Sorry for all the entry level stuff guys. You must get sick of it after awhile. Can I use a Dremel tool to clean up the keel rather then a chisel? I have never used chisels before and not too keen on using one... I plan to use a drum sander as well as one of these....
http://www.dremel.com/en-us/Accessories/Pages/ProductDetail.aspx?pid=512E
Of course I will do the planing of the lower keel first. Just trying to learn the ropes so to speak. UGGH the ropes. I have NO experience with knots. I am definitely in trouble there aren't I?
Current/But Not immediate Build Logs
I am still gathering the tools I need but starting preliminary work. Nothing to show just yet.
Fair American
Armed Virginia Sloop.
I would suggest a test of the tool and your skill on a scrap piece so you can determine if it is adequate for you.
Might take some practice/ multiple attempts before you can decide.
Alan O'Neill
Try the chisel and knife - on some scrap first - the chisel and knife are easily controlled and will be needed constantly through your modeling and while power tools are great and I use them a lot,  the Dremel can be a very aggressive cutter and can get away from you and can ruin a piece of work very fast.  Try both methods on scrap and then go with the one that works best for you.
Kurt
Kurt Van Dahm
Director
NAUTICAL RESEARCH GUILD
www.thenrg.org
CLUBS
Midwest Model Shipwrights
North Shore Deadeyes
Butch O'Hare - IPMS
as the other have said the dremel can be too much unless you have a really really good "touch" with it.
I would say that two issues are that it can very quickly take off to much wood and that it can also skip or jump if you are not careful.
and as was said get some other scraps of the same wood and try out each method a few times and get a better feel for each tool.
there are a lot of places I do use the dremel to sand and cut wood and a lot of places I use a good sharp blade.
Holding at Rigging stage :
MS Bluenose 1:64, rigging and finish work
Building Hull :
MS Fair American 1:48
In the yard:  18th Century Longboat, Model Shipways Kit
Done: AL Bounty Jolly Boat
Jim,
We will never get tired of questions, even repeated ones...... :)
Dremel is good as stated before me, but hand tools is in many ways better, as you will have a feeling of how much you are reducing.
As you will reduce so much less.
I am using a combo of both, but not for keel.
However, the latest Dremel Micro can do real low rpm's which makes it more controllable.
If you are not used to such a power tool you can create more harm than greatness. :)
Good luck
Edited by Nirvana
Respectfully
I agree with the others and you might as well learn how to use a chisel.
But,if your dead set against it, you might try sandpaper wrapped tightly around a long block, maybe 1/2 inch square and three to five inches long.
Its tough to adjust your lines if you take off too much or gouge the wood which is easy to do with a Dremel (most of us have learned that the hard way.)  Manual sanding will give you more control of the depth and the long flat surface under the sandpaper will help yield a level, smooth keel.
For me, part of the fun of this hobby is learning the skill and techniques including new tools.  I am new to the hobby and spend a lot of time learning how to use tools that are new to me from chisels to soldering, jig saw to lathe, and so on.
In Frolich's book, The Art of Ship Modeling he says, the ship modeler needs to be "... a carpenter, carver, coppersmith, block-maker, rigger, sail maker and painter" ... "using a multitude of crafts ... working with wood, metal, fit, saw, turn, solder, glue, make rope, drill, grind, cut sails, sew, dye, paint, dozens of motions, techniques, turns of the hand."
I agree with him.
Richard
Richard
Member: The Nautical Research Guild
A Dremel is nice but you will lack the control that you would have with chisels and knives.  Even bird carvers who use a Dremel go for a nice chisel on the delicate parts.  The Dremel is for large stock removal not for fine work.
David B
Other tools to try  : a small hand plane - needle files.
NRG member 50 years
Current:
NMS
The U.S. Ex. Ex. 1838-1842
Other
With my luck using Dremel Tools I would remove too much.  Try using a single edge raze blade to scrape the wood off.. It will allow you to remove just enough and with out having to sand out marks left by a chisel.  It's easy.
I also use a block of wood with different grit sandpaper to help shape and smooth , 60 or 80 grit will take off a lot of wood fast and then 180 or 220 will smooth things out.
using a wood block makes sure you are "flat" and you can see the rough angle you are getting at.
Building Hull :
Maby if you have a mini razor plane. With the blade set very shallow. Take your time.
Regards, Scott
Completed builds:
Awaiting construction:
Opps sorry, May I add that never be afraid to ask these rookie questions as we are here to help. We don't get sick of it because we all had to start somewhere. Best of luck to you I hope all will go to plan.
Regards, Scott
Completed builds:
