Mike, I moved this from the scratch area to the kit area.
Another  for us telescope  users  -  will pull up a chair.
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
21 hours ago, ccoyle said:
How can a gun barrel not be included in a kit? Seems like kind of an important part for any warship model. 🤔
Because barrels are cylinder shaped unlike PE parts which are flat.
In 1/700 you can buy extra brass barrels for big caliper guns. Smaller caliber guns are sold as a whole, as an extra upgrade. The ones in the kit were a single piece with the gun house so i couldnt use them.
Edited by mikegr
I made 2 20mm single guns with the shields. Another one was lost and the last one was over sprayed with primer and is beyond repair. Looks like I'm going to use 2 of those included in the kit. They will look like 40mm ones as they are bigger but i guess i can live with that😁
Edited by mikegr
I had to speed up my work cause of my 3 weeks leave. I finished the basics of the model while some finishing details will be added upon return.
So after making the base using two sheets of 4mm plywood I coated it with wood primer and several layers of dark ocean blue. Then added the epoxy. As time was running out,after only 8 hours  I coated the surface with medium gel giving the light waving effect. Note that the gel hasn't dried completely, therefore sea looks a bit wavy, white will turn into clear later.Next time I will try the more time consuming method of hairdryer(using hairdryer to make waves when resin starts to get solid).
I make the wakes with acrylic putty and toothpick. Same for waterline plus mix of PVA+cotton. Will paint it over with white acrylic upon return to make a more visible effect.
Wonderfully done  - really nice.
OC.
Current builds
Completed works.
