I've just completed the 1:200 Amati kit of the Bismarck and really enjoyed it.  I was about half way through and started to think about my next build.  I decided it would be neat to do the major Battleships of WW II in 1:200 identical scale.  I decided on Bismarck, the Yamato and the Missouri.  Not too interested in Hood as it was obsolete at the start and the Italian or French battleships were both obsolete and non-factors in the war.  The Amati Bismarck is a wooden hull with copious brass-clad super structure and LOTs of PE and plastic detail.  My chosen ships in 1:200 are pretty much limited to all-plastic, with Nichimo being the most commonly available for Yamato and Trumpeter for Missouri.  Just about the time I was completing Bismarck I decided to add a fourth--USS Enterprise CV-6--as representative of the ship that obsoleted the Battleships.  Once again it's all-plastic from Trumpeter.  The good thing is that after-market PE and deck details are readily available for all 3.  Initially, I was disappointed that there were no readily-available wooden hull models, but after reflection; I decided that I had spent a lot of time filling, sanding and priming the hull of Bismarck to make it look like plastic.  So, I decided that it wasn't too much of a compromise to go with plastic hull and superstructure--plus my shoulder was going to really appreciate not having to do all that sanding.
I first saw the Nichimo 1:200 kit of the Yamato back in the mid-1980's and bought one "for the shelf".  After about 10 years, I decided that I had too many kits and sold it.  So, I had to find another one here in the 2022 era.  An e-Bay search showed that there were a lot of "new" kits available in the $600-$800 range, plus shipping, but I did a wait and watch and found one that had been started back in the 90's.  It seemed to be complete and it's partial construction was limited to setting up the RC motor features and the mechanism to rotate the main 18" guns.  It was less than half the going rate for "new" kits, so I took a risk and bought it.  As the build log goes on I'll find out just what I will need to do as I discover the kits condition.
The detail parts I have bought are: Scale Decks wooden deck set, Fujimi PE Detail sets 201 and 202, Gold Medal Models PE crane and catapaults set + railings, Tom's model Works Deck Reels and most importantly the Anatomy of the Ship book of the Yamato and Musashi.  The Nichimo "instructions" are next to useless and I don't think I could contemplate doing this model without this book.  This will be a big difference from the Amati Bismarck and it's VERY comprehensive step-by-step instructions and illustrations.  I do think that the experience of having built the Amati Bismarck has given me a leg up in building the Yamato.  Time will tell as I proceed--and I'll illustrate what I've learned as I do it for any future builders of this kit.  So far as I could find, there are no build logs of this kit.
My next post will show pictures of things as I start.
Effort to date is taking out things I don't want, like the motorizing, and poor assembly.  Seems like this model was started by someone with little or no plastic modeling experience.  Nichimo used Styrene plastic for the hull, superstructure, and decks plus ABS for all the small details.  Means two types of plastic glue needed for optimum results.  Nichimo supplied small tubes of each type of cement, but this all dates from the mid-80's and quality is unknown, so I've discarded all of the little tin tubes.  As I started taking apart the pieces already built I discovered that the former builder only used the correct glue for the fore deck and 2 inserts.  All the rest used some type of glue unknown to me, which popped loose very easily.  It seems to be a type of urethane that bubbled as it cured.  I remember when "Gorilla Glue" first came out it was a urethane cured by humidity in the air and really did grip like a gorilla on wood.  It slightly foamed as it cured.  There were even some fillets around the prop shaft fairings that looked like Ambroid model airplane glue. Not a lot there to be undone, relatively speaking.
There are two inserts at the stern hanger deck area that were glued in with the correct cement, but poorly fitted, so I'm doing filler there.  I dry fit the wooden deck to the front bow area to see how the details would be attached.  It requires the details to be glued on top of the wooden deck, so I removed all the little do dads that had been glued on to the styrene deck (with some type of lousy cement) by the previous builder.  Just sanded down the areas where glue was and this will be no problem because the wood deck will cover all the plastic surface.  Same with the previously assembled gun turrets.  Took them all apart to do a better job of assembling and adding cloth blast bags, plus a decent paint job.  Threw away the Rube Goldberg levers, et al. that Nichimo provided to motorize the turret rotation.  It's going to be a static model.
Ted (my apologies if I misunderstood your handle),
      I'm curious if the Nichimo Yamato has what @Roger Pellett called the "rather humpbacked sheer" of this class. The picture on the Anatomy of the Ship cover you put in shows the apparent downward slant from the after to the more forward of the forward turrets, and here is a public domain pic of the Musashi showing what I'm asking about .
My grandfather built the Nichimo version in the late '60s, but I don't remember this at all (and it seems less than obvious on photos of the 1:10 model at the Yamato Museum), but I haven't seen the results of his build since the early '90s. Just curious if my memory is wrong or if this is one of the changes that was made with some of the newer kits or if some of the aftermarket parts make the change if I'm not misremembering.
Please don't take this as a comment on your build, which is looking great, and which I am following with interest. FWIW, I've trolled ebay for Nichimo Yamato's but have just balked at the prices, and, for sentimental reasons I might get go for the Nichimo version over the new MRC version.
Regards,
George K
Edited by gak1965
George--Yes, name is correct.  I adopted ted99 a long time ago for multi-media posts and have just kept it.  I think there is some alteration in perspective in the photo you show.  The kit has a definite "upsweep" to the bow, starting at about 1/3 of the distance from the bow.  The sheer is horizontal from that point aft.  In fact, the plastic deck portion for the part of the kit aft of the galvinized foredeck has a "cast-in" curve to match the upswept sheer line of the hull.  It looks to me like your photo was taken with the camera parallel to the upswept deck and makes the ship look like it's the midship area that is upswept--opposite of the case in the model.
I have a tag on e-Bay postings for 1:200 Yamato, watching for detail bits, and it looks like some people are offering the Nichimo kit at more reasonable prices, now.
George--I want to amend my previous statement regarding the kit being "horizontal" after the upswept bow.  I put a straightedge on the edge of the top of the plastic hull and there IS some upsweep from where the bow upsweep begins to aft.  So "Hogback" is an accurate description. It doesn't appear to be as much as the photo you show, but I still believe there is some perspective distortion in that photo because of the camera lens being parallel with the upswept deck.  The Anatomy book side view of both Yamato and Musashi also shows upsweep from aft of where the bow upsweep begins--to just about the same degree as the model hull.
Painted the bottom of the hull with Glidden spray can "brick red".  I'd like for a little more "orange" in the color to look like the color plates in "Anatomy", but one works with what one has.  Reason for painting now is that attaching the rudder needs to be done while I have access to the inside of the hull, and once the decks go on, no access.  I wanted to paint the hull bottom and rudder with the rudder off, so paint it now, I must.  The deck pieces fit OK, except for the next to last one aft.  The hull sides need to be squeezed in to mate up with the deck and I couldn't have done that without a clamp.  I used CA adhesive for this job as I did not think that a plastic cement would be strong enough.  It took a hard squeeze to get the edges in the correct place. There seemed to be some sort of incompatibility between the Nichimo styrene plastic used for the hull and decks because anywhere I put it seemed to weaken the plastic.  My first try was to hold everything together with the screws provided for deck to hull join when access is needed for the (unused by me) electric motors.  They held perfectly when dry assembled but when I applied thin CA to the hull/deck join, the plastic deck edges at the screws gave way and the hull sides sprung out.  The clamp had to be used.  After the CA set up, all seems to be well, but just in case I applied a fillet of epoxy at the hull/deck join at the rear of this section of deck.
I will have to paint the hull aft deck before I put in place the next to last deck section because this deck section protrudes over the aft-most deck piece.  I'll probably do all the topsides at the same time. This deck piece is fairly interesting.  The Nichimo casting has corrugations in the two triangular places at the edge of the deck that represent ventilation holes.  According to "Anatomy", this is actually a mesh.  I'm going to cut out these corrugations and replace them with very fine mesh copper screen.  This deck has two walkways that "A" (how I'm going to abbreviate "Anatomy") says are linoleum and are the color of old cork in the book.  I got some 1/4" wide copper foil and placed it in the indicated spot.  I'm hoping that this copper will tarnish a little to something closer to the correct color--just give it some time, hopefully.
As I look at the detail parts, the railings are going to be attached with CA adhesive at the edges of the wooden decks and it won't be possible to paint them after attachment.  So, my initial thought was to spray paint them while they are still attached to the sheet.  Then, I thought, why not "chemically" blue them with "Brass Black".  I've done so and the color has come out black rather than blue.  I've attached a picture.  Has anyone ever done/heard of this?  The chemical coating seems to be part of the brass now and added no thickness.
Brass Black, it does what it says.. black.  Probably what you need was the gun bluing stuff. but I'm not sure if works on brass.  You'll need to do Google on it and check.   Many hardware stores sell it   I'm not sure if popping the blackend brass in vinegar will remove but worth a try on some blackens scrap sprue.
Hi Ted. Mark is correct. Using ‘gun blue’ on the brass sheets before cutting them out produces a gun metal finish. That is how I am doing railings on my Mikasa. After putting in solution and drying, they appear jet black. I then buff the sheet with a soft cloth to achieve the final result which is a polished gunmetal. Possibly you can buff your blackened sheets to get same result? I don’t know as I haven’t used that particular product.
Tim Moore
Perfect is the enemy of good
In progress
DH.9a Ninak, 1/32, Wingnut Wings
Docked for Repairs
IJN Pre-Dreadnought Battleship Mikasa, 1:200, Hobby Boss
On Deck
The Blue Sky Company, 1:48, Sierra West Models
Completed
Triumph 3HW, 1/9, Italeri; Fiat 806 Grand Prix 1:12, Italeri; Fifie 1:32, Amati Victory Model; HMS Bounty 1:48, Artesania Latina; Endeavour 1:60; Corel; Miss Severn 1:8, Legend Model Boats; Calypso, Billing Boats; Carmen Fishing Trawler, A.L. ; Dallas Revenue Cutter, A.L., Bluenose, A.L.
^^^ Thanks for the above.  I did a vigorous rubbing and it just made it "more black".  Didn't think gun bluing would work on brass.  I'll give it a try.  In the meanwhile, I'll do a test with a vinegar soak.
I hope the test goes well.   If I remember right, the blackening agent bonds to the metal with little penetration.  However, it is a good bond as it's original purpose was for guns.
Tried a vinegar soak and it made no change.  I suspect that only mechanical action (sanding) will remove the black.  I'll wait until I've assembled some of these things to decide if I'll keep the black.  For instance, a truss tower could be lightly airbrushed (a capability I do not have as of now) on the outside over the black and not worry about getting a big buildup trying to get the gray on the inside of the truss's.
Just ordered some gun bluing for a test to see if it can result in the desired "dark grey".  I really do like the idea of a non-paint coating.
On 10/17/2022 at 7:23 AM, ted99 said:
Does anyone know what can accelerate the tarnishing of copper?
https://www.worldcoppersmith.com/articles/copper-patina-guide/#:~:text=Soaking copper in white vinegar,the darker the patina becomes.
A quick Google on "how to tarnish copper quickly" gives a lot of answers that are basically like the one above. So it might be worthwhile to run the search and see what else has worked for others.
The gun bluing does exactly that, turns the metal blue. Usually it's used on steel. Birchwood Casey and Jax both make products to turn your brass black. It could take several applications of the solution to achieve the level of black you want. The vinegar is a good surface prep/cleaner for brass.
For copper, you need something to accelerate the patina or turning the copper to a green shade. Not sure about what products do that.
