USS Maine by ERSRich - FINISHED - BlueJacket Shipcrafters - 3/32
Introduction
This is the USS Maine kit by Bluejacket.  This beautiful multimedia kit features: an enormous solid hull, resin turrets and sponsons, metal gun barrels, and many sheets of photo etch.
After planking many hulls, decided to build this solid hull kit; less time on hull building, means more time spent on topside buildout.  And, hopefully, quicker results.  Can I knock this out in 6 months?
This log may be less detailed than my USS Constitution log, and will show how I do the major tasks.  My building philosophy, at this point is to keep working, don’t sweat the small stuff - analysis/paralysis, and trust my ability to overcome the inevitable problems.
Please feel free to send a message with any questions you may have.
Edited by ERS Rich
Link to comment
Share on other sites
I look forward to following your build.  I missed out on getting the Maine kit as BlueJacket only made 100 of them.  I did manage to get the limited edition Olympia kit.  I have not worked up enough nerve to tackle that kit.
Ryland
               - Nautical Research Guild
Link to comment
Now you're doomed -- you're just gonna have to get Oregon to go along with it.
When you have to shoot, shoot. Don't talk.
- Tuco
Link to comment
Hull Preliminaries
Cut a building board from a piece of plywood and found a chuck block in the scrap pile.
Screwed the block in the bottom of the hull and clamped in the shoulder vise.  Used a 36” ruler to mark the centerline on the deck.
Picture 1 shows two pieces of decking, glued with epoxy, along the centerline.E7098BAD-0AD7-4E89-89C9-DA44C9A433E7.thumb.jpeg.298cb338ef86f27925566a8e5fbb8600.jpeg
Pretty simple, clamped lightly after the epoxy set.  Be careful as the deck can slide.  Let dry overnight.
Next flipped the hull and drilled a series of holes n the deck along the hull - picture 2.
Here picture 3 shows the hull back in the vice with the holes outlining the hull edge.  Ready to do the deck rough cut with a Tamiya razor saw.
Picture 4, cutting along “connecting the dots”…..
Finally cutting along the curves with a well sharpened flat chisel….pictures 5 and 6.
Picture 7.  Rough cut finished.  The deck will be sanded flush with the hull when  fairing the hull with the templates.
Edited by ERS Rich
Link to comment
27 minutes ago, alross2 said:
I designed it back in 2005, so if you have questions, feel free to ask.  If you break or lose anything, we still have the stuff to replace it.
Hello Mr. Ross!  Thank you!
Link to comment
This looks interesting. I didn’t know Bluejacket offered a limited edition.
Paul
On the Ways: Mighty Mite, Harbor Tugboat by pwog - NautiCurso - 1:64
__________________________________________________________________
Completed Builds:
Lobster Boat Red Baron (Bluejacket)
Sardine Carrier Pauline (Bluejacket)
Swampscott Dory (BlueJacket)
Link to comment
2 hours ago, alross2 said:
And, quite a bit further...
Thank you very much, these pictures are helpful…..
Link to comment
On 10/4/2022 at 8:54 PM, alross2 said:
Did the kit have the CD?  It has about 100 images of the build of the display model from start to finish.  You can still get one from BlueJacket.
Wow, no CD, can’t remember exactly, bought this kit (#004) from someone years ago.  I do have a second kit, I’ll look 👀 there…..
Link to comment
Deck Finish
Made up a few finish samples with deck scraps.
Tried Trewax, Ipswich Pine Stain, Spar Varnish, and 3 Bees Natural Wax.
Wax is easiest, but decided to go with Spar Varnish, like the natural color,.  Keep in mind wax would probably inhibit adhesives, so waxing the deck would be left unit the end.
Link to comment
Making the Air Vents
We need 80 air vents cut from the 5/32” aluminum rod.  Instructions call for 1/4” lengths (-0”, +1/32”).
I made a jig with a channel to hold the rod, with a fence, to make cuts with an Xacto razor saw.
Picture 1 shows using a 1/4” brass square rod and the razor saw blade to correctly position the fence, when glueing the fence to the base.5204E34E-1DED-42DB-ABE5-B841EFA548E5.thumb.jpeg.e3fde6fb29a74442c5f49f1a1dcb5f99.jpeg
Picture 2 shows the tools used to make the parts.  I was able to make exact 1/4” lengths.  First I trued the rod end with the Ultimation sander, then make the cut, last true the cut edge with the sander.  Check length with digital calipers.
Link to comment
Marking Airport Locations
We need a line along the side of the hull to locate the air vents.
The line needs to be 3/8” below the top of the deck.  The deck is 3/64” thick.  So the line is 21/64” below the bottom of the deck.  I made a spacer block 21/64” wide, and the picture below shows making the airport line by sliding the block along the bottom of the deck with a pencil.
Next I setup the hull on the plan and marked the locations of the sponsons and anchor bills.  Then I used dividers to mark the air port locations.
Link to comment
Airport Installation
The airport holes were drilled in 3 stages.  First a 1/32 pilot hole using a Tamiya battery operated hobby drill.  Second a 1/4” bit in the Foredom drill press.  And the final 5/32” cut with a hand drill.
Picture 1 shows the Foredom setup, with a high fence clamped to the bench.  For the ports near the bow and stern, wedges were used to angle the drill base and hull so the bit was perpendicular to the hole.
To minimize tear out, the final drill cut was done through a tongue depressor - Picture 2.  Also, start the final cut with counter clockwise revolutions until the bit is below the surface, then use the depressor.
Deal with tear out divots by inserting rod in the hole, filling with wood filler, and sand around the rod - Picture 3.
Round over the edge of the airport going into the hole first with the Ultimation sander - Picture 4.
The results….
Edited by ERS Rich
Link to comment
Shaping the Hull
Before starting, assembled the forward and aft superstructures by drilling out the alignment holes to 1/8”, then used a 1/8” dowel to align the lifts.  Assembled them with carpenters glue and clamps.  Then drilled 1/8” holes at the appropriate locations on the deck and dry fitted the superstructures.
Gathered the tools needed to do the job:  flat chisel, rasp, files, sanding sticks from Amati - Pic 1.
At first I was a little uncertain how to proceed.  I did trace the hull plan view, made a template and found my main deck centerline off slightly.
Did some chisel and file work at the bow starboard side, and went to town with a sanding block  - results not the best so on the bow port side and stern, found it best to simply start with the rasp and remove the lugs.
I was overthinking it, once the lugs are removed you are practically there.
Pic 2 - rasp in action, removes a little or a lot of material depending on the pressure.
Pics 3-4.  Used the bow and stern templates and the files to dial in the shape.  Mark the high spots with a pencil, file them down, repeat.
2BB6BB49-80B6-421B-8FEE-2808E5CA3B5E.thumb.jpeg.f0e16e67b54a805e7198975a875c0908.jpegC6BDCE11-2A40-48AC-8642-D9C24115C10F.thumb.jpeg.c35bf817867e8bbfa012faabb41fb50e.jpeg
Personally this step is tedious to me…..still have some work to do - to get her ship shape.  Enjoying the journey….
Link to comment
Aft Torpedo Tube
We need to make a 3/16” hole to accommodate a dowel that simulates the tube.
Marked the location on the hull.  As before drilled the hole in 3 stages, pilot hole with a Tamiya hobby drill, then 1/8”and finally 3/16” with a hand drill.
Picture 1 shows making the pilot hole, with the drill positioned on blocks.  When expanding the hole with the hand drill, start by rotating the bit counterclockwise to avoid tear out along the hole edge.
Picture 2 shows the dowel installed.
Link to comment
Rudder Post
I faired in the rudder/hull interface with the rasp, half round and round files.  It’s helpful to have a reference point while filing, in other words to register the file against something while filing.  Registering make it easy to make the port and starboard of the hull that lead to the rudder symmetrical.
After marking lines for the sternpost sides, start with the rasp - Pic 1.  Be sure to rotate the rasp along it’s long axis to prevent gouging the relatively soft pine.  Remove material until close to the lines.
Next move in with the half round file.  Register the file by keeping the handle in contact with the hull when filing in the aft direction - Pics 2 and 3.
E6196FD8-52AF-43BA-956C-2DAC7628E4A3.jpeg.2d69dfbdb01b43ea05f16a27008441e3.jpegD2AD9B22-1DC4-486E-845F-7F562584B316.jpeg.0dd3d0614b87b58e34360adc5678078c.jpeg
Getting close - Pic 4.
Retrace the rudder post side lines, then move in with the half round file towards the corner.  Picture 5 shows how the fingers can be used to register the file against the hull.617847C5-4785-4E0A-A96F-A7612CD2016E.thumb.jpeg.deb92faebe37410e3edddfa2501cbc74.jpeg
Finally proceed with smaller round files - where the finger tips can be used to register - Pic 6.
Still a little work to go, in the corner, but pretty close….
Edited by ERS Rich
Link to comment
Hull Prep
Decided to do the major hull preparation before attaching the Bilge Keel and Prop Shaft, Strut, and Hull Shaft Bearing.
Filled in major divots with Minwax wood filler applied with a tongue depressor - with an angle cut in the end.
After sanding, will apply several coats of spray can shellac, with a 220 sanding in between.
Flexifile helps with the curves…
Edited by ERS Rich
Link to comment
Fitting the Starboard Sponson
I made a template off the plan, of the outline of the aft end of the forward superstructure and the outboard side of the starboard turret.
