This is a build log for my 2nd model ship (my first being the Occre Golden Hind which i finished recently) and i hope to finish it in succession similar to my first.
 I have had a LOT of fun with this hobby and am hoping to keep it up, hope you all enjoy this build log as much as i will enjoy the build.
side notes, i am keeping it as faithful to the instructions as i possibly can, maybe making a few minor changes to the model because i didnt like how Occre did it but feel free to leave suggestions or criticisms as much as you like because they are all welcome.
as expected from occre the wood quality is great and the instructions are incredibly simple and easy to follow. only ran into an issue with one of the frames which had a knot and was weaker than the others but not weak enough to scrap and replace.
everything fits together nicely and i am enjoying putting it together.
Planking's always a challenging part but also potentially really rewarding. Good luck!
thank you! im trying to do it with no nail holes this time unless necessary and it seems to be going well!
Looking good!  For future builds, keep in mind that all of the decks have round up, they do not lay flat.  It may be the photos but the decks look to be flat.  Check out the build log of the  Endeavour by KJackson.  modelshipworld.com/topic/31858-hm-bark-endeavour-by-kjackson-occre-154/#comment-902995 where this has been discussed in detail in the last day or so.   It appears there are at least a couple kits that forgot to take into account round up/camber which would be found on virtually all ships.
Your first layer of hull planking looks to be going well.   Will you be tapering the strakes and spiling or hot edge bending?  If you have not already studied them, there are excellent tutorials here at MSW teaching proper planking techniques.
Allan
Allan
Hi allan, thank you for the tip ill be sure to take it into account on my next model. does seem to be an issue with occre kits in general but im sure its an easy fix and do you know of any good tutorial links on the site? im interested in different planking techniques as i dont really go into planking with a plan lol
The tutorial for spiling by David Antscherl is in the Articles data base under framing and planking as is the lining off article by Chuck Passaro.  https://thenrg.org/resource/articles   Note that in the first picture in Chuck's article he is very clear to avoid this unrealistic planking style.   All the strakes need to end at the rabbet unless there is one or perhaps two drop strakes.  If your model is double planked you have the first layer as a great learning practice before going to the second layer.
Allan
5 hours ago, E Z Breeze said:
This is the model that I have decided to build as my second ship. I'll follow your work with interest.
You are doing your first planking in a style unfamiliar to me, something I may well follow because my method is causing me a few anxious moments on my first build!
Those Occre planks look quite thick, can you tell me the dimensions please?
Thank you!
and funny enough this model kit is also my second ship!
this planking style is usually just a mix of the Occre plans and whatever comes to mind for me, the occre plans can only get you so far but i think the way i do it is sufficient for a nice rounded surface.
and the lumber is 3mm x 5mm x 60cm but some of the planks can be a bit wider/ slimmer than most which kind of sucks but i usually just skip out on using those planks and use them for fillers
2 hours ago, E Z Breeze said:
Yes I saw that. It encouraged me to go for this one despite some slight worries that it's a big step up from a herring drifter!
It's nice that they give you plans at all.
3mm thick seems enormous to me but you have plenty of material for sanding so I guess there are advantages.
yeah they may seem pretty thick but i find they are best for this size of model, and as you said, plenty of material for sanding so you can make it the shape you want
4 hours ago, E Z Breeze said:
I just checked the price of the kit and was pleasantly surprised. For that kind of money, I see nothing to complain about - so I've ordered one!
awesome! its a great kit for the price. i hope you enjoy the kit!
Your gluing looks very tidy. I struggle to keep it all as clean as yours. I wonder, are you using CA?
Edit: My kit having arrived, I see that no glue is used at this stage. Now I understand!
ive actually been using wood glue with a mix of using ca glue at parts i cant hold down with nails or gravity. then i clean it up with cotton buds or paper towels.
i cant wait to see your progress on the ship! its interesting to see the different ways people make these.
8 hours ago, mikegr said:
There is a step by step guide by an expert friend on you tube on this popular model
Thank you! but funny enough ive actually been using johns guide as a pointer in the right direction for a while! hes got plenty of tips and tricks for this ship.
Hello Clementine,
Your build is looking good. I also found your method of doing the first planking to be rather interesting. It seems like you got a nice result though and that's all that matters. Fast progress too! It took me about a year to do two planking layers on my own build...
Wishing you continued success with your model,
starlight
2 hours ago, starlight said:
Hello Clementine,
starlight
Thank you for the nice comment! i appreciate all the support you guys are giving me its giving me so much motivation!
