Fine run to that plank...dont forget to measure up from the top of that plank at the bow to make sure that you have enough room for all of the strakes along the stem.  I see many builds that curve the initial plank to high up on the stem and it causes issues later.
Thanks Chuck,
Measuring up 7/8" up from the top of the wale the top of my last plank will be a tad (+1/16") over the bow fillers.  Is that acceptable or should I move the wale down?
Sal
Current
Nordkap 476 - Billing Boats
Complete
USCG Harriet Lane - Model Shipways
U.S. Brig Syren - Model Shipways
New York Pilot Boat 'Phantom' 1868 - Model Shipways
Its been so long I am not entirely sure.  Tough to remember every last detail.  Best to be safe and move it down by at least 1/32" do give you a bit of wiggle room.
Chuck
I tried a little different approach for placing the planking above the wales than what is described in the instructions.  After pondering the pros and cons of placing these planks in a number of pieces as per the instructions or in one continuous piece I went with the one piece.  I know it’s not the way it was done way back when but the practical side of me took control and decided to deviate a bit from the norm.  Before setting the planks I use my jig to pre-bend the bow end of the planks.
Prior to setting the first plank I cut in four grooves across the plank to denote the faux ends that would have been made by the individual pieces.  For the second plank I notch out for the gun ports and sweeps but kept it as one long plank.
Clamping the first plank in position
First and second plank above the wale
The remaining five planks were all set as continuous pieces from stem to stern.
Then using the notches in the second planks as guides I cut out the gun ports.  I still need to do the sweeps.
I took care not to get glue on the exposed portion of the gun port frames so the planking would not stick there.
post-11922-0-96131100-1417629370_thumb.jpg post-11922-0-37866300-1417629372_thumb.jpg
Sal
Current
Complete
Looks really awesome. Great job.....
:cheers:
Till next time.....     😎
Steve
Finished:              Artesania Latina Constellation;   Model Shipways USF Confederacy:  Medway Longboat 1742 - Syren Ship Model Company
Current Build:     Syren's Winchelsea
Finished planking above the wale on the starboard side.  I used the same procedure as the port side gluing the planks on in one piece.  The only difference on this side was that I used my old drafting square template as a guide to cut out the gun ports and sweeps.  For the gun ports I used the 17/32” template based on the 15/32” gun port frame plus 1/32” frame width all around.  For the sweeps I used the 3/16” template.  Once the template was in place I used my x-acto knife to cut the plank.  You just need to be careful not to cut too deep to avoid cutting into the frame.
post-11922-0-68598300-1418134697_thumb.jpg post-11922-0-96489700-1418134698_thumb.jpg
post-11922-0-56603400-1418134700_thumb.jpg post-11922-0-79622100-1418134701_thumb.jpg
Finished starboard side.
post-11922-0-88087400-1418134705_thumb.jpg post-11922-0-39469800-1418134707_thumb.jpg
Planning ahead, I thought it would make planking the hull easier if I could steam the planks to make them more pliable. This is what I came up with.  Used a two foot long, 4” diameter pvc pipe with an end cap and a thread end cap; drilled a hole in the end cap and inserted the hose attachment for my HAAN’s steam cleaner; used a small wire basket inside the pipe to support the planks.  It works fairly well, tried it out and the plank came out very pliable after a few minutes.
post-11922-0-03532500-1418134721_thumb.jpg post-11922-0-19786700-1418134722_thumb.jpg
post-11922-0-56898000-1418134723_thumb.jpg post-11922-0-89223900-1418134724_thumb.jpg
Edited by DrWatson
Sal
Current
Complete
Patrick, glad to hear from you.  Use whatever you'd like and thanks for looking at my new build log.  This ship is certainly a lot different than the solid hull Phantom, a little bigger too, which is good so I can see it better.
Sal
Current
Complete
I finished placing the two 5/32” wales below the top most wale and the first 1/8” plank below them.  I also completed placing the garboard plank and the two 1/8” planks above it.  To shape each plank to conform to the shape of the hull I soaked and steamed each plank and then temporarily pinned them to the hull.  After letting them dry in place I removed them and glued them back into position.
The one deviation I made from the instructions was that I decided to skip Step 2 and not install the counter planking or the transom at the stern until I finished planking the hull.  I decided to do this for two reasons.  1)  Because of the way the counter planking and transom fit over the ends of the hull planking, I thought it would be easier to shape the counter planking if the hull planking was already in place.  And 2) I thought it would be easier to ‘tuck’ the hull planks around the counter if the planking was not on the counter yet.  I guess I’ll find out if it was a good or bad decision.
