order for timber sheet and strip to replace the plywood pin rails, timber heads, kevels etc arrived today along with some 5mm anvil cleats for the shrouds from model dockyard. Also finished planking the poop deck, dry fitted the catheads and started planking the quarter deck as well as spraying the cannon barrels.
Next job after planking is finished is to open out the holes for hatches and masts and sand them- interesting to see the difference in shade between old planking and new.
Keith
Thanks to all for the comments and likes so far. Planked the stern and the bottoms of the quarter galleries today will sand everything to correct profile if this awfull weather breaks and i can get outside!
Keith
Edited by clearway
Ty Geoff- still a lot of detail to go and not sure how to go about detailing the ornamentation as the billings laser-cut stuff is just plain with no detail except for the outline! Was going to invest in the caldercraft castings but at 1/72 scale they will be oversize- will have to get some dimensions off some of the caldercraft victory builders on here. Seeing your Santa Maria is making me feel guilty about ignoring my AL Pinta.
Keith
Nice build!
And sorry about your small companion!
Cheers, Daniel
Ty all for the comments and likes- appreciated, bit of a nightmare bending wood in two different directions. I used cardboard (cereal packet) to make templates for the pieces round the quarter gallery.
Keith
Saves on wasting timber Boyd and in our household is in plentiful supply!- hope the weather other side of Irish Sea is better than the Cumbrian side m8
Nice build and just read through all the work so far, being a late comer, there's so much here that really takes some beating.
Really like your work and will be watching this build with great interest. :rolleyes:
Foxy :piratebo5:
Ty Lawrence, i will be painting the stern galleries- as much as it pains me as i like all the wood effects! I have loads of spare veneer from other builds so used that to plank the stern and quarter galleries it just happens to be a nice colour contrast and as mentioned will be a shame.
Keith
Ty Foxy- i am going for the olde black n yellow for the colour sceme- thinking about using humbrol linen (matt 74) as this is a really subtle yellow.
Back to the build- not much done due to being press ganged by the mother in law to repair her fence today :P , but here is some more stern details added.
Keith
Edited by clearway
Ty Lawrence i was kind of hoping someone would bring out an upgrade for the billings Victory before i got this far- ah well- mind you if someone wants to produce 1/75 castings for the scrolls etc....................... ;)
Keith
Ty mrcc- it was primed and sanded back to remove the coarse wood grain- normally i would use high build primer but victory's hull has too much detail for this- well for me anyways! The hull will be primed again before final painting. You will end up with a smoother hull and better surface to paint but will lose any planking detail.
Keith
Edited by clearway
More timber added to the stern and made a start scratchbuilding some replacement catheads to replace the ply ones from the kit- someone gave me some hawthorn branches to chop for firewood and decided to use some of this- been seasoning in the shed for 12 months till i found a use for it!
Ply catheads on the left
keith
Ty everyone for the likes and comments- have been trimming the new catheads down some more today Lawrence still need a little taken off and then some work to make the holes look more sheave like.
Keith
Edited by clearway
After a couple of evenings whittling and sanding to shape the new hawthorn catheads are now down to the correct size- only dry fitted at the moment till i finish the stern- grrrr nights getting darker so alfresco modelling in the evenings is nearly over- i do all my sanding outside if i can help it. New catheads deffo look better than the ply one laid beside them.
Keith
Ty mike- still a way to go though- not sure what to do about the plain laser cut ply billings offerings for the scrolls etc on the stern.
Keith
Edited by clearway