Ken
Started: MS Bounty Longboat,
Well, I assume you mean other than fingers 😀. I've blackened copper chain with Brass Black, and Jax Pewter black Patina also works on copper. I guess the question is what color are you aiming for? Jax sells a chemicals that will give you green or gray-black but I've never used them. The other two go straight to solid black.
George
Thanks to all above.  This old fella did not know that one can simply pose a question on Google.  Live and learn.
It looks like the miracle-gro and water would be a good way to get a reasonably-priced (esp if you already have some miracle-gro) quantity large enough to simply immerse a sheet of PE brass.  I did the brass-black with a dipped Q-tip and it was tedious.  It would be easier to "catch" the process at just the right color change with a quick rinse if dipping was possible.
The color I'm looking for is the brownish color copper goes to when naturally exposed, but before it goes all the way to green--like old copper pipe.  The linoleum walkways on the flight deck are shown in "A" as being this color, with brass strips between the sections of linoleum.  If I can catch the copper strips at just the right stage of tarnishing, I can use an exacto blade to scratch the tarnished strip with the separations and then "fix" with matte clear spray.
I've cut a strip of the copper tape and placed it in my workshop area (but out of the sun so that the adhesive is not affected) to be exposed to see if it will naturally tarnish.   I can wait to install this on the flight deck until much later in the building process.  I'll slide it between my fingers every now and then, too (lol).  PE brass certainly starts to tarnish quickly once it's taken out of the plastic envelopes.
Continuing to prepare the hull for paint.  Did a dry fit of all three deck wood pieces.  Found minor places where the pre-cut holes needed a little adjustment to get the edges of the wood to line up with the sides in the correct position.  One major area of non-fit was at the front of the center deck piece where there are a number of pieces of deck furniture and the breakwater.  Big discrepancy in this area.  Not a deck piece alignment problem since this is all one piece of pre-cast deck.  Solution was to use an exacto knife and cut off the part of the front of the wooded deck that was done in grey shading, not wood simulation.  This area will now be grey-painted deck.  It already has grey painted deck furniture (the pre-cutouts for these pieces were way out of place) and I think it will be fine.  The alternative would have been to cut off the deck protrusions and remake them after the deck was laid.  I took the easier path.
Photo will show where I had to insert wood bulkheads between the hull and the deck to get the deck level across the area where the superstructure sits.  As it was, the deck was concave and the superstructure had gaps around the edges.  Epoxied these wood supports in place.  The superstructure sits on top of the wooden deck, once it's in place, I plan to epoxy the superstructure in place.  The instructions for the wood deck suggest using Gorilla Glue PVA for attachment and I think this will result in a good fitment--better and more durable than contact cement.
A temporary setback.  Those of you that followed my Bismarck build may recall that I have to do my spray painting from a rattle can on my 8th floor balcony.  I had just repainted the hull bottom with Rust-oleum "Rusty Metal Primer".  I like it better than the "brick red" for comparison to the color in the "A" color plates).  The hull was upside down resting on a board suspended at a corner of my balcony railing to dry.  Just as I was going out to bring it in, a big gust of wind (the mid-West cold spell front just arriving) blew the hull off the board and onto the concrete balcony.  Thankfully it went that way and not down 8 floors.  The hull was resting on the gun turrets, rather than flat on deck giving room for the wind to get beneath the hull and lift it.  The bow broke off, the stern was cracked and both the fore and aft-most sections of deck were knocked off.  Thankfully, I was there just as it happened and I was able to quickly retrieve all the bits and pieces before they blew off.
There will be a slight pause in progress while I reconstruct.
Yikes! I'm sure you'll get it all back together.
<JOKING>You could take this opportunity to switch to building the Musashi, which took a torpedo to the bow in March, 1944, and explain away any still visible evidence of the damage as representing the repairs! </JOKING>
In all seriousness, we all know how you feel. When I was building the Niagara I accidentally caught a line in my drill chuck and it snapped off the (fully rigged) jibboom. It took me a while to undo all of that damage, but now no one would guess - and I'm sure no one will guess once you are finished with the repairs!
