John,
Are you referring to the triangular light gray thing outboard of the cap rail close to Fred's elbow? I have puzzled over that also. It appears to be the corner of the venturi. The forward section of the venturi is bent inward like something had hit it, bending the outboard edge upward. I don't recall this happening. Because we got underway infrequently I can't imagine when this happened.
The ship had just had the venturis replaced when I first went aboard, so it wasn't old damage.
It wasn't a side light. Unlike every other ship I have seen, the Cape's side lights were tiny, like bicycle tail lights! Or like the wing tip lights on a small airplane. They were on the outboard side of the bridge bulwarks a bit below the cap rail.
Phil
Current build: USS Cape MSI-2
Phil, your eye for detail is plainly amazing.
Respectfully
Hi Phil, I believe John is talking about the device next to the pelorus inboard of the cap rail.
I assume there is a voice pipe to the engine room with a brass cap and perhaps a sort of telegraph with brass rotating angle?
Roel
Roel,
You have a good eye for detail! There is a rotary switch just aft of the pelorus on the bulkhead. A voice pipe - with a cap instead of a megaphone horn - is just aft of the switch. This went to the voice pipe on the navigator's desk, for use when taking bearings to objects to locate the ship's position.
We didn't have a voice pipe to the engine room. We could just open a door or two and shout - it was a small ship. Actually, we used sound powered phones and the Engine Order Telegraph.
I have looked through the blueprints (at least those I have digitized) and can't find reference to he switch. I'm sure it is listed somewhere in the several hundred pages of blueprints, but I don't know what it was for. It might have been added after the ship was built.
There were several changes from the initial construction, and some of these are apparent when comparing the Cape and the Cove. The blueprints show a 12 inch (30.5 cm) searchlight just aft of the voice tube, and there is one at that position on the Cove (and another on the port wing). But the Cape had both searchlights on the O2 level where they would be more effective. One of the things I am doing as I build the model is trying to verify that things actually were where the blueprints show them.
Edited by Dr PR
Phil
A very pleasant catch up Phil. I loved all the internal and external fittings "most of all the cup". I am amazed 13 years of accounts tallied exactly - shows an eye for detail as one might expect from your work.
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
Keith,
Thanks! Glad to see your Cangarda build underway again.
John,
The round thing is a weatherproof rotary switch. Only the top plate is round. The bottom part is octagonal - a standard US Navy switch box. And it all rests on a "D" shaped support. My guess is that it is a light switch. Minesweepers had a virtual Christmas tree of lights on the mast to signal all sorts of things from anchored, to sweeping moored mines (port and/or starboard), magnetic mine sweeps, acoustic mine sweeps, formation station, and such.
Phil
Phil!   I love all these operational details from a guy who's "been there".  It just really brings the model to life.  She's coming along beautifully!!
Steve
San Diego Ship Modelers Guild
This is a kit of parts for two bridge wing chairs like you can see in the photo in post #389. I have one more photo that shows a chair from the front. From these I photoguestimated the dimensions. The bases were cut from 0.030 inch (0.76 mm) brass sheet. The arm rests and back pieces are 0.032 x 0.032 inch (0.8 x 0.8 mm) square brass rod. The seat support pieces are 0.032 x 0.032 inch brass "L". The square rod and "L" were made by Special Shapes Company (stock numbers S-1 and A-1). Unfortunately the company is no longer in business making these small parts and I have found no other company that makes parts this small. I bought these pieces about 15 years ago when a local hardware store closed.
Here are the finished chair frames.
The assembly was pretty tricky. It took about five hours to solder together the eleven brass pieces for the first chair. Working with such small pieces can be difficult - several parts popped out of tweezers and were never seen again. Just finding a collection of repositionable clamps to hold the parts in place while soldering is an adventure in itself. Getting enough heat sinks in place to prevent the heat from the current solder joint from flowing the short distance to another joint and unsoldering it is a challenge! Some of these joints were soldered up to five times to get everything in the correct positions.
This is just good practice for the real challenges that will come when I start on all that complex minesweeping equipment on the stern. One thing I learned is that I need a lot more small heat sinks!
The seats will mount to the bridge bulwarks with the triangular supports under the seat. They will be painted grey and wooden cushions and arm rests will be added.
