Very nice Pete. Travel safely.
Rusty
"So Long For Now" B)
Current Builds: Speedwell
Have a good trip (but since it's work related, can it really be "good"?), Larry.   The hull is fairing up nicely.
Thank you all for checking in and the comments.
Wireless card went out on my laptop so sitting in the hotel lobby in the business center catching up befor going to a meeting.
You all have fun and keep working on your builds so I will have something to do at night (looking at yours) :D
Triton Cross Section 1:32
SEE YA LATER
im-outta-here-bye-bye-smiley-emoticon.gi
Your build is looking real good and nice and big of course. Stay safe on your trip.
Later 42rocker
Current Build -- Finishing a 1:1 House that I've been building for a while
Current Build -- Triton Cross Section
Hello everyone!!!!!
Seems like a long time since I had anything to post. Returned from my trip, got caught up on my yard work and resumed sanding on my cross section,
I wish I was amberdextrious so my left arm would be a big as my right arm from all the sanding  :D
I am pretty happy with the way it has turned out and satisfied with the inside fairing...will consider this done.
The outside need a little more work on one side and I will consider that done.
Here's a few pictures of my progress
Will now start sawing out some of the inside planking (limberboards and thickstuff so as to start assembling them
SEE YA LATER
Thanks Joss
Had time to work on it a little this morning so decided to install the Lower Deck Clamps. I am hoping that doing this I will be able to install them at the correct height and if any adjustment is needed will be able to correct width small amounts on different planks for any errors that will creep in.
I noticed in the Midship Cross Section Plan that the top of the deck clamp Item#12 was almost flat. So I made some sanding stick in order to get the angle correct.
Here I temporary clamp them in place
Made up some sanding sticks of sufficient  length to fit between the frames with 100 grit paper
You can see the angle I need to sand to for proper fit
Doing this gave me multiple reference marks along the clamp
Mounted them in my small vise and used a 3/8 hand chisel to remove the wast and cleaned up with some 220 sandpaper
Temporary put back on cross section to check for level
Then glued them in place
Once these dry will move on to the next ones
SEE YA LATER
Hi Pete, That is a great way of doing it and was done very nicely. Well done.
Rusty
Just a small update...thought I would post how I am marking for my planks....see if anyone out there has a better suggestion than how I am doing it.
First take the measurement from the plan
Transfer it to the section. making sure to locate point next to keelson  in middle of the frame (glue joint as a repeatable reference)
Using a 1/4" x 1/4" aluminum angle for a straight edges, should not have any bend or bow to it.
After marking each frame, checking measurement down from previous work to make sure have same gap from end to end and side to side
And here is where I am at now
If anyone has a suggestion please post. I take all type of critizism  good and bad.  Just can't spell worth a @!#$
SEE YA LATER
That method will work fine so long as distances you are measuring match up from plan to model. That might not always be the case. I think that measuring the width of each plank might work as well.
Russ
Russ, thanks for the reply...so far the plans are matching the model...took several measurements at different places before starting the inside. Also have been cutting each board as need using measurements from the plans and model both.
Paddy thanks for the kind words.....most of what I am working out has been worked out by others long before me...I just try to remember and look at notes I take from other logs to apply to mine.
I find that if think through the problem in a way that I would have to show and tell someone that has no knowledge of what this is  (like myself   :mellow: )  I can come closer of doing a descent job on my
build. That's why there are so many pictures of each step. (more for me than anything)
Edited by Pete38
SEE YA LATER
Really enjoying your work. Helps to watch you go at least. I'll keep working at it and someday will follow in your footsteps. Nice clamping by the way.
Later 42rocker
I have a question for you all out there.
On the limber boards..Please correct me if I have this wrong....
They were about 4 to 5 feet in length and had a notch (or hole) about 1 to 1 1/4 inch dia to aid in their removal..?????
Does this sound about right??
SEE YA LATER
Hi Pete,
Chach_86 Stated the following in his build log and I used the same for mine.
Can’t vouch for the accuracy but they looked good.
I hope it helps.
I had opened a thread a while back in the general discussion about it and came to the conclusion that they would be 3 feet long with openings on either side to pry them out. So scaled down gave me 3/4 inch long sections with half circles drilled out on each end.
Rusty
After the prompt reply from Rusty I started on my limber boards. (Thanks again)
This involved quite a bit of trail and error so far...more error than trail  :wacko:
I first cut and sanded the boards to the correct thickness and cut them extra wide to have material to play with and marked by eye the angle that I needed.
Then set up a wooden fence on the saw so that I could rip close to the fence without doing any damage to anything. Also temporary attached a shim to angle the board to
the correct angle.
Ran the board down the fence to rip the angle
SEE YA LATER
Sorry about that...hit the wrong button. :blush:   to continue
Ended up with an angle like this
Here is where the ERROR comes into play
Cut the board into length of 3'  about 1 1/4" scale.  Marked each board and fitted to the cross section.  After fitting removed and tried (note I said tried) to drill a 1 1/2" hole in the
joints ..about .0350 dia.   This did not work out so good...Holes were off centered...did not align up with the board next to them and just generally looked like crap  :angry:
Cut to lenght
Looking like !@#%&
Unless your a very very very good...do not try it this way
SEE YA LATER
!@#%*  hit the wrong button again....
stared with a new piece in one length and are (is) fitting this to the gap
After I have fitted the board will mark off 3' length and drill a hole a little bit bigger then saw at the joint...Hopefully will work out better.
The way thing are going right now..Can not type...hard to concentrate to fit board properly...so will wait until tomorrow to start again and post progress then.
Thanks for taking the time to look at my post
Off to the fridge for a cold one and time to relax..... :cheers:
SEE YA LATER
Thanks Rusty...
Will adjust to 3 feet long...sound about right...easy for 1 man to remove and manage in the tight place where they are at..
The only references I found in my limited library where ‘they were short’.  :huh:
Glad Rusty had some information on this and I’m going to follow with his lead too. Thanks for posting the question Pete. Now noted in my shop notes.
Edited by Paddy
1st Year Apprentice :mellow:
A new member of the NRG as of 8/28/13
Work in Progress -
 Triton 28 Gun Frigate Cross Section
Better Luck on the next try.
I'm off to try to cut the final planks that I need to start the build.
Later 42rocker
