HOLIDAY DONATION DRIVE - SUPPORT MSW - DO YOUR PART TO KEEP THIS GREAT FORUM GOING! (Only 66 donations so far out of 49,000 members - Can we at least get100? C'mon guys!) ×
Elvis sang that?   I thought it was Frank Sinatra....  <sigh>   Seriously.. you're the Captain, build it your way.  That is one of our tenets here.
Yeah Ray!
dO IT your way! what the hek!
sicerously after reading your post I have felt kind of ashame from the last post I wrote down. Who we are to judge you or your model skills? Sorry about that. I guess sometimes we all go pretty dramatic here. You have done much more work in a week than others - like me - in a month.
some pics of the process would be very appreciated. I mean the sanding of a single frame i.e.
best wishes Aaaaand dooo iiiit yooour Waaaaay!
daniel.
Hola Daniel,
I could not help but smile at your response. I was able to picture you singing the last part. I've been pretty busy this morning at work but when I get more frames done I will document how I work on each frame.
Greetings to all,
Since I had to work today I was not able to get much done on the Triton. I was able to buy more timber and finish my jig for her reusing materials for the jig I made for my Vietnamese Junk. Since she is only a cross section, the jig seems small in comparison to jigs other people use while conducting full builds. The following photos will show you what it looks like and how the Triton fits within it.
Edited by ziled68
I was able to complete the stack set up for my remaining frames, apply the pattern to them, and cut them on my band saw. I then roughly sanded them with my rotary tool just barely getting to the line so that I can truly fare them once they are together. I dry fitted them them on the keel within my jig to see how they look. If you notice, I still have to give frames 4, 5, and 7 its preliminary sanding before I can procede to treenail them.
Edited by ziled68
Today I’ve managed to take the Triton out of its jig in order to start sanding the inside and outside. I used a sanding stick to work on the outside hull and was quite pleased at how quickly it faired the outside. When I turned my attention to the inside hull, I realized that the straight edge of my sanding stick was causing it to leave gouge marks. I then decided to make a new sanding stick with a ½” PVC pipe I had left over from a plumbing job I did at the house. I’ve come to the conclusion that a straight edge sanding stick is good for the outside moving it fore to aft, and the PVC pipe sanding stick is good for the inside moving it port to starboard along the frames. I’ve also managed to place and treenail the keelson down, add the gun port’s sill and trestle, and am currently working on the wales. The following pictures will show you how she’s coming along.
I like the sanding sticks which seem to have done a nice job for you on an unpleasant build task- though would have to think before using them on a full build in case I lost some of the curve of the hull. Then again thinking about it maybe they wouldn't. Hmmm needs to think more
Hi Raymond
She`s coming along well, I like your determination.
mij
xebec 1:60 scale, scratch build
Thanks to everyone for your kind words.
Matrim,
The sanding sticks was just something I thought would help me fair the hulls and it only made sense to use something round to fair the inside. Of course there are different possibilities.
Mij,
Just think of me as a Rat-Terrier. Once I get a hold of something I won't be happy until she's done.
Daniel,
It was a warm day out in Arizona with temperatures getting up to 87 degrees farenheit (30 degrees celcius). Once you start sanding it seems the temperature gets higher.
Greetings to all,
Sadly there isn't much progress to report, but that only means that there is a little bit to report. I've managed to paint the wales black and am pretty glad at how the weight is evenly distributed along the cross section. If you notice the second picture, you can see that she is balancing herself on her keel. The last picture will show you the start of the lower deck being worked on. I've only just started filing away at the deck beam to accept the carlings.
Are you kidding me!!?? I have never seen a faster build log like yours. Every single piece of work is worthy and keep you moving ahead... Even that "little" job of marking the carlings on the beams is a big and beatiful task of patience and thinking.
Don´t know at what stage you´ll be on friday...
Keep going!
Daniel.
Looking Good.
Later Tim
Current Build -- Finishing a 1:1 House that I've been building for a while
Current Build -- Triton Cross Section
Greetings to all,
Here’s the latest update of my H.M.S. Triton cross-section. I went ahead and started working on the lower deck taking measurements from the frames and transferring them to my timber. When I had completed four of the five deck beams, I realized that I was in fact following the gun deck plans rather than the lower deck plans (way to go Murphy). What I then did was put aside the work I had thus far and got new timber to work on the lower deck with I might add, the correct plans. I then cut the new deck beams and carlings and glued them in place on top of the plans which was inside of a document protector so as not to get the plans glued to the bottom of my deck. After the deck was dry, I proceeded to cut the ledges one at a time and gluing them on the carlings after I slightly sanded the corners for a snugger fit. After everything was glued and dry, I slid the deck onto the deck beam clamps to see how she was starting to look and was quite pleased at the result. I was actually contemplating if I should go ahead and plank the frames but decided against it because I really like the way everything is coming along. What I will do is place a minimal amount of planking material on the outside frames starting two or three planks below the wales and working my way up. The following pictures will show you what I have so far.
Edited by ziled68
I said this on the other site and needs repeating.
Are you working on this 24/7 or what?? You are doing great. I'm guessing that in a few weeks you will be done and working on the cross cut of the bomb vessel next.
Enjoy and it's looking real good and I do hear the singing in the back ground.
Later Tim
Looking really nice with some fast progress...
I too found out ...that you need to check your plans 2 or 3 times to make sure you have the correct deck or even the correct scale you are working in.
Keep up the great work
Triton Cross Section 1:32
SEE YA LATER
im-outta-here-bye-bye-smiley-emoticon.gi
Greetings to all,
Please excuse the fact that I have not posted anything new recently. The fact of the matter is that I’ve been pretty busy at work and other side projects. Speaking of side projects, a Buddy of mine wanted me to help him enclose the back porch of his house to which I was thinking of doing for free but he insisted that I charge him something for my work. What I then did was tell him that I was looking at Model Shipways New Bedford Whaleboat on eBay. If he truly wanted to pay me for my work then I’d take that as payment. So, I’ll give you a guess as to what my next future project is.
Well back to the subject at hand. I have only been working on the Triton at least an hour a day sometimes two. As per the general consensus, I decided to plank the port side of the Triton and have added the ceiling up to the lower deck beam clamps. I’ve also completed the lower portion of the well with shot locker. I’ll be honest with all of you, looking at it outside of the Triton, I can’t help but think it looks like an ice-machine found at any hotel. I also added the shot locker’s door and door entrance to the lower well. I also made the chain pump casings for the well and just dry fitted them inside the lower well to see how they look. Not too shabby if I do say so myself. I hope to finish the lower deck in order to commence work on the gun deck sometime this week.
Pete,
I got information from "Anatomy of the Ship: H.M.S. Bellona", in regards to pump wells and tubes but it was really sketchy as to the actual shot locker. What I then did was review forums on this site and MSB and came up with my own measurements for the shot locker. Now the door was a little pain in the butt seeing how its only 3/4" wide and 1 1/4" tall but I think I was able to pull it off.
Greetings to all,
Well I said I would finish the lower deck by this week in order to get started on the gun deck but for some strange reason I find myself shying away from the hanging knees. I know that I have to get them done and incorporate them into my model. What I will do is follow Arthur’s suggestion and mount and secure my rotary tool onto a base frame and use it as a spindle sander to sand my hanging knees into shape. You may all wonder, “If Ray isn’t working on the hanging knees, then what in the heck is he doing?” Well I’m glad you asked. I am currently planking the port side of my model below the wales and she is starting to look rather sexy. The following pictures will show you what I’m talking about.
Your right, she sure is looking good.
Later Tim
Greetings to all,
Well, where to begin. I know it’s been a while since my last post but I must confess that I’ve only been working on my model for one to two hours a day or at the very least every other day. Guess what, that adds up pretty quickly and before I knew it I was already getting started on the second deck. I am currently pulling a 24-hour shift at my job and after I got here, I realized that the gun deck I had already started stayed at the house and I was not able to get any more work on it. So I concentrated on finishing all of the ledges, add the louvers on the lower deck, plank the lower deck, install the hatch coaming, make and place the ladder to the lower  hold area (which I thought I needed hence its placement), add limber boards against the keelson, and finally finish the outboard planking. All of my planking received simulated tree nails by using an awl to mark the location and following up with a pencil. The following photos will show you where I am so far.
P.S. I forgot to mention that I've also added the hanging knees on the lower deck (Hooray).
Edited by ziled68