Edited by Dr PR
Phil
I spent some time wondering how chairs with 2 legs work but fortunately I figured it out before asking  and thereby exposing my stupidity. As you know I have some nice wooden chairs to make that I worry will be quite delicate. Brass ones seem to have their own challenges though. Nicely done. Following your prompt I did find some dollhouse chairs at 1:25 scale but none of the styles were an adequate match.
Edited by KeithAug
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
John,
I did screw up the first one. I soldered the upper parts on rotated 90 degrees from what they should be! Instead of facing forward it faced inboard!! It was a long day.
Not much more to report. I am working on parts for the peloruses. But I had to post some pictures for Keith showing how two-legged chairs work!
bridgewingchair1.jpg.f324712780508775af815eb2fc0a8bd3.jpgbridgewingchair3.jpg.07ee86d433f6739697271c3307857f70.jpg
Phil
They look the business!
Steve
Here are one assembled pelorus and parts for a second. The gyro repeater is already assembled from three pieces of concentric brass tubing from 0.186 to 0.250 inch (4.7 to 6.4 mm) diameter. The center piece is a 0.154 inch (3.9 mm) brass rod.
The other parts are made from brass tubing from 0.125 inch to 0.311 inch (3.2 to 7.9 mm) diameter and brass plate 0.030 inch (0.76 mm) thick.
The trick with any part like this with many pieces that are to be soldered together is to figure out a soldering sequence so that when adding another part an existing solder joint doesn't melt and let the thing fall apart. The gyro head was assembled separately, and then the stand was soldered together from the top down.
pelorus1.jpg.89c85b172e600ff1e1ecb19bf63846f5.jpgpelorus3.jpg.d69e48df709da07086397895239ca02b.jpg
It just needs a good brushing with a steel wire brush and a coat of paint. Grey, of course! Then I'll glue a compass rose into the top of the repeater.
Edited by Dr PR
Phil
I was looking at the photo in post #389 and realized that I had cut the opening in the outer shell more of a "V" shape, and it should have been a wider "U" shape. I modified both units a bit, but still perhaps not wide enough at the bottom of the cut.
I also realized I had forgotten to add the cable from the gyro repeater down into the base.
The repeater was glued into the shell with super glue, so I just had to soak it in acetone to separate the parts. Looks like I got the repeater in the right hand part a bit misaligned when I glued it into place. I don't know if I will fix it. After it is in place on the model it won't be as noticeable as in this close up photo. (Note: I did fix it so the parts are aligned correctly.)
pelorus.jpg.d9f830a802a05ce89fde4e58c66fc24c.jpgpelorusonbridgewing.jpg.ac71a5a94d833aa50419aa66da0f71d1.jpg
Edited by Dr PR
Phil
Yep - but how do you turn them round to see the explosions?
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
Keith,
The explosions behind you aren't your concern. You want to watch for things in front of you that might blow you out of the water!
Here are some more details. This time it is the life rings.
The life rings were 24 inch diameter, and that comes out to half an inch (12.7 mm) at 1:48 scale. I looked through all the materials I have on hand and I could cut them from some 3/8 inch thick boxwood, or from some basswood sheets. But cutting from wood created the distinct possibility that it would break along the grain during the shaping process. It would be easier to cut them from a half inch dowel, but I didn't have any in stock.  The only thing that diameter was some clear acrylic (Plexiglas) tubing. However, the walls weren't thick enough. But I did have some white styrene tubing that was a tight press fit into the acrylic and had an inside diameter a bit smaller (0.25 inch/6.35 mm) than the inside diameter of the life rings. Acrylic and styrene are easy to work, so I decided to use that combination.
liferings1.jpg.c807e2e5744d481e6bdcd95e3d46cd43.jpgliferings2.jpg.4b32eaf0cc999ebea4e19ab0671aaf2f.jpg
I sawed slices off the end of the concentric tubes and then filed/sanded them into the right thickness (0.073 inch/1.85 mm). I fit these rings over a 1/4 inch brass tube chucked into a drill and used files to round the outer edges. Then a combination of tools were used to round the inside edges and bring the opening up to the desired 0.275 inch/7 mm diameter. After they were painted orange I wrapped some carpet thread to make the ropes. Then three "J" hooks were made for each to attach them to the deck house sides.
