Hi George,
Thanks for the comment.
I sanded the front fascia and I shall do a new attempt using an aerograph. The Caldercraft french blue will so be a little bit diluted and, may be, not so dark.
Presently, I am finishing the lining of the gunports of the starboard siide. I hope it will be done for the end of this week.
Pierre
Finally, some progress.
I finished the lining of the gunports without lids of the starboard side.
I am now ready to start a new phase in the construction of my Aggie.
Fist picture: the finished side.
Second picture: pieces are ready to start with the quarter galleries.
About the front fascia, I completely sanded it again and painted white.
My first attempt is for today. But, it's the first time in my live that I am using an aerograph and I am a little bit anxious about the result...
Pierre
Hi Pierre I'm really looking forward to the quarter deck galleries.
Regarding the aerograph : I must admit I'm as unexperienced as you are.
This may sound funny but lately  I've purchased some WW II planes on a 1/32 scale in order to acquire some experience regarding that matter.
Perhaps Santa Claus will give me a compressor ?
I'll post some pics of the unopened boxes  in the "shore leave" section the coming W.E.
Kind regards
Christian
"The original always beats the copy"
(supportive statement)
Hello Christian,
Thank you for your kind comments.
About the aerograph, I acquired mine by the way from Lidl. It was not expensive at all.
The compressorand all other pieces are looking fine. It's ,of course, to be used with water paint.
It sprays very well, and I obtained not too bad results on a test plank.
But, again, the result on the front fascia is horrible. May be that the bottom was too glad, because painted in white?
May be was my painting too diluted? But it's already less diluted thad in the instructions.
Any way, several layers are necessary, but that's not a problem and even better.
Be careful if you paint on plastic. Obviously if you are using water soluble paint.
I think, I will go back to the brush...
Pierre
Hi Christian,
I am coming back on the aerograph and send hereafter a picture of mine.
I made a new tentative of painting the front fascia not too dark.
This time I used the brush and I diluted the Jotika french blue with a couple of drops of water.
The resut, again, was not good for my point of view.
I realised that the problem comes from the dilution. The instructions of thr aerograph tell you have to dilute your paint, what I did.
Apparently, the jotika admiralty paint don't like water dilution at all.
Next step, without dilution, but, may be a little bit too dark...
Pierre
Thank you very much Pierre.
Much appreciated, the more is :  I'm more than ever convinced to puchase such a tool.
Maybe the dark color will result in a nice contrast with the coming details : strips, ornaments ?
Kind regards
Christian
Persistence will always pay off Pierre, well done for sticking with it.
Be Good
mobbsie
mobbsie
All mistakes are deliberate ( me )
Current Build:- HMS Schooner Pickle
Completed Builds :-   Panart 1/16 Armed Launch / Pinnace ( Completed ),  Granado Cross Section 1/48
Harwich Bawley, Restoration,  Thames Barge Edme, Repair / Restoration,  Will Everard 1/67 Billings
HMS Agamemnon 1781 - 1/64 Caldercraft KitHM Brig Badger,  HM Bomb Vessel Granado,
Thames Steam Launch Louise,  Thames Barge Edme,  Viking Dragon Boat
Next Build :-
Nice work Pierre,
Merry X-mas and a happy (shipbuilding) year 2014 !
I'm always looking forward to your updates.
Kind regards
Christian
Nice job on the bulkhead Pierre, well done for sticking with it and getting the colour right, that's looking much better.
I wish you and your a very Happy New Year and many happy hours of modelling.
Be Good
mobbsie
mobbsie
Next Build :-
I finally came back a little bit earlier than foreseen (aniway, the weather in the South of France was not so nice...) and that's a good news for my Aggie.
I first planked the stern gallery deck.
And that's not such an obvious job. As the deck is curved, I decided to plank it curved too to avoid distortion of the planking once in place.
And then, I glued it very carefully in position.
You will notice that (inspird by Mobbsie) I made a little checker after the wall. I don't know if it is useful or not.
I think that it will be completely invisible from outside...
Once completely dried, I made a first attempt to temporarily fix the stern fascia.
Here, a lot of chamfering is required to have it right in place. It's very important but it works well.
Now serious things can begin, such as fixing the edges.
Pictures will come later.
Pierre
Finally back after a long absence.
The quarter galleries appeared to be more complicated than expected.
An extreme accuracy is absolutely necessary if you want to avoid an extensive use of filler. That's my case.
After a first attempt I decided to remove all parts and to restart completely.
Angles and parallelism are extremely important and a mistake ca definitively spoil your model.
I finally discovered that pinning was much more efficient for the temporary fixing than rubber bands.
Here is the present status of my quarter galleries.
And now a view of my Aggie as she is today.
You will notice that I temporarly fixed the lower pattern (34) and the finishing casting.
