Here goes.
This is my first build log here, and this kit will be my second wood ship model.
The kit is typical of European kit makers today. I'm not the best authority on what's good or bad, due to limited experience in model ship building. The machine cut parts are mostly accurate, with some trimming and fitting required to get a fair hull shape.
Following are some pictures of the kit, plans, and my initial hull lay up. The design features a sliding keel, and a slot is created in the keel to allow its function. Enjoy!
John
Hi John:
Always been curious about this one and the Brittania - both are quite large, no? Looking forward to your progress on this one
hamilton
Hamilton;
There's a picture above that shows the full size plan, and the green ruler laid at the foot is 12" - 30.5cm. Yes, it has presence as the sails are quite large.
Thank you for checking in!
John
I *think* the hull is ready for planks, shaping and sanding went pretty well. I did botch a couple of places, fixed with shims.
The keel is tapered quite a bit, unlike most of the earlier ships. I think this taper helps ensure a very fine edge at the bow. I'm not sure how this was done on the full size ship, but I'll try to somehow create the effect.
The slot for the sliding keel can also be seen.
John
Hi John.
Looking very nice.
Regards Antony.
Best advice ever given to me."If you don't know ..Just ask.
Completed Mayflower
Completed Fun build Tail boat Tailboat
Completed Build Chinese Junk Chinese Pirate Junk
Completed scratch built Korean Turtle ship 1/32 Turtle ship
Completed Santa Lucia Sicilian Cargo Boat 1/30 scale Santa Lucia
On hold. Bounty Occre 1/45
Completed HMS Victory by DeAgostini modelspace. DeAgostini Victory Cross Section
Completed H.M.S. Victory X section by Coral. HMS Victory cross section
Completed The Black Pearl fun build Black Queen
Completed A large scale Victory cross section 1/36 Victory Cross Section
Thank you Antony.
I'm hoping to use just a single layer of planking instead of the double plank scheme from the kit. The kit wood intended for the first layer of planks was finished pretty rough (not their fault, it's supposed to be covered with a second layer of walnut), so I used basswood instead.
The fitting of planks is pretty fun, in a meditative sort of way. I've made a few mistakes, but so far have recovered from them.
John
Wonderful looking lines on this one John.. Some beautiful boats were built over on your side of the Pond.. still are I'm sure :D
All The Best
Eamonn
Current Build   :  HM Schooner Ballahoo
In the Pipeline :  HM Cutter Sherbourne, HM Mortar Convulsion, Emma C Berry & C18th English Longboat.. Eventually That Is..🙄
Thank you Eamonn, it does indeed have beautiful curves.
Big day today, I finished the hull planking!
The last plank required two stealers, and everything worked out ok. I made quite a few mistakes that will hopefully guide my next build to a better outcome.
Next up: add some sort of stem post, shape and level the hull, build and install the rudder.
John
Looking great John - the planking is very well done.
hamilton
Hello Hamilton, thanks!
I've been moving forward, the single layer of bass planking came out well enough that I'll omit the second layer.
I shaped the hull using sanding blocks and sand paper pulled around a piece of plastic pipe. I do have a few places where a bit of filler or wood is needed. The nibbing plank took forever to do, the rails too. But I'm really enjoying this build!! Sometimes I think it's a difficult project, but then I see some other complex models being built on this forum. I think my model would be considered a good beginners build. Yow!
John
And now, a few pics:
Eamonn,
Thank you.
OK, margin planks... got it. I have SO much to learn about ship terminology. Evidently, I didn't learn much while spending 11 years in the US Navy. What was I doing then??
John
Hi John,
I’m sorry to be late to this build.  I’ve always liked the Puritan, with its long bowsprit and have thought of building it myself.  Hopefully this will give me the kick I need to move it higher on the list of boats to build.  You’re doing a great job.
Bob
Current build:  SS_ Mariefred
You have picked a really beautiful boat I am sure that you will be very happy with her once you are finished
She is a big boat I had to build a special shelf in our home for her
Andy
Current Build
HM Granado CC
Past builds
 HMS Chatham CC, HM Convulsion CC,  Duke William German Kit, Fair American LSS, The Wright Flyer MS
Bob, Andy;
Thanks so much for checking in and nice words. I'm really having a good time building this boat.
Andy, did you do a build log on yours? I'd love to see pictures sometime. A special shelf for it, now that's a good idea.
I finished the cap rails and other small details. You can see where I had to apply some filler. A lot of these parts were made of non-kit wood. Hull finishing soon, and rudder work coming up.
John
Wayne, Jay, thank you for the encouragement.
I did a bit more today; added the side mouldings (is that what they are??) using some model RR basswood. Next, the hull was sealed with lacquer and sanded, then I carved the bowsprit from sitka spruce and did a rough fit.
John
Hello again. Hard to believe, but it took me nearly two days to make a cradle for this project. I left the wood rough, hoping it might add some kind of scale effect later on.
The toothpicks I used are bamboo. I use these often on model airplanes as well, and they add lots of strength.
Next up is finishing the rudder, then on to deck planking. I've been putting the deck off because it's definitely out of my comfort zone!
John
What a lovely build John,
it is a delight to see this model, wonderful lines, and the cradle also Looks superbe !
Is the centerboard  (dark space on keelup pic) workable ?
NIls
Current builds
-Lightship Elbe 1
Completed
Hello Nils, and thank you for the nice comments. They keep me motivated.
Yes, the sliding keel (or is it a centerboard?) is located on a hinge pin, and a deck winch (non-functional) moves it into or out of the keel.
Thanks again for checking in!
John
Eamonn, steal away. That's all I've been doing since discovering this site..
I began installing deck planking. I'm using *some kind* of wood from a long forgotten source. Maybe alder? Anyway, 1/8" strips were cut, and I'm off and running. Well, maybe a very slow jog.
John
I had a productive weekend, the deck was completed!
It's far from perfect, but I'm happy with the results. I don't know what kind of wood I used, how sad is that? Whatever it is, it's quite hard and splintery, and I wouldn't use it again. I'm always collecting ideas to improve future models.
John
Hi John, Very nice build you have going on here , I really like how you made the cradle , beautiful work , she's taking shape , It's always good to see am America's Cup boat ( I am a huge fan of the America's Cup ) I will pull up a chair and follow along
Best Regards,
Pete
"may your sails be full of wind and the sun on your back"
Current Builds :
 Future Builds :
N.G Herreshoff 12 1/2 Scratch Build 3/4" = 1' - 0" Scale
Completed Builds :
Volvo 65 Farr Yacht Design
Herreshoff Alerion
Herreshoff Buzzards Bay 14
Volvo Open 70
 Member :
The Herreshoff Registry                                  Montgomery Sailboat Owners Group       Peter Kunst Sailboat Models
http://www.herreshoffregistry.org/                       http://www.msog.org/                      http://www.facebook.com/Peter-Kunst-Sailboat-Models-1524464774524480/
Pete, Bob;
Thanks for checking in, I appreciate it very much. Thanks to all for the 'likes' too.
I feel as though I'm confronting a steep learning curve with this project, but it's definitely do-able, and darn fun!
After scraping the deck, I sanded it with 320 paper, then applied two brushed coats of lacquer. Right now it's curing in the sun.
Rudder work is next up.
Thanks again,
John
I like the deck. She's looking good.
Bob