liferings3.jpg.c42f2a23eaccd51e759473f24a1f1f6b.jpgliferings4.jpg.d3455aff973ff499f9491af0813f589b.jpg
The white cylinders beside the rings are light floats. When they are positioned with the flat base upward the lights are disabled. In the water the flat base is heavier (batteries) than the top so it floats with the conical light on top and the light is turned on. The light makes it easier to find the life ring in the dark.
deckhouseportside.jpg.b28d270f16751ef3e6d62aea680984e2.jpgdeckhousestbdside.jpg.9c1ba6ba16deae2aa5a24953656fc46c.jpg
I have added the pilot house doors and some other details. On the real ship the life rings were painted with "USS" in the top quadrant, "CAPE" on the bottom. "MSI" marked vertically on the left side and "TWO" vertically on the right. These letters would be only 0.010 to 0.015 inch (0.25 to 0.38 mm) high at 1:48 scale so I decided to not try to make them.
bridgewingport1.jpg.4dd85161b6862cd3de79bc12be4f1daa.jpgHere is a close up of the port bridge wing with the pilot house door, pelorus, life ring and ladder to the O2 level installed. This completes the open bridge and pilot house side details.
I guess the next work will be the venturis along the top of the bridge bulwarks and the port and starboard side lights. I still haven't decided how to make the venturis.
I might work on some other details on the aft end of the O1 level, including the funnel. I also need to add the life rails around the O2 level and on the after end of the O1 level. And there are the windows and awnings on the front of the bridge bulwarks. All of these will be very delicate and will be saved for the last work on the deck houses.
Here are a couple  more photos of the open bridge and pilot house.
bridgewingport2.jpg.3dc37fb793b7ac2a32c8fde1448c6e05.jpgbridgewingstbd1.jpg.f282b3e392ff2b93cb30b8ceb63c9594.jpg
Edited by Dr PR
Phil
Spendid and fine detailed work Phil,
L love your metalwork, a very fine model !!
Nils
Current builds
-Lightship Elbe 1
Completed
Ingenious and convincing Phil!
Steve
This has been fun to follow along.
One question. Life rings on my boat had a inner diameter big enough for a man to slip in to.  I've never see actual measurements for life rings (if indeed they are some what standard) but I think mine were more like 18 inches inner diameter and about 30 inches outer diameter.
Just curious,
Bill
Well , just did a little Google search which i should have done before and i see some life rings have a 13 inch inner diameter,  and a larger size have 23 inch. So there you go.
I guess the navy ones were for really small saliors (haha)
Bill
Thanks to everyone for the compliments.
Bill,
I wondered about the dimensions. The US Coast Guard uses 30 inch (762 mm) diameter rings with an 18 inch (457 mm) interior opening. We had 24 inch (610 mm) outside diameter life rings on the USS Oklahoma City CLG-5. The inside diameter was 13 inches (330 mm). It would be easier to squeeze into the larger life rings!
photoguestimation.jpg.df4f6787ad3942675ab0d4ad9b9d4fc2.jpgI used photoguestimation to determine the diameter of the life rings on the Cape as shown in this photo.
The port O1 level had air ports, a ladder and some life rails close to the life ring. The blueprints show how the ladders were made, with 12 inch (305 mm) spacing between the rungs. The top three pipes of the life rails were also spaced 12 inches (this was standard for the US Navy in the post WWII period). The air ports were 12 inches diameter.
This rather grainy Extachrome 400 side-on photo of the Cape shows all of these features, and it is clear the life rings were 24 inch diameter.
Just about any photo of a US Navy ship will show life rails, and these are a good "ruler" for measurement. You just have to be careful about perspective distortion in photos.
However, there really was no standard spacing for ladder rungs on US Navy ships. Often the blueprints show the position of the top ladder rung (about 6 inches/150 mm below the upper deck level) and bottom rung (about 12-15 inches/305-380 mm above the lower deck).  Then it shows some number of rungs between the top and bottom with "Equal" spacing. This usually came out between 11-13 inches (280-330 mm) between rungs. But the blueprints say all the vertical ladders on the Cape had 12 inch spacing between rungs.
Edited by Dr PR
Phil
