On 12/9/2024 at 6:21 PM, wmherbert said:
Nice job.
Your plates and rivets came out great.
What is a NWSL riveter tool?  even Mr. Google couldn't help me.
Bill
Hi Bill, and sorry about the delayed reply!
NWSL is NorthWest Short Line, a hobby tool company geared towards model railroaders but their tools will of course work on any genre. Their riveter tool is a calibrated table, part number 51-4, that attaches to their small arbor press, part number 50-4. You tape your work to the table allowing it to advance a precise amount, per the pitch of your 'rivets'.
With some practice you can draw pencil lines on your work and manually advance it to each 'rivet' location... this goes a lot faster than using the calibrated screw. I used this method for my Flower class corvette where I had over 10,000 rivets to emboss!
The dies come in assorted sizes and you operate the press every time you want to emboss a rivet. My understanding is that NWSL has had patent issues and so this and other products in their tool line have been knocked off, so if to can no longer find it at NWSL try Micro Mark or others, and I have seen it come up on ebay.
Edited by Lecrenb
G'day everyone, and thanks in advance for following along. Since my last update I have been working on the cap rails, starting with the main deck. These rails follow the curve of the bulwarks at each end where they sweep up to the fo'c's'le and poop decks.
No matter how much heat and hot water I applied the rails always splintered and buckled when I tried to bend them. I ended up wrapping the ends of each rail with thread as seen in the picture; this prevented the wood from splintering when bent. I also rolled the ends around a Tamiya paint jar which was close to the desired curve, this support prevented the wood from buckling when it came out of the hot water.
I made a jig from scrap pine, to hold the rails in the correct shape as they dried.
The first picture shows my setup; with a small slow cooker for the hot water, one rail set in place after drying, and the other drying in the jig with the wrapping at each end.
The rails were painted Tamiya X-18 semi-gloss black off the ship so I wouldn't have to deal with masking and touching up.
The second picture shows the painted rails installed on the ship as the glue dries.
Edited by Lecrenb
I was told to laminate tight bends with multiple thin strips.
Make the pieces wider because they will wander. Steam and bend them as an assembly without glue. Allow for spring back. When dry, glue them together and clamp. When cured, sand the edges to proper width then assemble on the model.
Alan O'Neill
Thanks Alan and Druxey... I appreciate your comments and advice.
I would have preferred using thin laminated strips but neither I nor the LHS had what I needed and the postal strike was looming when I made the rails. I had a good supply of correctly dimensioned scale lumber on hand, so at the end of the day I used the method that I did, with eventual success after some frustration... The string wrapping is similar to a pipe bending trick to keep a pipe from collapsing when bending, and it did work on my rails.
I did use shapes cut from basswood sheet to plank the hull around my stern section, and this method matches the plans of the original ship! I presume the shipwrights also had problems making sharp bends in Douglas Fir and Ironbark!
As you will see in my next post, when faced with bending the rails across their width to follow the curves of the upper decks, I used the saw kerf method with success, and more basswood sheet shapes to work around the stern rail.
Merry Christmas!
Good morning all...
Moving right along to the fo'c's'le rails, I sawed kerfs about 2/3 the way across the width of my lumber. After a bath in the hot water it then easily conformed to the shape of the bow. I clamped it in place to dry and it held the shape.
I then painted the sides and exposed edges of the rail bottom off the ship so I would not need to worry about masking and touching up.
After gluing in place I applied a smear of filler to hide the kerfs, then sanded and painted.
The upper wales are basswood strips and did not need to be sawn. Once steamed and clamped for shape they were also painted off the ship then glued.
I used a spacer to set a constant distance of the wale below the rail.
Cutting the kerfs, so the wide lumber will bend along the bow.
clamping the rail in place to dry after hot water treating. The kerfs are visible near the bow.
Bow rails competed and the fo'c's'le wale being glued in place. The next photo shows the spacer I made to set the distance below the rail.
Edited by Lecrenb
Good morning, and I hope everyone on the forum and in the Guild had a very Merry Christmas!
In my last post I told a bit of a fib... I did need to saw kerfs into the poop deck wale where is made the sharp turn around the stern...
The picture below is the wale being installed on the port side, where I used the same jig to set the spacing below the rail.
The next picture shows the cuts being made into the stern section of the wale. Even though the Zona saw kerfs are narrow the give me sufficient flexibility to bend the wale around the stern after soaking it in hot water.
The last picture is the wale drying in place on the ship, after which it will be gap filled, sanded, painted, and glued onto the ship.
Edited by Lecrenb
I am now at the point where I can drill holes into the hull... besides the various pump and engine discharges I need openings for the fairleads, hawse and portholes.
Following that and while waiting for my order from Cornwall Model Boats (the postal strike is over, at least for the time being!) I will be installing various fittings around the outside edges of the decks, and building the rudders (two of them, St. Roch carried a spare on deck).
The main wale, also referred to as the rub rail, can't be installed until the portholes and chain plates are on since the rail overlaps parts of them. Bottom line is it may be a while before my next update, so I will leave you with some pictures of St. Roch as she is today.
Thanks everyone for looking in and for your comments and critiques!
More than one way to skin a cat. I usually follow the thin lamination method and your method had never crossed my mind but I will log it for possible future use.  Thank you.
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
Thanks Keith...
Happy New Year, and it is -30 here this morning... a good day to hunker down and start making rudders...
This is the original plan, drawn in 1":1'. I checked actual dimensions on the plan to verify it is accurately scaled, and it is, therefore it was a simple job to divide by 4 to convert to my 1:48 scale dimensions...Rudderplan.thumb.jpg.ced953aac7b162af096270a56c856a2d.jpg
The blanks for the two rudders are three basswood sheet laminations, which in turn are laminated using 3M double sided tape. Then I sanded one edge flat as my reference and drew the rudder onto the face of the wood.
Laminatingblanks.thumb.jpg.b6de87f74787ff897879c2aef43013ee.jpgRudderOutline.thumb.jpg.424670e1c160ad5dc9bbc7eb9aaee960.jpg
Off to the bandsaw, then a first sanding to ensure both rudders are the same shape before separating the two blanks and rough sanding the profiles...
Bandsaw.thumb.jpg.c35490087d2ad2c0e222282b275f0af3.jpgFirstsanding.thumb.jpg.59f50156700cc895289ccdc986c5baf0.jpgSecondsanding.thumb.jpg.774bfd106f3e9c294f885bbaa06e3816.jpg
Next is a test fit on the ship... everything seems to line up! The second rudder is a spare that was carried on deck...Testfit.thumb.jpg.4da093ebde5bdd4b28267b6be3c8072b.jpg
Edited by Lecrenb
Excellent work, Bruce!
Sharp tools and clear skies,
Gabe
Current builds:  Harvey, Baltimore Clipper - Artesania Latina;  HMS Triton Cross Section, 18th Century Frigate - online scratch build; HMCS Agassiz, WW2 Flower-Class Corvette - HMV - card model
Completed:  Swift, Pilot Schooner - Artesania Latina --- Build log --- Gallery;  Skeeter, Ship-in-Bottle - Ships a Sailin' kit --- Build log;  Santa Maria, Caravel - Artesania Latina --- Build log
Companion SiteHMS Triton log and live feed
Continuing with the rudders, I primed and sealed them the same as the white hull... then I used styrene strips and Tichy Train Group rivets to apply reinforced steel straps in the same manner as I did on the stern post of the ship. Styrene rod served as my pintles, and some thin resin rod made the lifting pins...Rudderoutfitted.thumb.jpg.127be6b5119e5d0459354f015cc8ebb4.jpg
Now the rudder was test fit on the ship...
St. Roch's rudder was designed to be lifted to the deck via the rudder well using a tackle rigged to the main sail boom. The lifting pins, that can be seen at the top of the rudder, align with guides set into the sides of the well. I made mine by scaling from the same plan as the rudder... using styrene strips for the guide rails and .010 sheet for the bases. I painted them Tamiya 'Gunmetal'...
The rudder head extends above the poop deck. The brass collar is the inner half of the rudder bearing. The outer half is bolted to the deck. The hex section at the top of the rudder stock is where the tiller bolts on, the tiller is part of the quadrant assembly. The top of the guide rails can be seen flush with the deck.Rudderhead.thumb.jpg.0e03f0ac42eb97a4cfc8c5d52d89ff52.jpg
This picture shows the spare rudder stowed on the main deck...
This last picture is the rudder of the actual ship in the Vancouver Maritime Museum.
Now I have to make holes in the hull for various fittings such as portholes, hawse holes and fairleads. These need to be installed before further work can be done...
So thanks everyone for looking in and I do appreciate your comments and critiques!
Edited by Lecrenb
Looking forward to seeing her at the MSON club meeting tomorrow!
Edited by AON
Alan O'Neill
Great presentation today Bruce!  The model is beautiful.  Following going forward.
Steve
Steve
San Diego Ship Modelers Guild
The video of Bruce's presentation will be posted on the NRG's website very soon - it is in the hands of the webmaster already.
Sorry but its only for NRG members however, once a member, this and many other presentations are viewable as long as membership is maintained.
