thanks
i kept avoiding it as I was not sure about brick mortar and the "copper"
the heavy artist sketch/paint  paper works well with paint and it wont wrinkle as much as normal paper
  • 3 months later...
just curious, what's the box look like for this kit?   I think I have the same one!
Made some progress recently
i decided to attach the boat davits, etc so I can set up the chains in correct spots
i have been perusing photos of Morgan since Latina drawings are really not well researched as far as I can tell
going to put as much detail on hull before copper since I am worried about damaging copper while adding all the attachments to outer hull
I also added chain to bow sprit and some other blocks at bow
thanks
the davits are 3 pieces of wood laminated together using a curved pattern of small nails as a template
all 10 of them
  • 3 months later...
Little bit of progress the last while
bottom section of skylight done
i am thinking of not using ‘glass’ just leave it open
At this scale may be better to leave it open
I also started on port main an mizzen chains
used wire bent around deadeye and then soldered
then a nail in hull and epoxy
On future builds I am going to determine the locations in hull where chains and other attachments to hull are fixed and put blocking behind planks for extra support
A85FDFBF-FCFD-43C7-9610-54C2E94D377A.thumb.jpeg.6c6fbd6cd923d29e12dce9c57b38e83e.jpeg85FE9B71-D4F5-4F91-9F51-D1ACF4825B34.thumb.jpeg.e5a95a647797301054ebe5587e7ddd60.jpeg9A7113D2-14C0-47CC-AE49-272102037BBE.thumb.jpeg.4b527d60377d1c3537ae30050a675c85.jpeg90309567-EB4A-41B6-9DC3-19AEED8E9148.thumb.jpeg.dfedb6bc87d4e72b772c4b5e7703e347.jpeg
Thought I would do a quick update on the Morgan
i finished the main and mizzen chains/deadeyes as you can see from photos.
I used galvanized wire so I painted them with Tremclad galvanized primer first then the black color
after epoxying the wires onto chain plates I added a trim piece on the plate, already painted with white stripe on upper plates
I have found paint pens at the art store did a great job of the white stripe and the black on the trim pieces
wish I had done that earlier
1899EF18-6CDF-426B-B3F4-69EBA3AF7ED5.thumb.jpeg.af6c5188e6ebdf99fab568f309a0f20f.jpeg I am leaning toward not having the shelter/deck over the tryworks since it covers up all detail on deck.
I did find a historic photo of the tryworks in operation without the shelter so there is precedent 🤔
while I decide I am going back to finish the skylight and tryworks details, such as the metal brackets on both sides
still have not started the windlass, likely should do that also
i had a crazy thought about turning this into a diorama with a whale carcass and resin for the ocean but I think that would be too complex … not ruled out yet…
I suspect I am channeling my younger self making dioramas with tanks etc , none of which have survived
It's great to see the progress on this.
I never got started on my Charles W Morgan, I really don't have the space needed to devote full time to a model in progress.
Probably should pass my kit onto someone who will finish it.
Kits awaiting build: Charles W. Morgan [Artesania Latina], Skuldelev Viking [Billings], Lyde [Euromodel]
Thanks geoffs
Nice to get a response to my posts!
I am also glad there is progress; I also have Swift partially finished and Bounty still in the box.\
Someone gave me a Bluenose II because they have never looked at it; hopefully I can get to it someday  :)
My workshop is a bench squeezed in between my bikes, tools I rarely use and my son's tools (electrician)
I am constantly "rearranging" stuff and building shelves ; also tossing out things
Thanks Ian
I have definitely decided to forego the "shelter" over the tryworks.
Would be nice to see the tryworks detail
  • 9 months later...
Minor update
finished forechains:  I may add the extra link at the base of chain
I imagine this is extra strength on forechains to accommodate the bowsprit jib sails extra pull
Well, I had a bit of a disaster when I decided to add belaying pins
it seems I messed up the pintails so the belay pins hit the other rail when inserted into the holes
rather than tear off the pin rails I enlarged the holes which,of course, lead to breaking the rails
anyway I hacked it back together and hopefully won’t be too noticeable once I have shrouds, rigging loops, boats etc block8ng the view
I also bought belay pins and they were too fat so I sanded them all down using my pin sander
just clamp in chuck and sand away
I have been experimenting with 3D printer for the boats
I found a Beetle Whaleboat file on a 3D site and have printed a few
at this scale the detail is rough though that may indicate my ‘rookie’ level ability with 3D printing
 My brother said to get resin printer which looks like good advice at the moment
heres a couple samples from todays printing effort one with empty hull and one with seats etc
also one showing scale beside Morgan
i may print slightly larger, the empty shell could be the upside down spare or I may print all empties and fill in details with wood
While I mull over what to do about 3D print of boats, I decided to stop stalling and get the windlass done.
the parts in AL kit for this are real bad.  I attach a photo
i am modifying some of those parts and building it based on actual photos and my best guess
Her3 is photo of some of the parts I completed so far.  The drum at each end I whittled down from kit and shaped based on real ship.
i also used my 3D printer for the ratchet gear in the centre of the windlass
I am considering doing the main parts of the body with the metal pieces it wind the chain, still learning how to draw with Tinkercad et al so will see how it goes
Update to my Tinkering with Tinkercad and 3D printing
here’s a photo showing many trial prints and wood pieces along with the ‘skewer’ that has the current 3D parts
i believe I still have some changes as I expected these parts to be a bit wide : suspect I messed up measurements somewhere
I include photo from CWM herselfIMG_0196.jpeg.566af82301608870d7bd68746f584d53.jpeg
Edited by rookie
Wrong picture
IMG_0898.thumb.jpeg.ab54a850efd1ad3cdf185234b647daf5.jpegIMG_0899.thumb.jpeg.525b1474fdd6775b64e9dbbc9f5e0b2d.jpegIMG_0900.thumb.jpeg.be20dfc02ff147632b937175d5d8cd04.jpegWell, after many attempts at 3D print I managed to make progress on the windlass and the foremast mast band
i realized during this how far out if scale the belaying pins are on my model
These would be baseball bats if not belaying ropes on my Morgan
i may sand them smaller but then the pin rails would have giant holes
ah well…
  • 5 months later...
