HIJMS MIKASA 1902 by Jeff59 - FINISHED - HobbyBoss - 1/200 - PLASTIC
Also finished making the last of the davits, glad to get them done. Next stage is to paint them all. As you can see l  am starting to fit up the boat into position, lot of fiddling about at this stage, only two to go though, be glad when the boats are finished as well, been a bit of a slogging match.
Link to comment
Share on other sites
This photo of ship shows the deck davit, see its pointing forward so the only thing in that area is a deck hatch, so positioned it accordingly, again can’t say it’s right but it’s in this photo 🤞 That’s me for now, see if I can  finish this same as starboard side for next post 🤛  bye just now.
Link to comment
13 minutes ago, Haliburton said:
Simply outstanding work Jeff, time to start thinking about a display case?  I’m always interested to see how folks present their finished work of art.  Scott
Thanks Scott, have plans to have her with water along Starboard side along to boarding steps and  full hull on Portside with torpedo net extended. So shall be tackling a wooden display case, with a bit help and advice from friends 👍 Sooner it’s in a case the better, far to fragile, plus keeping dust of it at the same time, it’s a bugger to dust 👀 cheers.
Link to comment
Another short post guys, showing how I fitted the tie ropes for the canvas in place before fitting the parts together, obviously you have to paint the two parts before starting the rigging 👍 left them couple of days for paint to cure, Vallejo paint does take quite a while to fully cure, despite being dry to the touch in minutes.
Link to comment
Next part was doing the final fit up to try and make it work, seem to be like a cat, land on my feet most of the time 😂 be it a grumpy puss, Jaqueline shouts up stairs, your supposed to be enjoying that, it’s your hobby 🙄 anyway, got it together ok, just leaving the horrible boat strapping to do, have decided this is murder to do, the result works, but no fun.😂 Also finished the bridge wing bracing and rigging to the davits on boat deck.
Edited by Jeff59
Link to comment
Jeff,
a beautiful build of an exellent kit-model,
very well done
Nils
Current builds
-Lightship Elbe 1
Completed
Link to comment
Hello Jeff
Remarkable model you are making.
You may have noticed that I am making Mikasa too.
Can you please measure the hight of the finished model, from the bottom of the keel to the highest point of the main mast? Preferably in metric but imperial wil do as well.
As the hull is nearing completion, I have to decide wether I have place to put the model on pedestals or wether I have to put it directly on the bottom plate of the showcase.
Thanks,
Herby
Edited by Herby63
Link to comment
On 2/2/2024 at 7:04 PM, Herby63 said:
Hello Jeff
You may have noticed that I am making Mokasa too.
Thanks,
Herby
Hello Jeff
Thanks,
Herby
Appreciated 🤛 Just measured her just now. 315mm from keel to highest point on main mast, hope you can squeeze this into display case 👍 Shall take a look at your build log, always good to see other modellers efforts, especially on something that is as challenging as Mikasa, Not much  in the way of help or information on this ship, which is a shame considering her status. I started my build knowing absolutely nothing about her , even that she was built in England or indeed still existed, so it was one big learning curve. Hope you’re enjoying your own experience with her🤛 Thanks, Jeff.
Edited by Jeff59
Link to comment
On 2/2/2024 at 4:00 PM, yvesvidal said:
Your model is becoming a museum piece. It is incredible and I can see the Love and Patience being poured into that model.
Yves
Thanks Yves, museum piece, think if l take much longer l’ll be joining it in the museum 😂 your right though , been dragged in deeper and deeper , first model completed in over forty years so l never new that l could  go this far, think the Son likes it. 🤞
Link to comment
Just had another look at your build log 👍 impressive soldering, never new it was possible to do such fine soldering especially on those torpedo net booms, hat’s of to you that’s brilliant 🤛 something else l will have to learn how to do. 🙄 don’t think you can solder the walkways for torpedo nets cause they are stainless steel. Your soldering is definitely a great talent to have in your armoury.👍
Link to comment
Excelent, I made a displaycase for my 1/200 Bismarck, with an internal hight of 350 mm, and I prefered both cases to be the same hight.
I visited Japan in 2019. Some months after returning, I was browsing the net for a 1/200 model of HMS Dreadnought. Thats how I descovered this IJN Mikasa. We shall have to visit Japan again.  :)
Thank you very much for the measurement.
Thanks, I had an excelent example (Captain Slog)
Thanks, and to think that a couple of months ago I could only solder using huge blobs of tin.  :)
What an adaptable soldering station an soldering paste can't do for you.  😁
Edited by Herby63
Link to comment
Think l will look at investing in  this in the near future, could have done with this for some of the work on the masts for sure. Your build looks like it’s going to be impressive 🤛 Are you building 1902 or 1905 version?
Link to comment
I am not planning on doing extensive research on the differences between the 1902 and the 1905 version, but I am going for the black and white (light grey) paint sceme, in order not to have a house full of grey hulls.  😀
Link to comment
Thx, learning a lot from those who went before me and share on MSW or YT
Link to comment
I was intending to run a piece of rigging from mast to deck at this point using wire but when I started to look at old photos changed my mind again, decided that there wasn’t any rigging from mast to stern of ship whatsoever , you can always see the two lines on bow to mast on lots of photos but same photos never show lines on the stern. If l’m wrong can always add it later. Whilst looking at photos I also noticed the way the rigging worked for lines for battle ensigns, new there would be two lines up to this point and had run them vertically to each other, this photo shows them spaced apart on the centre stanchion.
Edited by Jeff59
Link to comment
If you look carefully you can see what I mean, so I cut the rigging out and reset in correct position 👍 also glued the small deck davit in place after last boat rigged. Fine I thought must be on easy street now, just the aft ensign staff to fit, wrong 😩 set up not right as usual.
Edited by Jeff59
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