Forming the second wale in place
Wales glued in place and forming the first 1/8" plank
Bending the plank around the 'tuck' of the counter
Garboard glued in place
Forming the first 1/8" planks above the garboard. Did both port and starboard sides at the same time.  Push pins seemed to work very well at holding the planks in position.
Planking at the counter
Garboard and first two planks in place
Port side with simulated butt ends of planking on wales to get an idea of how the second layer of wales should look.
Stern.  Pencil line on the counter denotes, what should be, the location of the bottom edge of the last plank of the counter.
Sorry for all the photo's, just a few more
Sal
Current
Complete
Looking good :)
Dirk
Thanks Dirk
Great symmetry on the planking as seen in the bow shot.
Thanks Augie,   I needed to sand the planks a bit to get them to line up and I think the starboard side is a bit lower but if I stand far enough back they look perfect.
Sal, your planking skills are outstanding! Great job with your planking so far. I also like the simulated caulking effect you've put into this.
Thanks Patrick, There are a few dents that don't show up in the photos but I'm happy with it so far.  Lets see what happens with the remaining planking.
Sal
Current
Complete
Prior to starting my planking I read “Planking the Built-Up Ship Model” by Jim Roberts , “Simple Hull Planking Techniques for Beginners” by Dirk DeBakker and Greg Brooker, and studied many building logs here on MSW.  All these references were very informative, however, and I know this might be a little over kill but for me personally, having more of a visual type learning style, I decided to draw up, as Chuck calls it, a ‘planking-plan-of-attack’.   :pirate41:
I started by measuring the gap along each bulkhead between the planking by using a tick strip.  Next I measured the length remaining to be planked along the curve of the bow and the total distance along the stern and counter and finally the distance between each bulkhead.  With these measurements I drew vertical lines representing the centerline of each bulkhead at their measured length and spacing.  The dimension at the mid-ship bulkhead was 2 7/8”, which would require 23 planks @ 1/8” wide to cover the area.  I used this number to divide the length of all the other bulkheads to determine the width that the plank should be at each bulkhead.  Using these dimensions I drew up a plank pattern for the port and starboard sides.
To test this planking shape I made a few copies of the pattern, cut them out and pinned them to the hull.  They appeared to fit well and had no puckers (clinkers).  I will use this shape for planking the bow.  For the stern I will either need wider (5/32”) planks or use steelers.
My thoughts are that I would use this pattern for about 7 or 8 planks and then re-adjust if need be to account for creep or ,heaven forbid, I don’t shape every plank perfectly.  :)
Sal
Current
Complete
The hull planking is coming along.  It took me a while to put that first plank on but now that I’ve started I’ve developed a system that seems to work pretty well for me.
First I made two templates from the plank pattern I drew as part of my “planking-plan-of-attack”, one for the planking of the bow and one for planking the stern.  I colored them with a red pencil to help distinguish them from other planks.
Using these templates as a guide I sanded eight planks at a time, four for the starboard side and four for the port. The red color on the edge of the template came in handy as an indicator as to when to stop sanding.  As soon as the red color became lighter I would know the planks were close to their final profile.
I would sand each plank individually and compare it to the plank pattern to get its final shape.
To form these planks to the shape of the hull I would first soak and steam them and then place them in position on the hull itself.  I would do this on each side of the hull.
After letting them dry overnight I would do any final sanding and then glue them in place one at a time.
Planking progress to date
One minor faux pas I discovered while laying out the planking at the stern was that I did not place the counter filler along the bulkhead former correctly.  When placing the filler I stop it at the bearding line and not at the rabbet.   Fortunately it wasn’t a hard fix so I added fillers to both sides of the stern and it sanded them smooth.
Sal
Current
Complete
Looking good.  I think everyone develops their own system eventually and that's why there are so many variations.  If it works, it's right!
Augie
Current Build: US Frigate Confederacy - MS 1:64
Previous Builds :
US Brig Syren (MS) - 2013 (see Completed Ship Gallery)
Greek Tug Ulises (OcCre) - 2009 (see Completed Ship Gallery)
Victory Cross Section (Corel) - 1988
Essex (MS) 1/8"- 1976
Cutty Sark (Revell 1:96) - 1956
Hey Dr. Watson can you post a better picture of that steam thing? I can't really tell how the inside is set up. I am going to try another idea first but if that doesn't work, I might give this a try. Thanks. Hope your doing okay in this brutal cold in CT.
