2 hours ago, JSGerson said:
After I finished my Rattlesnake (Hunt practicum), I wanted a change of pace before I started with the Constitution. I decided to work on the Conny's boats first. They were a lot of fun and you can load them up with as much or little (especially if you're going to cover them when they are finally installed on the ship) detail as you want. I relied a lot on the US Navy plans for the details. Surprisingly, the MS plan details were very close to the US Navy's. They were like eating potato chips - "you can't just eat one."
Jon
Jon - yours came to mind. I actually got so wrapped up in your boat build that I almost began mine that way too. I decided it was like a nice appetizer that’ll be eaten during the main course 🙂
Current Build: USS Constitution 1:76 Model Shipways MS 2040
At Sea [Completed 2023]: 1805 Swift
Y'all are making me hungry, dang it!  😄🤷‍♀️😋
Gregg
Current Projects:                                                             Completed Projects:        Waiting for Shipyard Clearance:
8 hours ago, Der Alte Rentner said:
Thanks for the vote of confidence, Mustafa.  One thought I have it to stain the bulk of the hull to be darker than the section along the gun ports.  But in general, is there anything I should know about applying stains, poly, polyacrylic, and subsequent gluing?  There will be many parts to affix to the hull in the coming months, and I'm concerned about how will these will adhere.  I would not want to sand away then, any finish I painstakingly apply now.
I only use varnish on my unpainted models and I have no problem gluing things on them but I previously had severe gluing problems on a model where I applied tung oil.
Edited by mtbediz
Experimenting with stains and finishes begins.  This will take some time because I'm trying oil based gel stain, which I've grown to love using on larger refinishing projects.  According to information gleaned from the internet, the curing time needs to be between 24 hours and 3 days before covering with polyacrylic varnish.  Why polyacrylic?  Because that's what the Hunt practicum advises.  He applies no less than four coats of this to the hull after planking but before painting.  (why? oh why? Mr. Hunt does your practicum not address painting the hull below the gunports?  and why would you need four coats of polyacrylic before you apply three coats of black paint? - but I digress..)
Since I'm still hoping to stick with a natural finish, I want a better/darker color than the kit's basswood hull planking provides.
My first experiment is the plank section on the left.  Tried a combination stain/finish in walnut, with the plank in the middle unstained surrounded by one and two coats of the walnut.  Next up are three samples using Old Master's gel stain and one Old Master's wipe on stain.  The gel is easier to work with, but since I did have one open can of the American walnut, I threw it into the mix.  The other three colors are maple, cherry and pecan.  The last piece in the mix has only one coat of polyacrylic - so far.  After the stains cure, I plan to apply four coats of polyacrylic to those samples as well.  Lastly, I'm going to experiment with gluing various parts to these samples to see how well Super Glue holds.
While I wait,  time to finish the last step in chapter 3 of the practicum - build a base for Conny.  I had a nice slab of oak left over from another project and reacquainted myself with my router table.  Oh Gee!  is that an ogee?  Pedestal fabrication is next.  I may unbox my Proxon lathe and try turning the pedestals myself.
Another option:  Black dye.  I used this with fantastic results on another project years ago where I wanted to simulate ebony.  Now, to use this, I'd either have to apply it to the wood before doing anything else (besides sanding), or I'd have to mix it with clear polyacrylic.  Here, I applied the dye directly to unfinished basswood sample.  I wasn't happy to see the warping, but think this won't be a problem on the hull, given everything seems to be solidly affixed.   If I decide to paint, then this option would give me a solid black color in one pass.
When I return to the ship yard,  I'm going to try mixing the dye with polyacrylic.  Most likely I will still try one of the stains above first.  If I'm unhappy with the result, back to plan B, which is to cover with polyacrylic, then to paint.   I have experimented with the paint before and learned that multiple coats would be required to cover properly.  Hopefully with a dye/poly I can get by with one?
Edited by Der Alte Rentner
added content - and, yes, once again corrected typos.
That’s a really solid looking Black. I was wondering if using black dye would work on the cannons? I’ve read all the tales of woe attempting to use chemical blackening and I had some issues using primer and black paint.
