Hi Mike
Are you sure that's not the full sized boat that you're pretending is your model? It must be, because it looks authentic, especially the way you've replicated the fillets against each deck beam to give strength and rigidity to the hull.
One heck of a nice job!
Cheers
Patrick
Hi Igor, Marc, Patrick, Michael, hi everyone
Thanks all of you for feedbacks, your visits and likes!
@Igor
In Log no. 149 I falsely claimed that three different setups regarding jib sail consist. But you're right, there are only two versions of jibs (normal jib and storm jib), as shown on the sketch in Post Nr. 151 (Letter “F“ means the storm jib). Thanks for the hint.
@Mark
Thanks for your encouragement, but I am still not sure whether my RC design will holding - on this topic,
I have to learn by trial and error ...  :huh:
@Michael and Patrick
Yes, I will certainly report you success or failure about the draining system ... Patrick, this is really a funny story, this toilet installation of your father - the model boat that (let's say) all two minutes a WC flushing ejects ...  :P
... back to the workshop. Concerning of the upcoming edge of the deck I worked on the chainplate. Last but not least, it was a welcome change to the wood work ...
post-14773-0-65904900-1442003463_thumb.jpg post-14773-0-68870500-1442003478_thumb.jpg
blank before and after hard soldering
raw chainplates
post-14773-0-41162800-1442003509_thumb.jpg post-14773-0-78114900-1442003525_thumb.jpg
multiple calibration and constriction
post-14773-0-26078200-1442003541_thumb.jpg post-14773-0-35933200-1442003557_thumb.jpg
contour grinding
post-14773-0-27461700-1442003572_thumb.jpg post-14773-0-20804300-1442003588_thumb.jpg
chamfering
post-14773-0-41901700-1442003614_thumb.jpg post-14773-0-18395600-1442003636_thumb.jpg
chamfering chainplate's head
post-14773-0-14399300-1442003652_thumb.jpg post-14773-0-71836000-1442003667_thumb.jpg
done ...
... and not too much unlike ...  :)
Best regards,
Mike
current scratch build 1:15
Colin Archer - RS14 "Stavanger"
Hi Mike
With the care and attention that you're giving to every bit of your ship, (as witnessed by your chain plates), I reckon she deservedly belongs in a museum when you're finished. However, the fact that she will be a working model, with such a high quality of workmanship, makes it all the more special.
Nicely done!
Cheers
Patrick
Nice work and thanks for all the pictures.
Bob
Current build:  SS_ Mariefred
Ach so, sieht ja toll aus, Mike (looking good) Looks like the big sister of my scratch build ... for now (only the colours probably ...)
Carl
Hi Greg, Patrick ...
... as well as everyone else who visit "Stavanger's" shipyard. Many, many thanks for all of your feedback, comments and likes. Always greatly appreciated!  :)
In the following post I would like to document a do-it-yourself tool.
In general, I swear on Proxxon tools - you can't win a war with it, but second to none is the price-performance ratio! ... Well, there is unfortunately no reasonable mini milling attachment for the IBS/E highspeed tool, but I need one for future cutting work on the semi-finished deck. So, I helped me myself ...
post-14773-0-16755100-1442152453_thumb.jpg post-14773-0-85383000-1442152473_thumb.jpg
Blanks before hard soldering
Finished attachment with router bits
post-14773-0-90095300-1442152509_thumb.jpg post-14773-0-98763200-1442152525_thumb.jpg
Application with milling guide
Best regards,
Mike
Edited by mikegerber
Hi again
Thanks everyone who visited the shipyard, and thanks for all the likes.
@Carl
Many thanks for such a great feedback! ...
“... well done ...“ – thanks a lot! ...  :)
“... something to remember ...“ – that would be a pleasure ...  ^_^
“... clever ...“ – maybe a little bit ...  :rolleyes:
“... master mind ...“ – there are also other opinions – to this you have to interviewing my admiral ...  ;)
The next thing that I must prepare are the double-width planks with the deck day-lights. To this I used a milling guide to obtain easily a high repeat accuracy (s. below) ...
