Thanks Geoff , she's starting to taking shape.  ( this one has been a bit tougher than the Buzzards Bay )once the new Profile drawing is made, with the corrections . the next one should be easier to build
Best Regards,
Pete
"may your sails be full of wind and the sun on your back"
Current Builds :
 Future Builds :
N.G Herreshoff 12 1/2 Scratch Build 3/4" = 1' - 0" Scale
Completed Builds :
Volvo 65 Farr Yacht Design
Herreshoff Alerion
Herreshoff Buzzards Bay 14
Volvo Open 70
 Member :
The Herreshoff Registry                                  Montgomery Sailboat Owners Group       Peter Kunst Sailboat Models
http://www.herreshoffregistry.org/                       http://www.msog.org/                      http://www.facebook.com/Peter-Kunst-Sailboat-Models-1524464774524480/
Thanks Michael,  I realy like this Wood Stain, its made by DALYS  chery # 45 it works well with Epifanes Varnish
Best Regards,
Pete
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
Pete the lines of this boat are really sweet and you are doing a great job of modeling them.
Michael
Thank you Dave, the 12 1/2 has beautiful lines ( thats why I am drawn to this Boat )
Thank you David B, I am thinking a gloss white on the hull with a blue waterline and sand color for the deck , all the bright work in cherry
Thank you Michael,  I appreciate it , These Herreshoff Boat's Have been fun to build
Here are a few more shots
Best Regards,
Pete
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
It is Raining once again here , So finish work will have to wait. It was however a great day to re-loft the 12 1/2 , and create a new lines drawing with the corrections . I feel alot more confident going into the next 12 1/2  Build with the new plans ( the Scale is 3/4" = 1' - 0" ) Here are the results
Edited by pete48
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
And here is the original lofted lines drawing, huge difference in the bow
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
You're right, Pete the newer bow looks fuller; also looks like the the newer version has slightly more dead rise and a bit more rake at the stern. Always nice seeing manual draughts--lookin' good!
Cheers,
Jay
Edited by JMaitri
Current Build:  Ariel
Thanks David, I dont want to do as much sanding and fairing on the next one , so the profile needs to be correct
Thank you Omega, I am pleased with the painted plank ends and varnished transom  , I will still need to round off the top of the transom
Thanks Jay, The Bow is fuller , and the stern did change as well , the original numbers got off somehow, ( I think I was to conservative with the bow section on the original ) I am old school and like to make the drawings by hand . ( plus I have no idea how to use CAD )  the new one looks alot better than the original, ( almost O.E. )LOL
Best Regards,
Pete
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
Today , I was able to get alot of work done on the 12 1/2. Starting with re shaping the Transom so that it rolls over the top , I then cut out all the seat braces and cut the frames down to more resemble Ribs. I then made the cockpit Coamings soaked them in alcohol , installed them, sanded them, and finaly stained them ( I stained the Transom at the same time ) . I also made the Cockpit Floor and Aft seat ( wich I had previously made templates for) I was very pleased with the results . Next will be to varnish the Transom and Coamings . Here are the results
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
And here is the rest of the pic's , I had alot to choose from. the seat's are held in position by wood  wedges
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
Yesterday morning was Brutal, the 12 1/2 fell from a high spot breaking the Transom off. And causing damage to the Starboard side Bow area in front of frame 3 to frame 2 . so the repair work began , by cutting back the remaining part of the Transom square, so that a new piece could be sandwiched in between 2 pieces of Birch Ply. ( to give it more strength ) I then glued some scrap pieces of planking material , to fill in the hull . Next, I re faired the hull . I then re-shaped the Cockpit coamings ( they were to tall ) I then Stained the Transom and Cockpit Coamings. I then Applied 3 coats of varnish. Here are the results
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
That sucks, Pete--know the feeling when these little guys take a tumble. Looks like you were able to repair her--don't see any signs of the mishap--and she's looking sweet as ever!
Cheers,
Jay
So sorry to hear about the mishap but great recovery!  "Stuff" happens at times  ;)
Cheers,
Piet, The Flying Dutchman.
                       VOC Ship Surabaya
                             Friendship Sloop Gwenfra
                           Muscongus Bay Lobster Smack
Thank You , Geoff,  It was a great learning experience, I was not sure at first if she could be repaired
Thank You Jay, It was heart wrenching , fortunatly, the repairs to the hull will be covered with paint.  The trickey part was where the Cockpit coamings meet the Transom , in the second photo you can see the line in the coaming ( port stern ) I think thats the only thing that is going to be noticable.
Thank You David B., It was rather unfortunate , However I was able to upgrade the transom ,with the birch ply
Thank You Piet, Stuff does happen from time to time that is out of your hands . I think how you handle it determines the outcome .
Thank You Dave , I appreciate it . I think she came back together rather nicely, I am going to re-primer the hull today
Thank You Michael, it ended up working out pretty good . I think the Birch on the transom is a great upgrade
In this Photo, you can see the repair where the hull meets the Transom
Best Regards,
Pete
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
beautiful as always Pete,
were the actual Bay 14 and the 12 1/2 ever built with clinker planking like the scandinavian "Drachen Class, (3-man keelboats)?
Nils
Current builds
-Lightship Elbe 1
Completed
Hi Nils, To the best of my knowledege , None of the Herreshoff boats built thru Herreshoff Mfg.Co or Cape Cod Shipbuilding , have been built in a Clinker . However a Company called Brooks Boats Designs, came up with a version of the 12 1/2, that boat is done clinker-built. here are a few photos
Best Regards,
Pete
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
Lovely, lovely !
Pete, that makes my heart jump, These boats are just the right size for keelboat daysailers, not too heavy good for trailor Transport and two adults Hands for handling in / out water twice a year
Nils
Current builds
-Lightship Elbe 1
Completed
Hi Nils, I agree this size boat is perfect for day Sailing, and she can be singlehanded  wich is a big bonus ( my Wife does not always want to go Sailing ) I would Sail everyday if I could, ( and to me this would be the boat to have ) I have been fortunate to Sail a few of the these, and you cant beat a full keel for directionality ( they track very well ) and no weather helm . One of the most beautifull boats I have ever seen, or have had the privilege to Sail
Best Regards,
Pete
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
Very Nice Pete, that green on e could cause drooling symptoms.
Michael
Michael, the green one is attractive  , I can look at them all day
Hi Dave, The Herreshoff boats are quite amazing , I would like to have one as well. I grew up Sailing, it is a great pastime. I highly recomend you try it
Best Regards,
Pete
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
Today, I was able to get the boat back in primer ( 3 coats ) before the rain came . I also sprayed the cockpit  a flat white. she is back to where she was before the incident. ( whew ) here are the results
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
