Hello everybody
Well, it’s too sad that all earlier postings are lost! Now, let’s start again with filling this wonderful forum.
I started my Victory in autumn 2011, was very busy until spring when I had to busy myself with other tasks (paper modelling). In last autumn I restarted with wood modelling while still being busy with card too.
First I will show you the coppering. I decided to use copper tape instead of the delivered plates. This was mainly because I don’t want to work with CA (which ends in strong problems with my broncheas). I also decided to do the coppering according to the original, meaning to have 12 copperbands on top and the rest
of them leading to them from the bottom. In addition the copper plates should overlap as usually in the Royal Navy, the upper band goes under the lower one and not the other way round as in merchand ships. So I had to start along the waterline and moving downwards. First I draw the lines with pencil and then I cut the foil into plates and then sticking them to the hull.
So much for the moment.
Cheers,
Rosmarie
In my shipyard:
HMS Victory 1:72, Caldercraft (wood): http://modelshipworld.com/index.php?/topic/416-hms-victory-by-romiol-caldercraft-172/
Schwarzer Rabe (Fluyte 1672) Shipyard, Card, 1:96: http://modelshipworld.com/index.php?/topic/424-schwarzer-rabe-fluyte-1627-by-romiol-shipyard-card-196/
The armament
All cannons on the upper gun deck are fully rigged - took me quite some time but was worth the trouble. I decided add all tackles and eyepins before the guns were fixed on the deck. It was easier to handle the guns but not easier to glue them on deck.
Cheers,
Rosmarie
In my shipyard:
The decks
The following pictures show the belfry, barricade, gratings, and other "small" but important details of the decks.
Cheers,
Rosmarie
In my shipyard:
Well, I know, it's not as it was in the earlier, lost version - then I did spend much time for writing which also meant to look after the English terms of all those parts on the vessel. I cannot do this once again, else I would need months for rebuilding the log - so I just add some of the many pictures I uploded so far.
So some more pictures of the past months...
Cheers,
Rosmarie
In my shipyard:
Cheers,
Rosmarie
In my shipyard:
The next series of pics shows the making of the stern and galleries.
Cheers,
Rosmarie
In my shipyard:
Next comes the bow / front part as well as some pictures showing the whole vessel.
With this I will finish the upload of old pictures. At the moment I am busy with the water buckets - they are ready but I didn't yet find a good solution to hang the tiny parts on their places...
Cheers,
Rosmarie
In my shipyard:
Hallo Rosmarie,
nice to have you and your great build back online!
Daniel
Welcome home, Rosemarie.  I am so glad to see both yourself and your Victory back on line.
Best regards----
Augie
Current Build: US Frigate Confederacy - MS 1:64
Previous Builds :
US Brig Syren (MS) - 2013 (see Completed Ship Gallery)
Greek Tug Ulises (OcCre) - 2009 (see Completed Ship Gallery)
Victory Cross Section (Corel) - 1988
Essex (MS) 1/8"- 1976
Cutty Sark (Revell 1:96) - 1956
Hi Romiol,
Thank you for re-posting some of your lost photos.  Much appreciated, as I am halfway through building and shipping my cannons and it's good to have your pics to hand.  I look forward to continuing to follow your build log.  Well done you for taking the time to add details of progress so far.
Cheers
Jim
Greetings Rosemarie
Yep it's sad that we lost all our build logs. And some of them went back a few years. Still we have a long way to go still, just enjoy it. Look forward to all your posts. Regards DAVID
Hi Rosmarie,
Glad you made it back and were able to post your pictures of your wonderful Victory.  It seems like the Victory builders are slowly coming back and we can once again count on each other for advice, support and suggestions.  Looking forward to seeing your build progress.
Patrick
Hi Romarie
Thanks for putting your pictures back up.  At times I can't understand the instructions at all so only by looking at the other logs can I begin to understand what is required.
Cheers
Yon
Hi Rosemarie,
Nice to see you and your Victory back.  You're doing a great job on her and I will enjoy following your progress.
Rosmarie
Your build is coming along very nicely, I really like your copper plating. Using the tape and overlapping the plates was a good idea.
Dave
Currently building CC HMS Victory (6 years and counting)
Future Builds: Victory models 1/64th HMS Victory, Commerce De Marseille (Scratchbuild)and my Japanese Model Rail layout
Hello
From now on I will continue my build log. If everybody has questions regarding to the older – lost – part, just ask them, I’m always ready to help you with tips and/or pictures.
In the last days I constructed the stairs to the poopdeck and glued them in place. The rail will follow when everything in this region is finished because I fear to break it while working on the water buckets.
