Hello Jeff,
Sorry, but it seems to me that the upper moulding strip coming from aft ends ABOVE the level of the caprail, and why did´nt you glue the caprail in the waist first? So you had to interrupt the run of the moulding strip....
Greetings
Werner
1 hour ago, wernerweiss said:
Hello Jeff,
Greetings
Werner
I had a look in the instructions.....yes, the caprails along the waist are not glued before the planking of the inner bulwarks is finished. Concerning the moulding strips I chose a different sequence and glued the moulding strips together with the channels, thus avoiding removing them where the channels are placed.
@wernerweiss
Hey! Thanks for the feedback!
I did check the instructions too, and it does specify to add the molding first next to the waist.  I did check the laser cut cap rails to see how far back they are cut to match up with the molding pieces.  The instructions say, to place the molding pieces correctly, place a 1/16" strip ontop of the waist and make sure the molding strip sits evenly with it.
I also checked the instruction photos and it also shows the molding strips sit slightly back, not up to the edge of the waist.
I think you have a good idea of adding the channels along with the molding strip to make sure it has a nice curve.  Also doing so won't make you cut out the molding strips where the channels will go.
I might do this with the other side, but i haven't decided yet.  I can be a little clumsy and if I have channels sticking out from the hull, I might accidentally knock them off! Haha!
Thanks for your input!
Jeff
Current Builds - USF ConfederacyCheerful
Generally, imo it is much too early for details like the moulding strips......I would rather FINISH the planking first - hull, inner bulwarks and the decks. Details like the moulding strips (together with the channels) come much later.......
@wernerweiss
Hello!
I wanted to let you know that I have not glued the cap rails on yet.  Gluing the cap rails is on page 118-119 in the instructions and I'm on page 42.
  I wanted to make sure that the molding strips would be at the correct placement, so I cut out a cap rail and a volute laser cut piece and test fitted them to the model. I also placed (not glued) the 1/16" strip ontop of the waist as well to check the lower molding strip.
This next pic shows the cap rail in place along with the waist piece.
This pic is where I have overlapped the volute piece over the top of the cap rail and ontop of the molding piece I glued on earlier.
It seems to line up with the molding very well!  I think I have the molding pieces glued into the correct position on the model.
On page 39 of the manual, it states that finishing the wales/molding/painting is optional at this point of the build if the builder wants a break from planking.  I sure wanted a break from planking! Haha!  So that's why I continued with the optional steps before continuing to plank the hull.
Thanks for your feedback!
Jeff
3 minutes ago, Zarkon said:
@wernerweiss
Thank you for your thoughts. I do appreciate the critiques, especially from someone who has finished The Confederacy!
By the way, you have a great build log of her and you did a fantastic job.  Your Confederacy is excellent.
Jeff
Thank you very much!
Hi Jeff,  I've been following your Confederacy build with great interest.  I too have the Confederacy kit in my stash and aspire to build her someday.  However, I'm in the same boat as you (pun intended).  I need to finish my current projects to improve my skills so I can do the model justice.  I've also got a clipper ship model on hold waiting for my skills to improve.
I'll be building some of my smaller, easier, kits with a plan to give them away to an interested kid at our upcoming model show in February.
In the meantime, I'll be following your Confederacy build with great interest.  She's a beautiful ship and you are doing an excellent job on her so far.
I hope you have a great new year 2025.
Wawona59
John
Current Project:
Wawona Lumber Schooner
@Wawona59 Hi John!
Thank you for following my build log!  I apologize for not replying sooner.  I caught pretty much everything since before Christmas and I'm finally starting to feel better.  Like you, I had my Confederacy kit sitting away for years before I felt mostly comfortable to start her.  It was fun just looking at the box with anticipation. Haha!
Thanks for following and I hope you and everyone have a great 2025!
Jeff
Happy 2025 everyone!
I finally felt better enough this week to make some progress.  I have completed the other side wales and decided to put the molding on like the other side. I already described how I complete the wales and molding in previous posts, so I'll just post some pics of both sides finished.
Oh, I have to note. I 3D printed a new holder for the ship while she is upside-down.  I made the design in Blender after measuring the ship and where I wanted the supports to go.
I made 4 support points.  Each connection joint is a different size so that the holder only fits in 1 way.  It took quite a while to print as each piece must be able to be printed within the size limitations of my 3D printer.
20250113_214326.thumb.jpg.e236b77f49b0f9275da240fa16aa620f.jpg20250113_214810.thumb.jpg.f5c4b850fa466a927dcb58042aca90cb.jpg
Whew! Finally those steps are completed!
I would like to start tree nailing,  but I'll wait until tomorrow to start.
Thanks!
Jeff
Hey all!
So I have decided to tree nail the hull from the wales upward. But only the hull section that's not painted black.
This is a pretty slow process and I'm trying to refine how im doing it.
Like the instructions say, I first started on the side with the exposed hull section.  I tried to line up the tree nails with the bulkheads as best I could.
Here are some pics of my process.
I first drill the holes.
