HMS Bellona by yvesvidal - CAF Model - 1:48
Thank you, Kevin.
While finishing the lamps, I have a few questions regarding the staff and ensign on these period ships:
- How was the ensign attached to the staff?
- Was the staff equipped with a pulley at the top, to raise the ensign?
Any precision or explanations would be much welcome.
I thank you in advance.
Yves
Link to comment
Share on other sites
57 minutes ago, yvesvidal said:
Thank you, Kevin.
Yves
There is a 1768 contemporary model that shows the attachment for the flag staff, It is hard to tell from the resolution on the RMG site, but there is clearly a loop of rope so there must have been some sort of pully so it could be raised or lowered. I suspect not a full block as they likely would have depicted it if it was, more likely just a metal hoop or maybe a sheeve in the staff itself?
https://www.rmg.co.uk/collections/objects/rmgc-object-66316
https://www.rmg.co.uk/collections/objects/rmgc-object-533928
Edit, actually on second reading it seems the model was made in 1974, so probably not a great source :(
Edited by Thukydides
Link to comment
Lamps are finally finished. These kits (from Syren) are little projects in themselves and take some time to be completed. Again, as mentioned before, the lamps are made of 80% Syren and 20% CAF Model parts. Through the glasses of the lamps, you can see the main candle, a blob of wax on the base and the black candlewick. A small maintenance door facing the stern, allows access inside the lamp.
Overall view of the stern:
Now, I have to find a solution for the staff. Then, we will move to the bow....
Yves
Edited by yvesvidal
Link to comment
Wonderful! Absolutely fine work and what a great result! You are definitely doing great justice to this project! The gun placements, railings and stern balconies and just the overall symmetry and attention to detail in that last shot are so awesome! Great work Yves!
Link to comment
just gets better and better
Its all part of Kev's journey, bit like going to the dark side, but with the lights on
All the best
Kevin :omg:
KEEP IT REAL!
On the build table
HMS Indefatigable 1794 by Kevin - Vanguard Models - 1:64 - Feb 2023
HMHS Britannic by Kevin
SD 14  - Marcle Models - 1/70 - March 2022 -  Bluebell - Flower Class - Revel - 1/72   U552 German U Boat - Trumpeter - 1/48  Amerigo Vespucci     1/84 - Panart-   HMS Enterprise  -CAF -  1/48
Finished
St-Nectan-Mountfleet-models-steam-trawler-1/32 - Completed June 2020
HMS Victory - Caldercraft/Jotika - 1/72 - Finished   Dorade renamed Dora by Kevin - Amati - 1/20 - Completed March 2021
Stage Coach 1848 - Artesania Latina - 1/10 -Finished Lady Eleanor by Kevin - FINISHED - Vanguard Models - 1/64 - Fifie fishing boat
Link to comment
On 2/8/2024 at 1:46 PM, yvesvidal said:
Thank you, Kevin.
Yves
Hi Yves,
This is how I dealt with the Ensign staff on my Pegasus build.
068
The truck was fitted with two sheaves.
58c3f9b9377ce_011ENSIGNATTACHMENT.jpg.d53e9bec972e245045b829f0c62f3dbaensign.jpg.4cbc70e5e7142f9a3a39a432272c4210.jpg
This is a schematic of how I attached the Ensign.
Hope it helps.
B.E.
Link to comment
  • 2 months later...
A quick update, as I have not had much time to work on this model, due to multiple side activities.
I completed the chimney for the oven. All parts are made of copper tubes and aluminum tubes, soldered and glued together. The shape is inspired from the Anatomy of the Ship book.
On the deck:
Hmmm... after seeing these pictures, I think I need to paint it darker....
Yves
Edited by yvesvidal
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
