I've been a bit slack in posting updates over the holidays, but the 'Duchess' has been quietly progressing in front of admiring holiday crowds at the museum. It always worries me that the unprotected model is very close to the public, unlike on the dedicated model makers' desk which was intentionally built wide, but I never have to worry about the kids touching the model - just (occasionally) their parents.
As you can see, the standing rigging is finally nearing completion (sans ratlines), with only a few more stays on the jigger and the mizzen spreaders to do. I'm now changing my focus to the sails and will hopefully play with the first sail - the flying jib - for a bit on Friday.
John
She's looking ever so much better, John. Is there anyway someone could video record the crowds interaction with you?
I have to agree with Keith that she in now looking pretty damn good John.
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
A major step forward (at least in my opinion). The 'Duchess is now boasting a sail!  Obviously a bit more work to do before this sail is complete on the model, but at least it's there! Only 33 more to go.
Concerning sails:
I broadly followed Tom Lauria's method with silkspan. I found the silkspan much easier to work with than I anticipated - it seems pretty strong and stable considering its structure. Having said that, I would highly recommend handling it carefully when it's wet (don't ask me how I know that); dry - it's great. I painted my silkspan with one coat of flow acrylic on one side and that seems to be sufficient - the paint soaking through the sail. I used a 'toy' iron as Tom demonstrated to iron down the linings and that worked very well - both sealing the dilute PVA glue and smoothing out the wrinkles at the same time. I had no issue with having a little too much glue on the seam. I tried furling a test sail in the workshop by spraying it with a fine mist of water and then coaxing it into folds; it worked well; hopefully the same will happen on the model.
Edit: In mentioning the delicacy of wet silkspan above, I should have clarified that I meant really wet - in this case the corner of a jib was soaked with glue and I was silly enough to try and fiddle with it.
John
Braver man than m e John, all that extra rigging to put in place (sail control/handling lines) :)  She's comiing along really nicely; I'll bet the museum staff are chuffed with it.
cheers
Pat
Pat: I usually show all the running rigging on my models that would be left aloft if the sails had only been taken down for a short time, so on the headsails I would rig the halliard and downhaul shackled together, but the sheets wouldn't be shows as they're taken below with the sail. I didn't really have much choice with this model as the museum wants her shown as she would have been as she was preparing to sail from Port Lincoln on her final voyage in 1936 - so the sails have to be rigged - staysails still furled and square sails "hanging in the gear" ready for setting.
Rick: The paint colour is called 'Soft Cloud', but that's obviously a brand name for it (Josonja Matte Flow Acrylic).  It's a pale grey to try and simulate the colour of worn canvas.
John
cheers
Pat
I once counted up all the buntlines on the 5-masted Preussen; I forget the total but it was huge enough to convince me to omit the sails and some associated rigging on my model.
Edited by Ian_Grant
Ian, the 'Duchess has (unusually) 5 buntlines on each square sail; 6 square sails per mast; 3 masts. If my arithmetic is correct, that makes a mere 90 buntlines in total! 😀
John
Beautiful work John,
I love that reconstruction of your 4 mast barque
Nils
Current builds
-Lightship Elbe 1
Completed
She's looking the goods John!
If memory serves, when I sailed on Bark Endeavour in 2015 the manual showed 100 lines in the running rigging. She's an older style rig with fewer sails and hands aloft to do everything so I can imagine in this rig with more sails and lines to do most of it from deck level she's going to keep you quite busy!
Been a couple of weeks, but I've been away at a conference for a week and last Monday I was working happily away when I accidentally (stupidly) cut straight through the jib stay, so most of the day was spent simply getting back to where things were when I came in! 🤢
Meanwhile, other work has been going on at home. Here is the foresail complete and rigged on its yard. It won't go onto the model for a while, but I plan on making and rigging all the square sails here at home and then taking them into the museum to fit on the model as required.
John
 The jib sails look great, John.
What Keith said. Looking ship shape John!
Keep it up!
Happy modelling!
Håkan
Previous builds
Kågen by Wintergreen
Regina by Wintergreen
Billing Boats Wasa
Gallery:
Nice work on the jibs John, she will be a great looking model when you finish your restoration.
cheers
Pat
Thanks for the encouragement one and all.
A small note on the jibs: for those planning to add sails and fixing the staysails to the stays with rope hanks, be careful when you lock the knots with a dab of glue. If you don't move the sails up and down the stays occasionally as the glue dries, the glue will also glue the hanks to the stays.  I can say this because of my vast intellect and my encyclopedic knowledge of model making (or was it because it didn't occur to me the first time and I suffered the consequences?). 🙂
John
