And so it begins - an occasional report from my build of Model Shipways kit.
To start - a selection of photos
- the first one is the bulkhead former in my clamping rig.
Current Project USF Confederacy
And the ever troublesome stem.
It needed adjustment in all of the scarf joints (marked with black circles) to overcome the gap at the top (blue recircle)
- the stem was longer than the bulkhead along its curve by approximately 5mm. It now fits perfectly along the curve of the bulkhead.
Nice start there oldpaperone (name???). Your keel clamp setup looks good. Are those cam cleats along the edge? Neat!
You need to remove all of that laser char before you glue them together.   That is important to get a good bond.  Once done....it will fit together well if you are careful.   Dont forget to darken the edges with a pencil.
Too many people dont remove the laser char and they wont get a good fit at all.  The laser does not produce a perfect right angle when cutting.  The the joints will be larger on one side than the other because of the slight angle the laser cuts at.   Once again this is important for all parts to make the edges a right angle and get a tight fit on both sides.
Enjoy the project and dont hesitate to ask me any questions.
Chuck
A hearty welcome aboard.  We're building up quite a Confederacy fleet!
Enjoy the voyage.
Augie
Current Build: US Frigate Confederacy - MS 1:64
Previous Builds :
US Brig Syren (MS) - 2013 (see Completed Ship Gallery)
Greek Tug Ulises (OcCre) - 2009 (see Completed Ship Gallery)
Victory Cross Section (Corel) - 1988
Essex (MS) 1/8"- 1976
Cutty Sark (Revell 1:96) - 1956
Hi all
Grant - the name is from my days of card modelling and these are cam cleats indeed.
Chuck - all laser char removed - still needed to remove 1.5mm from each scarph to shorten the stem to  mate with the curve of the bulkhead
Augie - thanks. I'm following your build for hints.
Chris
Further progress:
1.The stem is glued to the bulkhead former
2.Keel bolts - drill/refine with a push-pin/shade with pencil/fill with wood filler/sand/ finish with wipe on poly
3.Getting ready for the frames and fillers
4.Bow fillers
5.Frame 8 being trued
6.All the frames are in
Next step - fairing the hull
Yes, keeping it all square is the key.
I'm still puzzled at the stem dimensions - I had to modify it by at least 5mm (more than just removing the laser char ) so that the length along the curve was the same as the bulkhead former. Fairing of the hull has begun - any tips? I plan to do the fairing first and then do the sub gun deck platforms.
Edited by oldpaperone
Ben beat me to it on the fairing.  When you do get to the final fairing take your time.
Having a hard time visualizing your stem issue.  All I can say is if the fit is tight against the BF with the notch sitting in the right place you'll be fine.
Augie
Previous Builds :
Progress
1.Bowfillers
2.Stern - I decided to complete this before fairing the hull, but am I going to pay for this later?
3.Lintels and sills going in
4.Checking the alignment against the future window placement
5.Fairing the hull on my fairing station
6.Lower decks are going in - the pencil line for caulking
Last Day of Summer here - could this mean more modelling time?
Working on the exposed framing now - I have an idea of slightly trimming back the little separating tabs , so that they are not visible (or do these become covered by the planking ?)
I found an interesting quote in "The Naval History of the United States Volume 1 (of 2) by Willis J. Abbot"
"One slight disaster to the American cause alone remains to be mentioned. The "Confederacy," a thirty-two-gun frigate built in 1778, was captured by the enemy in 1781. She was an unlucky ship, having been totally dismasted on her first cruise, and captured by an overwhelming force on her second."
Hi Chris. Nice work so far. :)
Yes those "tabs" that keep the frames in alignment will be covered by the hull planking.
Keep up the good work!
Rusty
"So Long For Now" B)
Current Builds: Speedwell
Thanks for the supportive comments.
I glued in the frames and faired these to the hull - this removed the laser char.
Thanks for the watchful eye, Ben. Its good to know I have masters watching over my progress.
The frames were then treated with wipe on poly (with  a DASH of oak stain).
Next the stern ports - aligning the sills.
Then the lintels and mullions
And then the whole frame in place and faired.
I'm trying to get my head around the filler strips under the counter - how are they finished against the rabbet in the bulkhead former. Any hints?
Chris
Check out the photos on Ben and Rusty's logs.  Notice that all of the outer hull planks will need to contact the rudder post so you need to leave room.  Similarly, the fillers will support the planks under the counter so you need a little room.  I found it was something you have to play with.
Keep in mind that the total thickness of the planking from both sides, combined with the thickness of the bulkhead former, will need to be same as that of the finished rudder at the leading edge of the rudder.
Augie
Previous Builds :
Augies correct in that it takes a little playing with those fillers, take your time fairing them in using a piece of planking material to check the distances that you need to achieve.
I think there are some decent pics on my log of this and also what to avoid in that area.
If you are really stuck PM Chuck as he may have some other pictures from his prototype build that are better than mine, Rusty may have some input here too.
Ben