Current/But Not immediate Build Logs
I am still gathering the tools I need but starting preliminary work. Nothing to show just yet.
Fair American
Armed Virginia Sloop.
Sal, that is a nice planking plan. I use something similar though it is not as visually appealing as yours. Your planking looks great too.
Thanks Augie, This method seems to work well but I keep trying new things.
Jimz66, I'd be happy to post more pictures but it will have to wait until next week.  I'm on vacation in sunny Florida right now.  70 degrees today and not missing the cold weather back home  :)
It's not warm in RI either LOL.
Nice planking Doc. See you Saturday.
Thanks Joe, hope you're staying warm.  I'm on vacation this week and next so I'm going to miss the meeting this coming Saturday.
Great work on that planking Sal! It looks as though you are almost to the finish line with it.
Thanks Patrick, It's going slowly but I'm getting there.  Hull is going to need a bit of sanding I think.
And thanks all for all the 'likes'
Sal
Current
Complete
Thanks Tom,  I use AutoCad everyday in work so I find it easy to draw out the parts I need and plan ahead for the things I'll be working on.  Sort of like shop drawings.
Sal
Current
Complete
Update on the planking.  Starboard side is complete and only a few more planks to go on the port side. (Phew!!  :stunned: )  One thing I’ve discovered is that even the best laid plans can go awry.  After carefully laying out the planking profile for the hull I’ve ended up using a few partial planks at the center of the hull.  I didn’t bother shading the edges of the planks to simulate the caulking since the hull is going to be plated.
Starboard side, not sanded yet.                                               Port side with a few planks left to go.
post-11922-0-06483500-1421944770_thumb.jpg     post-11922-0-51471100-1421944768_thumb.jpg
Bow
I’ve also started planking the counter.  Planks around the tuck look a little ragged but they should clean up okay with the final sanding.
On a separate note, I’ve always had a hard time keeping a square edge on the little pieces of wood that I sand. To help me do a better job I made a little disc sander for my dremel flex-extension with some scrap pieces of wood.  I made a holder that the end of the extension sits in and is clamped in place.  For the disc I used a cap from a vitamin bottle and cut out round pieces of sandpaper, of different grit, held in place with double sided tape.  Now I can sand the ends square or at an angle using different drafting triangles.
Edited by DrWatson
Sal
Current
Complete
Thanks Patrick.  Planking is a lot of work, and I thought solid hulls were tough.  There were times I thought I should have started with a smaller ship but I'm almost finished.  The mini sander helps a lot.  Two things I always have a problem with are hand sanders and circular saws.  I could never sand evenly or cut a straight line to save my life.
Thanks everyone for all the likes also.
Sal
Current
Complete
I thought I would update my log while waiting for the blizzard to hit southern New England. They are predicting 20 to 30 inches by tomorrow night.
Well I finally found the piece of planking I was looking for the past several weeks (the last piece).  With the hull finished I moved onto the stern and completed the counter and transom.
Next I added the second layer of planking to the wales.  In hind sight I should have formed these planks at the same time I was doing the first set of wales and  kept them for later so I could have glued them right in place.  Since I didn't do that I used a set of pins that I modified to hold the plank in place after soaking.  I inserted the pins along the seam between the second and third wale to give me a support for the new wale and to hold it in place while it dried.  I have to apologize to the person who's log here on MSW I learned how to make the pins but I just can't find it now.
post-11922-0-93729000-1422281925_thumb.jpg post-11922-0-30239600-1422281922_thumb.jpg
Once this wale was dry and glued into place I used it to form against for the upper and lower wale.  When dried they were glued in place.
The sheer strake was then soaked and clamped in position until dry and then glued in place.  Prior to gluing the sheer strake on I cutout the four opening for the sheaves directly below it.  The sheaves were made from pear wood with a small piece of 1/8” diameter brass tube for the pulley held in place with a toothpick for the axle.  They are not glued in yet, I will do that after all the sanding and finishing is done.
post-11922-0-78007800-1422281933_thumb.jpg post-11922-0-64385000-1422281937_thumb.jpg
All in all I am pleased how the hull came out for my first attempt at a POB ship.  I still need to sand the hull down and do some treenailing.  Something to do while waiting to get plowed out from the blizzard.
Sal
Current
Complete
