I'm going up and down in the things I'm doing.  Stopped with the rigging and started with the rudder:
Out of a beech stir stick for paint I made the rudder (two layers glued on each onder. The smaller part was a square stick of balsa in the right dimension. After that a small brass strip cut in the right dimension, and soldered brass pins on it:
Then the strip made in the right lenght:
drilled holes in it (1 mm) and with small nails attached the hinges to the rudder:
The other part of the hinge - which goes on the ship (excuses for the bad photo)
And finaly the rudder completed - all the hinges on it - made dark with some brass-black.
I just have to fill out the small gaps on the front side of the rudder - between the hinges
Hans
Owner of Kolderstok Models - 17th century Dutch ships.
Please visit www.kolderstok.com for an overview of the model kits available
Very nicely done Hans, I love the picture from your meeting, she looks absolutely splendid.
Well done mate, keep up this terrific work.
Be Good
Mobbsie
mobbsie
All mistakes are deliberate ( me )
Current Build:- HMS Schooner Pickle
Completed Builds :-   Panart 1/16 Armed Launch / Pinnace ( Completed ),  Granado Cross Section 1/48
Harwich Bawley, Restoration,  Thames Barge Edme, Repair / Restoration,  Will Everard 1/67 Billings
HMS Agamemnon 1781 - 1/64 Caldercraft KitHM Brig Badger,  HM Bomb Vessel Granado,
Thames Steam Launch Louise,  Thames Barge Edme,  Viking Dragon Boat
Next Build :-
Hello Hans. It is becoming a beautiful model. Do you remember the Batavia 1:75  model in the Dutch "Modelbouwer" years ago in which Mr Hans Zeller from Switzerland showed his progresses . He used filler pieces of limewood between the bulkheads .Good building and regards, Richard
Hello Prutser  :)
No -  I don't know this model from Mr. Zeller - sorry :(
Hans
In the galleries on both sides of the ship where the toilets for the higher ranking people on the ship.
The "sewers" of these toilets where just simple pieces of copperpipe
A took a small piece of brass tube - some brownishing on it and mounted this under the galleries:
Hans
Hans;
You are the first person that adds that detail to a ship. It is necessary and many a sailor fell through the hole in the ocean and drowned.
On another note. The details on the Batavia are beautiful. You are pretty much adding everything that is on the replica and probably on the original ship.
Marc
Hans;
Marc
Marc,
I do have a lot of photos of the Batavia, so I can add pretty much of al these details, yes.
If she is the same as the original is only guessing.  The craftsman under which the Batavia was build - Willem Vos - did use a lot of his own imagination and intepretation on how ships where build in the 17th century.  He just did call her the Batavia because he had read about the voyage of the Batavia.
The ship could have easily be named "Willem Vos" as well...
Hans
I bought me some ribbon in the Dutch flag colours for the diverse flags and pennants on the ship.
However, it turned out that the largest ribbon still was to small for the main flag on the rear of the ship, so with some paint and thin cotton sheet I have made a flag myself.
Nowadays the Dutch flag is the well known red white blue but during the tachtig jarige oorlog (the 80 year war with Spain - 1568-1648  see http://en.wikipedia.org/wiki/Eighty_Years'_Warthe Orange family became stronger.
The Dutch flag at that time was moreless introduced by de Geuzen - the underground movement against the Spanish rulers (when you translate Geuzen you get Beggars - and in fact they where the poor people of Holland which started revolting against the Spanish). They had choosen a flag with an orange uppercolor - Oranje Boven - or Orange rules!
This flag was called Oranje Blanje Bleu - a loose translation of the French Orange-blanc-bleu which described the colours.
In the period up to around 1630 the official Dutch flag then was this Oranje blanje bleu, and there are diffirent storeys why this in the end changed into the red-white-blue which we have now - f.i.:
- The orange was a mixture of red and yellow pigment, and the yellow pigment couldnt stand the sunlight, rain etc. so the orange turned into red.
- the orange colour was quitte expencive to make, so the frugal Dutch choose the red.
The exact cause of changing from orange to red is not know, both flags excisted aside each other for a longer period.
After 1650-1670 only the red-white-blue remained.
In 1937 the Red White Blue was declared by Queen Wilhelmina  as the official Dutch flag
Hans
The foremast with its standing rigging is done - except for the ratlines. These will follow later.
Hans
Hoi Hans, great looking model !!  And thanks for the history lesson on the flag.  It sure brought back memories from school having  to "endure" the great history of a small nation.
Cheers,
Piet, The Flying Dutchman.
                       VOC Ship Surabaya
                             Friendship Sloop Gwenfra
                           Muscongus Bay Lobster Smack
Cheers,
I guess this must have been the lagere school, or ???
Hans
Hoi Hans,
Yup, and Mulo too!  I like to forget those years, real stressful for me.
Cheers,
                       VOC Ship Surabaya
Hoi Hans,
Cheers,
Well - must have been some time ago - 1968 the Mulo changed into Mavo. Should not give any stress anymore I think
Hans
Tribute.
Because my wife is a little bit afraid she is loosing me a little bit because of the Batavia (which is not true  :) of course) i sculpted  one of the heads on deck to her image:
Hans
Hello Hans, beautiful carving my friend, your wife must be very pleased with the likeness  ;)
Ref to previous post, yes, my Mulo experience ended in 1950.  Reason for the stressful times were associated with politics and the general "we don't care" attitudes by the powers that be.  A long story but this is not the place to get into.
Cheers,
                       VOC Ship Surabaya
Although VOC - ships used to carry up to six anchors I,ve decided only to make two of them (the manufacturer didn't supply more :))
One side is finished now:
Hans
Another nice thing to make is the lantern.
You can buy some standard lanterns - but these didn't match my requirements.
So I started with sanding some wood in shape
Then sketched the under and upper part and carved the top:
With some clay made some ornaments on it - and slept a night over it.
But to be honest - I didn't like it - to round, to much not what I wanted.
Then I made a second version - more right up, but here I used to much glue - and it was much to big!
As you can see it is over 5 cm (2 inch) high - which means in scale 1:72 a 3,5 meter lamp.
Fully out of proportion.
So I scrapped this lamp and started for the third time.
This is so far the result - an approx. 3 cm lamp which means in real life about 2,4 meter high. Still huge, but some more in the right size. :)
Hans
With this modelling clay there are always some leftovers. Of course I can throw these away, but it comes handy that I still have some carving to make on the bow:
- Some say its more like a dogshead
- Some say it has flappy ears
- Some say it looks a little bit like it.
Decide for yourself:
Sorry - wrong picture.
Hans
I made some modifications on the Liondogshead - this is a little bit more like it - to my opninion  :rolleyes:
And beware - otherwise I make a Sjorshead on the bow  :D
Hans
Much better Hans !!!
And you don't want my head as a figure head.......
But maybe it is a good thing ?
You are chasing the enemy away then !!!!!!  :D  :D
In the meantime on the Dutch forum we have a nice Anglo-Dutch ship discussion going on. Great fun!
This however must not stop us from doing what we like to do - modelbuilding.
The lantern is finished - including the little door in it to light the candle - and then mounted onto the ship.
Edited by *Hans*
Hans
Last saturday a small group of modelbuilders where on the Bataviawharf in Lelystad - to have a glimps on the 1/10 scale model of De Zeven Provinciën they are making - nice and interesting!
Another nice thing to see is the firing of the "old" canons they used on the ships:
The sound on this video is acceptable - but in real it will blow your eardrums out!
Edited by *Hans*
Hans
