What it is that provides motivation for me,  when building a model, such as a wooden boat, is taking on a bit more than I am skilled to do, then applying those newly learned skills to my project.
There are so many more steps involved when building a model boat made from wood.
Much like any new skill, it must be mastered though conscience effort,  ( Visual Thinking ) to include all the steps applied for that particular application learned. NO SHORT CUTS!
Hence the challenge and reward of accomplishing your vision of the completed project!
You show me instructions on how to assemble an IKEA cabinet and bam! It's done!
Open the plans to build a model ship, and you unfold the plans of History, Research and Skills to be learned.
Hopefully  I'll learn the rhythm and artful soul of this hobby!
With a few other tool boxes and tools not shown, all recently purchased is a product of a  commitment to build.
There is nothing like falling short of the proper tool to ease the pain, or apply it if you miss!
This is the start of my Amati kit, Lady Nelson.
As I view the pages here on MSW, there is incredible talent. All well deserved for putting in the time to do it correctly!
So right now, I feel like a retarded Moose in the woods,  getting my antlers hung up on all the branches of my build!
Its one step at a time ,from here on in!
*So my first lesson learned!  As I hear the term BLUFF BOW, especially with a model of this size, ( Quite small), It would have been helpful to fill the forward spaces between the formers with hard
Balsa wood, to assist forming the shape of the Bow as the formers are tapered. That would just give such a positive picture of the visual line the planks will run.
The stern on this little ship is pretty sexy as well and those filler blocks would ease the stress of shaping the strakes in that location.
But with the help of the You Tube video , by Tom Grigat (A time lapse construction build in Motion) and the book by Donald Dressel, Planking Techniques for Model Ship Builders,  I can picture how, the correct way to lay the planks will help overcome the Bull and Plow method we might be prone to use!  LIKE,  All clamps on DECK! Get out the entourage of nails ,rubber bands and anything sticky!
My gosh, I've see how skill, puts this one to sleep with ease!
I see this now, but hadn't read the concept until after the completion of a few steps as shown.
*I found my formers to be down right loose!  So I came up with using 90 degree hard balsa supports to assure they would be square to the backbone.
* I found the hull attachment to the display base, rather vague, but knew I had to formulate something before the planking goes on the hull,  as I want to use the supplied brass pedestals.
The keel is 1/8th inch thick, like walking on THIN ICE!
*So this is how I did it!....I used my V-Drill Guide. LIKE A MINI DRILL PRESS. Blocked a true 90 degrees placed block of wood, clamped next to the keel.
Since the smallest hole on this tool is 1/8th, I needed to drill a hole 3/32, for a brass tubing sleeve I would glue inside the keel.
So I sleeved the hole of the tool with a 1/8th length of brass tube. That gave me the 3/32nd diameter I needed to drill the keel.
The ID of the 3/32nd brass tube is 1/16th.  Perfect for my plan.
Why, because I will use a short length of piano wire glued into the base when completed as the alignment pin to slide into the glued in keel tubing.
So not shown,  are the brass pedestals in-between the display base and the hull,
I would like to sleeve to 1/16th,  the interior of those bases which are 5/32. That way,  the pedestal will not float around and will slide over the 1/16th wire.
Then the Hull will come to rest on the Pedestal and can be lifted off if needed.
Edited by flyenrw
corrected log title
Thanks Chris, Its a journey, that's for sure!
I had a look at your kit and build postings and it looks like you'll have your hands full for a while!
The ship really has nice lines. Looking forward to your progress.
I've been flying RC aircraft and Helicopters since dinosaurs walked the earth! That's when you actually built what you flew, unlike this day and age, you have Foam and ARF's to get you in the air!
Most of the builders are seasoned and scale competitive flyer's to compete in the Florida event called Top Gun.
I think subliminally, I really yearned to build again!, and all compasses pointed to Ships.
So with building in mind, I thought
I would detail the method I used to mount my Hull to it's display board.
Before I drilled the pilot hole for the 3/32 brass tube glued into the Hull, I shored up the outside edges of the keel former left and right sides with a 3 ply, 1/32nd birch plywood and CA glued the ply to the former.  This MDF material that mfg.'s have come to use,  is as a frail as cotton candy!  So the ply really gives that overkill support I like, for the next time I bump into my model.
I measured the ID of the Pedestals to be 5/32.  Too sloppy to fit over 1/16 piano wire so I built up the interior with a very snug Nylon tube about the same size OD, cut to a length of 5/8.
Pushed it inside from the bottom of the pedestal and then drilled out the center of the tube to 3/32 so to fit the brass tube that will inset into the center of the pedestal.
That way,DSC02473.thumb.JPG.c44c294ee31fa320d65f66f6801a2e29.JPG the pedestal will always be centered to the 1/16th wire.
Edited by flyenrw
Remove duplicate picture
As I was perusing the instruction sheet for this build I noted the single attached block for the main sheet on the transom Knee.
The first thing that went though my mind was, that in the full scale, I just couldn't fathom how a single eye bolt  would work out with the forces of a 52 ft Cutter.
In real life, I've sailed boats to 70 ft and took for granted the equipment used on those boats as what was needed to do the job.
So , as earlier mentioned, I really no nothing about sailing ships from this period in time.
I have found little in the way of hardware detail for ships of this period and specifically  Cutters.
In my recent search for how to plank my model, I've been gathering as much info as I can eat!
Having found and purchased items from SYREN Ship Model Company, I noticed Mr. Chuck Passaro's preliminary build,  here on MSW.  I then took a close look at his English Revenue Cutter, Cheerful 1806.
In doing so,  I noticed right away the rigging was much more stout and realistic, as it turns out, the model was designed from Original Ship Plans!
Stretched between the middle two transom knees was a simple traveler bar and given the size of this ship made more sense for strength in the real world.
So I thought, simple enough, I'll make one of those!
Here is how I created the traveler........using a .032 piece of piano wire, I cut it to the width used and left about 3/16th leg either side, to mount the traveler to the center two knees, after the ends were bent to 90 degrees.
To create a base plate, I soldered one ea. , 00-90 size washer to the legs. Gave them a quick wire brush polish with my dremel, then put some black magic marker to the surface for a temporary impression of the finished color. when it's ready to be fastened, I'll strip the marker color and properly prime and paint the metal.
It's small, but I like the extra rigging detail the traveler adds.
If anyone might share their view, I still would like to know if the single eye bolt mainsheet attachment is realistic , or the liberty of model design!
Here are a couple more pictures with the build.
I had intended to replace the tiller with a design I will fabricate. The last photo shows the top of the rudder post interfering with the traveler. I will be reducing the height of this by approximately 1/4".
It looked to stand proud and at attention!
The one thing I noticed with tiller boats,  is the point of attachment of the tiller was much lower on the stem of the rudder.  The configuration in the kit to me, with so much of the rudder post coming thru the transom, looks out of scale, especially the donut of wood to attach the model's tiller.  Just my thoughts!
Edited by flyenrw
When I hear someone comment,  ( Well I'm board ), I can't help but think of all the things I've learned when building my Lady Nelson.
Honestly, I had not heard the terms, WORM, PARCEL or SERVE a line, until involving myself in this new venture of building model ships.
Now, my eye is drawn to the detail of what is being viewed with insight,  when admiring these scale Ships.
So, I did some research while avoiding my next build step of planking the deck and hull, sort of circumnavigating the earth instead of my project!
I found this serving machine at SYREN,  Ship Model Company.
To see the finished product, built in the 1/4" Cherry wood, was a done deal for me.  OH and the embossed Mermaid, nice touch, that makes it officially nautical!
This product is solidly built, with simple features that will ( SERVE ) the test of time!  Sorry,  Had to do it!
I look forward to creating the rope detail that this little machine will assist in making for my Lady Nelson.
When building the kit, I used Gorilla Wood Glue, wiping off the over squeeze glue with a damp rag. The sanding was done with 220 sandpaper as my go to cut down and to prep the wood of glue spill, with a finish paper of 320 grit.
I had a can of MINWAX,  Water Based, POLYCRYLIC Clear Satin, having applied 3 coats between drying.
With all the Humidity  here in Florida, as every day has been rain, this product was perfect!   There was no trouble in it drying and the finish was free off the dreaded milky capture of water from spraying in humid air, all in my HOT Garage, I'm sure helped a lot!
I felt 3 coats was ample coverage to keep the wood looking clean, providing a solid base for a very light sanding with 320 grit paper,  that would remove paint, not wood and provide ease of maintenance with the last coat.