Generally- Do you recommend applying the poly, then primer, then paint? Or does the poly negate the need for primer?
cheers!
cheers!
Frankly, I have no idea, hence the experimentation.  My guess is poly negates the need for primer.  BTW, I did some prior experimentation with primer and think this is a complete waste of time.  You'll still need multiple coats of paint to adequately cover the primer.
Last night I tried making a paint by mixing a few drops of dye with a tsp of clear polyacrylic.  The resultant paint netted about the same awful result as the paint supplied by Model Shipways when I purchased my kit.  It will take multiple coats (at least 4) of either to get a uniform coat - and the brush marks are decidedly unsightly.   Were I committing to a black hull, I would definitely opt for the black dye.  It goes pitch black in one application.  Covering with poly may require many coats though, as the polyacrylic seems to dissolve the dye on the first two coats I've applied so far in this test.
As lousy as the results with paint have been in my experimentation, be it the Model Shipway product or my home made dye/poly paint, I would need to consider spray paint/air brush options, if paint ends up being the direction I choose.  The cleanest results are with gel stain followed by poly.   I could stain the entire hull and decide later to cover with paint, if I don't like the way it looks.  Boy, do I wish I'd chosen better materials in planking than this cruddy basswood.  If I'd known at the start of this project that wood matters, I may have used the Constructo kit materials on the Conny build instead.  Live and learn.
P.S.  Sorry, I forgot to answer your question about using dye on the cannons.  I don't think this would work.  If you want to experiment, let me know how that works for you.  Cannons are a ways off for me right now.  Wouldn't spray primer followed by spray black (or the combo primer/paint product) be the simplest approach?  I've used Rustoleum spray on metal before with great results.
added P.S.
On 4/29/2024 at 2:06 PM, Der Alte Rentner said:
At last!
Planking is done.  The last row was a royal PITA!  but all's well that ends well.
Next steps?  Decide whether or not to paint.  If not, figure out a staining scheme, but experiment mightily first!   To buy time, and not derail construction, I may divert to other aspects of the build - maybe start constructing masts and spars?  Or, as seems very popular amongst others here at MSW, start on the cannons.
But, First things first.  Tonight I celebrate this milestone with a double Manhattan and a fine meal out!  Tomorrow can wait.
It is truly beautiful. Having planked two hulls now on my Vanguard models, I am ready to go back and complete the Conny hull. You have inspired me.
22 hours ago, Gregory said:
Have you considered doing a 2nd planking with veneer?
You would have many options as to wood type.
Yes,  yes I have.  However, as long as it took to get the first round of planking done, I'm not really thrilled about the prospect of repeating the process.  My thoughts this morning are to try the stain first.  If I like the way it looks, great.  If not, covering the hull with the planking material provided in the Constructo kit may be preferable to painting..
P.S.  your signature phrase, “Indecision may or may not be my problem.”
― Jimmy Buffett  Made me LOL!
added P.S.
Nice looking pedestal!  Is the center brace a part of the practicum or was that an add-on?  Looks great and provides additional support, I am sure.
Gregg
Chapter 3 ends with Mr. Hunt building a base with materials he had on hand.
This is my own design, based on some photos of model ship bases I saw on the internet. The brass pedestals required counter sinking to allow the brass flat head screw to lie flush.
I got the shape for the cradle from the plans for Buckhead J, which seemed to be the right place in the hull for the support.
Some tweaking with drum sander required for good fit.
Added commentary
For those of you who want a black hull, of all the things I've tried, Old Masters Carbon Black Gel Stain netted the absolute best result. Two light applications with a foam brush, solid black, no warping of the wood, and I know from experience, once it's cured, it will take a coat of clear polyacrylic.
I will experiment further, to see if this can be applied over polyacrylic as well.
Hello!  In my digging through older build logs here, I found one by Cookster, who seems to be as finicky about workmanship and finish as I am.   In his build log, on page 3 post 76, he discussed the merits of aniline dye.  (This link takes you to page three of his build log).  He seems not to have finished the project, but I will be consulting the build intently as I work through the planking of the spar deck.
added content
Just venting today..
