small. The spotlights and speakers are like specs of dirt. Too small for tweezers. A wax pencil and holding my breath sometimes works.
1 minute ago, ChrisSC said:
This is a 1/700 photo etch marathon. I'm seeing double, maybe even triple!
"Holly Mollies"     thats hurting my eyes just viewing your masterpiece   - and look at that water in pool  - thats it Im getting my trunks...
OC.
Current builds
Completed works.
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
