I'm getting close to the point of cutting strip wood on my Byrnes table saw, and have been looking into ways to improve the safety of how I operate it.  One thing I came across recently was this Micro Jig Gripper system.  Has anyone used it on a hobby table saw?  There is an attachment that allows you to cut strips as thin as 1/8" (second link below).  It gets very good reviews, and seems like a very good safety option.
http://www.amazon.com/Micro-Jig-GR-100-GRR-Ripper/dp/B001I9UNWC/ref=sr_1_5?s=hi&ie=UTF8&qid=1406298396&sr=1-5
http://www.amazon.com/dp/B003E65XXQ/ref=wl_it_dp_o_pC_nS_img?_encoding=UTF8&colid=Q98WCH1760LZ&coliid=IHRUH9PG7315D
It's not cheap, but if it saves my fingers, it seems worth every penny.
Mike
Current Wooden builds:  Amati/Victory Pegasus  MS Charles W. Morgan  Euromodel La Renommèe
Plastic builds:    Hs129B-2 1/48  SB2U-1 Vindicator 1/48  Five Star Yaeyama 1/700  Pit Road Asashio and Akashi 1/700 diorama  Walrus 1/48 and Albatross 1/700  Special Hobby Buffalo 1/32   IJN Notoro 1/700  Akitsu Maru 1/700
Completed builds :  Caldercraft Brig Badger   CLC Annapolis Wherry  Amati Hannah - Ship in Bottle  Pit Road Hatsuzakura 1/700   Hasegawa Shimakaze 1:350
F4B-4 and P-6E 1/72  Accurate Miniatures F3F-1/F3F-2 1/48  Tamiya F4F-4 Wildcat built as FM-1 1/48  Special Hobby Buffalo 1/48  Eduard Sikorsky JRS-1 1/72
Citroen 2CV 1/24 - Airfix and Tamiya  Entex Morgan 3-wheeler 1/16
Terminated build:  HMS Lyme (based on Corel Unicorn)
On the shelf:  Euromodel Friedrich Wilhelm zu Pferde; Caldercraft Victory; too many plastic ship, plane and car kits
Future potential scratch builds:  HMS Lyme (from NMM plans); Le Gros Ventre (from Ancre monographs), Dutch ship from Ab Hoving book, HMS Sussex from McCardle book, Philadelphia gunboat (Smithsonian plans)
Are you sure it will work on yours Byrnes Table Saw? Looks like it is made for a full size saw. There have been some posts about making sleds to do the same thing, home made but look good and reports say work well.
jud
Looks like the second link would work well.  I have not ever used one, but I bet even if it were not meant for a hobby saw you could fashion something similar yourself without much trouble.
Jud, it's 7"x4.5"x4.5", so it will take up quite a bit of the Byrnes table.  I don't know if this is a problem or not.  Otherwise, from what I can tell, it looks like it's adjustable enough to work with wood on the scale that we use in this hobby.
Maturin, I think you're right that you can probably build something very similar on a smaller scale.
Mike
It looks like the guy here at the 1:30 mark is using the gizmo on his hobby table saw:
So it looks like with the 1/8" attachment you can cut very thin stock down to 1/8"/3.12mm.  That seems like it would work very well for cutting most scale planks in our hobby.  It's not cheap, but I might give it a try.  Working with the table saw really makes my back end pucker up, so this might help for most table saw jobs.
Mike
  • 2 years later...
I use it and I find it quite helpful.  My 1/8" attachment is a bit thinner than 1/8" these days, however.
Chuck Seiler
San Diego Ship Modelers Guild
Current Build:: Colonial Schooner SULTANA (scratch from Model Expo Plans), Hanseatic Cog Wutender Hund, Pinas Cross Section
Completed:  Missouri Riverboat FAR WEST (1876) Scratch, 1776 Gunboat PHILADELPHIA (Scratch), John Smith Shallop
Sorry for never updating this thread. After two years, I still love it! I use it all the time except when cutting very thin strips less than 1/8" when I use push sticks. I'm a lot more comfortable using my Byrnes saw, but my fingers are well worth the cost of the Grr Ripper. I never got around to building a sled, but haven't felt the need for one with the Grr Ripper.
Edited by Landlubber Mike
Mike
Hi Ken (Canute) I actually found the link to the modelshipworld site using a google search! I'm not tech savvy enough to be able to reproduce the link to the thread I unearthed but now that we've got Landlubber Mike's confirmation on this thread along with Chuck, there's no need! I see there are multiple gripper models and an additional deflector that can be added. If you go to the micro jig website you can see the options. Thanks Landlubber Mike for updating and Chuck for your comment. I think I will be picking one of these up, right after I get my Byrnes saw that is!
Currently building:
HM Yacht Chatham - 1:64 - Caldercraft
I have a couple of Grr-Rippers and use them all the time on my full-size table saw.  I have probably ripped to about 1/8" thickness, maybe less.
One possible problem with milling the smaller parts required in model building could be with the thickness of the narrowest "guide leg", I'll call it.  It's 0.235" wide.
One of the big benefits of the Grr-Ripper is it straddles the saw blade enabling you to guide the wood through on both sides of the blade.  This prevents the piece wedged between the fence and blade from shooting back at you. If you want to use that feature for ripping planks, for instance, the planks have to be at least as wide as the guide leg, almost 6mm.
You could take the Grr-Ripper to the table saw and rip one guide leg thinner.  It's all plastic with a rubber foot and designed not to damage a saw blade.  If modified to meet the needs of model makers, I could see the Grr-Ripper as a very useful, and safe, tool.
Julie
First and only build: Endeavour - 1934 American's Cup, UK Challenger, J-Class - Amati 1:35
You can get a 1/8 inch replacement leg.  That's .125" wide...at least it WAS until I started using it on smaller stuff.  Now mine is .06 wide at the bottom.  :-)
Chuck Seiler
