  • 4 months later...
  • 2 months later...
Hi am I correct in thinking that the Formast is supposed to be vertical and the Mizzen and Main at a slight angle?
Hi Stergios, nice to see an update!  I can't quite tell what you are showing in the picture.  Are you using wire for the stirrups, looks like rope in bottom picture (?)
Cheers,
Jason
In the shipyard:
Hi, yes that's right. Only the formast seems perpendicular to the deck, as per the plans.
Hi Jason, those are three tinny telephone wire twisted bundles.
The bottom pic is with the primer... I'm about to paint it black just to see its appearance
Thanks
Thinking to pass the twisted wire through a hole to the yard and accomplish the whole procedure covering the stirrup with a kind of lashing of additional relative's size black thread.
That will be the second version of realism, hanging the stirrups through the center of the yard and not behind it...
Edited by drtrap
Happy New Year 2018 to everyone!!
A couple of pics showing the progress of this phase, using a custom made jig just to set the same length [14 mm] of the stirrups........
Edited by drtrap
Thank you Jason.
Now all yards are almost ready for the final rigging.
I've applied of course a thin layer of the best in my opinion varnish: vallejo matt varnish 71120
Edited by drtrap
Starting the rigging fot the footropes.
I'm going for that with 0,5 black thread but I'm not feeling sure whether 0,5 seems "under-scaled", especially for the main yard....
Edited by drtrap
I think it is better to simulate the footropes using 0,75 black thread for the larger yards and leave 0,50 thread for the other two (nr 2 and 4)..
A couple of pictures demonstrating the preliminary result using 0,5 and 0,75 black thread for the footropes.
I'll leave the rigging semi-loose till the final placement just to be sure for the tension of the fittings and to simulate a sense of gravity rope "sagging" using floor cleaner as a rope hardener.
I've found the tip to save my photos in a 270 degrees orientation.
This way i can upload and show them without problem preserving my (and yours) cervical spine stablity. :D:D:rolleyes:
Edited by drtrap
Hi folks.
Any idea or suggestion on how to create, serve and fit those lower central slings of the "senior" masts?
Thank you in advance.
Now ii's time to find the right height for the yards.
I'll go using the respective platforms (I can't recall their names, now...) as a reference for the right height for the point to drill a 1mm hole and to fix the yard.
PS: The photos are "uploaded" in a 90 degrees orientation. :(
I sent a query mail to msw, no reply.....
Edited by drtrap
The rigging of the yards is almost complete.
Thinking to leave all of them unmounted out off the masts.
I'll continue with the permanent placement of the bowsprit and start this way the standing rigging of the ship.
If you consider I'm wrong, please say it now. :D
Edited by drtrap
1 hour ago, Davemc said:
Rotate the pictures on your computer before you download them to the site
Can't rotate and re-rotate everytime my computer's gallery.
The point is to fix this abnormality inside msw.
Hi friends.
A questionn in brief, for the spritsail...
Do you suggest to fix it to the bowsprit (using a 1mm pin etc as for the rest of the yards) or leave it hanging alone with the attached ropes and blocks?
2 hours ago, drtrap said:
Hi friends.
I did it!
On 6/3/2018 at 10:28 PM, Beef Wellington said:
Very good Stergios, just catching up on your work.  I really need to get back and finish my Snake...
That would be great Jason...