While I ponder finishing options, I began working on the spar deck and hatch coamings. Thankfully, I double checked everything in the practicum before committing too much material and time to this phase of the build.
1. Hunt's instructions are to cut the foremast from 7/16" dowel and to make the opening in its mast partner to fit that diameter stock.  The plans call for 3/8" inch, and the laser cut mast boot is likewise sized for a 3/8" foremast.
2. Hunt's instructions provide distances from the center line for the hatch coaming framework.  There were several discrepancies there, as compared to the plans - most notably the dimension for the framework between bulkheads D and E.  (my take?  Trust, but verify.)
3. Adding another Practicum observation (May 20) for the benefit of anyone following Hunt's directions for constructing hatch comings. On pages 19 and 20 in Chapter 4, Mr. Hunt provides detailed instructions for fabricating the material needed for the coamings.  Likewise on page 40 for the main hatch.  He glues up three pieces of stock for each coaming.  To boot, for the shorter coamings, because the kit didn't come with 3/32"x7/32" stock, he trims a piece of 3/32"x1/2" stock for the center piece.  All well and good.  But on page 26, where he shows the parts of the coaming in photo (P4.3.1-1), he says he
I think I'll go the milling route myself.  (I sure hope the zero clearance ring for my router table arrives soon. That will allow me to easily mill the material myself.)
4. Once again, the materials provided with the Model Shipways kit disappoint.  All the dowels for the masts (5/6", 3/8" and 7/16") are misshapen - the 3/8" piece is completely warped.   Were I to go ahead with the 7/16" dowel for the foremast, there wasn't enough material provided to then be able to construct the main mast. The dowels are all different colors ranging from near white to mahogany.  Also, there wasn't enough 3/32" x 1/4" stock to complete the hatch coaming framework.  Last but not least, the material for the deck planking is off by as much as a 64" inch in width and thickness.
Having spent much time reviewing Cookster's 2013 build log for the spar deck and coamings (wow!), I've decided not to mess around with cruddy materials going forward.  Even if I paint every thing later, I'm going to give myself better options by ordering replacement material from Modeler's Sawmill.
(and before you ask, no, I'm not going to waste my time contacting Model Expo, where I bought the kit.  I'm still waiting on the replacement material for the hull planking they said they were sending on December 1 of 2023.  (Ticket #22286: replacement stock for USS Constitution kit))
Not sure where I'll invest my energy while I await material delivery.  Maybe start the side galleries?  Or take advantage of the nice weather?
added commentary about Hunt's hatch coaming construction
3. Once again, the materials provided with the Model Shipways kit disappoint.  All the dowels for the masts (5/6", 3/8" and 7/16") are misshapen - the 3/8" piece is completely warped.   Were I to go ahead with the 7/16" dowel for the foremast, there wasn't enough material provided to then be able to construct the main mast. The dowels are all different colors ranging from near white to mahogany.  Also, there wasn't enough 3/32" x 1/4" stock to complete the hatch coaming framework.  Last but not least, the material for the deck planking is off by as much as a 64" inch in width and thickness.
This is why I don't buy kits.
Quote
Read your post about following Cookster, and his comment about is log being broken, I just want to let you know that I have all of his images that he posted. When I follow a build log dealing with the Constitution, I don't just read it, I copy the log and store it on my computer. BTW, I did the same thing when I was building my Rattlesnake. I don't trust the internet to keep websites forever or maintain original addresses. I've seen websites crash and lose everything (e.g., ModelShipWorld and ModelShipBuilder). So even though Cookster himself seems to have vanished in a puff of smoke and his log is starting to slowly disintegrate (images have disappeared), I have a copy of his log and all of the associated images. Should you need images from his log, just let me know.
Jon
Wow, that is fantastic. Since I finished the hull planking and am starting the spar deck, anything you have subsequent to his last Conny post would be of interest.  I already uploaded everything that's there as of yesterday.
Thanks Jon.
