Hi all! As I'm picking up various tools and supplies I keep running into the water line marker and was wondering if it really serves a purpose or is it one of those loom-A-line type tools that really don't work or are necessary.  Thanks! :)
Charlie
Build on hold: HM Sultana 1/64th scale
Current Build: 31 ton Doughty revenue cutter as USRC Active 1/64th scale (in progress)
Future Interests: Ballahoo, Diligence, Halifax and beyond...
A waterline marker of some kind is pretty essential for marking waterlines.  I have the Amati version, and it does the job well enough.  But if you are the enterprising sort, you can make your own, which is what I did for my first couple of models.  I got the Amati version because my home-builts weren't very durable.  :rolleyes:
Cool Ill pick it up then, relatively cheap just wasn't sure if it was something I could just fashion myself easily. Amati seems to have some nice tool like the keel holder :)
Edited by CharlieZardoz
Charlie,
You could make one.. I use this and just tape a pencil to it.  When I'm not using it to mark, it's used to pick off a dimension from the plans and transfer it to the model.
Edited by mtaylor
Ahoy Charlie :D
I find them indispensable for accurately transferring measurements from  the plans to your hull.  It only works if you also construct a building jig and I highly recommend those too.
 On with the Show.... B)
  J.Pett
“If you're going through hell, keep going” (Winston Churchill)
Current build:  MS Rattlesnake (MS2028)
http://modelshipworld.com/index.php?/topic/45-model-shipways-rattlesnake-ms2028-scale-164th/
Side Build: HMS Victory: Corel
http://modelshipworld.com/index.php?/topic/3709-hms-victory-by-jpett-corel-198/?p=104762
On the back burner:  1949 Chris Craft Racer: Dumas
http://modelshipworld.com/index.php?/topic/939-1949-chris-craft-racer-by-jpett-dumas-kit-no-1702/
Sometime, but not sure when: Frigate Berlin: Corel
http://www.corel-srl.it/pdf/berlin.pdf
Charlie,
A waterline marker is essential, as others have said. Make one or buy one but you will not get a good waterline without one.
Dan.
I've got the same one shown in your photo. In my opinion the base - which is just plastic - is too light. It works OK but if I had my time over I think I would do more research before buying one.
Hornet
             Current Build: - USRC Harriet Lane - Model Expo.
             Completed Ship Builds:   Vanguard - HMS Adder, OcCre - Shackleton’s Endurance
             Caldercraft - HM Bark EndeavourHMAV Bounty HM Brig Supply
             Aeropiccola - Golden Hind, Constitution
              Scientific -  Clipper Seawitch.     Corel - Victory
              Modeller's Shipyard - A Schooner of Port JacksonBrig `Perseverance'    Cutter `Mermaid'
               Sirius Longboat (bashed Sloop Norfolk
The bottom of the plastic base just pops off. You can fill it with something heavy like plaster of paris and then glue the cover back on.
In my opinion the type of marker is not as important as setting up your model such that the waterline is parallel with the table on which it sits. In other words the waterline at the bow and stern should be at an even height. Likewise the line should be the same on both sides. This requires propping up those points until they are at the level as defined in the plans.
Below are two pictures showing how I did this with my Connie. The table top was level, hence the sides could be leveled as shown. The fore and aft points were located and you can see the small wooden shim towards the bow.
I put small pieces of masking tape on the hull, made a wooden block to the correct height and used that to make my marks.
Jay
Current build Cross Section USS Constitution  http://modelshipworld.com/index.php/topic/10120-cross-section-forward-area-of-the-uss-constitution/
Finished USS Constitution:  http://modelshipworld.com/index.php?/topic/103-uss-constitution-by-modeler12/
'A picture is worth a  . . . . .'      More is better . . . .
