Now on to the gudgeons.
First, i formed the strip around the nail, then i silver soldered the piece.
Afterwards i cut it off.
Then i silver solderd it to another strip.
The finished pairs of gudgeons and pintles.
Chris
Current builds :
On hold :
IJN Yamato by DeAgostini - 1/250
Completed builds :
Bermuda boat Corsair (scratch)
President by Sergal - 1/60
I've started on the rudder. I prepared the necessary pieces for it.
I also blackened the pintles and gudgeons.
On one piece I've noticed a sort of white residue ?
Anyone an idea what that might be?  Too much flux used during silver soldering?
Chris
Current builds :
On hold :
Completed builds :
Continued working on the rudder.
First i glued the parts.
Then I made the recesses for the pintles.
The rudder is too small on the top to receive the tiller. So i added a piece of cherry wood on each side.
Afterwards when the glue dried, i sanded the whole thing and prepared it to receive the tiller.
Then up to the tiller.
And finally i've drilled the wholes in the pintles and gudgeons.
Chris
Current builds :
On hold :
Completed builds :
Continuation on the rudder.
The rudder is now complete, with the pintles epoxied on their place.
And finally putting it all together. I have now a working rudder on my little boat.
Chris
Current builds :
On hold :
Completed builds :
  • 3 months later...
Pfeww, quite a while since i've been posting here.
I've made a little jig in order to be able to create my masts and spars. The mast has been made with it and it went very smooth.
I always start from square stock, reduced to the size of the minimum diameter with the table saw.
The result of the bowsprit.
Mast and bowsprit fitted to the boat.
I've done a bit of metalwork as well.  I've started on the bowsprit clamp.
Below you'll see how i made the iron cap, for holding the bowsprit jibboom on the bowsprit.
First i've bended a strip of brass around my bowsprit.
Then i formed an '8' from that.
Which i fixed with some silver soldering.
Edited by WBlakeny
Chris
Current builds :
On hold :
Completed builds :
Chris,
Very very nice build, the lines on this boat are classic from bow to stern its so smooth it just flows like the rolling swells on a calm sea.
Kudos:cheers:
John Allen
Current builds HMS Victory-Mamoli
On deck
USS Tecumseh, CSS Hunley scratch build, Double hull Polynesian canoe (Holakea) scratch build
Finished
Waka Taua Maori War Canoe, Armed Launch-Panart, Diligence English Revenue Cutter-Marine  Model Co.
  • 2 years later...
What a long time i've posted here. I switched jobs and life was hectic.
Meanwhile i've finished her.  I'll be posting some pictures of the last stages of her build.
The bowsprit is held in place by a wooden brace, the bowsprit bitts . Outboard by a iron retainer bolted to the stem.
The cleats are installed on the mast and spritsail boom.
On the mast, near the top are two sheaves. Here they are simulated by drilling holes and forming them with a file.
The wheels of the sheave are simulated by a bamboo dowel.
I've created the blocks myself. There were only 10 to make. Corsair-50-5.JPG.5448029dea172e97d1fe61e5f7709578.JPG
I made the eyebolts for to attach the blocks on deck.
And installed the double blocks.
Chris
Current builds :
On hold :
Completed builds :
To make the sails, i first soaked the tissue in some tea for some time.
After drying, i ironed them and use some starch.  Then i drew with a pencil the bands and cut them off.
Then i glued them to each other with dilluted glue. Overlapping each other just slightly, taping them to a piece of glass.
When enough bands were glued to each other, i used a paper pattern of the sail to drew it on the tissue.
Cutting it out.
And finish each sail with sewing the boltropes around them.
And behold, one finished sail :)
So, i did for all the sails.
Chris
Current builds :
On hold :
Completed builds :
  • 3 months later...
I still need to add the reefing points to the mainsail.
Afterwards i applied some diluted pva glue to the reefing lines and hanged a clamp on them to straighten them.
When dried i cut of the excesses.
Then it was finally time to rig the first sail on her.
Slowly progressing and rigging all the sails.
Chris
Current builds :
On hold :
Completed builds :
Hello Chris,
Nice job, you really captured the look of a Bermuda boat. Also, a reminder that there is no need to rush!
Bruce
STAY SAFE
current builds:
Thank you all. I'm very proud of her.
As for my next project, i'm not decided yet.
I'd really love to make a frigate. Three choices, Chucks beautiful winchelsea, the Triton or the gorgeous Belle Poule.  However i'm not sure i can take that on.
Perhaps the cutter Cheerful or La jacynthe would be a wiser choice.
So much choices...
Chris
Current builds :
On hold :
Completed builds :
  • 4 months later...