Next the template was taped to the hull and the sponson placed in position.
The sponson was used to locate two bench dogs, then clamped over a piece of sandpaper to the hull to provide a channel and guide when sanding the sponson.
When sanding first applied pressure to he center of the sponson, then to the aft end for the final fit.  The result….
Link to comment
Priming Prep
Over the course of the week been filling small areas with Minwax wood filler and light sanding with strips of 220 to feather in.
Just about there and ready for a thin coat of shellac.
Note I don’t spend time on the very bottom since it won’t be seen.
Edited by ERS Rich
Link to comment
Prop and External Shafting
Back to work after finally getting the heat going in the shop.  Had to wait many months for the mini split system outside unit.
First photo shows installation of a shaft and it’s boss.  I used a pair of dividers to establish the boss and strut locations with a measurement from the plans.  A slot for the strut was cut with an xacto with a spade bit.  Tape is holding the boss position while the epoxy dries.  The length of the shaft was reduced to get the position of the prop hub in relation to the stern post.  Note I made a mistake, the plan calls for the metal strut hull attachment to be above the shaft.  Decided to let it go.
Photo 2 shows the stern and the propellers.  Initial intent was to assemble with epoxy, but found super glue worked very well.  The propeller hub had nice grooves which fit the blades nicely.  Notice the bilge keel is also installed.
Edited by ERS Rich
Link to comment
Final Sponson and Turret Shaping
Decided to do the final shaping with the sponson and turrets glued together; with sandpaper attached to the side and deck simultaneously; reasoning was to avoid filling the turret/sponson seam.
Found, as the instructions state, it is important to hollow out the underside of the turret and inside the sponson - did this with a Foredom hand piece, initially with a flame bur to get the seam between the sponson and turret, then with a drum sander bit.  Resin dust isn’t good for you, so vacuum.
Here are the assemblies dry fitted, note a small gap at the deck/hull corner is ok, as there will be 3/16” half-round trim installed along the edge later.
Link to comment
Custom Gun Barrel Fitting
Enlarged the turret ports slightly, again with the Foredom, to accommodate the custom gun barrels - provided with this kit purchased from a third party.  They are slightly longer than the kit provided barrels.
Link to comment
Turret Cowl Vents and Deck Varnish
Need to trim the turret vents to length shown on the plan.  Found the best way is to put the part in a vise and trim with an Xacto saw.  Mark the line with a pencil and position the part in the vise so the line is exposed, then use the vise edge as a guide.  Then used the Ultimation sander to even up the parts.
Turret vents in place.
Applied a second coat of Spar Varnish, will smooth with 0000 Steel Wool and apply a final coat.
Edited by ERS Rich
Link to comment
Final Deck Finish
By this point applied 3 or 4 thin coats of varnish.  Hit the first coat with steel wool.  Later coats were applied without sanding in between.
I want a good seal because later the waterways will be painted on the deck.
No matter how carefully I apply varnish, there always seem to be visible brush stokes.  Also I believe the glued up decking is pine, not sure, which can take a finish unevenly.
So to “finish the finish” rub down the deck with 0000 steel wool and a product called “Wool-Lube”, it’s a lubricant for the steel wool.  It kind of slows down the cutting action of the steel wool, making it harder to cut through the varnish.  A wood block over the steel wool helps even the surface.
The lube is water soluble, so wipe down the deck with a damp cloth.
Link to comment
Sealing the Hull
Zinsser Bulls Eye Shellac was used to seal the hull.  It’s an evaporative finish, and the alcohol base dries very quickly.  And additional coats easily blend into the finish.  Here the hull is upside down to avoid masking the deck.
Wood dowels were used to keep Minwax wood filler out of the port holes.  Shellac also does a good job filling minor imperfections.
Swauber Applicators help when applying shellac around the portals and along the lower edge.
Looking good after a rundown with steel wool.  A few drips and runs, shellac dries into a hard finish, were removed with fine flat and round files.
Link to comment
Priming the Hull
Before priming the anchor bills, ram stiffeners, and torpedo tube covers were installed, along with the half round trim along the deck edge.
First the deck was masked with tape and construction paper.29570DBD-4CD6-4410-8B8A-AFACE9078DDE.thumb.jpeg.c93803b15b32c291efbc790c9b827477.jpeg
The hull was positioned upside down on a lazy Susan, on the Artograph table.
Vallejo grey primer, thinned with Vallejo thinner was applied with an Iwata RG-3 mini gun, @20 psi.  Smoooooth….   Let dry overnight.  Vallejo is an acrylic primer  that adheres well to shellac, metal, and brass.
Edited by ERS Rich
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