Location of the double-width planks
Some experiments
post-14773-0-56307600-1442269987_thumb.jpg post-14773-0-58387400-1442270002_thumb.jpg
Making of the milling guide
post-14773-0-81411300-1442270018_thumb.jpg post-14773-0-51214300-1442270035_thumb.jpg
Get ready for milling
post-14773-0-80877000-1442270051_thumb.jpg post-14773-0-32303700-1442270068_thumb.jpg
First cut
post-14773-0-42699800-1442270084_thumb.jpg post-14773-0-92014400-1442270136_thumb.jpg
Second cut
post-14773-0-66222900-1442270153_thumb.jpg post-14773-0-25510700-1442270170_thumb.jpg
Post processing
Best regards,
Mike
Hi Patrick, hi Dimitris,
@ Patrick
Patrick, you faithful companion - always welcome and thanks a lot!
@Dimitris
It’s good to know you back in the MSW shipyards - and thanks a lot for such a great feedback and all the likes!
I’ve decided to tackle the design and construction process of the deck in a little unconventional way. At this point the following points are to noticing:
- There is only one construction layer for the deck - no false deck below (s. Log #90 and #76).
- Cut-outs boundaries are already prepared (s. Log #156).
- Deck will planked through on its whole surface.
- Cut-outs will later milled (Only this way, I can be sure that later everything just fits - hyperbolic shaped deck - s. also Log #90).
- Longitudinal planking joints are subsequently milled (due to the future dark coloration of the deck, almost no one will remark the continuous wood structure as disturbing).
- Caulking in a separate work step (s. Log #76).
So, the following pictures show the beginning of this process ...
Everything ready, plank stack in the background, plans.
post-14773-0-62979000-1443163878_thumb.jpg post-14773-0-25099400-1443163891_thumb.jpg
The first two - straight! ...  :)
post-14773-0-94356400-1443163906_thumb.jpg post-14773-0-46757000-1443163921_thumb.jpg
... and a pair of plank per day^_^
Til soon,
Mike
... once more a little update ...
... after some planks, I have to cut through the cockpit frames. This way, I must later milling out only to a depth of 3 mm (dimenson of planks) for finishing the cockpit opening ...
... same process for the front opening ...
post-14773-0-73434700-1443306063_thumb.jpg post-14773-0-71534800-1443306033_thumb.jpg
... and then the planks with day lights.
Best regards,
Mike
Very nice Progress Mike,
clean accurate work on deck-Planks as on whole of ship...
Nils
Current builds
-Lightship Elbe 1
Completed
Hi Patrick, Greg, Nils ...
... as well as everyone else who visit “Colin Archer’s“ shipyard. Thanks for all of your feedback, comments and likes. Always greatly appreciated!
@Greg
... yes, I'm looking forward to the caulking process and the subsequent scraping of the deck toward the final shape - to this, you finde a preview of the making of in Log #76.
Best regards,
Mike
Hi Patrick
Concerning covered thoughts ...
... sometimes, even myself I don't know, what exactly I have had in mind :huh: - such a long time, I was thinking about this deck construction process. I'll be glad if all went well and if I can everything disassemble and reassemble after milling the openings.  ;)
Cheers,
Mike
Great progress Mike the deck planks are looking super.
Michael
Hi Patrick
Cheers,
Mike
Hi Mike
That sounds very familiar to me!  I often thought "now, how am I going to fit this in...oh yer, just cut the deck open again...!
I look forward to seeing how you pull it altogether, for no doubt, she's gonna be a beauty.
Cheers and all the best!
Patrick
Hi again
Thank you all for the visits and so many likes!
@Patrick
... thanks a lot and cheers!  ;)
@Paul
... thanks a lot, always greatly appreciated!  :)
A special case of the planking we'll find in the area of the wide groove of the openings (they will be later equipped with an elastic gasket). There I have a “flying“ plank without bearing - it's hanging in the air.
The fix of this problem shows two planks coupled on the underside (s. below).
Best regards,
Mike