I added the 11/16th length of black colored nylon tubing," I happened to have in my stuff ", for just a little more body captured by the nails,  used for raping the line.
Without a gun to my head,  this build took one week.....a little here and a little there!,  with the final assembly this morning!
Well, it goes without saying, I've got a few more grey hairs, Lucky for me, they all blend in!
This was truly a learning experience!  I would image it to be similar to experiencing G-forces in Centrifuge astronaut training!
I learned a lot!  WHAT NOT TO DO!
BUT ! Many errors in my ways for this first step planking,  cannot be used on the outside skin, yet to be applied.
Another learning curve ahead.
I thought I knew a little bit when I started after reading various methods of the process, and then I  found the cocky street kid in this kit, that kicked my butt!
 ( My humble thoughts ),
The week link in this build, Leaves construction steps for a little more experienced builder without noting a process or an alert to a particular step.
By no means , no regret, I like this little ship far too much!
I'm getting thru this build, but I wouldn't call this a first time build kit, because there are Far Too many rocks to turn over.
Argh, fifty lashes for this builder.....it hurt so good.
I decided to try my my hand at yet,  another mind bender and replace the strip deck  with a Four Butt Shift .
What really prompted the decision was that the kit material was of pretty poor quality.
The supplied planks are twisted every which way and the edges are fuzzy!
I felt it was too small a scale wood to deal with trying to clean them up, let alone pencil the edges for simulated calking, they would have ended up looking more like leaves had been stuffed between the planks.
So, I purchased some wood from SYREN Ship Model Company and look forward to a nice clean finish to start the deck.
That's going to give me more time to learn more about properly attaching the out layer of finish planks.
ship builder
Edited by flyenrw
duplicates picture
I felt it was a turn of the tide to see the second planking started and honestly looked forward to how that will end up looking, I'm hopeful!
As earlier mentioned, I ordered some Pear Wood from Syren Ship Model Company to replace the deck material supplied and received notification today that it had been shipped.
So I wanted to finish the upper Bulwark before starting the decking.
I covered the transom second wood planking and the outside starboard Bulwark today.
I have been building and flying RC model aircraft since dinosaurs walked the earth and CA glue has been my Go to adhesive.
It's like fast food, for building.
Had I used any other glue, I would not have been able to accomplish what I did today.
I like it because, when I have a thought, as to what I hope to accomplish when I sit at my bench, I want to Make it so, as Captain
Pilchard would say!
I’ll pull up a chair and hang around if you don’t mind. I have been appreciating the fact that you have dove right in to the work. The first layer of planking is looking good, and I’ll be interested to see how the pear turns out for your decking. What motivated you to choose pear?
Johnathon
Current Build: Lady Nelson
Completed Build: NRG Half-Hull Planking Project
Well, my plans got redirected ,  as I thought to do the decking before the hull planking, but the natives got restless!
I just simply screwed up with my choice of Pearwood ordered for the decking material , thinking it was a much different color than what I received. It was very Red Brown! Not what I wanted!
So I chose and ordered some cherry wood and in the mean time, so not to waist time, I continued on with the hull planking.
It was like forcing me to take my medicine!
BUT, I'm getting thru it while waiting for Hurricane Helene to pass by later this evening. you can now hear the wind ripping up, outside! Definitely getting stronger!
Fortunately for us, it's far enough away, we'll only have gusty conditions, like 50-70 mph winds and lots of rain.
The waterfront conditions are already showing the flooding with projected storm surge for our area of 5-8 feet.
We are not too far from the Manatee River,  which will take on the surge and Flood certain inland tributaries near by. Definitely a sit and wait situation!
So make it so, as Capt. Picard would say!
I wanted to see the transom finished, for the hull to start taking shape,  so I completed that feature.
Obviously after the planking is finished, I can add the Wales and wood in-between the gun ports and au sundry details.
Soon to start the decking!
Pictured are the tools and methods of bending the planking I decided to use, as shown below in the photos.
Bending the planking in a Lateral method as illustrated in Chuck Passaro's here on MSW and videos was a no brainer for me to choose to use. It proves to be faultless and without a doubt, the best WAY TO GO!
Still,  viewing , measuring and lots of patience is the secrete sauce for planking!
I figure , I'm about half way there to the finish line.
i goffed up and really thought the Pear wood
That looks like a very neat planking!
