On another thread I mentioned that I got inspired by reading a recent book about a little-known vessel that was pressed into the West Africa Squadron to fight the slave trade. The name sounds terribly racist, but it has nothing to do with that; the ship was named after an incredibly bawdy and raunchy pub song which I will not make reference to here!
I will not go much into the back story but if you want to pick it up here is the Amazon link:
The Black Joke: The True Story of One Ship's Battle Against the Slave Trade: Rooks, A.E.: 9781982128265: Amazon.com: Books
I looked at several kits to try and modify including the Occre kit Dos Amigos (Which the Black Joke actually captured!)
The Dos Amigos had some pretty stark differences, so I decided not to go with it. (I did buy the kit anyway...)
Trying to get plans were pretty difficult but someone on this site suggested that Chappelle had dug up some plans in Norway (or somewhere in greater Scandanavia...) and put them in his book "The Search for Speed Under Sail".
I digitized the plans in 8.5 x 11 format from the book. The measurements on the vessel identically matched those of the Black Joke.
The vessel in Chappelle's book was not the actual ship (the deck fittings were not correct for the Joke) it was VERY likely a sister ship built in Baltimore.
The scale I decided on was 1/50.
This put the length of the model at 21.84 inches and 6.36 inches at max beam.
The plans were then blown up to the proper size. I then used tracing paper to cut out the keel and deck. I then started to cut out a few of the frames before I ran out of steam on the evening.
If anyone has suggestions as this is my first TRUE scratch-build I am open for pointers and pitfalls.
Black Joke Work Sheet Hull Forward.pdf
I read that book, too, and had the same thought that the ship would make an interesting modeling project. It'll be neat to follow along on this. I enjoyed the book overall, though it was pretty clear the author knew nothing about nautical affairs and hadn't bothered to run the book by anyone who did. But the history itself was interesting.
Have you researched similar ships on the RMG site?   There are a number of plans of brigs at the Collections site as well as scantlings from David Steel (1805) for similar sized ships.  The drawings you show may be spot on though.  Regardless, this sounds like a very interesting project.
Allan
Looks like you are making progress, should be an attractive model when finished.
Just a point to satisfy my curiosity: have you allowed for the camber of the deck? From the photos, especially photo #3, it seems the tops of the bulkheads are at full height for the intended level of the finished deck. If you have not glued them in place yet I suggest you cut the camber before assembly as it will be much easier than trying to do so after they are glued up.
The camber will be the same along the whole length of the deck so a simple jig should make quick work of all the bulkheads. Use the curve shown in the stern view. If you have this in hand already, ignore me 🤐
Interesting subject, I will be watching to see the progress of a fellow first-time scratch builder.
Bruce
STAY SAFE
current builds:
Bruce
Bruce,
This is my first true scratch for a wood from plans. Any help is ALWAYS appreciated. The plans showed me the underside of the main deck and I subtracted a microscopic amount from that prior to cutting the bulkheads. I freely admit that the guys in my club make this look FAR easier than it really is but even if this only goes this far I have already gotten over my apprehension of "lofting" bulkheads from plans.
The stern looks like the most daunting part right now as the stern chine follows the sheer pretty boldly. In many of the books I have seen the ships had a gun deck so the stern seemed easier. I think I am probably worrying over nothing but I will collide with that bridge when I get there! 😀
Hi Highlanderburial
It appears you did not mark out the plank widths at each bulkhead which may be part of the problem. The width of the plank is dynamic as it goes from the stem to the stern.  If you have not already done so maybe consider studying David Antscherl's planking writeup here in the MSW Articles archive and Chuck Passaro's videos on planking and you will have an easier time of it on the next planking job.
Allan
The initial hull is complete and shaped. I will be adding a "dressier" plank layer with copper. Overall the shape of the hull is fascinating with some serious tumble home on the very thin stern. It transitions much like powered craft would in a very "tear drop" fashion. It really looks like it should have a propeller. I have started shaping the bulwarks but will not be installing until the deck is laid. Yes those are nails. No I did not pound them in!
I opted for 6 ish inch planks as that seems to have been standard deck plank size on post 1812 Baltimore Clippers of the time period. This means the wood size is roughly 3mm. I am using basswood and painting one edge black. I have laid the king plank and drilled the mast holes. I am taking the planking slowly as I tend to screw this part up.
I wanted to try treenails so I dyed a bunch of toothpicks with light brown acrylic maple stain. So far it seems promising. I pre drilled the holes and stuck the picks in gently and then when both were inserted I used more force. I used some flush nippers to cut the picks off pretty close to flush. At first the stain looked drastic but after a quick sanding the effect was nice.
I think I was shooting for around 1 inch treenail heads. The drill bit is a .5 so the nails will likely be a skosh big for hitting .75. I would love to say I was factoring in for the white glue but I think this was the drill head I had at hand...
Slow and steady. I added a slew more treenails to the deck especially near the plank butts. I sanded the nubs down flush. I then took a rag with some thinner and actually got to see what it looked like. There are still several spots that still need some more nails but overall I am happy with the effect.
Edited by highlanderburial
Typo
I got the initial bulwark planking in place. This was kind of a "do or die" for me on this model. Fortunately this came out well and I will be looking to build the cap rail soon. I also did a lot of lay out work on how the steering gear will work. This ship will have a wheel with drum and block tiller system. I noticed after looking at the plans several times that the cover on the steering tiller seemed pretty wide and oversized. I then remembered that this vessel has a stern launched small boat. This would be a platform that the crew could stand on while prepping the boat and staying out of the tiller swing radius. It also gives the crew a step up to get up to the davits. I also did some more sanding and prepped the hull for the next plank layer.
  • 4 months later...
One of the major stumbling points on the project when I am not able to get down to the shop and work with wood is I wanted a decent pivot gun for the vessel. There really are none for sale that match this time period. On one of the forums here another user posted some amazing pics of a computer drawn version of the exact pivot gun I was looking for. Still there were no actual CAD files I could directly print from so I chipped away at sculpting my own. I finished modeling the gun, carriage and rail (with super challenging chamfer supports). Here are some pics. I have it on the printer right now and will post pics when complete. To be clear the last pic is not mine it is found by putting in a search on MSW for 18 lb pivot gun and you will see the thread.
The metal ring looks alot like a piston ring for an internal combustion engine (motorcycle, lawnmower, small car).  If one could find the right size the carriage build would be pretty straightforward?
Really cool project and deck planking!
Edited by Coyote_6
Steve
San Diego Ship Modelers Guild