George K
Thought I'd pass on some experience with adhesives.  First, this kit is now about 50 years old--I wonder if the styrene is getting more brittle with age?  Second, the hull, decks and major superstructure are styrene and all the other details are ABS plastic.  Are kits with contemporary plastics better than 50 years ago.  Dies can live forever and plastic kits can be reissued at any time by any company with the rights to the die with contemporary plastic mixes.  I suspect that the "new" kits of the Yamato with a different brand name that have appeared on e-Bay are using the old Nichimo dies.
The Plastruct is the only one that actually "melts" ABS and it does a good job of "welding" ABS to styrene.  But, it's a very aggressive solvent, so one must be very sparing on small parts.  The "Same Stuff" from Micro Mark is supposed to be the same as the old Tenax 7R--I don't think so.  Doesn't work at all on ABS and it's not an aggressive solvent so it's better on very small styrene to styrene parts.
I've been using the Ambroid plastic cement in a tube for hull to deck joints and it really doesn't do a good job of "welding".  The thickness is good for gap-filling, but it doesn't melt the plastic substrate like the Plastruct.  I used it for the hull to deck joins and as you can see, both the fore and Aft-most decks "popped off" on impact with the concrete porch deck and I'm able to just scrape the old cement off.  Even though it is thin, I think the Plastruct would have been a better choice.  I even wonder if the hull would have broken off if there had been a good weld between the hull and decks. I also wonder if the Testor's "Red" is a better thickened solvent?  I already had the Ambroid.  Anybody have an opinion?  The maker of the wooden deck recommends Testor's Red for gluing superstructure details to the wooden deck.
Best of all is the Epoxy.  I'll be using it (with reinforcement) inside the hull at the breaks.  But Epoxy is a pain to use because of the mixing.  I only use it where I'm looking for maximum strength--especially if it's embeded with fiberglass cloth.
Dies will not live forever. Actually, they get damaged relatively fast and this is why manufacturers issue the so called "New Tooling" on a regular basis.
The Nichimo kit (50 years old) and the new Trumpeter kit (2022) are two completely different animals and have nothing in common.
Yves
Trumpeter has a 1:200 Yamato?  I'll have to look it up.  Sure am sorry I missed that one and got an old Nichimo!  My opinion on dies was based on seeing airplane kits and 1:72 ship kits being reissued in different boxes.  Learned something new, here.
It's being issued through Gallery Models I believe, but yep. There is a review on the site:
Found it on Amazon.  I sure never saw it 6 months, ago.  Also one seller in the UK on eBay.  The usual Chinese discounted sellers of Trumpeter kits haven't made any postings, yet.  I bought both of my Trumpeter Missouri and CV-6 Enterprise from that source and the slow shipping was not a problem as both are "next" after Bismarck and Yamato.  It's an "enhanced" kit with several sheets of PE, which look a lot like the old "Gold Metal" offerings.  I wonder how the plastic bits stack up with the Nichimo kit.  One would think it's improved.  Much improved?  One would never call the Nichimo plastic details "fine".
Well, this is "live and learn" day.  I read your review, Yves, and it hits everything I dislike about the Nichimo kit.  I wrapped up my "research" for a Yamato kit back at the beginning of the year.  When I saw the ads later, I thought the MRC kit was just a reissue of the Nichimo kit at a higher price than the old kits available on eBay.  Wrong, Wrong, Wrong.  I would have given pause if anything I read pointed out that it was Trumpeter.  I may abandon this Nichimo kit.  I'll keep on a little while and see if the coming recession results in any price reductions.  Perhaps MRC will lose their exclusivity and the Chinese discounters will be able to pick it up.  Call continuing the build "practice" to see where I need to watch out for in the Trumpeter kit.
The irony is that the MRC/Trumpeter kit is (was) way cheaper than any Nichimo kit available on Da-Bay for a long time. Now that the Nichimo speculation has ended, the MRC/Trumpeter kit is suddenly "expensive" by comparison.
Yves