Regards,
Dan
Hi Dan and Thanks for the encouragement,  as it is too easy,  to find fault in our own work !
I also give thanks to all who have marked a Thumbs up to segments of my build. That is appreciated very much!
It's the overall view that we all typically strive for and perceive first and if that's a home run, great!
This is my first model ship and considering the complex nature of a ship build no matter the size, I'm happy with my progress so far.
But sometime the inexperience eye doesn't see the entire picture with enough detail, to place stop signs in the build process.
I will reiterate my thoughts , that as simple a kit this may be, all construction details are not covered well!
With that approach, it makes this kit a more Mid Level build than an First model inexperienced build. Just my humble opinion!
As any ship sits in the water, it's displacement determines it's natural water line. Even a free standing bath tub represents this if placed on water!
To place a cargo hold in an incorrect location, the ship will list.
Something visual has bothered my eye of this model finished from the many builds I have admired so far.
I came to realize it was the various locations and placement of the water line and how it effected the overall shape and the outline of this ship!
This is so easy to do as we utilize the plans and parts provided for the build.  To best of our knowledge,  all details are properly provided in the instructions!
Here is my point!
The plans clearly show on  ( Sheet 3 of 5 ), a Starboard profile of the Lady Nelson indicating a water line, low in the stern and the bow proud of the water.
Well guess what, I didn't notice this important detail until just now,  several weeks into my build,  as I near the end of the second layer of planking.
The kit provides two brass pedestals as shown in my photos, that are exactly the same measurements. This places the Keel basically horizontal!
If an artist where to paint a picture of a field with a Horizon and that Horizon were tilted down left or lifted up right  , your eye would pic up the down hill or up hill direction as not being horizontal!
This creative  angular direction is done with intent to carry or place ones sight to view another feature of the painting!
So here's the rub, if one chooses to paint the waterline as the plans indicate it to be,  then mount the ship on the pedestals,  the bow of the ship will be perceived as pointing down by 3/8" and the stern rising high respectively!
The only way to overcome this illusion is to improperly paint the waterline, when the ship sits in the cradle horizontally or provided brass pedestals.
Technically, one pedestal for the bow should be 3/8" higher! As per plan profile Illustration.
So in my build I have finished drilling holes and securely mounted brass tubing perfectly perpendicular for even height pedestals. Things that make you go HUMMM!
I have devised a plan to bend the bow mounting wire I'll be using to offset the angular discrepancy,  as I raise the bow pedestal with a collection of washers to the height needed.
This really was a fortunate find for me, before doing all the hull waterline painting.
Possibly I'll be able to find a pedestal that is 1 3/8" tall for the Bow to be placed in the correct position.
I hope this helps others with a decision how to address this dichotomy.
  As I recall of the Fair American, the bottom of the keel at the stern is definitely lower than at the bow, so whatever stand or mounting is used has to take this keel 'drop' into account.
I see your point. I don't know yet how I will solve it. Putting the model on its stand with a tilted waterline might look odd. I saw many models of cutters painted up to the wales, but I would like to avoid this a leave a bit of planking exposed. The other possibility, would be cheating and painting the waterline parallel to the keel. 🙃
Regards,
Dan
If I recall these pedestals come in different heights.  I can see 35mm, 29mm and 26mm on sale in the UK.  Although the last is narrower than the first 2.   Would the 6mm difference in the first two work for your build?
Cheers
Craig
Current Build
HMS Indefatigable
Erycina - Vanguard Models
Finished: HM Bomb Vessel Granado - Caldercraft, HMS Pegasus - Victory models, Nisha - Vanguard Models
Dan Looking good, if to pick up a ( fine ) diamond file 90 degrees or flat, you'll be able to square up the corners to your liking.    Have a look at Tamiya!             Yeah that transom is enigmatic , took a lot of pondering to get what was needed to finish it.                                                             I was relieved when I came across Amati 51 mm wooden, (walnut) pedestals. I ordered them  and they have shipped from Cornwell Model Boats. Being that they are wood, I can cut one smaller for the stern and adjust as needed.            Dan, You're so right,  how awkward the waterline turns out when the keel is horizontal to its display base. That feature is just totally disregarded by Amati, when supplying two equidistant pedestals or the cradle that also displays the keel parallel to the base. Shame!, but we conquer and overcome!
