I scribed the waterline using the tool from Vanguard which works very well.  You may also noticed I also added the upper strake. Although not called for I painted it black so it would be more noticeable. IMG_9706.thumb.jpg.051ba5fb82364510ee9ce60ff17d2f3a.jpgIMG_9710.thumb.jpg.7aa1274648eb6eed2b3ef1b503d68fd5.jpgIMG_9708.thumb.jpg.6b331a89ecc76babab7d33a35b59d595.jpg
Following that, I taped the . After a few adjustments it looked even and the distance from the ports to the line the same on both sides.
IMG_9711.thumb.jpg.bc35c6caeaffa35d02c935e8d71582eb.jpgIMG_9712.thumb.jpg.998d02a22b0139ac0c0e6433abc0ee39.jpgIMG_9713.thumb.jpg.89bd6fcecdf33aad436fb41762b1e5b4.jpg
The a the fun began . I also painted the area in copper paint to minimize any small openings from standing out.
IMG_9721.thumb.jpg.002e39e82b603be916994b7e5eeb1818.jpgIMG_9720.thumb.jpg.db7c454b78a5328f51dda5b8ad32c3d0.jpgIMG_9718.thumb.jpg.8f324634383fba867761bcc14e5f3139.jpgIMG_9719.thumb.jpg.640c25fa2d448831dd26f29eb4d3035d.jpg
The rudder also had a nice single piece to cover it . Otherwise it is a pain to copper it.
Very nice paint work. Awesome.  And your copper is amazing  as well.
:cheers:
Edited by Knocklouder
More info
                   WASA
                   USRC Harriet Lane
As I was finishing coppering , had to add the stern fish plate. I just put some pin heads in to give more 3-d appearance and then glued as there were no holes in the false keel.
Next was the prow horseshoe plate. There are holes pre-drilled in the false keel. I could have juste covered with copper and glue it on top but decided to finish one side then clamp a thick piece of scrape wood over the copper then drill from the un-coppered side then repeated the process for the other side.
Then just nailed into place and painted
IMG_9739.thumb.jpg.94cf56d031bba6eae61ae69802f09ee1.jpgIMG_9740.thumb.jpg.4385cbe02c0c0fda9421750477ef15ce.jpg
Finally cleaned the tiles then I used Blue Ensign's idea of lining the copper border as he did in Pegasus. He figured 1mm width. As I had no scrap that size I substituted 1mm rope instead. Final product came out  not bad.
IMG_9742.thumb.jpg.e2f2082d95c6f89d6e2b697f77923264.jpgIMG_9743.thumb.jpg.fd2e819e269dc3f347c275e602e4693b.jpgIMG_9744.thumb.jpg.085b9d0245d3ae8627cbbcd72bc6775c.jpgIMG_9745.thumb.jpg.5c7e046ef79ef454e3edab0ac9614d1e.jpgIMG_9750.thumb.jpg.2af4d2dcc8525ca97cebd08864c3cd71.jpgIMG_9749.thumb.jpg.cccfe83bc06736af9ad772b25b87f858.jpgIMG_9748.thumb.jpg.36d7e882e614b7d879527459b9762d45.jpgIMG_9747.thumb.jpg.9680584cef012744f454d96ba1a17e32.jpgIMG_9746.thumb.jpg.02861d45805b9f278f42bab923eb72ec.jpgIMG_9753.thumb.jpg.e98ddc9a64168fe082baa074e95b6515.jpgIMG_9751.thumb.jpg.9aaa8a22e5f8e70819957e4d4bc09c48.jpgIMG_9754.thumb.jpg.097fbac1e3ad07f3f5dc3d82dc913484.jpg
Thanks!  I am jealous of your skill set as not sure I would have the patience to your more historically accurate approach to ship building. Your skill set is amazing and certainly gave me good ideas during the build so far. Your and Glenn UK planking skills definitely much better although for the next one I will try and incorporate some of your tricks of the trade
Wow, the speed of your progress is amazing. I'm only up to the second planking and I've not done much of that. Well done.
Richard
Current builds:
Completed builds:
SBLim-2A, MiG 15 variant, WAK card
Harpy by Vanguard
AL's Endeavour,  Corel's BellonaAmati's Xebec,  Billing's Roar Ege, Panart's Armed Launch
Ships' Boats - Vanguard 1:64 and Master Korabel 1:72
 Alexander Arbuthnot,  Christiaan Brunings,  Pevenseall by World of Paperships, card
HMS Pegasus by Victory
Captain John Smith's Shallop by Pavel Nitikin
Rumpler "Taube" 1911 by HMV, card
So the hull is pretty well done. Few things I will add at the end as I usually break anything sticking out while I do the masts/yards/rigging.  May not get much work done this weekend being on call. Fitted the 18ft cutter to the stern davits.
IMG_9826.thumb.jpg.ecebd33fb346e998f9797c742972791c.jpgIMG_9825.thumb.jpg.4c3f40345db3b57066b0f5cf8df013c1.jpgIMG_9824.thumb.jpg.ef3d43a3e2b6c0ad1ec52ab5b6b2f051.jpgIMG_9822.thumb.jpg.eee4a3c023bb0ba61f1ae1f5d4656f32.jpgIMG_9821.thumb.jpg.bf68b290a583fdb8514ae271a71c5650.jpgIMG_9830.thumb.jpg.58f258ab8ada7f0bbbd8bab487ff6c7e.jpgIMG_9829.thumb.jpg.f005f4d76864c4342afdc295fca91a5a.jpgIMG_9828.thumb.jpg.7cf0c71385e469802cea830f2e1917c4.jpgIMG_9827.thumb.jpg.86730f6074d1bf7f018f09b43781aa8c.jpgIMG_9823.thumb.jpg.f9428ef6d1fb094e5923d0c244808e4b.jpg
Thanks! They are included if you want to mount them on the stern. There also 2 stairs not mentioned in the instructions but in the kit to go from the deck to the rails where the battons for boarding on the side are. As they cover a cleat, will add them later once I tie off rigging to the cleat.
Finished attaching the various blocks to the yards. Here they re temporarily pinnegn to the masts. Next is rigging the spritsail then i will mount the yards to the masts properly before starting on the shrouds.IMG_9895.thumb.jpg.d9a2e5bc47190383b0ad1ed136021ef6.jpgIMG_9896.thumb.jpg.1b2c261baca456d9adc6ec94fdb30945.jpgIMG_9897.thumb.jpg.56aef5487dca00fc32b1ff535aaa5d08.jpg
I really enjoy your build logs.  Your work is always great,