I place a piece of tape down to match where the ribs are, then I place a square next to the tape to try and make sure it's straight.
I manually drill one column at a time until I have completed 3" of tree nails.
It's hard to see the drill holes unless I have lower light.
I then lightly sand the holes with 400 grit sandpaper just to clean up the tops from loose wood.   I don't have enough an awl, so instead, I took a T pin to each of the drilled holes lightly touching just to make sure the holes are round.  Afterwards, it looks like this.
Then comes the messy part. I fill in each hole with natural wood filler (the kind recommended in the instructions)
I then sanded it down to remove the excess.
I hope you can see some of it.  I have to sand more of the excess off.
Sometimes it's really hard to tell if I sanded enough,  so I have to take a very lightly damp cloth and rub the hull for the tree nails to appear.  I had to do that with the pic above, but i can tell it needs more sanding.  I do think it will look really nice once it's done.
This will be a very labor intensive timely process.  I will try to give update as to how its going in a few days.
Wish me luck!
Jeff
What show in February and where in WA? Like to be there... unless it interfere with my DF95 or IOM saiing
Respectfully
Hey all!
I know it's been a while. I got sick a few times since December. I swear I caught everything that was going around.
Anyway,  it's taken a long time to tree nail!  I'm almost done with the starboard side of her.  I am counting every tree nail I make, so if you guys want to guess how many tree nails it took me for the starboard side, be my guest!
I'll leave a few pics as to my progress.
20250216_203353.thumb.jpg.3a39919fd96479716f932375c23ad654.jpg20250213_221251.thumb.jpg.263601f5482dabc2e109dc9b967dc534.jpg
As you can see, I only have a small portion at the stern to finish.
I know it looks like a mess right now.  But I'll clean it up and stain/varnish this side before moving to the other side.  I will have to touch up the black painted whales a little bit too.
Anyway, this is a short update and I'll continue tree nailing!
Thanks for following along!
Jeff
Nice work on a tedious process Jeff.  I finished the Confed several years ago as a joint build, and am actually going to build her again later this year after I finish the Pegasus. Haven’t seen many logs of her recently, so it’s good to see a fresh build of one of my favorite kits.
Thanks Bug!
Like the instructions say, focusing on 3" segments really helps me get through this process.  I hope she will look better with these tree nails!  I also can see why this is one of your favorite kits.  It has been very fun so far and the instructions are excellent.
Ill check out your joint build log!  Also, if you decide to make a build log of her later this year, I would be interested in following along!
Jeff
Edited by Zarkon
Realized Bug creates a build log for the joint build
Hey all!
Finally finished tree nailing the hull!  That sure took a while to do.
It took a total of 6327 tree nails. Whew!  I completed this step by re-staining and varnishing the hull.
Now, this is the first time I've tried to both tree nail and varnish a hull.  I can see spots where I can clean it up and bit; but I learned quite a lot doing this.  Doing 3 inches at a time was key to not get overloaded with this step.
Here are the pics of the hull as she stands now.
You might have to zoom in to really see the tree nails.
I won't be tree nailing below the wales.
I might take a day or two off before starting to plank the hull.
Thanks all!
Jeff
Hey all!
Thank you for the likes!
Just a quick update. My entire family has been sick and we had to deal with a leak in our shower that was coming down upon our kitchen ceiling. Yuck. So not too much time for modeling unfortunately.
But I have a small update today.
I have started planking the hull below the wales.
Before I started, I read the instructions quite a few times.  It's a lot to take in at once.  @Chuck recommended in his instructions to read the book "Planking the Build-Up Ship Model" by Jim Roberts.
I ordered this book from Model Shipways and it didn't take too long to arrive.  This book, like what Chuck said, is highly detailed and is a great resource for planking.  I read through a few chapters and noticed that some pics in this book, are also in the instructions of the USF Confederacy!  Chuck's instructions does a good job summarizing what is in this book.  Which is a lot of information.
I did create the jig written in the instructions with the supplied laser cut curved batten.  Here is a pic of it after i bent 3 wood strips.  (Though I have already used 2 of then hah!)
It's definitely helpful for edge bending 3 strips at a time.
I was able to finish 1 row and started the next.  Here are some pics of my progress.
20250331_224218.thumb.jpg.aa2ce7ce62c74c1a4967c6d87cafa8cc.jpg20250331_224119.thumb.jpg.aaef74ebd6390474aba38662d45c0ded.jpg20250331_224124.thumb.jpg.eecb8bb398f6a626cbbb1fbdcb662046.jpg20250331_224149.thumb.jpg.f2097f43829bbe64c6f55c8c59fc984c.jpg
As you can see, it's just the beginning of the process.  I will start to make steady progress soon.  Once I complete 10 rows,  I will then start the other side's planking.
Thanks all!
Jeff
Hey all,
I've been able to get more planking done.  I am almost done with the first belt on the port side.  I believe it's looking pretty good so far.
This is how I place the plank on the bow.  First, after I use the jig to pre-edge bend the planks, I test fit it on the bow.  I have noticed with the basswood strips,  I don't really need to pre bend the planks in any another direction other than on the edge.  When I test fit the plano, I do bottome edge bevel so that it sits as flush as I can get it to the previous plank.
After test fitting, I darken one side edge and the end of the plank where it will butt against the next plank.  I make sure to not have both edges darkened. There are 2 reasons for that.  I don't want to make the edges too dark, and if there is a small gap between it and the previous plank after gluing, if you fill the small hole, it will look odd having the filler used surrounded by the black pencile lines.  If you only darken one edge, the filling looks like it's attached to the plank that does not have the darkened edge.  It looks a lot better.  I hope that makes sense.
When ready to glue, I first only glue the very tip of the plank.  I don't glue the plank to the thicker bulkhead yet.
After the glue dries (I use thin CA glue), I then glue the plank to the first bulkhead former.
I then added some glue to the next bulkhead but a super small amount to the previous plank edge (only add glue to the  space between bulkheads.  This helps me make sure that I can get the planks to stick to the previously place plank below it.
I then continue in this fashion, only gluing the plank to 1 bulkhead former at a time until it's all glued on.20250406_213416.thumb.jpg.ea3372ed4775b414d7897de0e04e6a08.jpg
The pic above shows I have a problem.  I wasn't able to glue the plank totally against the previous plank.  That was my fault.  To fix it, I mixed wood glue, some basswood shavings I sanded off the basswood strip I was using, and a few drops of water to make my own wood filler.
Here is the wood shavings next to the glue.  I mixed in a few drops of water to the wood and added a very little amount of the wood glue.  I then filled the small gap between the 2 planks.
After it dried, I lightly sand it with 220 grit sandpaper to even it out.
I continue in this fading to the stern.
For the stern, I overlap the stern plank with the plank next to it to give me room when I'm adjustmenting the stern edge of the plank.
I then marked the stern edge as well.
I then bent the plank to shape, especially at the stern edge as that has the most curve to it.  I then use a sharp hobby knife to cut along the diagonal line I marked.
I then test fit and modify the stern most edge of the plank to fit nicely against the lower counter.
Once satisfied, it cut and used my disk sander to slowly shorten the plank so it butts against the previous plank with a nice fit.
Once i am satisfied with the fit, I bevel the bottom edge to sit better against the plank under it, and darken one edge.
Like the bow plank, I glued it onto one bulkhead at all time until it's fully glued onto the hull.
This pic (above) shows how much CA glue I use when gluing to the lower counter.  It's not much honestly.
I then contiue the plank per bulkhead
So here are some pics as to how far along I am on planking so far.
Thank you for following along with me!
Jeff
@Ronald-V Thank you very much for the compliment!  You're right about it being harder to have one layer of planking instead of 2.  But I have to admit, I do like to do it this way a little better because I only have to plank the hull once haha!
I wanted to give an update.  I finally finished the 1st belt on the port side. As I was almost done, I realized the planks attached to the bow were not beveled enough edge wise.  It's not by much, but I noticed it. I also completed a light sanding too so I will have to come back later and finish the sanding.
Thanks all for following and for the likes!
Next up is completing the 1st belt on the starboard side.
Thanks all!
Jeff
Looking very good!
Respectfully
Jeff,
I am baffled by your precision of Confederacy. Looking good!
I have the same kit waiting for me, but not to be touched until I am done with others.
Respectfully
Hello Jeff,
looking at the moulding strips above the foremost gun port I am wondering why the run of the moulding strips does not match the run of the planks. Is that intended?
@wernerweiss After looking at it again, i do accidentally have the molding strip slightly lower than it should be at the bow from the foremost gunport forward.  Thanks for noticing.  I'll see if I can fix it later!
I have finally finished the port side second planking belt.  This sure took me a while!  This was the first time I have ever created stealers (all at the stern).  Please let me know what you think!  I think i did ok, but I did learn a lot doing this side, so the starboard side should be even better!
I do need to complete some more sanding on these planks, and see if I need to make some filler with some sawdust, but I'll do this once the final belt is planked.
Its fun seeing how the curve starting at the bow/keel evolves as it move up the ship.  The same with the stern.
The only thing I'm not super happy with, is the different shades of the strips.  I tried to separate them by shade, but there was quite a range of shades unfortunately.
The wider strips I used for the garboard plank is a lot lighter in color than the normal planking strips. All of the wider 3/16" planks were a lot lighter in color.  Because of this, I tended to have quite the color contrast between some planks.  I wonder if lightly staining the planks (a lighter color than the planking above the wales) would help?  Or should I just varnish the lower hull?  I don't know yet.  What I do know, is I don't want to paint the hull planking.  I just like the natrual unpainted wood look better.
Thanks all for reading!
Jeff
Fine looking stealers 👌
Personally I never really cared about color difference, because it gives a bit more life in my opinion. But some people like to make it as flat and perfect as possible, it's a matter of taste. I like to see individual planks, as long as it's not too much of a contrast, but that doesn't seem to be the case with you. Plus you have to take into account that e.g. staining as you did the top, connects the planks with each other in terms of color