I also finished the barricade (? Or how is this thing names on which the water buckets are hanged???) and prepared the buckets: I drilled holes and put the “ropes” through them. At the moment I’m waiting for THE GOOD IDEA how to hang them on the small hooks…
Cheers,
Rosmarie
In my shipyard:
Hi Rosmarie...I am new to this forum and have enjoyed looking at your pictures and beautiful job of the HMS Victory.  I'm waiting for my kit to arrive from England and surely will be watching your posts for all the help I can get.  Thank you so much for taking the time to log your build as it surely helps everyone.  Have a great day.  Jerry
its nice to see all the builds coming back online, thank you, im sure between us we can fill the gaps, to help others, i do however have phots from all parts of my build - lots of them, it is the silly chit chat i am missing in my build log, already i have had requests to see pictures of my wabbits
- they will be returning to a forum soon - maybe tonight
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
Hello Rosmarie,
This is a great ship! You are a very talented lady.
I really love the copper plating.
Thank you for sharing this wonderful build.
From now on I will follow your progress.
Keep up the good work.
Take care,
Anja
Edited by Anja
Those we loved but lost are no longer where they were, but are always where we are.
In the gallery: Albatros 1840 - Constructo
Hi Rosemarie,
Great job. Keep up the great work.
Mort
Current Build - Caldercraft Diana
Completed - Artesiana Latina Swift, Harvey, MGS Prince de Neufchatel, Imai USS Susquehanna, Mamoli Constitution, Rattlesnake per Hunt Practium, Caldercraft Snake, Diana, Caldercraft Victory, Kammerlander Duke William
Waiting to be Launched -  Bluejacket Constitution
Proud member of The New Jersey Ship Model Society, Model Shipwrights of Niagara, Model Shipwrights of Western New York and Offshore member of the Society of Model Shipwrights
Thanks for all the kind words!!
Jerry: I hope you won’t have to wait too long and that you start your own build log of your Victory. And sure, everybody in the forum will help you, just ask…
Kevin, garym, mort: thanks for looking by and for your kind comments.
Anja: thanks for the compliments, especially since it comes from an extremely talented lady. I mean, it’s nice to find other female modellers in this forum.
Since the absolutely brilliant idea didn’t arrive while sleeping this night, I simply started with gluing the water buckets at their places, with thick CA. I will wait until tomorrow, when everything is absolutely fix and then I will care for the ropes, hang them over the hooks, then some watered wood glue over the know and then some dark colour – I don’t want the ropes to shine…
In the meantime I started with the work on the galion. The first paint is done with some smears… Well, tomorrow a second and better one will follow anyway…
Cheers,
Rosmarie
Edited by romiol
In my shipyard:
Hi Anja
Thanks a lot for the good wishes!!
Rosmarie
In my shipyard:
Happy Birthday Rosemarie! I hope you get to spend the whole day in the shipyard!
Same here. A very happy birthday to you.
Mort
Patrick, Grant, Mort: Thanks for the good wishes and yes, I spent most of yesterday in my shipyard - however not working on Victory but on my paper model "Schwarzer Rabe".
Cheers,
Rosmarie
In my shipyard:
Hi Rosmarie,  You've made wonderful progress since I last looked in (on the old site). Completing the bow and stern makes it look like a real ship. While you are having trouble recalling the English terms, I'm lucky if I can remember how I did things.  I've enjoyed your log and look forward to many more posts.  Cheers, Gil
http://modelshipworld.com/index.php?/topic/485-hmsHMS Victory by Gil Middleton - JoTika - 1:72
Gil: Yes, it’s real tough work form to find all those special nautical terms in English. Many of them are not in a usal German/English dictionary at all. And while the PC on which I work is in the living room, the books about Victory are in the workshop downstairs… One more reason why I love the re-upload of your log, there I can see what’s the English term of a lot of those parts I’m building.
Hello everybody
I couldn’t work much on my Victory in the last few days. Last Friday-night the heating facility in my workshop crashed. And since  temperatures are freezing (-3-10 degrees C) on Saturday morning the room was more than just cool, it was cold (only 5 degrees C!). I had to carry my Victory upstairs to the living room because I feared that the low temperature could made the wood work too much…
And since our brilliant electrician (he made the 30 years old industrial heater blower work after years of unused) is in skiing for a few days I have to wait… But he promised to arrive tomorrow.
The good thing – I had more time for working on my card model….
Cheers,
Rosmaire
PS: Fortunately the palm trees will not suffer as long as it doesn't freeze in the room and as you can see, Victory temporarily serves as carrier...
In my shipyard:
