I started a Bluenose in the mid 2000s and was way over my head. Attempt number two began today.
Bulkhead K will have some internal character.
Howard Chapelle's "The American Fishing Schooners 1825-1935" (W. W. Norton & Company, New York, 1973, 690 pages) is an excellent reference for these fishing schooners. The 370 page "Notebook" at the back of the book has detailed drawings and descriptions of many details on these vessels.
Phil
Current build: USS Cape MSI-2
I remember this taking much longer the first time. It’s been so long I’m not really sure where I got to.
Now that I have a better understanding of fairing the hull this part may go better.
Fair a frame MS105 was good enough to square up the bulkheads. I built it to hold the hull. I got it a try for it’s intended purpose. Not my favorite tool, but it did the job.
 The book is on order. Thank you. I found it in hardcover.
I've got this one in the works too, still my first attempt even if I am 16 years into it.  I'll be following along with interest!  Looks like a nice solid start for you.
Bob
Current build -- MS Bluenose
Future build - MS Flying Fish
"A ship is safe in harbor, but that's not what ships are for." - William G. T. Shedd
Bob
So far so good!
This transom wood is hard for soft wood.
I’ve broken the bonds in the N and O formers. I completely broke off the rear keel at the weakest point. I’ve spent some good money on Dremel toys. I remember this being a bugger the first time.
I’m trying to not make a mess of this transom.
IMG_8607.thumb.jpeg.b0ebf6d97d6cd6e805d8e1b75833475f.jpegIMG_8608.thumb.jpeg.68c2b5d7cddd01f28723aff984f7dc91.jpegIMG_8609.thumb.jpeg.9aeea070dbe61052a4d40fe55025ff8e.jpeg
Edited by MajorChaos
A few dollars in Dremel tools bits and sanders and the transom looks good!
Much of the fairing of the hull is done. Taking my time. I’m in no rush.
The Bluenose transom is crazy hard for me to figure out. I think I’ve got it 95-97% what it should be. It flows nice. It seems to fit the next piece to go on top. It not clear what to plank it with. The notes seem to not say both parts of the stick size.
It does not say to cut a slot for part of the great beam in front of H. But it clearly has it be notched out. It might be on a note on the plans I have not found yet.
My kit is missing 3/32 x 1/8 sticks. I have 20 different sticks, the list is 21 items long. What a bit of fun to figure out what size everything is without dial calipers, ordered those and on the way.
I’ve  faired it well. I see more stuff to sand as I  study it. It should plank well.
The transom is very close to the picture of the Bluenose II. I’m thrill I got it to look like this.
I’ve stopped and studied the plans the instructions, pictures everything I could find.
I think I even understand where the fashion piece fits in.
Soon to learn how to cove. Then figure out the scuppers, and fake stanchions.
Soon I’ll be past the point I got stuck years ago.
There are certain things to be done in a different order. The great beam it shows last for stage 1. I don’t think that would work out. The water ways rest on the great beam.
The main rail on the aft section needs an aft boom sheet buffer fitted before installing. Or at least it looks a lot simpler to do it now.
I’ve cleaned up and fitted bulkhead stanchions until it looks like they fit and flow well.
I have convinced myself nothing will fit going up to the top rails, we shall see. I have no idea which wood to use for the main rail. There is some 1/16 inch thick 1/2 wide, looks like these would fit the curves every 6 inches.
I think I will start a few top side planks before the top rail, so the waist can be fitted nicely before gluing the top rail in place. This should allow fitting of fake stanchions also.
Model Expo still hasn’t shipped a small order made last Sunday for some 3/32 x 1/8 sticks and other stuff for the fore waterway. I bought what was missing so I didn’t have to wait until they got around to it.
By the time I figured out I used the wrong size waterways on the foredeck it was to late. They were well placed, nicely fitted and won’t be noticeable unless looked at by a boat expert.
This project is about where I was almost 20 years ago. I think the main rail is what I got stuck on.
The current goal was/is to plank the sides enough to get the waist installed, to get all the stanchions installed and the main rail on top of that.
As many of the instructions and guides state, I’m trying to make each plank a victory in itself. Hundreds more to follow. 😳
The Modena just won’t fall off…..
Just found your log and will pull up a chair and follow. You’re doing a great job, especially the transom. I wouldn’t worry about the number of stanchions, the ship will look just as nice. First builds are like school, every task is a learning experience so don’t beat yourself up (BN was my first build as well). I found Bob Herman’s log very helpful.
Current build: HMS Pegasus, English Pinnace (on hold)
Completed build: MS BluenoseSkippercraft
Great start, Major Chaos!  Looks really nice!  I've had a busy spring/summer, so haven't done much on my Bluenose for a while.  Am just back to it, painting the bulwarks, the hull and finishing the deck. Will be posting an update soon, but in the meantime, will be following yours, as well.  Carry on!
Gregg
Current Projects:                                                             Completed Projects:        Waiting for Shipyard Clearance:
Moving along. It’s turned out as good or better then I hoped so far. The waist looks good with some trial fits. I wanted to build up to a flat surface to make the main rail.
Thank you for the encouragement. The transoms has worked out so far, the tale will be the main rail fit. 🤞🏻@DBorgens @GGibson
When I worry about perfection I just look at the real ship planking I decide I’m doing ok.
The wood has different dimensions from piece to piece and from end to end on the same piece. Perfection is almost impossible.
I want to go visit some of the ships some day, my work is way to busy, it’s hard to take time off.
Slow and steady. I find if I don’t want to at the moment I shouldn’t. I make a mess if I’m not into it. After sanding the planks in place they fair nicely.
If your reading this trying to find answers to your questions, you were right, some of us are winging it and got it close lol. Reading ahead my not be enough to miss a detail.
I may have to call this the Bluenose 3. Others with a sharp eye will notice a few oddities. Who needs plans lol.
71452202184__4E2D2361-A09C-4036-B305-E13EA77C7911.thumb.jpeg.3c7aba57c763a19a30b8a4615c6564a6.jpeg
Lined up nicely, Major!  👍
Gregg
Planking the sides. Slow and steady. Cutting fitting sanding and trimming to make sure each piece fits and the rows stay stable.
A shot of the common tools I’m using. I’ve got sets and set sn of files but these diamond files 150 and 220 grit are the ones I grab the most. The riff files set I have is fantastic for all kinds of detail work. The jig and saw blades with handle are great for getting many pieces cut quickly and accurately.
I have to relearn patience constantly, I keep thinking about farther steps and other ships I have in boxes ready to build.
I wasn’t sure how it make the cove, so I skipped it. The waist doesn’t fit and finish like I hoped, all I can do is make it work.
Planking is going well. Nothing appears to be out of place.
Currently I do not know which metal pieces go where. Or what some of them even are.
I’ve no idea how to make the letters on the sides and transom.
I have not decided if I want to build deck pieces and plank around them, or plank the deck and build the stuff on top.
Something on top will need paint or stain soon ish, before I get the top/main rail in place. I’ve not worked out how I’m cutting out the mail rail parts yet.
One board at a time.
