Looking really sharp and crisp.  I've been putting off getting those catheads in but it's almost time......
Augie
Current Build: US Frigate Confederacy - MS 1:64
Previous Builds :
US Brig Syren (MS) - 2013 (see Completed Ship Gallery)
Greek Tug Ulises (OcCre) - 2009 (see Completed Ship Gallery)
Victory Cross Section (Corel) - 1988
Essex (MS) 1/8"- 1976
Cutty Sark (Revell 1:96) - 1956
nothing glued on yet.......just positioned......including the deck......................noticed one of my errors....the center line on deck doesn't quite match the center line on the transom....doesn't show up too much though...happened by finishing the deck separate from the ship......
   just noticed that there may be enough stanchions for the waist rail do double them up to make them thicker.....
Edited by yancovitch
I've blackened mine up to now, Vic.  Not a dark black but just enough to look 'used'.
Augie
Previous Builds :
thanks........hmmmmm.....i'll try the tiny bit of blackening them a bit trick first, maybe just enough to dull the brass....................chris...isn't tamiya waterbased?....thought it would be too thick and scrape off easily...?...but you had success, and they look good, so if i can't get the blackening to work well, i'll order some of that paint online....gets kind of expensive for a few belaying pins:):).....especially if i rig the ship, where most of them will be covered up........well i got something to work on now............cheers........vc
Blacken them a little more than you think you need as the final product.  Then let them sit a few days before you install them so you know exactly what the finished color will be.  Keep in mind that you can always paint them after you blacken them if you're not happy.  The etching caused by the blackening agent acts as a pretty good primer and gives the paint something to 'bite' into.
Augie
Previous Builds :
okee dokee......will go for the tamiya grey primer........what the heck..... ya can't beat the tried and true.........but i may also try augie's idea of using the blackening as a primer at the same time.....love experimenting.............
belaying pins temporarily on ship so i don't loose them....put a little ledge on gangways....can remove if it's a real no no .............decided to put guns on the port side..........slowly getting there.....ordered the taubman plans for basic rigging.....will still have to check about belaying points etc.....got one of chuck's lanterns....no shaky hands allowed :)......micro crystal clear for the windows.......he very thoughtfully included two lanterns in the kit, so if you screw up one, which i did a little bit on this one, didn't sand off the burnt edges, ya got another to make good....can'[t believe all the extra considerations chuck puts into his work.................anyways, will have much touching up to do.....
    i glued two of the waist rail stanchions together to make them thicker......many of the sprues attached to the bottom, broke off as they were very thin.....i will probably embed the stanchions i tiny bit lower to give them more purchase..............used blacken it, but will sand and paint..............
ok......still much touching up to do...which i like doing......so i start the rigging now......guess i won't bother posting much anymore....much tedious rigging stuff to do.......at least tedious for me:)...............grateful to have seen some of the wonderful builds here, which were inspiring me to try and make a better effort......but we all have our limitations :)...anyways, cheers..................
Hi Vic,
As always, a wonderfully clean and beautiful build and great to see her starting to gain some height in the last shot.
I hope you keep posting to show us your progress on the rigging. I know I've been looking forward to watching this!
Cheers,
Nigel.
Current Build Logs: H.M.S. Triton Cross SectionUSF Confederacy Model Shipways
Completed Log: Red Dragon Artesania Latina
Gallery: Red Dragon: Artesania Latina
Member:  Nautical Research Guild
beautiful build Vic,
the Stern rounding Windows look excellent...
Nils
Current builds
-Lightship Elbe 1
Completed
Very nice, Vic.  Don't be bashful.....we all want to see her reaching for the sky !
Augie
Previous Builds :
thanks gratefully........i'll post an occasional where i'm at, but it will probably take a longer time in between....they should call ALL these sailing ships dreadnoughts,  like i dread tying noughts on all those ratlines, as i'd rather nought...but i can't cheat and glue of course.....
   oh....another thing....i noticed too late that the inverted knees on the channels are tapered at the bottom....didn't think one could laser cut on an angle.....may put a tiny bit of fill there....if i sanded them down i thought they would be too thin....but of course, that's what i should have done :).....like i said i reveal my errors to help a new builder.......and embarrass myself in the process ha ha...
oh...i thought i should add the fact that i always felt the main and foremast were too fat, but i didn't want to embarrassing myself by complaining :) ...then i discovered this, which, if correct, explains everything...(taubman plans)..so this is an option for future builders....even though it's only  a stubby mast......again, i say, if correct......cheers....
Came to the same conclusion on mine a while back so I have several size dowels to consider.  But first I have to get there!
Augie
Previous Builds :
ok.....best i show some progress........oh.......had to lower the lantern, because of the boom.......
 used micro kristal klear for window sample.....not sure if i will use, although it looks ok.....
bindings on the mast not finished, but came out too shiny......will have to do something with them, althought i like the fact that the sythetic line doesn't have hairs, althought a little beeswax help there........c'est tout for now, until i get well into the rigging....cheers.............
oh well.....thought i'd show improved wooldings with railwood added....rewound with black rope....used wire instead of middle links on the chainplates, as the sizes provided wouldn't fit...........yards basically finished and painted.....next the dread threads :)............will still have a lot of fine finishing to do of course.sanding painting...cleaning up the moldings etc.......i'll know when it's the right time and i'll really enjoy it...............got the confed...glued to the stern...yuk....quite frustrating....three efforts......
Hi Vic,
You are doing some wonderful work. Love it. :)
Rusty
"So Long For Now" B)
Current Builds: Speedwell