Kurt Van Dahm
Director
NAUTICAL RESEARCH GUILD
www.thenrg.org
CLUBS
Midwest Model Shipwrights
North Shore Deadeyes
Butch O'Hare - IPMS
Good evening Bruce. I just watched the NRG video of your presentation last Saturday...  Well Done!  :cheers:
I am sorry I missed sitting in on it but I had an unexpected early morning appointment elsewhere that kept me away.
Alan
Alan O'Neill
Still waiting on parts to arrive from Cornwall Model Boats, I was going to paint the rudders but decided to wait until I had made the cradles since some lower hull touch up will be required then for sure!
So it is on to making the display base... I decided to laminate pine strips. It looks similar to the Douglas Fir that St. Roch is made from, and I had a supply of pine offcuts in my shop from other projects. I made my HMCS Chicoutimi base in similar fashion but using oak (Hearts of Oak and all that!), and it is a great way to use up wood that would otherwise be consigned to the fire pit!
This picture shows the model sitting on the base, just making sure there is about 3 or 4 inches clearance all around...Modelonmadebase.thumb.jpg.01cda5693f3b710c897ff6ee7dd800d1.jpg
First I rounded the corners about an inch, just to take off the sharp edge... then I routed a simple Ogee all the way around.
The base will have either a glass or acrylic cabinet to protect the model, I haven't decided which yet. Since the thickness of the cabinet material is not known at this point I decided to install cabinet stops around the base edges, instead of routing a groove. Here is that work in progress, once all four pieces are installed I will do a bit of cleanup.
I used oak strips, just for a bit of contrast and I thought pine stops might chip easily when taking the cabinet on or off. Next I will move on to making the cradles that St. Roch will sit in.
Thanks for looking in!
Edited by Lecrenb
Now I am making cradles for St. Roch to sit on when mounted on the base. I debated on whether or not to use finials, simulate drydock blocks, or copy the mounts used on the original ship in the Vancouver Maritime Museum. In the end I decided to use some pieces of 3/16" thick acrylic I had laying around to make a pair of cradles. First I used my contour shaper to take the hull shapes at each cradle location, about 10" apart.contourshaper.thumb.jpg.8a424d10bc987b9f2ca1de861863f37a.jpg
Then I transferred the shapes to graph paper to complete the cradle outlines. Note the forward cradle raises the keel higher than the aft cradle, so the waterline will sit level (St. Roch draws more water aft).
Then transferred onto the acrylic sheet...
Next I used my Dremel router to cut out the shapes. Patience is key because the acrylic will melt onto the cutter and needs to be frequently cleaned. If you're careful the pattern will come out clean. The picture shows the aft cradle after some filing and a first edge polish after cutting out.
"PA" refers to port, aft... so I don't lose track of the cradle orientation. Multiple fittings and adjustments followed... just a little bit of fine shaping each time...
Here is the aft cradle test fit to the ship and the base...
Now I get to have more fun cutting and fitting the forward cradle...
I'll come back here after the base is completed!
Regards,
Bruce
Edited by Lecrenb
I was asked to include a picture of my Dremel router, so here it is...
It is an attachment that screws onto the end of the Dremel, then add the cutter of choice, set the depth stop, and off you go!
Actually I found it easier to mount the cutter with the router off the Dremel, just more room to work around the chuck. I am cutting one of St. Roch's cradles.
And here is the base complete!
2 oats of clear coat finished it off...
St. Roch trying out her new cradles...
And my parts from Cornwall Model Boats arrived today... 10 days from the UK is not too shabby!
I will have to modify some of them to be period correct, so that work and getting them on the ship are next!
Edited by Lecrenb
To finish the exterior hull I began with the portholes... these are RB Models 5mm flanged and glazed, exactly what is needed.
I scaled the locations of the portholes onto the hull using photos and original plans, and I used a piece of lumber sized to match the rub rail to ensure proper alignment.
A Forstner bit is essential to drill the holes as the spurs cut cleanly and do not tear out the wood.
Test fitting the portholes... the rub rail will overlap a part of each flange per the original ship. For this reason the fasteners are not evenly spaced around the flange.
The portholes come with five holes drilled into the flange. St. Roch has eight fasteners per porthole. I used .032 diameter Grandt Line rivets, their heads superglued around each flange, and filled the unused flange holes.
Then the portholes were glazed, the glazing recessed per the actual ship. After painting they were superglued into the hull.
Paintandglaze.thumb.jpg.130dd7cb15671ca75e96215f922211f2.jpgNext up is the chain plates, then the rub rail.
Your work is excellent! I live about a 15 minute drive from the St Roch so if you ever need specific photos let me know!
hamilton