19 hours ago, mtbediz said:
That is why I don't buy kits
Mustafa, if I had your level of expertise and experience, instead of being a newbie, I too would be building only from scratch. By the way he hasn't finished it, but cookster started a different build from scratch that you might want to have a look at.
When I responded to you, I checked Cookster's site and saw that there were a lot of images missing and those were the images I was referring to. You want the images for anything subsequent to his last relevant posting which was post #261 (Sep 8, 2014). I checked today to see what pictures were missing that you needed and to my surprise, the only images now missing, were on the first page of his log. If you want those, I can still send them to you. I don't have any more relevant images after his post #261 (Sep 8, 2014) which you stated you downloaded. Sorry for the misunderstanding.
Jon
Was not familiar with Cookster's build log, although I have been bookmarking other logs for when I get to my own Constitution build.  Will add his to all of yours, as well!  Lots of research and reading to do once I get to that point!
Gregg
Thanks for the follow up, but I've got everything of relevance to me already downloaded.  No need for the earlier stuff.
Best.
Peter
On 5/17/2024 at 10:32 AM, Der Alte Rentner said:
for the benefit of anyone following Hunt's directions for constructing hatch comings. On pages 19 and 20 in Chapter 4, Mr. Hunt provides detailed instructions for fabricating the material needed for the coamings.  Likewise on page 40 for the main hatch.  He glues up three pieces of stock for each coaming.  To boot, for the shorter coamings, because the kit didn't come with 3/32"x7/32" stock, he trims a piece of 3/32"x1/2" stock for the center piece.  All well and good.  But on page 26, where he shows the parts of the coaming in photo (P4.3.1-1), he says, "I made these pieces from a single piece of basswood with edge rabbets milled, but the principle is the same."  I think I'll go the milling route myself.  (I sure hope the zero clearance ring for my router table arrives soon. That will allow me to easily mill the material myself.)
(Quoting myself..)
I decided not to wait on the zero clearance rings for my router table.  As it turns out, they weren't needed.  Milling the hatch coamings was relatively easy using existing machinery - Delta Thickness sander, Wood Pecker router table, and Proxxon mini table saw.
1.  I had some scrap 1/4" basswood sheet and used my thickness drum sander to work that down to 5/32".
2.  Set up my router table with a bit height of 1/32".  Used my Incra fence to dial in the distances for the rabbets.  Easily done with this tool!  Once zeroed out to the sacrificial fence, I could set the fence to 1/16", 1/8" and 3/16" rabbet depths.
3.  Cut rabbets on both sides of the board. It was easier to do this with the board wide, as opposed to dimensioning the boards first, then cutting the rabbets.
4.  Marked the heights on the boards (old school method - ruler and pencil) and
5.  Cut to the line on the Proxxon table saw - the least easy tool to set up.  Because I couldn't get the precision I desired across multiple cuts, I
6.  Revisited the thickness drum sander to nail the coaming heights.  As narrow as these coamings are, they nevertheless stayed vertical on their way through the drum sander.  (sorry, no pictures of that machine here.)
      NOTE:  I removed material from the bottom of the strips, so as not to mess with the depths of the rabbets.
7. Fabricated two hatch coamings - the one forward of the foremast, and the one that abuts the bowsprit.
Note:  I found the business of making lap joints tedious and opted for miter joints instead.  Power tools were of no particular help in their construction, except the belt sander did make shaping the forward part of the bowsprit coaming easier to trim and shape.  Hobby miter box and saw were the tools du jour.
(I didn't bother marking all the dimension on this sketch.  The grid represent 1/32" squares.  The dimensions (after double checking) came from Bob Hunt's practicum.  Chapter 4.
Rather than start another entry for these two hatch coamings, I added the photo to this post.
typo corrected, and added two hatch coamings to post AND clarified process in steps 4, 6 and 7.