Another fine cutter joining the MSW fleet. I will be following along. 🍿
Andrew
Completed (Kits):-
Really fast delivery over the Pond from the UK to Florida in just a week, put a big smile on my face considering the wrath of Hurricane Milton, just around the corner!
I ordered ( 2 ) ,  51 mm wooden  pedestals by Amati,  from Cornwall Model Boats,  to alleviate the discrepancy created in the Waterline by a parallel support using same height pedestals and the provided cradle.
Again, looking at SHEET 3 of 5 in the Amati plans clearly shows the keel at an upward angle, from left,  to rising to the right.
That resting angle,  is negated on even height pedestals or the provided cradle.
My intensions are,  to cut the angle into the two wooden pedestals, so that the waterline is properly placed across the Hull.
" A Beginners error" , having been working on my project and being distracted with impending Hurricane, errands and a slip and fall where my wife ended up in the Emergency Room with a broken nose,
right wrist and a list of other damage, I just didn't pay attention to the limited thickness the Hull planking is.
I saw a curve I wanted to create and went at it too vigorously, only to enter the inside of the hull.  I felt like  Urkel, " Did I do that!  Yup!
Well fortunately for me it is in the bottom paint zone and won't be seen!
I enlarged the hole, and  with walnut planking used, filled  the opening with the wood glued in place with thick CA.
Using  ZAP Finishing Resin and Top Flight  Micro balloons Filler , I made a past that I spread thin with a cur Baseball card as a Squeegee.
When hardened,  I very carefully sanded it with 320 grit sandpaper and have coated the area with MINWAX Clear matte,  Polycrylic which I am using to finish all the wood Hull.
With a couple more planks to go, I'll be finished the hull planking.
The two wood Pedestals are shown in the picture, with the material finishing products I am using.
Gotta go for now and help my Son button down his house windows for Hurricane Milton just around the corner!DSC02559.thumb.JPG.c381ae6f656e58809caad9075b8ff420.JPG.
So , I got to work! chopped off the tops of these wooden pedestals just received and adjusted the heights accordingly.
There is 1/8th rise between the height of each pedestal from the rear to the front.
The finished height of the rear pedestal with a 1/4" capture of the keel,  is 1 3/8".
The finished height of the front pedestal with a 1/4" capture of the keel, is 1 1/2".
'To view the picture of the metal ruler resting in the slots of the adjusted height pedestals, there is a noticeable incline , even if only  just 1/8th inch.
At this scale,  that works out to 8 inches. In full scale, I believe that would really stand out, like a stop sign!
So now I look forward to finishing the hull planking and sealing the wood on the hull.
One and one half months later the real sense of what I have been building is actually on it's way to looking like a Ship!
To have told me then, when starting,..... I couldn't see this far into the project, as all I had,  was motivation to guide me here.
All the great assistance to those on MSW thru articles,  accounts of construction projects, techniques and conversations have been invaluable. A terrific forum to have come across!
The hull planking is complete,...... good thing for bottom paint to hide my errors!
Next is the decking.
Bringing out additional details, I applied the Wales to the Ship sides. Using the kit supplied 1 X 3 mm Walnut wood, I ran into trouble with it breaking!  Well, a couple times you could hear the Pittsburg Steal Mill Whistle Blowing, as the wood fractured and in some cases Broke in two!  Very brittle wood, even having been soaked before bending. Thank goodness for extra thin CA!
Much to my surprise, the wood took a lateral bend with less trouble, but when it came to a natural curve....snap, crackle, pop!
My advise, be very careful, patient, and be sure the wood is well moistened!
To have it sit well, use a gig to bend it laterally with heat and it's natural curve into the BOW.
I found that the kit supplied Mahogany wood trim, for the brass filigree used at the stern and placed against the transom, to be too thick and overhanging the turn of the bilge,  causing it to break as it cracked upon attempt to bend it to shape of the hull.
The turn of the hull becomes notable at the stern, leaving a large enough gap to prevent the wood from taking shape.
My remedy, was to slightly re- design the abutting transom side detail.
I used left over, 1 X 4mm hull planking walnut, just wide enough to capture the brass filigree.
Also a subtle design change to the stern Wale, as the curve under the hull produced an awkward lay of the wood. The 1 X 4mm Walnut, worked out , without issue, at all!