These parts will be removed before starting the second planking. They are just there to see how it looks, and they still need some further adjustment. But forming the patterns necessitated the use of my Dremel machine, it means a lot of dust, and I was obliged (by the Admiral, of course) to wait for better weather to do it outside..
Best greetings to all of you,
Pierre.
nice work Pierre,
well done !
thats a good base for the second planking, I would love to see...
Nils
Current builds
-Lightship Elbe 1
Completed
Hi Pierre,
Good to have you back in the shipyard mate. Been a while.
Your stern galleries are coming along nicely mate and are looking good, their not as easy as you think and do require a lot of attention. It's good to know she still has a sting in her tail though.
Your outside pics of her are really good and show just what a big beast she is.
Keep up this splendid work.
Be Good
mobbsie
mobbsie
Next Build :-
Hi Pierre,
To mention mobbsie, it's good you're back in the shipbuilding business. I sincerely wish I could do the same.
It is a good thing to emphasize on the complexity of the stern & quarterdeck galleries. All these parts are related one to another. Being just a frigate,  I've suffered enough on my Diana...
Kind regards
Christian
Awesome build! i found this thread to be very inspiring,
As a starter in the hobby myself, i'm gonna practise on other kits before attempting a larger build like this one.
but eventually I will make the investment (in time and money :) ) to attempt caldercrafts aggy as well, she's such a beauty *Goal Set*
Laat in ieder geval de trappistjes je smaken!
Pierre, shes looking great.  I can only imagine the amount of work to get all the gunports cut and lined.  Beautiful photos, but I am jealous of your weather, we still have snow on the ground and the temperatures way below freezing :mellow:
Cheers,
Jason
In the shipyard:
Hoi Pierre,
I just spended some time to read the entyre build log.
Great job you're doing :D
I am biulding the HMS Agamemnon myself at the moment.
You are ahead of me, so i can use your build as a example ;)
Current build: HMS Agamemnon 1781
Website: http://www.henkvanluinen.com
I finally finished with the quarter galleries and am ready to begin the second planking.
My quarter galleries are not so nice as expected, but it's not their final appearance and some adjustments will be possible later.
For the second planking, I shall also make planks of 12,5 cm. I think it's a good idea and also much easier to put in place.
Thank you  to all friendly "like's" and messages.
To Nils, Mobbsie and Christian,
thank you for your kind words, I try (slowly) to do my best...
To Glawen,
I hope to see you soon with an Aggie or another build.
Trappist is always helpful, but much better outsine when the weather is nice. And that's OK when you make too much dust!
To Jason,
cutting and aligning the gunports was really a long and fastidious work, but I tried to do my best using more than often the calliper square. I tried to have them right with an accuracy of 0,1 to 0,2mm, I think it will pay back in the future.
About the weather, we had here a couple of fine days. But I think it's over now. About snow, I have the impression you kept all in North America this yearand left nothing for us. I already permuted the winter tyres to the summer one's.
To Klaas,
I follow also with very much interest your buildlog full of good ideas (such as your galley floor).
Your Aggie is coming out very nicely. I started mine more than 3 years ago, and I think that you will soon pass me over...
Who is the fastest? Mobbsie or you, or , may be, Sjors? I am surely not!
Pierre
I started my second planking using planks 125mm long.
It handles pretty well and takes easily the curvature. Longer would be more hazardous.
But I HATE CYANO!
I prefer from far PVA, but everybody recommends cyano for the second planking.
So it did it too. I started with the planks that will be covered by the wales. If it's not well done, I don't care because, anyway, it will be covered.
Actually, it works. It's fast and all, except for my fingers because I cannot use cyano without putting some on my fingers.
And so, I am obliged to stop after laying 5 or 6 planks...
Pictures are following soon,
Pierre
It is good to make the planks for 2 planking 125 mm, that works better, besides that, it was about the same ss on the original.
My work will be al little different,  because my whales (top and butt system) will be directly on the the first planking, and 2 mm, when second planking is placed, i will have the same result.
I don't know who buils the fastest, the main goal is to learn from each other.
So kep up the good work, and looking forward for your pictures :)
Welcome to the club Pierre, I've forgotten how many times my fingers have been glued together with that stuff. A little or a lot of nail varnish remover will do the clean up for but my guess is that you already know.
A word of warning my friend, on page 9 of the manual under the heading "Hull Side Fittings" it mentions the Bow Timber Heads, it tells us to drill a 2mm hole to take the Main Stay Collar, this is the only mention of this, on sheet plan 9 there is a diagram showing the Bow Sprit and how the Collars ( Main & Preventer ) fit around it. There is no further mention of using the Timber Heads at all.
I have just ripped out my old Timber Heads and replaced them with new undrilled ones, also there are two eyebolts in each Timber Head, it's going to be a lot easier to fit these before you place the Timber Heads onto the ship.
Hope this is a help as you get further into your build.
Hopefully Klaas will read this too.
Be Good
mobbsie
Edited by mobbsie
mobbsie
Next Build :-