On 7/7/2023 at 4:32 PM, Der Alte Rentner said:
Before I continue with my build, I have a question for any of you who have build Conny from this kit.  The next step in the process is to glue the bulkheads onto the keel.  I noticed that the some (?) bulkhead components have yet another flaw.  See below:
I don't plan to install a gun deck, so the fact that the flaw is repeated in what would be the gundeck (lower) cutout may not be an issue.  However, when it'll get to be time to plank the spar deck, absent a fix now, the portside of the deck will be slightly lower than the starboard side.  I see two options.  One is also illustrated below, and the approach I am taking with bulkhead C.  It occurs to me that I could also slightly taper slots in the offending pieces to allow for a little wiggle room to align the bulkhead so the deck edges line up with the closest neighbors.  C would align with B and E, and so forth.
Sorry, the photos are out of sequence.  But I think third one (Bulkhead A) clearly illustrates the problem.
(I now see the advantage to making the bulkheads from scratch, but it's probably less work to fix the poorly laser-cut parts than dust off my scroll saw.202307-07USSConstitutionBuild03.thumb.jpg.c2516c393de930c3aaf0da24534b5212.jpg202307-07USSConstitutionBuild03.thumb.jpg.c2516c393de930c3aaf0da24534b5212.jpg)
Thoughts?  Advice?
You are not really on your own. It's just that I am somewhat confused by what you are trying to accomplish in the photos. Perhaps a more detailed description would work well with the photos.
Bill
On 5/10/2024 at 6:58 PM, Der Alte Rentner said:
While I'm experimenting with paints, stains, dies, and finishes, I finished the last task in Chapter 3 of the practicum.
That is a beautiful job planking the hull!!!  Well done!
Bill
Bill
I am struggling to find the right word to describe the asymmetry between the port side and starboard side curves for the deck on the bulkheads. Camber?
I had to shim up a couple of bulkheads so that there wouldn't be peaks or valleys when it came time to plank the deck.  Checking the photo from above in post 170, I can see that the worst offenders were bulkheads D and P.  Those needed to be to shimmed up on the port side of both.  For bulkheads A and C, It seems that I trimmed the Starboard sides.  I believe I laid planks on top of the bulkheads to find the high and low spots and/or asymmetry before trimming or adding to these four bulkheads.
Hope that helps.
After a week's downtime, due in part to a pit bull attack, and exacerbated by a power failure that took my shipyard off line, I returned to work this morning and knocked off the galley stack hatch.  (Chapter 4.3.4, if you're following along with the Hunt practicum.)
As with the previous hatches, I found it easier to work with mitered corners than the lap joinery Hunt used.  I realized after I was finished that I didn't need to produce another coaming piece.  I could simply have used the same material I used to make the basic box, and filled the space under the planks on the stack side of the coaming with a slightly smaller filler block.  Oh well..  I like the idea of the filler block because it made easy work of planking the stack end of the hatch.  I just applied glue to five sides of the block and shoved it into the opening from the bottom.
My router table was still setup from fabricating the strips I made for the two forward hatch coaming, so it took less than a minute to make the blank for the center piece.  For that 1/32" overlap, I used the Proxxon mill to cut out the notch.  Once the stack hatch coaming was assembled, I reduced the height of the stack side of the coaming by milling away 1/32".
I little trimming here, a little sanding there, and viola, galley stack hatch done.
202405-30USSConstitutionBuild20composit.thumb.jpg.9276eee101f6f694c65167587adb4cc4.jpg
Cutting the notch.
Gally Stack Hatch Coaming from the bottom.  Note the filler block below the coaming.
I realized afterwards that I used 5 planks (3.2mm each) instead of the 7 Hunt used.  Not worth it to me to correct that error.
added content, and corrected typo
6 hours ago, Geoff Matson said:
Hatches look great
Thanks Geoff.  I went to the shipyard this morning intending to start the main hatch.  After a quick peek at the practicum, I was ready, willing and able to take the easy route by not cutting up the pre-fab laser cut grate provided in the kit.  When I took a closer look at that large grate and how it would look in the coamings, I realized I probably should not have sanded the other grates smooth.  Furthermore, I it dawned on me that these grates had a top and bottom side.  Now that I know which side is up, I'll have to make sure I retain the detail in grate for the main hatch, which could be lost if I over sand.  Live and learn..
By the way, how goes the rigging?
and lastly,  I checked out your Armed Virginia Sloop in the Gallery.  Very nice!