I must have miss sharpened the curve too much, trying to achieve a graceful curve. For me, one area of the hull shape I struggled with in the initial build!
I am happy I was able to save my wood for the Wales,  after three fractures and two breaks!
Well, I finally got there and the decking is done! Hu Raah!
It was a lot easier to do than I had put in my mind it would become, partly because I was really thinking beyond simplicity and overwhelming my first time project with possible detail.
I just decided I wouldn't do it.
At this scale, Just too small to fuss with, besides, I feel,  there'll be plenty of eye candy when all is said and done and my skill level just isn't there yet!
I have been thinking to add a weathered look to the deck of my Lady. DSC02585.thumb.JPG.cbf3a091bec2689214221f8830aed5da.JPGand used DR. Bens Weathering stain, to achieve the look pictured.
Basically one and one half coats. It is a water based stain WASH not a stain!
The color I used is called AGED DRIFTWOOD. I'm going to seal this final finish with a Matt Finish KRYLON rattle can spray paint, found in the art stores, like Hobby Lobby.
 Dr. Ben's  is a product You'll find Model Railroader's use in the Diorama, to include buildings, barns, signs and fence about the track layout.
Pretty easy to control the effects! I used a very fine camel hair 1" paint brush to apply it.
If I felt too much was applied, I simply wiped it off, or applied it again, for the look I was going for and did a lot of control of color depth with a water dampened cloth and re- application if wanted.
For a first time use, I'm very pleased with the product and for the look I had hoped to achieve.
By the time I finish the deck furniture, rugs carpet, place matts and lighting :  ) Oh and the cannons! I look forward to it's variation and completed decking effect.
Edited by flyenrw
That's the look of bleached deck! Very well done.
Dan
Well' its mid day here in Florida and I just sprayed the deck with a Non-yellowing, Krylon Brand,  Matt Finish.
Having used this product before, I like that it does not change the color or raw finish in any way! Dries in minutes!
Todays picture is outside, under natural daylight, rather than incandescent and LED influence that I have in my office as earlier posted..
Even in the light of day, color is influenced, but I wanted to share what my eye sees outside in natural light.
Computer monitor screens and settings will have a little less influence on what is perceived as the real way this wash has turned out.
Thanks to all who have given their thumbs up and positive feedback, it is so much appreciated, while experimenting on new skills!
Best Regards, Roger
Great looking deck Roger, enjoying following yours and Dan’s Lady Nelson’s, almost a dual build going on!
Andrew
Completed (Kits):-
Good day, y'all....just wanting to bring attention to a problem with the bowsprit brackets and breast hook of the Lady. The in board end of the bowsprit mounts to posts with a sq. wood pin thru the bowsprit into the  support brackets. These brackets are too long and out of scale and the hole too high. This forces the bowsprit to point downwards rather than with a subtle few degree incline. Adjustments are needed before this part of the build is completed....more to follow!
Edited by flyenrw
So, the first picture shows how high the bowsprit support post is to the Bulwark: but in addition to this is the square hole for a Square dowel to be inserted.
If to use these stock part dimensions, the last picture is the result with the height pointing the bowsprit down.
Now , I did file the recessed groove next to the bow stem, for the bowsprit, intentionally deeper than the MFG laser cut slot which exacerbates this bowsprit angle downward!
I felt the bowsprit looked like it sat on top of the rail, like a TOP HAT!, so I made it deeper and had even considered deep enough to cover it with a re-mastered Breast Hook, that has to be made as the tapering to the breast hook received in the kit is much sharper than the Bluff Bow formed.  My fault possible?, but I followed the bending to the T. So I believe it to be another error.
I haven't done my mod yet, but I will share what I plan to do as I work it all out.
Since this will be a painted piece on deck, it won't matter that Frankenstein lives underneath the paint.
It will be like Bondo fixing a dented car!
I am going to cut the posts, to align the holes with the proper angle to the bowsprit resting on the horizontal bracket that lies underneath.
The pre-cut notches in the up-right posts, will be filled with wood and sanded smooth to surface heights and the new notches will be cut further down.
Since the Square hole does not match any wood in the kit, I'll work my magic to fabricate a piece to fit.
In my opinion,  this area of assembly is a necessary total redo.
Will post these changes as soon as they have been made.
Edited by flyenrw
