Thank you Geoff, She is starting to get her shape back
Thank you David, I appreciate your kind words
Best Regards,
Pete
"may your sails be full of wind and the sun on your back"
Current Builds :
 Future Builds :
N.G Herreshoff 12 1/2 Scratch Build 3/4" = 1' - 0" Scale
Completed Builds :
Volvo 65 Farr Yacht Design
Herreshoff Alerion
Herreshoff Buzzards Bay 14
Volvo Open 70
 Member :
The Herreshoff Registry                                  Montgomery Sailboat Owners Group       Peter Kunst Sailboat Models
http://www.herreshoffregistry.org/                       http://www.msog.org/                      http://www.facebook.com/Peter-Kunst-Sailboat-Models-1524464774524480/
Today, I finally got the Hull Painted,( it took 2 days & sanding her back to wood twice) I went with a semi-gloss white . (3 coats ) I also detailed the seats and cockpit floor.I then Stained and applied 3 coats of varnish. Here are the results
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
Thank you Michael
Best Regards,
Pete
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
Thank you Geoff , I appreciate it
Best Regards,
Pete
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
Thank you Zoran
Best Regards,
Pete
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
As today is a day of rest for most ( I am included with most ) I thought I would give the "Boxing Kangaroo " ( Thanks Geoff ) a break , and clean up the paint mess on the 12 1/2 ( no matter how well  I mask somthing, (not all the time but with this boat ) Paint gets in spots that I cant figure out ) like all over the inside of the transom and Coamings . So I sanded the bright work down to the wood and re-stained . Then applied 2 coats of Varnish. It was easy and it was the perfect task for today. The first 2 photos are what I started with ( so that you can see the excess paint ) Here are the results
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
And here are the pics, after the varnish, She is starting to come together
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
Today, I was able to get alot done on the 12 1/2 , I first installed the Cockpit floor. Then masked off the Coamings and Painted the deck and aft deck.( a sand color ) After the Paint dried , I installed the Aft deck and Seats, I then added the mouldings . The forward moulding will still be sanded to match the Deck camber . I was very pleased with the results, and here they are
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
Here are a few more
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
Thank's Jay, I am pleased with how she is starting to turn out Starting to look like a 12 1/2
Best Regards,
Pete
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
Hello Pete
I only recently saw this build, looks great. My question is on the scale, as I saw then photos of her sailing: I plan I build a 1":1' scale boat starting soon, & hopefully she will also sail ok as a pond boat. Did you adjust anything to get her to work as a working (scale) sail boat? Not sure if the question is clear.
Thanks, MP
Hello Mark, Let me see if I can clear this up , First off you saw my Herreshoff Buzzards Bay 14 sailing . I was refering to building a 12 1/2 at 1:1 scale, wich means the boat would be full size.  This proto-type is being built so that I can make sure that all the calculations are correct .  the scale for the model is at 3/4" = 1' - 0" as far as the adjustment's there are no plans available for the 12 1/2 ( they are owned by Cape Cod Ship Building ) So I have been developing the plans , using the Buzzards Bay plans as reference . ( And all the other resources that I have found pertaining to  the 12 1/2 ) I hope that helps
Best Regards,
Pete
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
Today, After a nice little break , I stated by trimming the forward cockpit trim to match the deck camber. I then made the Mast support / Belaying pin rack ( I made some pins out of brass) I then made the Main Sheet traveler , and installed it. I then installed the rub rails and toe rails. I added the door at the back of the cockpit and started the Masting .I would like to get her finished this week. Here are the results
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
How sweet she looks Pete.  Gwen and I would love one of those 1:1 and sail the Inter-coastal nearby or the St. John's river.
Cheers,
Piet, The Flying Dutchman.
                       VOC Ship Surabaya
                             Friendship Sloop Gwenfra
                           Muscongus Bay Lobster Smack
Thank you Russ, I Think the Bright work turned out alot better on this one, than it did on the Buzzards Bay, It's been a great learning experience
Hi Onega, since this one is a proto-type , I did not build her the same way as if I was going to put her in water. ( I did not use any West Sytem Epoxy ) The Revised version will be built to sail
Thank you Piet, I will be starting a 1 : 1 somtime next month , and I will give updates on that build in my build logs. ( as it is a full size boat )Kate and I are very excited about it .
Thank you Geoff, Cogatulations  I see that you are now a Captain
Best Regards,
Pete
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
Thank you Geoff, I know it does not mean much , but it's still kinda Cool.
Best Regards,
Pete
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
Pete I am regressing in my age.  Can I take your 12 1/2 home with me?  I will take good care of it.  And when I invent a shrinking ray I can sail it in the pond near my sister's house. :D
David B
Hey David b., How is that shrinking machine coming along
Best Regards,
Pete
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
Is it a wattage issue
Best Regards,
Pete
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
Naw I am using the same equipment that was used for the movie Fantastic Voyage.  Maybe i should throw away the test tubes and go to chips and dreams.
David B
Pete this is a wonderful model and I am also looking forward to your 1:1. It will be a great build as well I am sure.
Michael
Thank you Michael, It's been a few years since I have done a full size build ,( about 15  ) and this is one that I have always wanted to build .  So I am pretty excited about it , and next summer I will be Sailing ( its a win win )
Best Regards,
Pete
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
Last night, I made a revised Keel & Transom from my new drawings, I then did a mock-up using the rejected frames from the Buzzards Bay and 12 1/2 Proto-type , She lines up alot better than the proto-type,so My new numbers look good. Here are the results
Edited by Pete48
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
